path: root/include/linux/module.h
2007-05-11module_author: don't advise putting in an email addressRene Herman
module_author: don't advise putting in an email address It's information that's easily outdated and easily mistaken for a driver contact which is a problem especially for modules with multiple current and non-current authors as well as for modules with a maintainer who may not even be a module author. Signed-off-by: Rene Herman <rene.herman@gmail.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Allow arch to initialize arch field of the module structureRoman Zippel
This will later allow an arch to add module specific information via linker generated tables instead of poking directly in the module object structure. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Fix race between cat /proc/slab_allocators and rmmodAlexey Dobriyan
Same story as with cat /proc/*/wchan race vs rmmod race, only /proc/slab_allocators want more info than just symbol name. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Fix race between cat /proc/*/wchan and rmmod et alAlexey Dobriyan
kallsyms_lookup() can go iterating over modules list unprotected which is OK for emergency situations (oops), but not OK for regular stuff like /proc/*/wchan. Introduce lookup_symbol_name()/lookup_module_symbol_name() which copy symbol name into caller-supplied buffer or return -ERANGE. All copying is done with module_mutex held, so... Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Fix race between rmmod and cat /proc/kallsymsAlexey Dobriyan
module_get_kallsym() leaks "struct module *" outside of module_mutex which is no-no, because module can dissapear right after mutex unlock. Copy all needed information from inside module_mutex into caller-supplied space. [bunk@stusta.de: is_exported() can now become static] Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Simplify module_get_kallsym() by dropping length argAlexey Dobriyan
module_get_kallsym() could in theory truncate module symbol name to fit in buffer, but nobody does this. Always use KSYM_NAME_LEN + 1 bytes for name. Suggested by lg^WRusty. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02remove "struct subsystem" as it is no longer neededGreg Kroah-Hartman
We need to work on cleaning up the relationship between kobjects, ksets and ktypes. The removal of 'struct subsystem' is the first step of this, especially as it is not really needed at all. Thanks to Kay for fixing the bugs in this patch. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-16sysfs: fix build errors: uevent with CONFIG_SYSFS=nRandy Dunlap
Fix source files to build with CONFIG_SYSFS=n. module_subsys is not available. SYSFS=n, MODULES=y: T:y SYSFS=n, MODULES=n: T:y SYSFS=y, MODULES=y: T:y SYSFS=y, MODULES=n: T:y Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07/sys/modules/*/holdersKay Sievers
/sys/module/usbcore/ |-- drivers | |-- usb:hub -> ../../../subsystem/usb/drivers/hub | |-- usb:usb -> ../../../subsystem/usb/drivers/usb | `-- usb:usbfs -> ../../../subsystem/usb/drivers/usbfs |-- holders | |-- ehci_hcd -> ../../../module/ehci_hcd | |-- uhci_hcd -> ../../../module/uhci_hcd | |-- usb_storage -> ../../../module/usb_storage | `-- usbhid -> ../../../module/usbhid |-- initstate Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07MODULES: add the module name for built in kernel driversKay Sievers
2006-12-08[PATCH] Generic BUG implementationJeremy Fitzhardinge
This patch adds common handling for kernel BUGs, for use by architectures as they wish. The code is derived from arch/powerpc. The advantages of having common BUG handling are: - consistent BUG reporting across architectures - shared implementation of out-of-line file/line data - implement CONFIG_DEBUG_BUGVERBOSE consistently This means that in inline impact of BUG is just the illegal instruction itself, which is an improvement for i386 and x86-64. A BUG is represented in the instruction stream as an illegal instruction, which has file/line information associated with it. This extra information is stored in the __bug_table section in the ELF file. When the kernel gets an illegal instruction, it first confirms it might possibly be from a BUG (ie, in kernel mode, the right illegal instruction). It then calls report_bug(). This searches __bug_table for a matching instruction pointer, and if found, prints the corresponding file/line information. If report_bug() determines that it wasn't a BUG which caused the trap, it returns BUG_TRAP_TYPE_NONE. Some architectures (powerpc) implement WARN using the same mechanism; if the illegal instruction was the result of a WARN, then report_bug(Q) returns CONFIG_DEBUG_BUGVERBOSE; otherwise it returns BUG_TRAP_TYPE_BUG. lib/bug.c keeps a list of loaded modules which can be searched for __bug_table entries. The architecture must call module_bug_finalize()/module_bug_cleanup() from its corresponding module_finalize/cleanup functions. Unsetting CONFIG_DEBUG_BUGVERBOSE will reduce the kernel size by some amount. At the very least, filename and line information will not be recorded for each but, but architectures may decide to store no extra information per BUG at all. Unfortunately, gcc doesn't have a general way to mark an asm() as noreturn, so architectures will generally have to include an infinite loop (or similar) in the BUG code, so that gcc knows execution won't continue beyond that point. gcc does have a __builtin_trap() operator which may be useful to achieve the same effect, unfortunately it cannot be used to actually implement the BUG itself, because there's no way to get the instruction's address for use in generating the __bug_table entry. [randy.dunlap@oracle.com: Handle BUG=n, GENERIC_BUG=n to prevent build errors] [bunk@stusta.de: include/linux/bug.h must always #include <linux/module.h] Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Andi Kleen <ak@muc.de> Cc: Hugh Dickens <hugh@veritas.com> Cc: Michael Ellerman <michael@ellerman.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04[PATCH] severing module.h->sched.hAl Viro
2006-12-01Driver core: show drivers in /sys/module/Kay Sievers
Show the drivers, which belong to the module: $ ls -l /sys/module/usbcore/drivers/ hub -> ../../../bus/usb/drivers/hub usb -> ../../../bus/usb/drivers/usb usbfs -> ../../../bus/usb/drivers/usbfs Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-11[PATCH] fix Module taint flags listing in Oops/panicFlorin Malita
Module taint flags listing in Oops/panic has a couple of issues: * taint_flags() doesn't null-terminate the buffer after printing the flags * per-module taints are only set if the kernel is not already tainted (with that particular flag) => only the first offending module gets its taint info correctly updated Some additional changes: * 'license_gplok' is no longer needed - equivalent to !(taints & TAINT_PROPRIETARY_MODULE) - so we can drop it from struct module * exporting module taint info via /proc/module: pwc 88576 0 - Live 0xf8c32000 evilmod 6784 1 pwc, Live 0xf8bbf000 (PF) Signed-off-by: Florin Malita <fmalita@gmail.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] list module taint flags in Oops/panicRandy Dunlap
When listing loaded modules during an oops or panic, also list each module's Tainted flags if non-zero (P: Proprietary or F: Forced load only). If a module is did not taint the kernel, it is just listed like usbcore but if it did taint the kernel, it is listed like wizmodem(PF) Example: [ 3260.121718] Unable to handle kernel NULL pointer dereference at 0000000000000000 RIP: [ 3260.121729] [<ffffffff8804c099>] :dump_test:proc_dump_test+0x99/0xc8 [ 3260.121742] PGD fe8d067 PUD 264a6067 PMD 0 [ 3260.121748] Oops: 0002 [1] SMP [ 3260.121753] CPU 1 [ 3260.121756] Modules linked in: dump_test(P) snd_pcm_oss snd_mixer_oss snd_seq snd_seq_device ide_cd generic ohci1394 snd_hda_intel snd_hda_codec snd_pcm snd_timer snd ieee1394 snd_page_alloc piix ide_core arcmsr aic79xx scsi_transport_spi usblp [ 3260.121785] Pid: 5556, comm: bash Tainted: P 2.6.18-git10 #1 [Alternatively, I can look into listing tainted flags with 'lsmod', but that won't help in oopsen/panics so much.] [akpm@osdl.org: cleanup] Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] /sys/modules: allow full length section namesIan S. Nelson
I've been using systemtap for some debugging and I noticed that it can't probe a lot of modules. Turns out it's kind of silly, the sections section of /sys/module is limited to 32byte filenames and many of the actual sections are a a bit longer than that. [akpm@osdl.org: rewrite to use dymanic allocation] Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-30[SCSI] MODULE_FIRMWARE for binary firmware(s)Jon Masters
Right now, various kernel modules are being migrated over to use request_firmware in order to pull in binary firmware blobs from userland when the module is loaded. This makes sense. However, there is right now little mechanism in place to automatically determine which binary firmware blobs must be included with a kernel in order to satisfy the prerequisites of these drivers. This affects vendors, but also regular users to a certain extent too. The attached patch introduces MODULE_FIRMWARE as a mechanism for advertising that a particular firmware file is to be loaded - it will then show up via modinfo and could be used e.g. when packaging a kernel. Signed-off-by: Jon Masters <jcm@redhat.com> Comments added in line with all the other MODULE_ tag Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-14[PATCH] null-terminate over-long /proc/kallsyms symbolsAndreas Gruenbacher
Got a customer bug report (https://bugzilla.novell.com/190296) about kernel symbols longer than 127 characters which end up in a string buffer that is not NULL terminated, leading to garbage in /proc/kallsyms. Using strlcpy prevents this from happening, even though such symbols still won't come out right. A better fix would be to not use a fixed-size buffer, but it's probably not worth the trouble. (Modversion'ed symbols even have a length limit of 60.) [bunk@stusta.de: build fix] Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: add is_module_address()Ingo Molnar
Add is_module_address() method - to be used by lockdep. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] Add EXPORT_UNUSED_SYMBOL and EXPORT_UNUSED_SYMBOL_GPLArjan van de Ven
Temporarily add EXPORT_UNUSED_SYMBOL and EXPORT_UNUSED_SYMBOL_GPL. These will be used as a transition measure for symbols that aren't used in the kernel and are on the way out. When a module uses such a symbol, a warning is printk'd at modprobe time. The main reason for removing unused exports is size: eacho export takes roughly between 100 and 150 bytes of kernel space in the binary. This patch gives users the option to immediately get this size gain via a config option. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] x86_64: reliable stack trace supportJan Beulich
These are the generic bits needed to enable reliable stack traces based on Dwarf2-like (.eh_frame) unwind information. Subsequent patches will enable x86-64 and i386 to make use of this. Thanks to Andi Kleen and Ingo Molnar, who pointed out several possibilities for improvement. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] module.h: updated comments with a new licenseXose Vazquez Perez
"Dual MIT/GPL" is also accepted (kernel/module.c), so updated comments. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-20Merge git://git.infradead.org/hdrcleanup-2.6Linus Torvalds
* git://git.infradead.org/hdrcleanup-2.6: (63 commits) [S390] __FD_foo definitions. Switch to __s32 types in joystick.h instead of C99 types for consistency. Add <sys/types.h> to headers included for userspace in <linux/input.h> Move inclusion of <linux/compat.h> out of user scope in asm-x86_64/mtrr.h Remove struct fddi_statistics from user view in <linux/if_fddi.h> Move user-visible parts of drivers/s390/crypto/z90crypt.h to include/asm-s390 Revert include/media changes: Mauro says those ioctls are only used in-kernel(!) Include <linux/types.h> and use __uXX types in <linux/cramfs_fs.h> Use __uXX types in <linux/i2o_dev.h>, include <linux/ioctl.h> too Remove private struct dx_hash_info from public view in <linux/ext3_fs.h> Include <linux/types.h> and use __uXX types in <linux/affs_hardblocks.h> Use __uXX types in <linux/divert.h> for struct divert_blk et al. Use __u32 for elf_addr_t in <asm-powerpc/elf.h>, not u32. It's user-visible. Remove PPP_FCS from user view in <linux/ppp_defs.h>, remove __P mess entirely Use __uXX types in user-visible structures in <linux/nbd.h> Don't use 'u32' in user-visible struct ip_conntrack_old_tuple. Use __uXX types for S390 DASD volume label definitions which are user-visible S390 BIODASDREADCMB ioctl should use __u64 not u64 type. Remove unneeded inclusion of <linux/time.h> from <linux/ufs_fs.h> Fix private integer types used in V4L2 ioctls. ... Manually resolve conflict in include/linux/mtd/physmap.h
2006-05-08Finally remove the obnoxious inter_module_xxx()David Woodhouse
This was already a bad plan when I argued against adding it in the first place. Good riddance. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-25Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [NETFILTER] x_table.c: sem2mutex [IPV4]: Aggregate route entries with different TOS values [TCP]: Mark tcp_*mem[] __read_mostly. [TCP]: Set default max buffers from memory pool size [SCTP]: Fix up sctp_rcv return value [NET]: Take RTNL when unregistering notifier [WIRELESS]: Fix config dependencies. [NET]: Fill in a 32-bit hole in struct sock on 64-bit platforms. [NET]: Ensure device name passed to SO_BINDTODEVICE is NULL terminated. [MODULES]: Don't allow statically declared exports [BRIDGE]: Unaligned accesses in the ethernet bridge
2006-03-25[PATCH] Remove MODULE_PARMRusty Russell
MODULE_PARM was actually breaking: recent gcc version optimize them out as unused. It's time to replace the last users, which are generally in the most unloved drivers anyway. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[MODULES]: Don't allow statically declared exportsPatrick McHardy
Add an extern declaration for exported symbols to make the compiler warn on symbols declared statically. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[PATCH] fix module sysfs files reference countingGreg Kroah-Hartman
The module files, refcnt, version, and srcversion did not properly increment the owner's module reference count, allowing the modules to be removed while the files were open, causing oopses. This patch fixes this, and also fixes the problem that the version and srcversion files were not showing up, unless CONFIG_MODULE_UNLOAD was enabled, which is not correct. Cc: Nathan Lynch <ntl@pobox.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] add EXPORT_SYMBOL_GPL_FUTURE()Greg Kroah-Hartman
This patch adds the ability to mark symbols that will be changed in the future, so that kernel modules that don't include MODULE_LICENSE("GPL") and use the symbols, will be flagged and printed out to the system log. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-30[PATCH] modules: fix sparse warning for every MODULE_PARMPavel Roskin
sparse complains about every MODULE_PARM used in a module: warning: symbol '__parm_foo' was not declared. Should it be static? The fix is to split declaration and initialization. While MODULE_PARM is obsolete, it's not something sparse should report. Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] modules: add version and srcversion to sysfsMatt Domsch
This patch adds version and srcversion files to /sys/module/${modulename} containing the version and srcversion fields of the module's modinfo section (if present). /sys/module/e1000 |-- srcversion `-- version This patch differs slightly from the version posted in January, as it now uses the new kstrdup() call in -mm. Why put this in sysfs? a) Tools like DKMS, which deal with changing out individual kernel modules without replacing the whole kernel, can behave smarter if they can tell the version of a given module. The autoinstaller feature, for example, which determines if your system has a "good" version of a driver (i.e. if the one provided by DKMS has a newer verson than that provided by the kernel package installed), and to automatically compile and install a newer version if DKMS has it but your kernel doesn't yet have that version. b) Because sysadmins manually, or with tools like DKMS, can switch out modules on the file system, you can't count on 'modinfo foo.ko', which looks at /lib/modules/${kernelver}/... actually matching what is loaded into the kernel already. Hence asking sysfs for this. c) as the unbind-driver-from-device work takes shape, it will be possible to rebind a driver that's built-in (no .ko to modinfo for the version) to a newly loaded module. sysfs will have the currently-built-in version info, for comparison. d) tech support scripts can then easily grab the version info for what's running presently - a question I get often. There has been renewed interest in this patch on linux-scsi by driver authors. As the idea originated from GregKH, I leave his Signed-off-by: intact, though the implementation is nearly completely new. Compiled and run on x86 and x86_64. From: Matthew Dobson <colpatch@us.ibm.com> build fix From: Thierry Vignaud <tvignaud@mandriva.com> build fix From: Matthew Dobson <colpatch@us.ibm.com> warning fix Signed-off-by: Greg Kroah-Hartman <greg@kroah.com> Signed-off-by: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
