path: root/include/linux/netdevice.h
2008-12-22net: Remove unused netdev arg from some NAPI interfaces.Neil Horman
When the napi api was changed to separate its 1:1 binding to the net_device struct, the netif_rx_[prep|schedule|complete] api failed to remove the now vestigual net_device structure parameter. This patch cleans up that api by properly removing it.. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-15net: Add Generic Receive Offload infrastructureHerbert Xu
This patch adds the top-level GRO (Generic Receive Offload) infrastructure. This is pretty similar to LRO except that this is protocol-independent. Instead of holding packets in an lro_mgr structure, they're now held in napi_struct. For drivers that intend to use this, they can set the NETIF_F_GRO bit and call napi_gro_receive instead of netif_receive_skb or just call netif_rx. The latter will call napi_receive_skb automatically. When napi_gro_receive is used, the driver must either call napi_complete/napi_rx_complete, or call napi_gro_flush in softirq context if the driver uses the primitives __napi_complete/__napi_rx_complete. Protocols will set the gro_receive and gro_complete function pointers in order to participate in this scheme. In addition to the packet, gro_receive will get a list of currently held packets. Each packet in the list has a same_flow field which is non-zero if it is a potential match for the new packet. For each packet that may match, they also have a flush field which is non-zero if the held packet must not be merged with the new packet. Once gro_receive has determined that the new skb matches a held packet, the held packet may be processed immediately if the new skb cannot be merged with it. In this case gro_receive should return the pointer to the existing skb in gro_list. Otherwise the new skb should be merged into the existing packet and NULL should be returned, unless the new skb makes it impossible for any further merges to be made (e.g., FIN packet) where the merged skb should be returned. Whenever the skb is merged into an existing entry, the gro_receive function should set NAPI_GRO_CB(skb)->same_flow. Note that if an skb merely matches an existing entry but can't be merged with it, then this shouldn't be set. If gro_receive finds it pointless to hold the new skb for future merging, it should set NAPI_GRO_CB(skb)->flush. Held packets will be flushed by napi_gro_flush which is called by napi_complete and napi_rx_complete. Currently held packets are stored in a singly liked list just like LRO. The list is limited to a maximum of 8 entries. In future, this may be expanded to use a hash table to allow more flows to be held for merging. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-15net: Add frag_list support to GSOHerbert Xu
This patch allows GSO to handle frag_list in a limited way for the purposes of allowing packets merged by GRO to be refragmented on output. Most hardware won't (and aren't expected to) support handling GRO frag_list packets directly. Therefore we will perform GSO in software for those cases. However, for drivers that can support it (such as virtual NICs) we may not have to segment the packets at all. Whether the added overhead of GRO/GSO is worthwhile for bridges and routers when weighed against the benefit of potentially increasing the MTU within the host is still an open question. However, for the case of host nodes this is undoubtedly a win. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-15Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/e1000e/ich8lan.c
2008-12-09netpoll: fix race on poll_list resulting in garbage entryNeil Horman
A few months back a race was discused between the netpoll napi service path, and the fast path through net_rx_action: http://kerneltrap.org/mailarchive/linux-netdev/2007/10/16/345470 A patch was submitted for that bug, but I think we missed a case. Consider the following scenario: INITIAL STATE CPU0 has one napi_struct A on its poll_list CPU1 is calling netpoll_send_skb and needs to call poll_napi on the same napi_struct A that CPU0 has on its list CPU0 CPU1 net_rx_action poll_napi !list_empty (returns true) locks poll_lock for A poll_one_napi napi->poll netif_rx_complete __napi_complete (removes A from poll_list) list_entry(list->next) In the above scenario, net_rx_action assumes that the per-cpu poll_list is exclusive to that cpu. netpoll of course violates that, and because the netpoll path can dequeue from the poll list, its possible for CPU0 to detect a non-empty list at the top of the while loop in net_rx_action, but have it become empty by the time it calls list_entry. Since the poll_list isn't surrounded by any other structure, the returned data from that list_entry call in this situation is garbage, and any number of crashes can result based on what exactly that garbage is. Given that its not fasible for performance reasons to place exclusive locks arround each cpus poll list to provide that mutal exclusion, I think the best solution is modify the netpoll path in such a way that we continue to guarantee that the poll_list for a cpu is in fact exclusive to that cpu. To do this I've implemented the patch below. It adds an additional bit to the state field in the napi_struct. When executing napi->poll from the netpoll_path, this bit will be set. When a driver calls netif_rx_complete, if that bit is set, it will not remove the napi_struct from the poll_list. That work will be saved for the next iteration of net_rx_action. I've tested this and it seems to work well. About the biggest drawback I can see to it is the fact that it might result in an extra loop through net_rx_action in the event that the device is actually contended for (i.e. the netpoll path actually preforms all the needed work no the device, and the call to net_rx_action winds up doing nothing, except removing the napi_struct from the poll_list. However I think this is probably a small price to pay, given that the alternative is a crash. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-08netdevice: Kill netdev->privWang Chen
This is the last shoot of this series. After I removing all directly reference of netdev->priv, I am killing "priv" of "struct net_device" and fixing relative comments/docs. Anyone will not be allowed to reference netdev->priv directly. If you want to reference the memory of private data, use netdev_priv() instead. If the private data is not allocted when alloc_netdev(), use netdev->ml_priv to point that memory after you creating that private data. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25DCB: fix kconfig optionJeff Kirsher
Since the netlink option for DCB is necessary to actually be useful, simplified the Kconfig option. In addition, added useful help text for the Kconfig option. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25netdev: add HAVE_NET_DEVICE_OPSStephen Hemminger
As a concession to vendors who have to deal with one source for different kernel versions, add a HAVE_NET_DEVICE_OPS so they don't end up hard coding ifdef against kernel version. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20ixgbe: this patch adds support for DCB to the kernel and ixgbe driverAlexander Duyck
This adds support for Data Center Bridging (DCB) features in the ixgbe driver and adds an rtnetlink interface for configuring DCB to the kernel. The DCB feature support included are Priority Grouping (PG) - which allows bandwidth guarantees to be allocated to groups to traffic based on the 802.1q priority, and Priority Based Flow Control (PFC) - which introduces a new MAC control PAUSE frame which works at granularity of the 802.1p priority instead of the link (IEEE 802.3x). Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20netdev: add more functions to netdevice opsStephen Hemminger
This patch moves neigh_setup and hard_start_xmit into the network device ops structure. For bisection, fix all the previously converted drivers as well. Bonding driver took the biggest hit on this. Added a prefetch of the hard_start_xmit in the fast path to try and reduce any impact this would have. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-19netdev: introduce dev_get_stats()Stephen Hemminger
In order for the network device ops get_stats call to be immutable, the handling of the default internal network device stats block has to be changed. Add a new helper function which replaces the old use of internal_get_stats. Note: change return code to make it clear that the caller should not go changing the returned statistics. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-19netdev: network device operations infrastructureStephen Hemminger
This patch changes the network device internal API to move adminstrative operations out of the network device structure and into a separate structure. This patch involves some hackery to maintain compatablity between the new and old model, so all 300+ drivers don't have to be changed at once. For drivers that aren't converted yet, the netdevice_ops virt function list still resides in the net_device structure. For old protocols, the new net_device_ops are copied out to the old net_device pointers. After the transistion is completed the nag message can be changed to an WARN_ON, and the compatiablity code can be made configurable. Some function pointers aren't moved: * destructor can't be in net_device_ops because it may need to be referenced after the module is unloaded. * neighbor setup is manipulated in a couple of places that need special consideration * hard_start_xmit is in the fast path for transmit. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-07net: Guaranetee the proper ordering of the loopback device. v2Eric W. Biederman
I was recently hunting a bug that occurred in network namespace cleanup. In looking at the code it became apparrent that we have and will continue to have cases where if we have anything going on in a network namespace there will be assumptions that the loopback device is present. Things like sending igmp unsubscribe messages when we bring down network devices invokes the routing code which assumes that at least the loopback driver is present. Therefore to avoid magic initcall ordering hackery that is hard to follow and hard to get right insert a call to register the loopback device directly from net_dev_init(). This guarantes that the loopback device is the first device registered and the last network device to go away. But do it carefully so we register the loopback device after we clear dev_boot_phase. Signed-off-by: Eric W. Biederman <ebiederm@maxwell.aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-07Revert "net: Guaranetee the proper ordering of the loopback device."David S. Miller
This reverts commit ae33bc40c0d96d02f51a996482ea7e41c5152695.
2008-11-05net: Guaranetee the proper ordering of the loopback device.Eric W. Biederman
I was recently hunting a bug that occurred in network namespace cleanup. In looking at the code it became apparrent that we have and will continue to have cases where if we have anything going on in a network namespace there will be assumptions that the loopback device is present. Things like sending igmp unsubscribe messages when we bring down network devices invokes the routing code which assumes that at least the loopback driver is present. Therefore to avoid magic initcall ordering hackery that is hard to follow and hard to get right insert a call to register the loopback device directly from net_dev_init(). This guarantes that the loopback device is the first device registered and the last network device to go away. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03bonding, net: Move last_rx update into bonding recv logicJay Vosburgh
The only user of the net_device->last_rx field is bonding. This patch adds a conditional update of last_rx to the bonding special logic in skb_bond_should_drop, causing last_rx to only be updated when the ARP monitor is running. This frees network device drivers from the necessity of updating last_rx, which can have cache line thrash issues. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-30net: delete excess kernel-doc notationRandy Dunlap
Remove excess kernel-doc function parameters from networking header & driver files: Warning(include/net/sock.h:946): Excess function parameter or struct member 'sk' description in 'sk_filter_release' Warning(include/linux/netdevice.h:1545): Excess function parameter or struct member 'cpu' description in 'netif_tx_lock' Warning(drivers/net/wan/z85230.c:712): Excess function parameter or struct member 'regs' description in 'z8530_interrupt' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-23net: Fix disjunct computation of netdev featuresHerbert Xu
My change commit e2a6b85247aacc52d6ba0d9b37a99b8d1a3e0d83 net: Enable TSO if supported by at least one device didn't do what was intended because the netdev_compute_features function was designed for conjunctions. So what happened was that it would simply take the TSO status of the last constituent device. This patch extends it to support both conjunctions and disjunctions under the new name of netdev_increment_features. It also adds a new function netdev_fix_features which does the sanity checking that usually occurs upon registration. This ensures that the computation doesn't result in an illegal combination since this checking is absent when the change is initiated via ethtool. The two users of netdev_compute_features have been converted. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-13net: Rationalise email address: Network Specific PartsAlan Cox
Clean up the various different email addresses of mine listed in the code to a single current and valid address. As Dave says his network merges for 2.6.28 are now done this seems a good point to send them in where they won't risk disrupting real changes. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08dsa: add support for Trailer tagging formatLennert Buytenhek
This adds support for the Trailer switch tagging format. This is another tagging that doesn't explicitly mark tagged packets with a distinct ethertype, so that we need to add a similar hack in the receive path as for the Original DSA tagging format. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Tested-by: Byron Bradley <byron.bbradley@gmail.com> Tested-by: Tim Ellis <tim.ellis@mac.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08dsa: add support for original DSA tagging formatLennert Buytenhek
Most of the DSA switches currently in the field do not support the Ethertype DSA tagging format that one of the previous patches added support for, but only the original DSA tagging format. The original DSA tagging format carries the same information as the Ethertype DSA tagging format, but with the difference that it does not have an ethertype field. In other words, when receiving a packet that is tagged with an original DSA tag, there is no way of telling in eth_type_trans() that this packet is in fact a DSA-tagged packet. This patch adds a hook into eth_type_trans() which is only compiled in if support for a switch chip that doesn't support Ethertype DSA is selected, and which checks whether there is a DSA switch driver instance attached to this network device which uses the old tag format. If so, it sets the protocol field to ETH_P_DSA without looking at the packet, so that the packet ends up in the right place. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Tested-by: Nicolas Pitre <nico@marvell.com> Tested-by: Peter van Valderen <linux@ddcrew.com> Tested-by: Dirk Teurlings <dirk@upexia.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08net: Distributed Switch Architecture protocol supportLennert Buytenhek
Distributed Switch Architecture is a protocol for managing hardware switch chips. It consists of a set of MII management registers and commands to configure the switch, and an ethernet header format to signal which of the ports of the switch a packet was received from or is intended to be sent to. The switches that this driver supports are typically embedded in access points and routers, and a typical setup with a DSA switch looks something like this: +-----------+ +-----------+ | | RGMII | | | +-------+ +------ 1000baseT MDI ("WAN") | | | 6-port +------ 1000baseT MDI ("LAN1") | CPU | | ethernet +------ 1000baseT MDI ("LAN2") | |MIImgmt| switch +------ 1000baseT MDI ("LAN3") | +-------+ w/5 PHYs +------ 1000baseT MDI ("LAN4") | | | | +-----------+ +-----------+ The switch driver presents each port on the switch as a separate network interface to Linux, polls the switch to maintain software link state of those ports, forwards MII management interface accesses to those network interfaces (e.g. as done by ethtool) to the switch, and exposes the switch's hardware statistics counters via the appropriate Linux kernel interfaces. This initial patch supports the MII management interface register layout of the Marvell 88E6123, 88E6161 and 88E6165 switch chips, and supports the "Ethertype DSA" packet tagging format. (There is no officially registered ethertype for the Ethertype DSA packet format, so we just grab a random one. The ethertype to use is programmed into the switch, and the switch driver uses the value of ETH_P_EDSA for this, so this define can be changed at any time in the future if the one we chose is allocated to another protocol or if Ethertype DSA gets its own officially registered ethertype, and everything will continue to work.) Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Tested-by: Nicolas Pitre <nico@marvell.com> Tested-by: Byron Bradley <byron.bbradley@gmail.com> Tested-by: Tim Ellis <tim.ellis@mac.com> Tested-by: Peter van Valderen <linux@ddcrew.com> Tested-by: Dirk Teurlings <dirk@upexia.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-30netdev: use const for some name functionsStephen Hemminger
dev_change_name and netdev_drivername should use const char on parameters that are read-only input values. The strcpy to newname is not needed since newname is not used later in function. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22net: network device name ifalias supportStephen Hemminger
This patch add support for keeping an additional character alias associated with an network interface. This is useful for maintaining the SNMP ifAlias value which is a user defined value. Routers use this to hold information like which circuit or line it is connected to. It is just an arbitrary text label on the network device. There are two exposed interfaces with this patch, the value can be read/written either via netlink or sysfs. This could be maintained just by the snmp daemon, but it is more generally useful for other management tools, and the kernel is good place to act as an agreed upon interface to store it. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-04net: Kill plain NET_XMIT_BYPASS.David S. Miller
dst_input() was doing something completely absurd, looping on skb->dst->input() if NET_XMIT_BYPASS was seen, but these functions never return such an error. And as a result plain ole' NET_XMIT_BYPASS has no more references and can be completely killed off. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-04net_sched: Add qdisc __NET_XMIT_STOLEN flagJarek Poplawski
Patrick McHardy <kaber@trash.net> noticed: "The other problem that affects all qdiscs supporting actions is TC_ACT_QUEUED/TC_ACT_STOLEN getting mapped to NET_XMIT_SUCCESS even though the packet is not queued, corrupting upper qdiscs' qlen counters." and later explained: "The reason why it translates it at all seems to be to not increase the drops counter. Within a single qdisc this could be avoided by other means easily, upper qdiscs would still increase the counter when we return anything besides NET_XMIT_SUCCESS though. This means we need a new NET_XMIT return value to indicate this to the upper qdiscs. So I'd suggest to introduce NET_XMIT_STOLEN, return that to upper qdiscs and translate it to NET_XMIT_SUCCESS in dev_queue_xmit, similar to NET_XMIT_BYPASS." David Miller <davem@davemloft.net> noticed: "Maybe these NET_XMIT_* values being passed around should be a set of bits. They could be composed of base meanings, combined with specific attributes. So you could say "NET_XMIT_DROP | __NET_XMIT_NO_DROP_COUNT" The attributes get masked out by the top-level ->enqueue() caller, such that the base meanings are the only thing that make their way up into the stack. If it's only about communication within the qdisc tree, let's simply code it that way." This patch is trying to realize these ideas. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-31netdev: Fix lockdep warnings in multiqueue configurations.David S. Miller
When support for multiple TX queues were added, the netif_tx_lock() routines we converted to iterate over all TX queues and grab each queue's spinlock. This causes heartburn for lockdep and it's not a healthy thing to do with lots of TX queues anyways. So modify this to use a top-level lock and a "frozen" state for the individual TX queues. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-22net: Fix build failure with 'make mandocs'.Dave Jones
The function header comments have to go with the functions they are documenting, or things go horribly wrong when we try to process them with the docbook tools. Warning(include/linux/netdevice.h:1006): No description found for parameter 'dev_queue' Warning(include/linux/netdevice.h:1033): No description found for parameter 'dev_queue' Warning(include/linux/netdevice.h:1067): No description found for parameter 'dev_queue' Warning(include/linux/netdevice.h:1093): No description found for parameter 'dev_queue' Warning(include/linux/netdevice.h:1474): No description found for parameter 'txq' Error(net/core/dev.c:1674): cannot understand prototype: 'u32 simple_tx_hashrnd; ' Signed-off-by: Dave Jones <davej@redhat.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-21net: Print the module name as part of the watchdog messageArjan van de Ven
As suggested by Dave: This patch adds a function to get the driver name from a struct net_device, and consequently uses this in the watchdog timeout handler to print as part of the message. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18pkt_sched: Manage qdisc list inside of root qdisc.David S. Miller
Idea is from Patrick McHardy. Instead of managing the list of qdiscs on the device level, manage it in the root qdisc of a netdev_queue. This solves all kinds of visibility issues during qdisc destruction. The way to iterate over all qdiscs of a netdev_queue is to visit the netdev_queue->qdisc, and then traverse it's list. The only special case is to ignore builting qdiscs at the root when dumping or doing a qdisc_lookup(). That was not needed previously because builtin qdiscs were not added to the device's qdisc_list. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17pkt_sched: Kill netdev_queue lock.David S. Miller
We can simply use the qdisc->q.lock for all of the qdisc tree synchronization. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17netdevice: Move qdisc_list back into net_device proper.David S. Miller
And give it it's own lock. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17pkt_sched: Schedule qdiscs instead of netdev_queue.David S. Miller
When we have shared qdiscs, packets come out of the qdiscs for multiple transmit queues. Therefore it doesn't make any sense to schedule the transmit queue when logically we cannot know ahead of time the TX queue of the SKB that the qdisc->dequeue() will give us. Just for sanity I added a BUG check to make sure we never get into a state where the noop_qdisc is scheduled. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17pkt_sched: Make QDISC_RUNNING a qdisc state.David S. Miller
Currently it is associated with a netdev_queue, but when we have qdisc sharing that no longer makes any sense. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17pkt_sched: Move gso_skb into Qdisc.David S. Miller
We liberate any dangling gso_skb during qdisc destruction. It really only matters for the root qdisc. But when qdiscs can be shared by multiple netdev_queue objects, we can't have the gso_skb in the netdev_queue any more. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17netdev: Kill plain netif_schedule()David S. Miller
No more users. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17netdev: Add netdev->select_queue() method.David S. Miller
Devices or device layers can set this to control the queue selection performed by dev_pick_tx(). This function runs under RCU protection, which allows overriding functions to have some way of synchronizing with things like dynamic ->real_num_tx_queues adjustments. This makes the spinlock prefetch in dev_queue_xmit() a little bit less effective, but that's the price right now for correctness. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17netdev: netdev_priv() can now be sane again.David S. Miller
The private area of a netdev is now at a fixed offset once more. Unfortunately, some assumptions that netdev_priv() == netdev->priv crept back into the tree. In particular this happened in the loopback driver. Make it use netdev->ml_priv. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17netdev: Kill struct net_device_subqueue and netdev->egress_subqueue*David S. Miller
No longer used. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17net: Use queue aware tests throughout.David S. Miller
This effectively "flips the switch" by making the core networking and multiqueue-aware drivers use the new TX multiqueue structures. Non-multiqueue drivers need no changes. The interfaces they use such as netif_stop_queue() degenerate into an operation on TX queue zero. So everything "just works" for them. Code that really wants to do "X" to all TX queues now invokes a routine that does so, such as netif_tx_wake_all_queues(), netif_tx_stop_all_queues(), etc. pktgen and netpoll required a little bit more surgery than the others. In particular the pktgen changes, whilst functional, could be largely improved. The initial check in pktgen_xmit() will sometimes check the wrong queue, which is mostly harmless. The thing to do is probably to invoke fill_packet() earlier. The bulk of the netpoll changes is to make the code operate solely on the TX queue indicated by by the SKB queue mapping. Setting of the SKB queue mapping is entirely confined inside of net/core/dev.c:dev_pick_tx(). If we end up needing any kind of special semantics (drops, for example) it will be implemented here. Finally, we now have a "real_num_tx_queues" which is where the driver indicates how many TX queues are actually active. With IGB changes from Jeff Kirsher. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17netdev: Kill NETIF_F_MULTI_QUEUE.David S. Miller
There is no need for a feature bit for something that can be tested by simply checking the TX queue count. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17netdev: Allocate multiple queues for TX.David S. Miller
alloc_netdev_mq() now allocates an array of netdev_queue structures for TX, based upon the queue_count argument. Furthermore, all accesses to the TX queues are now vectored through the netdev_get_tx_queue() and netdev_for_each_tx_queue() interfaces. This makes it easy to grep the tree for all things that want to get to a TX queue of a net device. Problem spots which are not really multiqueue aware yet, and only work with one queue, can easily be spotted by grepping for all netdev_get_tx_queue() calls that pass in a zero index. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-15netdev: Add netdev->addr_list_lock protection.David S. Miller
Add netif_addr_{lock,unlock}{,_bh}() helpers. Use them to protect operations that operate on or read the network device unicast and multicast address lists. Also use them in cases where the code simply wants to block calls into the driver's ->set_rx_mode() and ->set_multicast_list() methods. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-15netdev: Add addr_list_lock to struct net_device.David S. Miller
This will be used to protect the per-device unicast and multicast address lists, as well as the callbacks into the drivers which configure such state such as ->set_rx_mode() and ->set_multicast_list(). Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-14vlan: deliver packets received with VLAN acceleration to network tapsPatrick McHardy
When VLAN header stripping is used, packets currently bypass packet sockets (and other network taps) completely. For locally existing VLANs, they appear directly on the VLAN device, for unknown VLANs they are silently dropped. Add a new function netif_nit_deliver() to deliver incoming packets to all network interface taps and use it in __vlan_hwaccel_rx() to make VLAN packets visible on the underlying device. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-11net: add netif_napi_del function to allow for removal of napistructsAlexander Duyck
Adds netif_napi_del function which is used to remove the napi struct from the netdev napi_list in cases where CONFIG_NETPOLL was enabled. The motivation for adding this is to handle the case in which the number of queues on a device changes due to a configuration change. Previously the napi structs for each queue would be left in the list until the netdev was freed. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-08netdev: Move atomic queue state bits into netdev_queue.David S. Miller
2008-07-08net: Delete NETDEVICES_MULTIQUEUE kconfig option.David S. Miller
Multiple TX queue support is a core networking feature. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08netdev: Move _xmit_lock and xmit_lock_owner into netdev_queue.David S. Miller
Accesses are mostly structured such that when there are multiple TX queues the code transformations will be a little bit simpler. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08netdev: Make netif_schedule() routines work with netdev_queue objects.David S. Miller
Only plain netif_schedule() remains taking a net_device, mostly as a compatability item while we transition the rest of these interfaces. Everything else calls netif_schedule_queue() or __netif_schedule(), both of which take a netdev_queue pointer. Signed-off-by: David S. Miller <davem@davemloft.net>
