Pull devicetree updates from Rob Herring:
- Import of latest upstream device tree compiler (dtc)
- New function of_get_child_by_name
- Support for #size-cells of 0 and #addr-cells of >2
- Couple of DT binding documentation updates
Fix up trivial conflicts due to of_get_child_by_name() having been added
next to the new of_get_next_available_child().
* tag 'dt-for-3.7' of git://sources.calxeda.com/kernel/linux:
MAINTAINERS: add scripts/dtc under Devicetree maintainers
dtc: import latest upstream dtc
dt: Document general interrupt controller bindings
dt/s3c64xx/spi: Use of_get_child_by_name to get a named child
dt: introduce of_get_child_by_name to get child node by name
of: i2c: add support for wakeup-source property
of/address: Handle #address-cells > 2 specially
DT: export of_irq_to_resource_table()
devicetree: serial: Add documentation for imx serial
devicetree: pwm: mxs-pwm.txt: Fix reg field annotation
of: Allow busses with #size-cells=0
This patch introduces of_get_child_by_name function to get a child node
by its name in a given parent node.
Without this patch each driver code has to iterate the parent and do
a string compare, However having of_get_child_by_name libary function would
avoid code duplication, errors and is more convenient.
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com>
Macro for_each_child_of_node() makes it easy to iterate over all of the
children for a given device tree node, including those nodes that are
marked as unavailable (i.e. status = "disabled").
Introduce for_each_available_child_of_node(), which is like
for_each_child_of_node(), but it automatically skips unavailable nodes.
This also requires the introduction of helper function
of_get_next_available_child(), which returns the next available child
node.
Pull irqdomain changes from Grant Likely:
"Round of refactoring and enhancements to irq_domain infrastructure.
This series starts the process of simplifying irqdomain. The ultimate
goal is to merge LEGACY, LINEAR and TREE mappings into a single
system, but had to back off from that after some last minute bugs.
Instead it mainly reorganizes the code and ensures that the reverse
map gets populated when the irq is mapped instead of the first time it
is looked up.
Merging of the irq_domain types is deferred to v3.7
In other news, this series adds helpers for creating static mappings
on a linear or tree mapping."
* tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux-2.6:
irqdomain: Improve diagnostics when a domain mapping fails
irqdomain: eliminate slow-path revmap lookups
irqdomain: Fix irq_create_direct_mapping() to test irq_domain type.
irqdomain: Eliminate dedicated radix lookup functions
irqdomain: Support for static IRQ mapping and association.
irqdomain: Always update revmap when setting up a virq
irqdomain: Split disassociating code into separate function
irq_domain: correct a minor wrong comment for linear revmap
irq_domain: Standardise legacy/linear domain selection
irqdomain: Make ops->map hook optional
irqdomain: Remove unnecessary test for IRQ_DOMAIN_MAP_LEGACY
irqdomain: Simple NUMA awareness.
devicetree: add helper inline for retrieving a node's full name
Pull PWM subsystem from Thierry Reding:
"The new PWM subsystem aims at collecting all implementations of the
legacy PWM API and to eventually replace it completely.
The subsystem has been in development for over half a year now and
many drivers have already been converted. It has been in linux-next
for a couple of weeks and there have been no major issues so I think
it is ready for inclusion in your tree."
Arnd Bergmann <arnd@arndb.de>:
"Very much Ack on the new subsystem. It uses the interface
declarations as the previously separate pwm drivers, so nothing
changes for now in the drivers using it, although it enables us to
change those more easily in the future if we want to.
This work is also one of the missing pieces that are required to
eventually build ARM kernels for multiple platforms, which is
currently prohibited (amongs other things) by the fact that you cannot
have more than one driver exporting the pwm functions."
Tested-and-acked-by: Alexandre Courbot <acourbot@nvidia.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Philip, Avinash <avinashphilip@ti.com> # TI's AM33xx platforms
Acked-By: Alexandre Pereira da Silva <aletes.xgr@gmail.com> # LPC32XX
Acked-by: Sachin Kamat <sachin.kamat@linaro.org>
Fix up trivial conflicts with other cleanups and DT updates.
* 'for-3.6' of git://gitorious.org/linux-pwm/linux-pwm: (36 commits)
pwm: pwm-tiehrpwm: PWM driver support for EHRPWM
pwm: pwm-tiecap: PWM driver support for ECAP APWM
pwm: fix used-uninitialized warning in pwm_get()
pwm: add lpc32xx PWM support
pwm_backlight: pass correct brightness to callback
pwm: Use pr_* functions in pwm-samsung.c file
pwm: Convert pwm-samsung to use devm_* APIs
pwm: Convert pwm-tegra to use devm_clk_get()
pwm: pwm-mxs: Return proper error if pwmchip_remove() fails
pwm: pwm-bfin: Return proper error if pwmchip_remove() fails
pwm: pxa: Propagate pwmchip_remove() error
pwm: Convert pwm-pxa to use devm_* APIs
pwm: Convert pwm-vt8500 to use devm_* APIs
pwm: Convert pwm-imx to use devm_* APIs
pwm: Conflict with legacy PWM API
pwm: pwm-mxs: add pinctrl support
pwm: pwm-mxs: use devm_* managed functions
pwm: pwm-mxs: use global reset function stmp_reset_block
pwm: pwm-mxs: encode soc name in compatible string
pwm: Take over maintainership of the PWM subsystem
"A small set of changes for devicetree:
- Couple of Documentation fixes
- Addition of new helper function of_node_full_name
- Improve of_parse_phandle_with_args return values
- Some NULL related sparse fixes"
Grant's busy packing.
* tag 'dt-for-3.6' of git://sources.calxeda.com/kernel/linux:
of: mtd: nuke useless const qualifier
of: return -ENOENT when no property
usage-model.txt: fix typo machine_init->init_machine
of: Fix null pointer related warnings in base.c file
LED: Fix missing semicolon in OF documentation
of: fix a few typos in the binding documentation
prom_update_property() currently fails if the property doesn't
actually exist yet which isn't what we want. Change to add-or-update
instead of update-only, then we can remove a lot duplicated lines.
Suggested-by: Grant Likely <grant.likely@secretlab.ca>
Signed-off-by: Dong Aisheng <dong.aisheng@linaro.org>
Acked-by: Rob Herring <rob.herring@calxeda.com>
The pattern (np ? np->full_name : "<none>") is rather common in the
kernel, but can also make for quite long lines. This patch adds a new
inline function, of_node_full_name() so that the test for a valid node
pointer doesn't need to be open coded at all call sites.
While common irqdesc allocation is node aware, the irqdomain code is not.
Presently we observe a number of regressions/inconsistencies on
NUMA-capable platforms:
- Platforms using irqdomains with legacy mappings, where the
irq_descs are allocated node-local and the irqdomain data
structure is not.
- Drivers implementing irqdomains will lose node locality
regardless of the underlying struct device's node id.
This plugs in NUMA node id proliferation across the various allocation
callsites by way of_node_to_nid() node lookup. While of_node_to_nid()
does the right thing for OF-capable platforms it doesn't presently handle
the non-DT case. This is trivially dealt with by simply wraping in to
numa_node_id() unconditionally.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Cc: Rob Herring <rob.herring@calxeda.com>
This commit adds an empty of_parse_phandle_with_args() function for
!CONFIG_OF builds.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
This commit adds an empty of_property_match_string() function for
!CONFIG_OF builds.
Currently most code to get child count in kernel are almost same,
add a helper to implement this function for dt to use.
Cc: Grant Likely <grant.likely@secretlab.ca>
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
This patch adds macros of_property_for_each_u32() and
of_property_for_each_string(), which iterate over an array of values
within a device-tree property. Usage is for example:
struct property *prop;
const __be32 *p;
u32 u;
of_property_for_each_u32(np, "propname", prop, p, u)
printk("U32 value: %x\n", u);
const char *s;
of_property_for_each_string(np, "propname", prop, s)
printk("String value: %s\n", s);
Based on work by Rob Herring <robherring2@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull a few more things for powerpc by Benjamin Herrenschmidt:
- Anton's did some recent improvements to EPOW event reporting on
pSeries (power supply failures and such). The patches are self
contained enough and replace really nasty code so I felt it should
still go in
- I did the vio driver registration change Greg requested, I don't see
the point of leaving that til the next merge window
- The remaining EEH changes I said were still pending to get rid of the
EEH references from the generic struct device_node
- A few more iSeries removal bits
- A perf bug fix on 970
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
powerpc/perf: Fix instruction address sampling on 970 and Power4
powerpc+sparc/vio: Modernize driver registration
powerpc: Random little legacy iSeries removal tidy ups
powerpc: Remove NO_IRQ_IGNORE
powerpc/pseries: Cut down on enthusiastic use of defines in RAS code
powerpc/pseries: Clean up ras_error_interrupt code
powerpc/pseries: Remove RTAS_POWERMGM_EVENTS
powerpc/pseries: Use rtas_get_sensor in RAS code
powerpc/pseries: Parse and handle EPOW interrupts
powerpc: Make function that parses RTAS error logs global
powerpc/eeh: Retrieve PHB from global list
powerpc/eeh: Remove eeh information from pci_dn
powerpc/eeh: Remove eeh device from OF node
Pull "ARM: More device tree support updates" from Olof Johansson:
"This branch contains a number of updates for device tree support on
several ARM platforms, in particular:
* AT91 continues the device tree conversion adding support for a
number of on-chip drivers and other functionality
* ux500 adds probing of some of the core SoC blocks through device
tree
* Initial device tree support for ST SPEAr600 platforms
* kirkwood continues the conversion to device-tree probing"
Manually merge arch/arm/mach-ux500/Kconfig due to MACH_U8500 rename, and
drivers/usb/gadget/at91_udc.c due to header file include cleanups.
Also do an "evil merge" for the MACH_U8500 config option rename that the
affected RMI4 touchscreen driver in staging. It's called MACH_MOP500
now, and it was missed during previous merges.
* tag 'dt2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits)
ARM: SPEAr600: Add device-tree support to SPEAr600 boards
ARM: ux500: Provide local timer support for Device Tree
ARM: ux500: Enable PL022 SSP Controller in Device Tree
ARM: ux500: Enable PL310 Level 2 Cache Controller in Device Tree
ARM: ux500: Enable PL011 AMBA UART Controller for Device Tree
ARM: ux500: Enable Cortex-A9 GIC (Generic Interrupt Controller) in Device Tree
ARM: ux500: db8500: list most devices in the snowball device tree
ARM: ux500: split dts file for snowball into generic part
ARM: ux500: combine the board init functions for DT boot
ARM: ux500: Initial Device Tree support for Snowball
ARM: ux500: CONFIG: Enable Device Tree support for future endeavours
ARM: kirkwood: use devicetree for rtc-mv
ARM: kirkwood: rtc-mv devicetree bindings
ARM: kirkwood: fdt: define uart[01] as disabled, enable uart0
ARM: kirkwood: fdt: facilitate new boards during fdt migration
ARM: kirkwood: fdt: absorb kirkwood_init()
ARM: kirkwood: fdt: use mrvl ticker symbol
ARM: orion: wdt: use resource vice direct access
ARM: Kirkwood: Remove tclk from kirkwood_asoc_platform_data.
ARM: orion: spi: remove enable_clock_fix which is not used
Originally, the PCI sensitive OF node is tracing the eeh device
through struct device_node->edev. However, it was regarded as
bad idea.
The patch removes struct device_node->edev and uses PCI_DN to
trace the corresponding eeh device according to BenH's comments.
Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com>
Pull powerpc merge from Benjamin Herrenschmidt:
"Here's the powerpc batch for this merge window. It is going to be a
bit more nasty than usual as in touching things outside of
arch/powerpc mostly due to the big iSeriesectomy :-) We finally got
rid of the bugger (legacy iSeries support) which was a PITA to
maintain and that nobody really used anymore.
Here are some of the highlights:
- Legacy iSeries is gone. Thanks Stephen ! There's still some bits
and pieces remaining if you do a grep -ir series arch/powerpc but
they are harmless and will be removed in the next few weeks
hopefully.
- The 'fadump' functionality (Firmware Assisted Dump) replaces the
previous (equivalent) "pHyp assisted dump"... it's a rewrite of a
mechanism to get the hypervisor to do crash dumps on pSeries, the
new implementation hopefully being much more reliable. Thanks
Mahesh Salgaonkar.
- The "EEH" code (pSeries PCI error handling & recovery) got a big
spring cleaning, motivated by the need to be able to implement a
new backend for it on top of some new different type of firwmare.
The work isn't complete yet, but a good chunk of the cleanups is
there. Note that this adds a field to struct device_node which is
not very nice and which Grant objects to. I will have a patch soon
that moves that to a powerpc private data structure (hopefully
before rc1) and we'll improve things further later on (hopefully
getting rid of the need for that pointer completely). Thanks Gavin
Shan.
- I dug into our exception & interrupt handling code to improve the
way we do lazy interrupt handling (and make it work properly with
"edge" triggered interrupt sources), and while at it found & fixed
a wagon of issues in those areas, including adding support for page
fault retry & fatal signals on page faults.
- Your usual random batch of small fixes & updates, including a bunch
of new embedded boards, both Freescale and APM based ones, etc..."
I fixed up some conflicts with the generalized irq-domain changes from
Grant Likely, hopefully correctly.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (141 commits)
powerpc/ps3: Do not adjust the wrapper load address
powerpc: Remove the rest of the legacy iSeries include files
powerpc: Remove the remaining CONFIG_PPC_ISERIES pieces
init: Remove CONFIG_PPC_ISERIES
powerpc: Remove FW_FEATURE ISERIES from arch code
tty/hvc_vio: FW_FEATURE_ISERIES is no longer selectable
powerpc/spufs: Fix double unlocks
powerpc/5200: convert mpc5200 to use of_platform_populate()
powerpc/mpc5200: add options to mpc5200_defconfig
powerpc/mpc52xx: add a4m072 board support
powerpc/mpc5200: update mpc5200_defconfig to fit for charon board
Documentation/powerpc/mpc52xx.txt: Checkpatch cleanup
powerpc/44x: Add additional device support for APM821xx SoC and Bluestone board
powerpc/44x: Add support PCI-E for APM821xx SoC and Bluestone board
MAINTAINERS: Update PowerPC 4xx tree
powerpc/44x: The bug fixed support for APM821xx SoC and Bluestone board
powerpc: document the FSL MPIC message register binding
powerpc: add support for MPIC message register API
powerpc/fsl: Added aliased MSIIR register address to MSI node in dts
powerpc/85xx: mpc8548cds - add 36-bit dts
Pull core device tree changes for Linux v3.4 from Grant Likely:
"This branch contains a minor documentation addition, a utility
function for parsing string properties needed by some of the new ARM
platforms, disables dynamic DT code that isn't used anywhere but on a
few PPC machines, and exports DT node compatible data to userspace via
UEVENT properties. Nothing earth shattering here."
* tag 'dt-for-linus' of git://git.secretlab.ca/git/linux-2.6:
of: Only compile OF_DYNAMIC on PowerPC pseries and iseries
arm/dts: OMAP3: Add omap3evm and am335xevm support
drivercore: Output common devicetree information in uevent
of: Add of_property_match_string() to find index into a string list
* spear/dt:
(update to v3.3-rc7)
arch/arm/mach-spear6xx/spear6xx.c
arch/arm/mach-vexpress/Kconfig
The conflicts are between the previous contents of the next/dt2
branch and upstream changes from v3.3-rc7.
of_property_read_bool
Search for a property in a device node.
Returns true if the property exist false otherwise.
Original EEH implementation depends on struct pci_dn heavily. However,
EEH shouldn't depend on that actually because EEH needn't share much
information with other PCI components. That's to say, EEH should have
worked independently.
The patch introduces struct eeh_dev so that EEH core components needn't
be working based on struct pci_dn in future. Also, struct pci_dn, struct
eeh_dev instances are created in dynamic fasion and the binding with EEH
device, OF node, PCI device is implemented as well.
The EEH devices are created after PHBs are detected and initialized, but
PCI emunation hasn't started yet. Apart from that, PHB might be created
dynamically through DLPAR component and the EEH devices should be creatd
as well. Another case might be OF node is created dynamically by DR
(Dynamic Reconfiguration), which has been defined by PAPR. For those OF
nodes created by DR, EEH devices should be also created accordingly. The
binding between EEH device and OF node is done while the EEH device is
initially created.
The binding between EEH device and PCI device should be done after PCI
emunation is done. Besides, PCI hotplug also needs the binding so that
the EEH devices could be traced from the newly coming PCI buses or PCI
devices.
Only two architectures use the OF node reference counting and reclaim bits.
There is no need to compile it for the rest of the PowerPC platforms or for
any of the other architectures. This patch makes iseries and pseries
select CONFIG_OF_DYNAMIC, and makes it default to off for everything else.
It is still safe to turn on CONFIG_OF_DYNAMIC on all architectures, it just
isn't necessary.
v2: Also select OF_DYNAMIC for PPC_CHROMA and MPC885ADS as reported by Michael
Meuling
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Jimi Xenidis <jimix@pobox.com> (for PPC_CHROMA bug fix)
Add empty of_find_compatible_node function for !CONFIG_OF build.
Add a helper function for finding the index of a string in a string
list property. This helper is useful for bindings that use a separate
*-name property for attaching names to tuples in another property such
as 'reg' or 'gpios'.
devicetree/next changes queued for v3.3 merge window
* tag 'devicetree-for-linus-20120104' of git://git.secretlab.ca/git/linux-2.6:
ARM: prom.h: Fix build error by removing unneeded header file
irq: check domain hwirq range for DT translate
dt: add empty of_get_node/of_put_node functions
of/pdt: fix section mismatch warning
i2c-designware: add OF binding support
dt/i2c: Enumerate some of the known trivial i2c devices
dt: reform for_each_property to for_each_property_of_node
ARM/of: allow *machine_desc.dt_compat to be const
of/base: Take NULL string into account for property with multiple strings
OF/device-tree: Add some entries to vendor-prefixes.txt
Fix up trivial add-add conflicts in include/linux/of.h
Add empty of_get_node/of_put_node functions for !CONFIG_OF builds.
Make this macro easier to use(do not need to pass properties, a node is
enough), also change to a more sensible name as for_each_child_of_node.
of_parse_phandle_with_args() needs to return quite a bit of data. Rather
than making each datum a separate **out_ argument, this patch creates
struct of_phandle_args to contain all the returned data and reworks the
user of the function. This patch also enables of_parse_phandle_with_args()
to return the device node pointer for the phandle node.
This patch also ends up being fairly major surgery to
of_parse_handle_with_args(). The existing structure didn't work well
when extending to use of_phandle_args, and I discovered bugs during testing.
I also took the opportunity to rename the function to be like the
existing of_parse_phandle().
v2: - moved declaration of of_phandle_args to fix compile on non-DT builds
- fixed incorrect index in example usage
- fixed incorrect return code handling for empty entries
Reviewed-by: Shawn Guo <shawn.guo@freescale.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
The patch adds an empty function for non-dt build, so that
drivers migrating to dt can save some '#ifdef CONFIG_OF'.
v3: New patch
devicetree/merge
* 'next/cleanup2' of git://git.linaro.org/people/arnd/arm-soc: (31 commits)
ARM: OMAP: Warn if omap_ioremap is called before SoC detection
ARM: OMAP: Move set_globals initialization to happen in init_early
ARM: OMAP: Map SRAM later on with ioremap_exec()
ARM: OMAP: Remove calls to SRAM allocations for framebuffer
ARM: OMAP: Avoid cpu_is_omapxxxx usage until map_io is done
ARM: OMAP1: Use generic map_io, init_early and init_irq
arm/dts: OMAP3+: Add mpu, dsp and iva nodes
arm/dts: OMAP4: Add a main ocp entry bound to l3-noc driver
ARM: OMAP2+: l3-noc: Add support for device-tree
ARM: OMAP2+: board-generic: Add i2c static init
ARM: OMAP2+: board-generic: Add DT support to generic board
arm/dts: Add support for OMAP3 Beagle board
arm/dts: Add initial device tree support for OMAP3 SoC
arm/dts: Add support for OMAP4 SDP board
arm/dts: Add support for OMAP4 PandaBoard
arm/dts: Add initial device tree support for OMAP4 SoC
ARM: OMAP: omap_device: Add a method to build an omap_device from a DT node
ARM: OMAP: omap_device: Add omap_device_[alloc|delete] for DT integration
of: Add helpers to get one string in multiple strings property
ARM: OMAP2+: devices: Remove all omap_device_pm_latency structures
Fix up trivial header file conflicts in arch/arm/mach-omap2/board-generic.c
It shows up as a build failure on MIPS, as it is used in
three of_property function stubs.
include/linux/of.h:275: error: 'ENOSYS' undeclared (first use in this function)
include/linux/of.h:282: error: 'ENOSYS' undeclared (first use in this function)
include/linux/of.h:295: error: 'ENOSYS' undeclared (first use in this function)
Add function of_alias_get_id() reporting -ENOSYS
for non-dt builds, so that drivers migrating to dt
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
When compiling ath6kl for beagleboard (omap2plus_defconfig plus
CONFIG_ATH6KL, CONFIG_OF disable) with current linux-next compilation
fails:
include/linux/of.h:269: error: 'ENOSYS' undeclared (first use in this function)
include/linux/of.h:276: error: 'ENOSYS' undeclared (first use in this function)
include/linux/of.h:289: error: 'ENOSYS' undeclared (first use in this function)
Fix this by including errno.h from of.h.
Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Add an empty macro for of_match_node() that will save
some '#ifdef CONFIG_OF' for non-dt builds.
I have chosen to use a macro instead of a function to
be able to avoid defining the first parameter.
In fact, this "struct of_device_id *" first parameter
is usualy not defined as well on non-dt builds.
Add empty of_device_is_compatible() and of_parse_phandle() for non-dt
builds to work.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Add a helper similar to of_property_read_u32() that handles 64-bit
integers.
v2/v3: constify device node and property name parameters.
Reviewed-by: Rob Herring <rob.herring@calxeda.com>
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
Add of_property_read_string_index and of_property_count_strings
to retrieve one string inside a property that will contains
severals strings.
Signed-off-by: Benoit Cousson <b-cousson@ti.com>
Signed-off-by: Kevin Hilman <khilman@ti.com>
Add a macro of_match_ptr() that allows the .of_match_table
entry in the driver structures to be assigned without having
an #ifdef xxx NULL for the case that OF is not enabled
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
The patch adds a couple empty functions for non-dt build, so that
The patch adds function of_alias_scan to populate a global lookup
table with the properties of 'aliases' node and function
of_alias_get_id for drivers to find alias id from the lookup table.
v3: Split out automatic addition of aliases on id lookup so that it can be
debated separately from the core functionality.
v2: - Add of_chosen/of_aliases populating and of_alias_scan() invocation
for OF_PROMTREE.
- Add locking
- rework parse loop
The patch adds empty function of_get_property for non-dt build, so that
This also fixes the current Tegra compile problem in linux-next.
This reverts commit 750f463a749e28464151ad26938d11b07b1c43cb.
of_alias_* still needs work to be generalized for 'promtree' dt
platforms, and to no implicitly create entries for available ids.
[grant.likely: add locking and rework parse loop]
The helper functions for reading u32 integers, u32 arrays and strings
should have the property name as a const pointer.
The patch adds empty functions of_property_read_u32 and
of_property_read_u32_array for non-dt build, so that drivers
[grant.likely: Moved things around so only one new static inline is needed]
[grant.likely: Added _string variant]
Rework of_property_read_u32 to read an array of values. Then
of_property_read_u32 becomes an inline with array size of 1.
Also make struct device_node ptr const.
