path: root/include/linux/nfs_fs.h
2009-08-12NFS: Fix an O_DIRECT Oops...Trond Myklebust
We can't call nfs_readdata_release()/nfs_writedata_release() without first initialising and referencing args.context. Doing so inside nfs_direct_read_schedule_segment()/nfs_direct_write_schedule_segment() causes an Oops. We should rather be calling nfs_readdata_free()/nfs_writedata_free() in those cases. Looking at the O_DIRECT code, the "struct nfs_direct_req" is already referencing the nfs_open_context for us. Since the readdata and writedata structures carry a reference to that, we can simplify things by getting rid of the extra nfs_open_context references, so that we can replace all instances of nfs_readdata_release()/nfs_writedata_release(). Reported-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Tested-by: Catalin Marinas <catalin.marinas@arm.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-03NFS: nfs_readpage_async() needs to be accessible as a fallback for local cachingDavid Howells
nfs_readpage_async() needs to be non-static so that it can be used as a fallback for the local on-disk caching should an EIO crop up when reading the cache. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03NFS: Use local disk inode cacheDavid Howells
Bind data storage objects in the local cache to NFS inodes. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03NFS: Add FS-Cache option bit and debug bitDavid Howells
Add FS-Cache option bit to nfs_server struct. This is set to indicate local on-disk caching is enabled for a particular superblock. Also add debug bit for local caching operations. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-01Merge branch 'devel' into for-linusTrond Myklebust
2009-03-27constify dentry_operations: NFSAl Viro
2009-03-11NFS: Throttle page dirtying while we're flushing to diskTrond Myklebust
The following patch is a combination of a patch by myself and Peter Staubach. Trond: If we allow other processes to dirty pages while a process is doing a consistency sync to disk, we can end up never making progress. Peter: Attached is a patch which addresses a continuing problem with the NFS client generating out of order WRITE requests. While this is compliant with all of the current protocol specifications, there are servers in the market which can not handle out of order WRITE requests very well. Also, this may lead to sub-optimal block allocations in the underlying file system on the server. This may cause the read throughputs to be reduced when reading the file from the server. Peter: There has been a lot of work recently done to address out of order issues on a systemic level. However, the NFS client is still susceptible to the problem. Out of order WRITE requests can occur when pdflush is in the middle of writing out pages while the process dirtying the pages calls generic_file_buffered_write which calls generic_perform_write which calls balance_dirty_pages_rate_limited which ends up calling writeback_inodes which ends up calling back into the NFS client to writes out dirty pages for the same file that pdflush happens to be working with. Signed-off-by: Peter Staubach <staubach@redhat.com> [modification by Trond to merge the two similar patches] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-11NFS: cleanup - remove struct nfs_inode->ncommitTrond Myklebust
2008-12-23optimize attribute timeouts for "noac" and "actimeo=0"Peter Staubach
Hi. I've been looking at a bugzilla which describes a problem where a customer was advised to use either the "noac" or "actimeo=0" mount options to solve a consistency problem that they were seeing in the file attributes. It turned out that this solution did not work reliably for them because sometimes, the local attribute cache was believed to be valid and not timed out. (With an attribute cache timeout of 0, the cache should always appear to be timed out.) In looking at this situation, it appears to me that the problem is that the attribute cache timeout code has an off-by-one error in it. It is assuming that the cache is valid in the region, [read_cache_jiffies, read_cache_jiffies + attrtimeo]. The cache should be considered valid only in the region, [read_cache_jiffies, read_cache_jiffies + attrtimeo). With this change, the options, "noac" and "actimeo=0", work as originally expected. This problem was previously addressed by special casing the attrtimeo == 0 case. However, since the problem is only an off- by-one error, the cleaner solution is address the off-by-one error and thus, not require the special case. Thanx... ps Signed-off-by: Peter Staubach <staubach@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23NFSv4: Convert the open and close ops to use fmodeTrond Myklebust
2008-12-23NFSv4: Convert delegation->type field to fmode_tTrond Myklebust
2008-12-23NFS: Move declaration of nfs_mount() to fs/nfs/internal.hChuck Lever
Clean up: The nfs_mount() function is not to be used outside of the NFS client. Move its public declaration to fs/nfs/internal.h. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-17Make nfs_file_cred more robust.Neil Brown
As not all files have an associated open_context (e.g. device special files), it is safest to test for the existence of the open context before de-referencing it. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-14NFS: Fix the resolution problem with nfs_inode_attrs_need_update()Trond Myklebust
It appears that 'jiffies' timestamps do not have high enough resolution for nfs_inode_attrs_need_update(). One problem is that a GETATTR can be launched within < 1 jiffy of the last operation that updated the attribute. Another problem is that RPC calls can take < 1 jiffy to execute. We can fix this by switching the variables to use a simple global counter that gets incremented every time we start another GETATTR call. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-07NFS: Allow concurrent inode revalidationTrond Myklebust
Currently, if two processes are both trying to revalidate metadata for the same inode, they will find themselves being serialised. There is no good justification for this now that we have improved our ability to detect stale attribute data, so we should remove that serialisation. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-26[PATCH] get rid of indirect users of namei.hAl Viro
fs.h needs path.h, not namei.h; nfs_fs.h doesn't need it at all. Several places in the tree needed direct include. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] sanitize ->permission() prototypeAl Viro
* kill nameidata * argument; map the 3 bits in ->flags anybody cares about to new MAY_... ones and pass with the mask. * kill redundant gfs2_iop_permission() * sanitize ecryptfs_permission() * fix remaining places where ->permission() instances might barf on new MAY_... found in mask. The obvious next target in that direction is permission(9) folded fix for nfs_permission() breakage from Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-09NFS: use documenting macro constants for initializing ac{reg, dir}{min, max}Chuck Lever
Clean up. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-09NFS: set transport defaults after mount option parsing is finishedTrond Myklebust
Move the UDP/TCP default timeo/retrans settings for text mounts to nfs_init_timeout_values(), which was were they were always being initialised (and sanity checked) for binary mounts. Document the default timeout values using appropriate #defines. Ensure that we initialise and sanity check the transport protocols that may have been specified by the user. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-04-19make nfs_automount_list staticAdrian Bunk
nfs_automount_list can now become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-04-19NFS: Ensure that the write code cleans up properly when rpc_run_task() failsTrond Myklebust
2008-03-07NFS: Fix the fsid revalidation in nfs_update_inode()Trond Myklebust
When we detect that we've crossed a mountpoint on the remote server, we must take care not to use that inode to revalidate the fsid on our current superblock. To do so, we label the inode as a remote mountpoint, and check for that in nfs_update_inode(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-01Merge branch 'task_killable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'task_killable' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: (22 commits) Remove commented-out code copied from NFS NFS: Switch from intr mount option to TASK_KILLABLE Add wait_for_completion_killable Add wait_event_killable Add schedule_timeout_killable Use mutex_lock_killable in vfs_readdir Add mutex_lock_killable Use lock_page_killable Add lock_page_killable Add fatal_signal_pending Add TASK_WAKEKILL exit: Use task_is_* signal: Use task_is_* sched: Use task_contributes_to_load, TASK_ALL and TASK_NORMAL ptrace: Use task_is_* power: Use task_is_* wait: Use TASK_NORMAL proc/base.c: Use task_is_* proc/array.c: Use TASK_REPORT perfmon: Use task_is_* ... Fixed up conflicts in NFS/sunrpc manually..
2008-01-30nfs: convert NFS_*(inode) helpers to static inlineBenny Halevy
Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30nfs: obliterate NFS_FLAGS macroBenny Halevy
use NFS_I(inode)->flags instead Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: define a function to update nfsi->cache_change_attributeTrond Myklebust
2007-12-06NFS: Switch from intr mount option to TASK_KILLABLEMatthew Wilcox
By using the TASK_KILLABLE infrastructure, we can get rid of the 'intr' mount option. We have to use _killable everywhere instead of _interruptible as we get rid of rpc_clnt_sigmask/sigunmask. Signed-off-by: Liam R. Howlett <howlett@gmail.com> Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-11-26NFS: make nfs_wb_page_priority() staticAdrian Bunk
nfs_wb_page_priority() can now become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-19NFS: Fix a race in sillyrenameTrond Myklebust
lookup() and sillyrename() can race one another because the sillyrename() completion cannot take the parent directory's inode->i_mutex since the latter may be held by whoever is calling dput(). We therefore have little option but to add extra locking to ensure that nfs_lookup() and nfs_atomic_open() do not race with the sillyrename completion. If somebody has looked up the sillyrenamed file in the meantime, we just transfer the sillydelete information to the new dentry. Please refer to the bug-report at http://bugzilla.linux-nfs.org/show_bug.cgi?id=150 Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Add a boot parameter to disable 64 bit inode numbersTrond Myklebust
This boot parameter will allow legacy 32-bit applications which call stat() to continue to function even if the NFSv3/v4 server uses 64-bit inode numbers. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09[23/37] Clean up duplicate includes inJesper Juhl
Hi, This patch cleans up duplicate includes in include/linux/nfs_fs.h Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Get rid of some obsolete macrosTrond Myklebust
- NFS_READTIME, NFS_CHANGE_ATTR are completely unused. - Inline the few remaining uses of NFS_ATTRTIMEO, and remove. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFSv4: Fix nfs_atomic_open() to set the verifier on negative dentries tooTrond Myklebust
2007-10-09NFS: Remove nfs_begin_data_update/nfs_end_data_updateTrond Myklebust
The lower level routines in fs/nfs/proc.c, fs/nfs/nfs3proc.c and fs/nfs/nfs4proc.c should already be dealing with the revalidation issues. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Remove NFS_I(inode)->data_updatesTrond Myklebust
We have no more users... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: NFS_CACHEINV() should not test for nfs_caches_unstable()Trond Myklebust
The fact that we're in the process of modifying the inode does not mean that we should not invalidate the attribute and data caches. The defensive thing is to always invalidate when we're confronted with inode mtime/ctime or change_attribute updates that we do not immediately recognise. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: nfs_mark_for_revalidate don't update cache_change_attributeTrond Myklebust
Just let the subsequent inode revalidation do the update... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Fix nfs_verify_change_attribute()Trond Myklebust
We don't care about whether or not some other process on our client is changing the directory while we're in nfs_lookup_revalidate(), because the dcache will take care of ensuring local atomicity. We can therefore remove the test for nfs_caches_unstable(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Fix the sign of the return value of nfs_save_change_attribute()Trond Myklebust
Also fix up the comments. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Fake up 'wcc' attributes to prevent cache invalidation after writeTrond Myklebust
NFSv2 and v4 don't offer weak cache consistency attributes on WRITE calls. In NFSv3, returning wcc data is optional. In all cases, we want to prevent the client from invalidating our cached data whenever ->write_done() attempts to update the inode attributes. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Fix atime revalidation in readdir()Trond Myklebust
NFSv3 will correctly update atime on a readdir call, so there is no need to set the NFS_INO_INVALID_ATIME flag unless the call to nfs_refresh_inode() fails. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Don't force a dcache revalidation if nfs_wcc_update_inode succeedsTrond Myklebust
The reason is that if the weak cache consistency update was successful, then we know that our client must be the only one that changed the directory, and we've already updated the dcache to reflect the change. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: fix nfs_verify_change_attributeTrond Myklebust
We always want to check that the verifier and directory cache_change_attribute match. This also allows us to remove the 'wraparound hack' for the cache_change_attribute. If we're only checking for equality, then we don't care about wraparound issues. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFSv4: Simplify _nfs4_do_access()Trond Myklebust
Currently, _nfs4_do_access() is just a copy of nfs_do_access() with added conversion of the open flags into an access mask. This patch merges the duplicate functionality. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Replace file->private_data with calls to nfs_file_open_context()Trond Myklebust
2007-10-09NFS: Add a helper to extract the nfs_open_context from a struct fileTrond Myklebust
2007-10-09NFS: Fall back to synchronous writes when a background write errors...Trond Myklebust
This helps prevent huge queues of background writes from building up whenever the server runs out of disk or quota space, or if someone changes the file access modes behind our backs. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Clean up NFS writeback flush codeTrond Myklebust
The only user of nfs_sync_mapping_range() is nfs_getattr(), which uses it to flush out the entire inode without sending a commit. We therefore replace nfs_sync_mapping_range with a more appropriate helper. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Clean up write code...Trond Myklebust
The addition of nfs_page_mkwrite means that We should no longer need to create requests inside nfs_writepage() Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-09-01NFS: Fix a write request leak in nfs_invalidate_page()Trond Myklebust
Ryusuke Konishi says: The recent truncate_complete_page() clears the dirty flag from a page before calling a_ops->invalidatepage(), ^^^^^^ static void truncate_complete_page(struct address_space *mapping, struct page *page) { ... cancel_dirty_page(page, PAGE_CACHE_SIZE); <--- Inserted here at kernel 2.6.20 if (PagePrivate(page)) do_invalidatepage(page, 0); ---> will call a_ops->invalidatepage() ... } and this is disturbing nfs_wb_page_priority() from calling nfs_writepage_locked() that is expected to handle the pending request (=nfs_page) associated with the page. int nfs_wb_page_priority(struct inode *inode, struct page *page, int how) { ... if (clear_page_dirty_for_io(page)) { ret = nfs_writepage_locked(page, &wbc); if (ret < 0) goto out; } ... } Since truncate_complete_page() will get rid of the page after a_ops->invalidatepage() returns, the request (=nfs_page) associated with the page becomes a garbage in nfs_inode->nfs_page_tree. ------------------------ Fix this by ensuring that nfs_wb_page_priority() recognises that it may also need to clear out non-dirty pages that have an nfs_page associated with them. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
