path: root/include/linux/nfs_xdr.h
2010-11-22NFS: Ensure we return the dirent->d_type when it is knownTrond Myklebust
Store the dirent->d_type in the struct nfs_cache_array_entry so that we can use it in getdents() calls. This fixes a regression with the new readdir code. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-24NFSv4.1: pnfs: add LAYOUTGET and GETDEVICEINFO infrastructureAndy Adamson
Add the ability to actually send LAYOUTGET and GETDEVICEINFO. This also adds in the machinery to handle layout state and the deviceid cache. Note that GETDEVICEINFO is not called directly by the generic layer. Instead it is called by the drivers while parsing the LAYOUTGET opaque data in response to an unknown device id embedded therein. RFC 5661 only encodes device ids within the driver-specific opaque data. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Dean Hildebrand <dhildebz@umich.edu> Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: Mike Sager <sager@netapp.com> Signed-off-by: Ricardo Labiaga <ricardo.labiaga@netapp.com> Signed-off-by: Tao Guo <guotao@nrchpc.ac.cn> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-24NFS: ask for layouttypes during v4 fsinfo callAndy Adamson
This information will be used to determine which layout driver, if any, to use for subsequent IO on this filesystem. Each driver is assigned an integer id, with 0 reserved to indicate no driver. The server can in theory return multiple ids. However, our current client implementation only notes the first entry and ignores the rest. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-24Revalidate caches on lockRicardo Labiaga
Instead of blindly zapping the caches, attempt to revalidate them if the server has indicated that it uses high resolution timestamps. NFSv4 should be able to always revalidate the cache since the protocol requires the update of the change attribute on modification of the data. In reality, there are servers (the Linux NFS server for example) that do not obey this requirement and use ctime as the basis for change attribute. Long term, the server needs to be fixed. At this time, and to be on the safe side, continue zapping caches if the server indicates that it does not have a high resolution timestamp. Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-23NFS: Readdir plus in v4Bryan Schumaker
By requsting more attributes during a readdir, we can mimic the readdir plus operation that was in NFSv3. To test, I ran the command `ls -lU --color=none` on directories with various numbers of files. Without readdir plus, I see this: n files | 100 | 1,000 | 10,000 | 100,000 | 1,000,000 --------+-----------+-----------+-----------+-----------+---------- real | 0m00.153s | 0m00.589s | 0m05.601s | 0m56.691s | 9m59.128s user | 0m00.007s | 0m00.007s | 0m00.077s | 0m00.703s | 0m06.800s sys | 0m00.010s | 0m00.070s | 0m00.633s | 0m06.423s | 1m10.005s access | 3 | 1 | 1 | 4 | 31 getattr | 2 | 1 | 1 | 1 | 1 lookup | 104 | 1,003 | 10,003 | 100,003 | 1,000,003 readdir | 2 | 16 | 158 | 1,575 | 15,749 total | 111 | 1,021 | 10,163 | 101,583 | 1,015,784 With readdir plus enabled, I see this: n files | 100 | 1,000 | 10,000 | 100,000 | 1,000,000 --------+-----------+-----------+-----------+-----------+---------- real | 0m00.115s | 0m00.206s | 0m01.079s | 0m12.521s | 2m07.528s user | 0m00.003s | 0m00.003s | 0m00.040s | 0m00.290s | 0m03.296s sys | 0m00.007s | 0m00.020s | 0m00.120s | 0m01.357s | 0m17.556s access | 3 | 1 | 1 | 1 | 7 getattr | 2 | 1 | 1 | 1 | 1 lookup | 4 | 3 | 3 | 3 | 3 readdir | 6 | 62 | 630 | 6,300 | 62,993 total | 15 | 67 | 635 | 6,305 | 63,004 Readdir plus disabled has about a 16x increase in the number of rpc calls and is 4 - 5 times slower on large directories. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-23NFS: readdir with vmapped pagesBryan Schumaker
We can use vmapped pages to read more information from the network at once. This will reduce the number of calls needed to complete a readdir. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> [trondmy: Added #include for linux/vmalloc.h> in fs/nfs/dir.c] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-23NFS: decode_dirent should use an xdr_streamBryan Schumaker
Convert nfs*xdr.c to use an xdr stream in decode_dirent. This will prevent a kernel oops that has been occuring when reading a vmapped page. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-09-24NFSv4.1: keep seq_res.sr_slot as pointer rather than an indexBenny Halevy
Having to explicitly initialize sr_slotid to NFS4_MAX_SLOT_TABLE resulted in numerous bugs. Keeping the current slot as a pointer to the slot table is more straight forward and robust as it's implicitly set up to NULL wherever the seq_res member is initialized to zeroes. Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-09-17nfs: make sillyrename an async operationJeff Layton
A synchronous rename can be interrupted by a SIGKILL. If that happens during a sillyrename operation, it's possible for the rename call to be sent to the server, but the task exits before processing the reply. If this happens, the sillyrenamed file won't get cleaned up during nfs_dentry_iput and the server is left with a dangling .nfs* file hanging around. Fix this problem by turning sillyrename into an asynchronous operation and have the task doing the sillyrename just wait on the reply. If the task is killed before the sillyrename completes, it'll still proceed to completion. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-09-17nfs: standardize the rename response containerJeff Layton
Right now, v3 and v4 have their own variants. Create a standard struct that will work for v3 and v4. v2 doesn't get anything but a simple error and so isn't affected by this. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-09-17nfs: standardize the rename args containerJeff Layton
Each NFS version has its own version of the rename args container. Standardize them on a common one that's identical to the one NFSv4 uses. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-09-17NFS: Add an 'open_context' element to struct nfs_rpc_opsTrond Myklebust
2010-09-17NFS: Clean up nfs4_proc_create()Trond Myklebust
Remove all remaining references to the struct nameidata from the low level NFS layers. Again pass down a partially initialised struct nfs_open_context when we want to do atomic open+create. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-07-30NFSv4: Add support for the RELEASE_LOCKOWNER operationTrond Myklebust
This is needed by NFSv4.0 servers in order to keep the number of locking stateids at a manageable level. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-07-30NFSv4: Ensure that we track the NFSv4 lock state in read/write requests.Trond Myklebust
This patch fixes bugzilla entry 14501: https://bugzilla.kernel.org/show_bug.cgi?id=14501 Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-06-22NFSv41: Clean up exclusive createTrond Myklebust
2010-05-14NFSv4: Clean up the NFSv4 setclientid operationTrond Myklebust
2010-05-14NFS: Reduce stack footprint of nfs_proc_remove()Trond Myklebust
2009-12-16Merge branch 'for-2.6.33' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.33' of git://linux-nfs.org/~bfields/linux: (42 commits) nfsd: remove pointless paths in file headers nfsd: move most of nfsfh.h to fs/nfsd nfsd: remove unused field rq_reffh nfsd: enable V4ROOT exports nfsd: make V4ROOT exports read-only nfsd: restrict filehandles accepted in V4ROOT case nfsd: allow exports of symlinks nfsd: filter readdir results in V4ROOT case nfsd: filter lookup results in V4ROOT case nfsd4: don't continue "under" mounts in V4ROOT case nfsd: introduce export flag for v4 pseudoroot nfsd: let "insecure" flag vary by pseudoflavor nfsd: new interface to advertise export features nfsd: Move private headers to source directory vfs: nfsctl.c un-used nfsd #includes lockd: Remove un-used nfsd headers #includes s390: remove un-used nfsd #includes sparc: remove un-used nfsd #includes parsic: remove un-used nfsd #includes compat.c: Remove dependence on nfsd private headers ...
2009-12-14nfsd: Fix independence of a few nfsd related headersBoaz Harrosh
An header should be compilation independent, .i.e pull in any header who's declarations are directly used by this header. And not let users re-include all it's dependencies all over again. [At the end of the day what's the use of a header if it does not have more then one user?] Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-12-05nfs41: RECLAIM_COMPLETE XDR functionalityRicardo Labiaga
XDR encoding and decoding for RECLAIM_COMPLETE. Implements the necessary encoding to indicate reclaim complete for the entire client. In the future, it can be extended to provide reclaim complete functionality for a single file system after migration. Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-12-05nfs41: check SEQUENCE status flagAlexandros Batsakis
the server can indicate a number of error conditions by setting the appropriate bits in the SEQUENCE operation. The client re-establishes state with the server when it receives one of those, with the action depending on the specific case. Signed-off-by: Alexandros Batsakis <batsakis@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-12-03NFS: reorder nfs4_sequence_regs to remove 8 bytes of padding on 64 bitsRichard Kennedy
reorder nfs4_sequence_args to remove 8 bytes of padding on 64 bit builds. The size of this structure drops to 24 bytes from 32 and reduces the text size of nfs.ko. On my x86_64 size reports text data bss 2.6.32-rc5 200996 8512 432 209940 33414 nfs.ko +patch 200884 8512 432 209828 333a4 nfs.ko Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41: create_session operationAndy Adamson
Implement the create_session operation conforming to http://tools.ietf.org/html/draft-ietf-nfsv4-minorversion1-26 Set the real fore channel max operations to preserve server resources. Note: If the server returns < NFS4_MAX_OPS, the client will very soon get an NFS4ERR_TOO_MANY_OPS. A later patch will handle this. Set the max_rqst_sz and max_resp_sz to PAGE_SIZE - we preallocate the buffers. Set the back channel max_resp_sz_cached to zero to force the client to always set csa_cachethis to FALSE because the current implementation of the back channel DRC only supports caching the CB_SEQUENCE operation. The client back channel server supports one slot, and desires 2 operations per compound. Signed-off-by: Ricardo Labiaga <ricardo.labiaga@netapp.com> Signed-off-by: Andy Adamson<andros@umich.edu> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: remove extraneous rpc_clnt pointer] Use the struct nfs_client cl_rpcclient. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: nfs4_init_channel_attrs, just use nfs41_create_session_args] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: use rsize and wsize for session channel attributes] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: set channel max operations] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: set back channel attributes] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: obliterate nfs4_adjust_channel_attrs] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: have create_session work on nfs_client] Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: move CONFIG_NFS_V4_1 endif] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: pass *session in seq_args and seq_res] [moved nfs4_init_slot_table definition here] Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: use kcalloc to allocate slot table] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> [nfs41: fix Xcode_create_session's xdr Xcoding pointer type] [nfs41: refactor decoding of channel attributes] Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: get_lease_timeAndy Adamson
get_lease_time uses the FSINFO rpc operation to get the lease time attribute. nfs4_get_lease_time() is only called from the state manager on session setup so don't recover from clientid or sequence level errors. We do need to recover from NFS4ERR_DELAY or NFS4ERR_GRACE. Use NFS4_POLL_RETRY_MIN - the Linux server returns NFS4ERR_DELAY when an upcall is needed to resolve an uncached export referenced by a file handle. [nfs41: sequence res use slotid] Signed-off-by: Andy Adamson<andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: remove extraneous rpc_clnt pointer] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: have get_lease_time work on nfs_client] Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: get_lease_time recover from NFS4ERR_DELAY] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: pass *session in seq_args and seq_res] [define nfs4_get_lease_time_{args,res}] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41: exchange_id operationBenny Halevy
Implement the exchange_id operation conforming to http://tools.ietf.org/html/draft-ietf-nfsv4-minorversion1-26 Unlike NFSv4.0, NFSv4.1 requires machine credentials. RPC_AUTH_GSS machine credentials will be passed into the kernel at mount time to be available for the exchange_id operation. RPC_AUTH_UNIX root mounts can use the UNIX root credential. Store the root credential in the nfs_client struct. Without a credential, NFSv4.1 state renewal fails. [nfs41: establish clientid via exchange id only if cred != NULL] Signed-off-by: Andy Adamson<andros@umich.edu> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfsd41: move nfstime4 from under CONFIG_NFS_V4_1] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: do not wait a lease time in exchange id] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: pass *session in seq_args and seq_res] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> [nfs41: Ignoring impid in decode_exchange_id is missing a READ_BUF] Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: fix Xcode_exchange_id's xdr Xcoding pointer type] [nfs41: get rid of unused struct nfs41_exchange_id_res members] Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: setup_sequence methodAndy Adamson
Allocate a slot in the session slot table and set the sequence op arguments. Called at the rpc prepare stage. Add a status to nfs41_sequence_res, initialize it to one so that we catch rpc level failures which do not go through decode_sequence which sets the new status field. Note that upon an rpc level failure, we don't know if the server processed the sequence operation or not. Proceed as if the server did process the sequence operation. Signed-off-by: Rahul Iyer <iyer@netapp.com> [nfs41: sequence args use slotid] [nfs41: find slot return slotid] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: remove SEQ4_STATUS_USE_TK_STATUS] As per 11-14-08 review [move extern declaration from nfs41: sequence setup/done support] [removed sa_session definition, changed sa_cache_this into a u8 to reduce footprint] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: rpc_sleep_on slot_tbl_waitq must be called under slot_tbl_lock] Otherwise there's a race (we've hit) with nfs4_free_slot where nfs41_setup_sequence sees a full slot table, unlocks slot_tbl_lock, nfs4_free_slots happen concurrently and call rpc_wake_up_next where there's nobody to wake up yet, context goes back to nfs41_setup_sequence which goes to sleep when the slot table is actually empty now and there's no-one to wake it up anymore. Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41: set up seq_res.sr_slotidAndy Adamson
Initialize nfs4_sequence_res sr_slotid to NFS4_MAX_SLOT_TABLE. [was nfs41: sequence res use slotid] Signed-off-by: Andy Adamson <andros@netapp.com> [pulled definition of struct nfs4_sequence_res.sr_slotid to here] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41: nfs41: pass *session in seq_args and seq_resBenny Halevy
To be used for getting the rpc's minorversion and for nfs41 xdr {en,de}coding of the sequence operation. Reset the seq session ptrs for minorversion=0 rpc calls. Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41: use nfs4_fs_locations_resBenny Halevy
In preparation for nfs41 sequence processing. Signed-off-by: Andy Admason <andros@netapp.com> [find nfs4_fs_locations_res] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41: use nfs4_setaclresBenny Halevy
In preparation for nfs41 sequence processing. Signed-off-by: Andy Admason <andros@netapp.com> [define nfs_setaclres] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41: use nfs4_getaclresBenny Halevy
In preparation for nfs41 sequence processing. Signed-off-by: Andy Admason <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: embed resp_len in nfs_getaclres] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41: use nfs4_pathconf_resBenny Halevy
In preparation for nfs41 sequence processing. Signed-off-by: Andy Admason <andros@netapp.com> [define nfs4_pathconf_res] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41: use nfs4_fsinfo_resBenny Halevy
In preparation for nfs41 sequence processing. Signed-off-by: Andy Admason <andros@netapp.com> [define nfs4_fsinfo_res] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41: use nfs4_statfs_resBenny Halevy
In preparation for nfs41 sequence processing. Signed-off-by: Andy Admason <andros@netapp.com> [define nfs4_statfs_res] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41: use nfs4_readlink_resBenny Halevy
In preparation for nfs41 sequence processing. Signed-off-by: Andy Admason <andros@netapp.com> [define nfs4_readlink_res] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41: use nfs4_server_caps_argBenny Halevy
In preparation for nfs41 sequence processing. Signed-off-by: Andy Admason <andros@netapp.com> [define nfs4_server_caps_arg] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41: sessions client infrastructureAndy Adamson
NFSv4.1 Sessions basic data types, initialization, and destruction. The session is always associated with a struct nfs_client that holds the exchange_id results. Signed-off-by: Rahul Iyer <iyer@netapp.com> Signed-off-by: Andy Adamson<andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [remove extraneous rpc_clnt pointer, use the struct nfs_client cl_rpcclient. remove the rpc_clnt parameter from nfs4 nfs4_init_session] Signed-off-by: Andy Adamson<andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [Use the presence of a session to determine behaviour instead of the minorversion number.] Signed-off-by: Andy Adamson <andros@netapp.com> [constified nfs4_has_session's struct nfs_client parameter] Signed-off-by: Benny Halevy <bhalevy@panasas.com> [Rename nfs4_put_session() to nfs4_destroy_session() and call it from nfs4_free_client() not nfs4_free_server(). Also get rid of nfs4_get_session() and the ref_count in nfs4_session struct as keeping track of nfs_client should be sufficient] Signed-off-by: Alexandros Batsakis <Alexandros.Batsakis@netapp.com> [nfs41: pass rsize and wsize into nfs4_init_session] Signed-off-by: Andy Adamson <andros@netapp.com> [separated out removal of rpc_clnt parameter from nfs4_init_session ot a patch of its own] Signed-off-by: Benny Halevy <bhalevy@panasas.com> [Pass the nfs_client pointer into nfs4_alloc_session] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: don't assign to session->clp->cl_session in nfs4_destroy_session] [nfs41: fixup nfs4_clear_client_minor_version] [introduce nfs4_clear_client_minor_version() in this patch] Signed-off-by: Benny Halevy <bhalevy@panasas.com> [Refactor nfs4_init_session] Moved session allocation into nfs4_init_client_minor_version, called from nfs4_init_client. Leave rwise and wsize initialization in nfs4_init_session, called from nfs4_init_server. Reverted moving of nfs_fsid definition to nfs_fs_sb.h Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: Move NFS4_MAX_SLOT_TABLE define from under CONFIG_NFS_V4_1] [Fix comile error when CONFIG_NFS_V4_1 is not set.] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [moved nfs4_init_slot_table definition to "create_session operation"] Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: alloc session with GFP_KERNEL] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41: client xdr definitionsBenny Halevy
Define stubs for sequence args and res data structures and embed them in all other nfs4 and nfs41 xdr types. They are needed for sending any op in a nfs41 compound rpc. Signed-off-by: Andy Adamson<andros@netapp.com> [moved new args/res definitions away, to where they're first used] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-04-01Merge branch 'devel' into for-linusTrond Myklebust
2009-03-27constify dentry_operations: NFSAl Viro
2009-03-19NFS: Optimise NFS close()Trond Myklebust
Close-to-open cache consistency rules really only require us to flush out writes on calls to close(), and require us to revalidate attributes on the very last close of the file. Currently we appear to be doing a lot of extra attribute revalidation and cache flushes. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-11NFS: Fix the type of struct nfs_fattr->modeTrond Myklebust
There is no point in using anything other than umode_t, since we copy the content pretty much directly into inode->i_mode. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-11NFS: Shrink the struct nfs_fattrTrond Myklebust
We don't need the bitmap[] field anymore, since the 'valid' field tells us all we need to know about which attributes were filled in... Also move the pre-op attributes in order to improve the structure packing. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-11NFSv4: Support NFSv4 optional attributes in the struct nfs_fattrTrond Myklebust
Currently, filling struct nfs_fattr is more or less an all or nothing operation, since NFSv2 and NFSv3 have only mandatory attributes. In NFSv4, some attributes are optional, and so we may simply not be able to fill in those fields. Furthermore, NFSv4 allows you to specify which attributes you are interested in retrieving, thus permitting you to optimise away retrieval of attributes that you know will no change... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-10NFSv3: Fix posix ACL codeTrond Myklebust
Fix a memory leak due to allocation in the XDR layer. In cases where the RPC call needs to be retransmitted, we end up allocating new pages without clearing the old ones. Fix this by moving the allocation into nfs3_proc_setacls(). Also fix an issue discovered by Kevin Rudd, whereby the amount of memory reserved for the acls in the xdr_buf->head was miscalculated, and causing corruption. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23NFSv4: Convert the open and close ops to use fmodeTrond Myklebust
2008-12-23NFSv4: Convert delegation->type field to fmode_tTrond Myklebust
2008-10-14NFS: Fix the resolution problem with nfs_inode_attrs_need_update()Trond Myklebust
It appears that 'jiffies' timestamps do not have high enough resolution for nfs_inode_attrs_need_update(). One problem is that a GETATTR can be launched within < 1 jiffy of the last operation that updated the attribute. Another problem is that RPC calls can take < 1 jiffy to execute. We can fix this by switching the variables to use a simple global counter that gets incremented every time we start another GETATTR call. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-08NFS: Save padding bytes in struct nfs4_setclientidTrond Myklebust
Peter Staubach suggested reducing NFS4_SETCLIENTID_NAMELEN by one byte so as to avoid 7 bytes of unnecessary padding. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
