path: root/include/linux/of_pci.h
2014-06-04of/irq: provide more wrappers for !CONFIG_OFArnd Bergmann
The pci-rcar driver is enabled for compile tests, and this has now shown that the driver cannot build without CONFIG_OF, following the inclusion of f8f2fe7355fb "PCI: rcar: Use new OF interrupt mapping when possible": drivers/built-in.o: In function `rcar_pci_map_irq': :(.text+0x1cc7c): undefined reference to `of_irq_parse_and_map_pci' pci/host/pcie-rcar.c: In function 'pci_dma_range_parser_init': pci/host/pcie-rcar.c:875:2: error: implicit declaration of function 'of_n_addr_cells' [-Werror=implicit-function-declaration] As pointed out by Ben Dooks and Geert Uytterhoeven, this is actually supposed to build fine, which we can achieve if we make the declaration of of_irq_parse_and_map_pci conditional on CONFIG_OF and provide an empty inline function otherwise, as we do for a lot of other of interfaces. This lets us build the rcar_pci driver again without CONFIG_OF for build testing. All platforms using this driver select OF, so this doesn't change anything for the users. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: devicetree@vger.kernel.org Cc: Rob Herring <robh+dt@kernel.org> Cc: Grant Likely <grant.likely@linaro.org> Cc: Lucas Stach <l.stach@pengutronix.de> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Magnus Damm <damm@opensource.se> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ben Dooks <ben.dooks@codethink.co.uk> Cc: linux-pci@vger.kernel.org Cc: linux-sh@vger.kernel.org [robh: drop wrappers for of_n_addr_cells and of_n_size_cells which are low-level functions that should not be used for !OF] Signed-off-by: Rob Herring <robh@kernel.org>
2013-10-24of/irq: Create of_irq_parse_and_map_pci() to consolidate arch code.Grant Likely
Several architectures open code effectively the same code block for finding and mapping PCI irqs. This patch consolidates it down to a single function. Signed-off-by: Grant Likely <grant.likely@linaro.org> Acked-by: Michal Simek <monstr@monstr.eu> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-10-24of/irq: Replace of_irq with of_phandle_argsGrant Likely
struct of_irq and struct of_phandle_args are exactly the same structure. This patch makes the kernel use of_phandle_args everywhere. This in itself isn't a big deal, but it makes some follow-on patches simpler. Signed-off-by: Grant Likely <grant.likely@linaro.org> Acked-by: Michal Simek <monstr@monstr.eu> Acked-by: Tony Lindgren <tony@atomide.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-10-24of/irq: Rename of_irq_map_* functions to of_irq_parse_*Grant Likely
The OF irq handling code has been overloading the term 'map' to refer to both parsing the data in the device tree and mapping it to the internal linux irq system. This is probably because the device tree does have the concept of an 'interrupt-map' function for translating interrupt references from one node to another, but 'map' is still confusing when the primary purpose of some of the functions are to parse the DT data. This patch renames all the of_irq_map_* functions to of_irq_parse_* which makes it clear that there is a difference between the parsing phase and the mapping phase. Kernel code can make use of just the parsing or just the mapping support as needed by the subsystem. The patch was generated mechanically with a handful of sed commands. Signed-off-by: Grant Likely <grant.likely@linaro.org> Acked-by: Michal Simek <monstr@monstr.eu> Acked-by: Tony Lindgren <tony@atomide.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-08-12of: pci: add registry of MSI chipsThomas Petazzoni
This commit adds a very basic registry of msi_chip structures, so that an IRQ controller driver can register an msi_chip, and a PCIe host controller can find it, based on a 'struct device_node'. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-05-19of/pci: Add of_pci_parse_bus_range() functionThierry Reding
This function can be used to parse a bus-range property as specified by device nodes representing PCI bridges. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-05-19of/pci: Add of_pci_get_devfn() functionThierry Reding
This function can be used to parse the device and function number from a standard 5-cell PCI resource. PCI_SLOT() and PCI_FUNC() can be used on the returned value obtain the device and function numbers respectively. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-05-21OF: PCI: const usage needed by MIPSJohn Crispin
On MIPS we want to call of_irq_map_pci from inside arch/mips/include/asm/pci.h:extern int pcibios_map_irq( const struct pci_dev *dev, u8 slot, u8 pin); For this to work we need to change several functions to const usage. Signed-off-by: John Crispin <blogic@openwrt.org> Cc: linux-pci@vger.kernel.org Cc: devicetree-discuss@lists.ozlabs.org Cc: linux-mips@linux-mips.org Acked-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Patchwork: https://patchwork.linux-mips.org/patch/3710/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-06-08pci/of: Match PCI devices to OF nodes dynamicallyBenjamin Herrenschmidt
powerpc has two different ways of matching PCI devices to their corresponding OF node (if any) for historical reasons. The ppc64 one does a scan looking for matching bus/dev/fn, while the ppc32 one does a scan looking only for matching dev/fn on each level in order to be agnostic to busses being renumbered (which Linux does on some platforms). This removes both and instead moves the matching code to the PCI core itself. It's the most logical place to do it: when a pci_dev is created, we know the parent and thus can do a single level scan for the matching device_node (if any). The benefit is that all archs now get the matching for free. There's one hook the arch might want to provide to match a PHB bus to its device node. A default weak implementation is provided that looks for the parent device device node, but it's not entirely reliable on powerpc for various reasons so powerpc provides its own. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Michal Simek <monstr@monstr.eu> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-02-04of/pci: move of_irq_map_pci() into generic codeSebastian Andrzej Siewior
There is a tiny difference between PPC32 and PPC64. Microblaze uses the PPC32 variant. Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> [grant.likely@secretlab.ca: Added comment to #endif, moved documentation block to function implementation, fixed for non ppc and microblaze compiles] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
