path: root/include/linux/nfsd/nfsfh.h
2011-08-26Remove include/linux/nfsd/const.hJ. Bruce Fields
Userspace shouldn't have a use for these constants. Nothing here is used outside fs/nfsd. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-05-03nfsd: further comment typosJ. Bruce Fields
Whoops, missed some more. "Reviewed-by, I guess": Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2010-04-22nfsd4: fix filehandle commentJ. Bruce Fields
Minor typos. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-12-15nfsd: move most of nfsfh.h to fs/nfsdJ. Bruce Fields
Most of this can be trivially moved to a private header as well. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-12-14nfsd: Headers Independence and include cleanupsBoaz Harrosh
* Add includes that are directly used by headers * Remove includes that are not needed These are the changes made: [xdr.h] struct nfsd_readdirres has an embedded struct readdir_cd from nfsd.h fixing that we can drop other includes [xdr4.h] embedded types defined both at state.h and nfsd.h [syscall.h] After export.h fix none of these stuff is needed. fix extra space in # include <> statement [stats.h] does not need <linux/nfs4.h> but was export to user-mode so I don't touch it [state.h] embedded types from nfsfh.h like struct knfsd_fh. bringing that eliminates the need for all other includes [nfsfh.h] directly manipulating types from sunrpc/svc.h. Removed Other unused headers. [nfsd.h] removed unused headers include [export.h] lots of sunrpc/svc.h types and a single prototype declaration with pointer from nfsfh.h, but all users of export.h do need nfsfh.h any way. remove now un-needed include. [const.h] Unfixed (not independent) [cache.h] could do with a forward declaration of "struct svc_rqst;" from sunrpc/svc.h but all users absolutely will need sunrpc/svc.h it is easier overall this way. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-12-14nfsd: Remove unused dprintkBoaz Harrosh
This doesn't appear to be useful. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-29nfsd: support ext4 i_versionJ. Bruce Fields
ext4 supports a real NFSv4 change attribute, which is bumped whenever the ctime would be updated, including times when two updates arrive within a jiffy of each other. (Note that although ext4 has space for nanosecond-precision ctime, the real resolution is lower: it actually uses jiffies as the time-source.) This ensures clients will invalidate their caches when they need to. There is some fear that keeping the i_version up-to-date could have performance drawbacks, so for now it's turned on only by a mount option. We hope to do something better eventually. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Cc: Theodore Tso <tytso@mit.edu>
2009-03-18nfsd4: use helper for copying filehandles for replayJ. Bruce Fields
2009-01-30headers_check fix: nfsd/nfsfh.hJaswinder Singh Rajput
fix the following 'make headers_check' warnings: usr/include/linux/nfsd/nfsfh.h:17: include of <linux/types.h> is preferred over <asm/types.h> usr/include/linux/nfsd/nfsfh.h:28: found __[us]{8,16,32,64} type without #include <linux/types.h> Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
2009-01-06nfsd: document new filehandle fsid typesJ. Bruce Fields
Descriptions taken from mountd code (in nfs-utils/utils/mountd/cache.c). Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2007-10-09knfsd: 64 bit ino support for NFS serverPeter Staubach
Modify the NFS server code to support 64 bit ino's, as appropriate for the system and the NFS protocol version. The gist of the changes is to query the underlying file system for attributes and not just to use the cached attributes in the inode. For this specific purpose, the inode only contains an ino field which unsigned long, which is large enough on 64 bit platforms, but is not large enough on 32 bit platforms. I haven't been able to find any reason why ->getattr can't be called while i_mutex. The specification indicates that i_mutex is not required to be held in order to invoke ->getattr, but it doesn't say that i_mutex can't be held while invoking ->getattr. I also haven't come to any conclusions regarding the value of lease_get_mtime() and whether it should or should not be invoked by fill_post_wcc() too. I chose not to change this because I thought that it was safer to leave well enough alone. If we decide to make a change, it can be done separately. Signed-off-by: Peter Staubach <staubach@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Acked-by: Neil Brown <neilb@suse.de>
2007-02-14[PATCH] knfsd: add some new fsid typesNeilBrown
Add support for using a filesystem UUID to identify and export point in the filehandle. For NFSv2, this UUID is xor-ed down to 4 or 8 bytes so that it doesn't take up too much room. For NFSv3+, we use the full 16 bytes, and possibly also a 64bit inode number for exports beneath the root of a filesystem. When generating an fsid to return in 'stat' information, use the UUID (hashed down to size) if it is available and a small 'fsid' was not specifically provided. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-26[PATCH] knfsd: replace some warning ins nfsfh.h with BUG_ON or WARN_ONNeilBrown
A couple of the warnings will be followed by an Oops if they ever fire, so may as well be BUG_ON. Another isn't obviously fatal but has never been known to fire, so make it a WARN_ON. Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-20[PATCH] nfsd: misc endianness annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] nfsfh simple endianness annotationsAl Viro
2006-10-02[PATCH] nfsd: lockdep annotationPeter Zijlstra
while doing a kernel make modules_install install over an NFS mount. ============================================= [ INFO: possible recursive locking detected ] --------------------------------------------- nfsd/9550 is trying to acquire lock: (&inode->i_mutex){--..}, at: [<c034c845>] mutex_lock+0x1c/0x1f but task is already holding lock: (&inode->i_mutex){--..}, at: [<c034c845>] mutex_lock+0x1c/0x1f other info that might help us debug this: 2 locks held by nfsd/9550: #0: (hash_sem){..--}, at: [<cc895223>] exp_readlock+0xd/0xf [nfsd] #1: (&inode->i_mutex){--..}, at: [<c034c845>] mutex_lock+0x1c/0x1f stack backtrace: [<c0103508>] show_trace_log_lvl+0x58/0x152 [<c0103b8b>] show_trace+0xd/0x10 [<c0103c2f>] dump_stack+0x19/0x1b [<c012aa57>] __lock_acquire+0x77a/0x9a3 [<c012af4a>] lock_acquire+0x60/0x80 [<c034c6c2>] __mutex_lock_slowpath+0xa7/0x20e [<c034c845>] mutex_lock+0x1c/0x1f [<c0162edc>] vfs_unlink+0x34/0x8a [<cc891d98>] nfsd_unlink+0x18f/0x1e2 [nfsd] [<cc89884f>] nfsd3_proc_remove+0x95/0xa2 [nfsd] [<cc88f0d4>] nfsd_dispatch+0xc0/0x178 [nfsd] [<c033e84d>] svc_process+0x3a5/0x5ed [<cc88f5ba>] nfsd+0x1a7/0x305 [nfsd] [<c0101005>] kernel_thread_helper+0x5/0xb DWARF2 unwinder stuck at kernel_thread_helper+0x5/0xb Leftover inexact backtrace: [<c0103b8b>] show_trace+0xd/0x10 [<c0103c2f>] dump_stack+0x19/0x1b [<c012aa57>] __lock_acquire+0x77a/0x9a3 [<c012af4a>] lock_acquire+0x60/0x80 [<c034c6c2>] __mutex_lock_slowpath+0xa7/0x20e [<c034c845>] mutex_lock+0x1c/0x1f [<c0162edc>] vfs_unlink+0x34/0x8a [<cc891d98>] nfsd_unlink+0x18f/0x1e2 [nfsd] [<cc89884f>] nfsd3_proc_remove+0x95/0xa2 [nfsd] [<cc88f0d4>] nfsd_dispatch+0xc0/0x178 [nfsd] [<c033e84d>] svc_process+0x3a5/0x5ed [<cc88f5ba>] nfsd+0x1a7/0x305 [nfsd] [<c0101005>] kernel_thread_helper+0x5/0xb ============================================= [ INFO: possible recursive locking detected ] --------------------------------------------- nfsd/9580 is trying to acquire lock: (&inode->i_mutex){--..}, at: [<c034cc1d>] mutex_lock+0x1c/0x1f but task is already holding lock: (&inode->i_mutex){--..}, at: [<c034cc1d>] mutex_lock+0x1c/0x1f other info that might help us debug this: 2 locks held by nfsd/9580: #0: (hash_sem){..--}, at: [<cc89522b>] exp_readlock+0xd/0xf [nfsd] #1: (&inode->i_mutex){--..}, at: [<c034cc1d>] mutex_lock+0x1c/0x1f stack backtrace: [<c0103508>] show_trace_log_lvl+0x58/0x152 [<c0103b8b>] show_trace+0xd/0x10 [<c0103c2f>] dump_stack+0x19/0x1b [<c012aa63>] __lock_acquire+0x77a/0x9a3 [<c012af56>] lock_acquire+0x60/0x80 [<c034ca9a>] __mutex_lock_slowpath+0xa7/0x20e [<c034cc1d>] mutex_lock+0x1c/0x1f [<cc892ad1>] nfsd_setattr+0x2c8/0x499 [nfsd] [<cc893ede>] nfsd_create_v3+0x31b/0x4ac [nfsd] [<cc8984a1>] nfsd3_proc_create+0x128/0x138 [nfsd] [<cc88f0d4>] nfsd_dispatch+0xc0/0x178 [nfsd] [<c033ec1d>] svc_process+0x3a5/0x5ed [<cc88f5ba>] nfsd+0x1a7/0x305 [nfsd] [<c0101005>] kernel_thread_helper+0x5/0xb DWARF2 unwinder stuck at kernel_thread_helper+0x5/0xb Leftover inexact backtrace: [<c0103b8b>] show_trace+0xd/0x10 [<c0103c2f>] dump_stack+0x19/0x1b [<c012aa63>] __lock_acquire+0x77a/0x9a3 [<c012af56>] lock_acquire+0x60/0x80 [<c034ca9a>] __mutex_lock_slowpath+0xa7/0x20e [<c034cc1d>] mutex_lock+0x1c/0x1f [<cc892ad1>] nfsd_setattr+0x2c8/0x499 [nfsd] [<cc893ede>] nfsd_create_v3+0x31b/0x4ac [nfsd] [<cc8984a1>] nfsd3_proc_create+0x128/0x138 [nfsd] [<cc88f0d4>] nfsd_dispatch+0xc0/0x178 [nfsd] [<c033ec1d>] svc_process+0x3a5/0x5ed [<cc88f5ba>] nfsd+0x1a7/0x305 [nfsd] [<c0101005>] kernel_thread_helper+0x5/0xb Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Neil Brown <neilb@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
