path: root/include/linux/mod_devicetable.h
2013-09-07Revert "Input: introduce BTN/ABS bits for drums and guitars"Linus Torvalds
This reverts commits 61e00655e9cb, 73f8645db191 and 8e22ecb603c8: "Input: introduce BTN/ABS bits for drums and guitars" "HID: wiimote: add support for Guitar-Hero drums" "HID: wiimote: add support for Guitar-Hero guitars" The extra new ABS_xx values resulted in ABS_MAX no longer being a power-of-two, which broke the comparison logic. It also caused the ioctl numbers to overflow into the next byte, causing problems for that. We'll try again for 3.13. Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de> Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: David Herrmann <dh.herrmann@gmail.com> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-06Merge branches 'for-3.12/devm', 'for-3.12/i2c-hid', 'for-3.12/i2c-hid-dt', ↵Jiri Kosina
'for-3.12/logitech', 'for-3.12/multitouch-win8', 'for-3.12/trasnport-driver-cleanup', 'for-3.12/uhid', 'for-3.12/upstream' and 'for-3.12/wiimote' into for-linus
2013-09-04Input: introduce BTN/ABS bits for drums and guitarsDavid Herrmann
There are a bunch of guitar and drums devices out there that all report similar data. To avoid reporting this as BTN_MISC or ABS_MISC, we allocate some proper namespace for them. Note that most of these devices are toys and we cannot report any sophisticated physics via this API. I did some google-images research and tried to provide definitions that work with all common devices. That's why I went with 4 toms, 4 cymbals, one bass, one hi-hat. I haven't seen other drums and I doubt that we need any additions to that. Anyway, the naming-scheme is intentionally done in an extensible way. For guitars, we support 5 frets (normally aligned vertically, compared to the real horizontal layouts), a single strum-bar with up/down directions, an optional fret-board and a whammy-bar. Most of the devices provide pressure values so I went with ABS_* bits. If we ever support devices which only provide digital input, we have to decide whether to emulate pressure data or add additional BTN_* bits. If someone is not familiar with these devices, here are two pictures which provide almost all introduced interfaces (or try the given keywords with a google-image search): Guitar: ("guitar hero world tour guitar") http://images1.wikia.nocookie.net/__cb20120911023442/applezone/es/images/f/f9/Wii_Guitar.jpg Drums: ("guitar hero drums") http://oyster.ignimgs.com/franchises/images/03/55/35526_band-hero-drum-set-hands-on-20090929040735768.jpg Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-07-18ssb: fix alignment of struct bcma_device_idArnd Bergmann
The ARM OABI and EABI disagree on the alignment of structures with small members, so module init tools may interpret the ssb device table incorrectly, as shown by this warning when building the b43 device driver in an OABI kernel: FATAL: drivers/net/wireless/b43/b43: sizeof(struct ssb_device_id)=6 is not a modulo of the size of section __mod_ssb_device_table=88. Forcing the default (EABI) alignment on the structure makes this problem go away. Since the ssb_device_id may have the same problem, better fix both structures. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: John W. Linville <linville@tuxdriver.com> Cc: Michael Buesch <mb@bu3sch.de> Cc: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-07-03rapidio: add udev notificationAlexandre Bounine
Add RapidIO-specific modalias generation to enable udev notifications about RapidIO-specific events. The RapidIO modalias string format is shown below: "rapidio:vNNNNdNNNNavNNNNadNNNN" Where: v - Device Vendor ID (16 bit), d - Device ID (16 bit), av - Assembly Vendor ID (16 bit), ad - Assembly ID (16 bit), as they are reported in corresponding Capability Registers (CARs) of each RapidIO device. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@Prodrive.nl> Cc: Micha Nelissen <micha.nelissen@Prodrive.nl> Cc: Stef van Os <stef.van.os@Prodrive.nl> Cc: Jean Delvare <jdelvare@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03dmi: add support for exact DMI matches in addition to substring matchingJani Nikula
dmi_match() considers a substring match to be a successful match. This is not always sufficient to distinguish between DMI data for different systems. Add support for exact string matching using strcmp() in addition to the substring matching using strstr(). The specific use case in the i915 driver is to allow us to use an exact match for D510MO, without also incorrectly matching D510MOV: { .ident = "Intel D510MO", .matches = { DMI_MATCH(DMI_BOARD_VENDOR, "Intel"), DMI_EXACT_MATCH(DMI_BOARD_NAME, "D510MO"), }, } Signed-off-by: Jani Nikula <jani.nikula@intel.com> Cc: <annndddrr@gmail.com> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Cornel Panceac <cpanceac@gmail.com> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-29mei: bus: Initial MEI Client bus type implementationSamuel Ortiz
mei client bus will present some of the mei clients as devices for other standard subsystems Implement the probe, remove, match, device addtion routines, along with the sysfs and uevent ones. mei_cl_device_id is also added to mod_devicetable.h A mei-cleint-bus.txt document describing the rationale and the API usage is also added while ABI/testing/sysfs-bus-mei describeis the modalias ABI. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-24mod/file2alias: make modalias generation safe for cross compilingAndreas Schwab
Use the target compiler to compute the offsets for the fields of the device_id structures, so that it won't be broken by different alignments between the host and target ABIs. This also fixes missing endian corrections for some modaliases. Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-10-01Merge tag 'fixes-non-critical' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull non-critical ARM soc bug fixes from Olof Johansson: "These were submitted as bug fixes before v3.6 but not considered important enough to be included in it. Some of them cross over to cleanup territory as well, and aren't strictly bugfixes." * tag 'fixes-non-critical' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits) ARM: nomadik: remove NAND_NO_READRDY use ARM: pxa: fix return value check in pxa2xx_drv_pcmcia_probe() ARM: SAMSUNG: Add missing variable declaration in s3c64xx_spi1_set_platdata() ARM: S3C24XX: removes unnecessary semicolon ARM: S3C24xx: delete double assignment ARM: EXYNOS: fix address for EXYNOS4 MDMA1 ARM: EXYNOS: fixed SYSMMU setup definition to mate parameter name ARM: ep93xx: Move ts72xx.h out of include/mach ARM: ep93xx: use __iomem pointers for MMIO ARM: msm: Fix early debug uart mapping on some memory configs ARM: msm: io: Change the default static iomappings to be shared ARM: msm: io: Remove 7x30 iomap region from 7x00 ARM: msm: Remove call to missing FPGA init on 8660 ARM: OMAP4: wakeupgen: remove duplicate AUXCOREBOOT* read/write ARM: OMAP4: wakeupgen: Fix the typo in AUXCOREBOOT register save dma: tegra: make data used as *of_device_id.data const can: mpc5xxx_can: make data used as *of_device_id.data const macintosh/mediabay: make data used as *of_device_id.data const i2c/mpc: make data used as *of_device_id.data const mfd/da9052: make i2c_device_id array const ...
2012-09-11of: add const to struct *of_device_id.dataUwe Kleine-König
Drivers should never need to modify the data of a device id. So it can be const which in turn allows more consts in the driver. Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2012-09-07staging/ipack: Fix bug introduced by IPack device matchingJens Taprogge
~0 can not be casted to u8. Instead of using the IPACK_ANY_ID for the format field we introduce a new IPACK_ANY_FORMAT specifically for that field and defined as 0xff. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Jens Taprogge <jens.taprogge@taprogge.org> Acked-by: Samuel Iglesias Gonsálvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-04Staging: ipack: implement ipack device table.Jens Taprogge
The modaliases look like ipack:fXvNdM, where X is the format version (8 bit) and N and M are the vendor and device ID represented as 32 bit hexadecimal numbers each. Using 32 bits allows us to define IPACK_ANY_ID as (~0) without interfering with the valid ids. The resulting modalias string for ipoctal.ko looks like this (once ipoctal provides a device table): alias: ipack:f01v000000F0d00000048* alias: ipack:f01v000000F0d0000002A* alias: ipack:f01v000000F0d00000022* (output from modinfo) Signed-off-by: Jens Taprogge <jens.taprogge@taprogge.org> Signed-off-by: Samuel Iglesias Gonsálvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-18USB: properly pad out usb_device_id.driver_infoGreg Kroah-Hartman
On some systems, struct usb_device_id doesn't align properly due to the recent changes in it. So pad out the driver_info field to align on a boundry that systems can handle it. Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-13USB: allow match on bInterfaceNumberBjørn Mork
Some composite USB devices provide multiple interfaces with different functions, all using "vendor-specific" for class/subclass/protocol. Another OS use interface numbers to match the driver and interface. It seems these devices are designed with that in mind - using static interface numbers for the different functions. This adds support for matching against the bInterfaceNumber, allowing such devices to be supported without having to resort to testing against interface number whitelists and/or blacklists in the probe. Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-01HID: Allow bus wildcard matchingHenrik Rydberg
Most HID drivers do not need to know what bus driver is in use. A generic group driver can drive any hid device, and the device list should not need to be duplicated for each new bus. This patch adds wildcard matching to the HID bus, simplifying device list handling for group drivers. Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Acked-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-05-01HID: Add device group to modaliasHenrik Rydberg
HID devices are only partially presented to userland. Hotplugged devices emit events containing a modalias based on the basic bus, vendor and product entities. However, in practise a hid device can depend on details such as a single usb interface or a particular item in a report descriptor. This patch adds a device group to the hid device id, and broadcasts it using uevent and the device modalias. The module alias generation is modified to match. As a consequence, a device with a non-zero group will be processed by the corresponding group driver instead of by the generic hid driver. Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Acked-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-03-27Merge tag 'rpmsg' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "remoteproc/rpmsg: new subsystem" from Arnd Bergmann: "This new subsystem provides a common way to talk to secondary processors on an SoC, e.g. a DSP, GPU or service processor, using virtio as the transport. In the long run, it should replace a few dozen vendor specific ways to do the same thing, which all never made it into the upstream kernel. There is a broad agreement that rpmsg is the way to go here and several vendors have started working on replacing their own subsystems. Two branches each add one virtio protocol number. Fortunately the numbers were agreed upon in advance, so there are only context changes. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" Fixed up trivial protocol number conflict due to the mentioned additions next to each other. * tag 'rpmsg' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (32 commits) remoteproc: cleanup resource table parsing paths remoteproc: remove the hardcoded vring alignment remoteproc/omap: remove the mbox_callback limitation remoteproc: remove the single rpmsg vdev limitation remoteproc: safer boot/shutdown order remoteproc: remoteproc_rpmsg -> remoteproc_virtio remoteproc: resource table overhaul rpmsg: fix build warning when dma_addr_t is 64-bit rpmsg: fix published buffer length in rpmsg_recv_done rpmsg: validate incoming message length before propagating rpmsg: fix name service endpoint leak remoteproc/omap: two Kconfig fixes remoteproc: make sure we're parsing a 32bit firmware remoteproc: s/big switch/lookup table/ remoteproc: bail out if firmware has different endianess remoteproc: don't use virtio's weak barriers rpmsg: rename virtqueue_add_buf_gfp to virtqueue_add_buf rpmsg: depend on EXPERIMENTAL remoteproc: depend on EXPERIMENTAL rpmsg: add Kconfig menu ... Conflicts: include/linux/virtio_ids.h
2012-02-23Merge tag 'rpmsg-for-3.4' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc into next/rpmsg * tag 'rpmsg-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc: remoteproc: s/big switch/lookup table/ remoteproc: bail out if firmware has different endianess remoteproc: don't use virtio's weak barriers rpmsg: rename virtqueue_add_buf_gfp to virtqueue_add_buf rpmsg: depend on EXPERIMENTAL remoteproc: depend on EXPERIMENTAL rpmsg: add Kconfig menu remoteproc: add Kconfig menu remoteproc: look for truncated firmware images remoteproc/omap: utilize module_platform_driver remoteproc: remove unused resource type remoteproc: avoid registering a virtio device if not supported remoteproc: do not require an iommu samples/rpmsg: add an rpmsg driver sample rpmsg: add virtio-based remote processor messaging bus remoteproc/omap: add a remoteproc driver for OMAP4 remoteproc: create rpmsg virtio device remoteproc: add debugfs entries remoteproc: add framework for controlling remote processors
2012-02-08rpmsg: add virtio-based remote processor messaging busOhad Ben-Cohen
Add a virtio-based inter-processor communication bus, which enables kernel drivers to communicate with entities, running on remote processors, over shared memory using a simple messaging protocol. Every pair of AMP processors share two vrings, which are used to send and receive the messages over shared memory. The header of every message sent on the rpmsg bus contains src and dst addresses, which make it possible to multiplex several rpmsg channels on the same vring. Every rpmsg channel is a device on this bus. When a channel is added, and an appropriate rpmsg driver is found and probed, it is also assigned a local rpmsg address, which is then bound to the driver's callback. When inbound messages carry the local address of a bound driver, its callback is invoked by the bus. This patch provides a kernel interface only; user space interfaces will be later exposed by kernel users of this rpmsg bus. Designed with Brian Swetland <swetland@google.com>. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> (virtio_ids.h) Cc: Brian Swetland <swetland@google.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Tony Lindgren <tony@atomide.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Greg KH <greg@kroah.com> Cc: Stephen Boyd <sboyd@codeaurora.org>
2012-02-02Merge 3.3-rc2 into the driver-core-next branch.Greg Kroah-Hartman
This was done to resolve a merge and build problem with the drivers/acpi/processor_driver.c file. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-26Add driver auto probing for x86 features v4Andi Kleen
There's a growing number of drivers that support a specific x86 feature or CPU. Currently loading these drivers currently on a generic distribution requires various driver specific hacks and it often doesn't work. This patch adds auto probing for drivers based on the x86 cpuid information, in particular based on vendor/family/model number and also based on CPUID feature bits. For example a common issue is not loading the SSE 4.2 accelerated CRC module: this can significantly lower the performance of BTRFS which relies on fast CRC. Another issue is loading the right CPUFREQ driver for the current CPU. Currently distributions often try all all possible driver until one sticks, which is not really a good way to do this. It works with existing udev without any changes. The code exports the x86 information as a generic string in sysfs that can be matched by udev's pattern matching. This scheme does not support numeric ranges, so if you want to handle e.g. ranges of model numbers they have to be encoded in ASCII or simply all models or families listed. Fixing that would require changing udev. Another issue is that udev will happily load all drivers that match, there is currently no nice way to stop a specific driver from being loaded if it's not needed (e.g. if you don't need fast CRC) But there are not that many cpu specific drivers around and they're all not that bloated, so this isn't a particularly serious issue. Originally this patch added the modalias to the normal cpu sysdevs. However sysdevs don't have all the infrastructure needed for udev, so it couldn't really autoload drivers. This patch instead adds the CPU modaliases to the cpuid devices, which are real devices with full support for udev. This implies that the cpuid driver has to be loaded to use this. This patch just adds infrastructure, some driver conversions in followups. Thanks to Kay for helping with some sysfs magic. v2: Constifcation, some updates v4: (trenn@suse.de): - Use kzalloc instead of kmalloc to terminate modalias buffer - Use uppercase hex values to match correctly against hex values containing letters Cc: Dave Jones <davej@redhat.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Jen Axboe <axboe@kernel.dk> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Huang Ying <ying.huang@intel.com> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Thomas Renninger <trenn@suse.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-20Revert "ARM: sa11x0: Implement autoloading of codec and codec pdata for mcp ↵Russell King
bus." This reverts commit 5dd7bf59e0e8563265b3e5b33276099ef628fcc7. Conflicts: scripts/mod/file2alias.c This change is wrong on many levels. First and foremost, it causes a regression. On boot on Assabet, which this patch gives a codec id of 'ucb1x00', it gives: ucb1x00 ID not found: 1005 0x1005 is a valid ID for the UCB1300 device. Secondly, this patch is way over the top in terms of complexity. The only device which has been seen to be connected with this MCP code is the UCB1x00 (UCB1200, UCB1300 etc) devices, and they all use the same driver. Adding a match table, requiring the codec string to match the hardware ID read out of the ID register, etc is completely over the top when we can just read the hardware ID register.
2012-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (59 commits) rtc: max8925: Add function to work as wakeup source mfd: Add pm ops to max8925 mfd: Convert aat2870 to dev_pm_ops mfd: Still check other interrupts if we get a wm831x touchscreen IRQ mfd: Introduce missing kfree in 88pm860x probe routine mfd: Add S5M series configuration mfd: Add s5m series irq driver mfd: Add S5M core driver mfd: Improve mc13xxx dt binding document mfd: Fix stmpe section mismatch mfd: Fix stmpe build warning mfd: Fix STMPE I2c build failure mfd: Constify aat2870-core i2c_device_id table gpio: Add support for stmpe variant 801 mfd: Add support for stmpe variant 801 mfd: Add support for stmpe variant 610 mfd: Add support for STMPE SPI interface mfd: Separate out STMPE controller and interface specific code misc: Remove max8997-muic sysfs attributes mfd: Remove unused wm831x_irq_data_to_mask_reg() ... Fix up trivial conflict in drivers/leds/Kconfig due to addition of LEDS_MAX8997 and LEDS_TCA6507 next to each other.
2012-01-09ARM: sa11x0: Implement autoloading of codec and codec pdata for mcp bus.Jochen Friedrich
Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-11-22ARM: amba: Move definition of struct amba_id to mod_devicetable.hDave Martin
The general kernel infrastructure for adding module alises during module post processing expects the affected device type identification structures in a common header <linux/mod_devicetable.h>. This patch simple moves struct amba_id to the common header, and adds the appropriate include in <linux/amba/bus.h>. Signed-off-by: Dave Martin <dave.martin@linaro.org>
2011-08-25Staging: hv: add driver_data to hv_vmbus_device_idGreg Kroah-Hartman
This is going to be needed by some drivers that handle more than one device, like all other bus types do, so prepare for that in advance before the user/kernel api is used. Cc: K. Y. Srinivasan <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-25Staging: hv: Add struct hv_vmbus_device_id to mod_devicetable.hK. Y. Srinivasan
In preparation for implementing vmbus aliases for auto-loading Hyper-V drivers, define vmbus specific device ID. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-10bcma: add Broadcom specific AMBA bus driverRafał Miłecki
Broadcom has released cards based on a new AMBA-based bus type. From a programming point of view, this new bus type differs from AMBA and does not use AMBA common registers. It also differs enough from SSB. We decided that a new bus driver is needed to keep the code clean. In its current form, the driver detects devices present on the bus and registers them in the system. It allows registering BCMA drivers for specified bus devices and provides them basic operations. The bus driver itself includes two important bus managing drivers: ChipCommon core driver and PCI(c) core driver. They are early used to allow correct initialization. Currently code is limited to supporting buses on PCI(e) devices, however the driver is designed to be used also on other hosts. The host abstraction layer is implemented and already used for PCI(e). Support for PCI(e) hosts is working and seems to be stable (access to 80211 core was tested successfully on a few devices). We can still optimize it by using some fixed windows, but this can be done later without affecting any external code. Windows are just ranges in MMIO used for accessing cores on the bus. Cc: Greg KH <greg@kroah.com> Cc: Michael Büsch <mb@bu3sch.de> Cc: Larry Finger <Larry.Finger@lwfinger.net> Cc: George Kashperko <george@znau.edu.ua> Cc: Arend van Spriel <arend@broadcom.com> Cc: linux-arm-kernel@lists.infradead.org Cc: Russell King <rmk@arm.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Andy Botting <andy@andybotting.com> Cc: linuxdriverproject <devel@linuxdriverproject.org> Cc: linux-kernel@vger.kernel.org <linux-kernel@vger.kernel.org> Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-05-21Merge branch 'modules' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus * 'modules' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: module: drop the lock while waiting for module to complete initialization. MODULE_DEVICE_TABLE(isapnp, ...) does nothing hisax_fcpcipnp: fix broken isapnp device table. isapnp: move definitions to mod_devicetable.h so file2alias can reach them.
2010-05-19isapnp: move definitions to mod_devicetable.h so file2alias can reach them.Rusty Russell
2010-05-18Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: include/linux/mod_devicetable.h scripts/mod/file2alias.c
2010-05-17m68k: amiga - Zorro bus modalias supportGeert Uytterhoeven
Add Amiga Zorro bus modalias and uevent support Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2010-04-02phylib: Support phy module autoloadingDavid Woodhouse
We don't use the normal hotplug mechanism because it doesn't work. It will load the module some time after the device appears, but that's not good enough for us -- we need the driver loaded _immediately_ because otherwise the NIC driver may just abort and then the phy 'device' goes away. [bwh: s/phy/mdio/ in module alias, kerneldoc for struct mdio_device_id] Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Andy Fleming <afleming@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-23spi: prefix modalias with "spi:"Anton Vorontsov
This makes it consistent with other buses (platform, i2c, vio, ...). I'm not sure why we use the prefixes, but there must be a reason. This was easy enough to do it, and I did it. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Jean Delvare <khali@linux-fr.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Samuel Ortiz <sameo@openedhand.com> Cc: "John W. Linville" <linville@tuxdriver.com> Acked-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23spi: add support for device table matchingAnton Vorontsov
With this patch spi drivers can use standard spi_driver.id_table and MODULE_DEVICE_TABLE() mechanisms to bind against the devices. Just like we do with I2C drivers. This is useful when a single driver supports several variants of devices but it is not possible to detect them in run-time (like non-JEDEC chips probing in drivers/mtd/devices/m25p80.c), and when platform_data usage is overkill. This patch also makes life a lot easier on OpenFirmware platforms, since with OF we extensively use proper device IDs in modaliases. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Jean Delvare <khali@linux-fr.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-24platform: introduce module id table for platform devicesEric Miao
Now platform_device is being widely used on SoC processors where the peripherals are attached to the system bus, which is simple enough. However, silicon IPs for these SoCs are usually shared heavily across a family of processors, even products from different companies. This makes the original simple driver name based matching insufficient, or simply not straight-forward. Introduce a module id table for platform devices, and makes it clear that a platform driver is able to support some shared IP and handle slight differences across different platforms (by 'driver_data'). Module alias is handled automatically when a MODULE_DEVICE_TABLE() is defined. To not disturb the current platform drivers too much, the matched id entry is recorded and can be retrieved by platform_get_device_id(). Signed-off-by: Eric Miao <eric.miao@marvell.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27Fix longstanding "error: storage size of '__mod_dmi_device_table' isn't known"Alexey Dobriyan
gcc 3.4.6 doesn't like MODULE_DEVICE_TABLE(dmi, x) expansion enough to error out. Shut it up in a most simple way. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-29HID: fix hid_device_id for cross compilingAndreas Schwab
struct hid_device_id contains hidden padding which is bad for cross compiling. Make the padding explicit and consistent across architectures. Signed-off-by: Andreas Schwab <schwab@suse.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-10-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (32 commits) Input: wm97xx - update email address for Liam Girdwood Input: i8042 - add Thinkpad R31 to nomux list Input: move map_to_7segment.h to include/linux Input: ads7846 - fix cache line sharing issue Input: cm109 - add missing newlines to messages Input: document i8042.debug in kernel-parameters.txt Input: keyboard - fix potential out of bound access to key_map Input: psmouse - add OLPC touchpad driver Input: psmouse - tweak PSMOUSE_DEFINE_ATTR to support raw set callbacks Input: psmouse - add psmouse_queue_work() for ps/2 extension to make use of Input: psmouse - export psmouse_set_state for ps/2 extensions to use Input: ads7846 - introduce .gpio_pendown to get pendown state Input: ALPS - add signature for DualPoint found in Dell Latitude E6500 Input: serio_raw - allow attaching to translated (SERIO_I8042XL) ports Input: cm109 - don't use obsolete logging macros Input: atkbd - expand Latitude's force release quirk to other Dells Input: bf54x-keys - add power management support Input: atmel_tsadcc - improve accuracy Input: convert drivers to use strict_strtoul() Input: appletouch - handle geyser 3/4 status bits ...
2008-10-14modpost: add support for hidJiri Slaby
Generate aliases for hid device modules to support autoloading. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-10-13Automatic MODULE_ALIAS() for DMI match tables.David Woodhouse
This makes modpost handle MODULE_DEVICE_TABLE(dmi, xxxx). I had to change the string pointers in the match table to char arrays, and picked a size of 79 bytes almost at random -- do we need to make it bigger than that? I was a bit concerned about the 'bloat' this introduces into the match tables, but they should all be __initdata so it shouldn't matter too much. (Actually, modpost does go through the relocations and look at most of them; it wouldn't be impossible to make it handle string pointers -- but doesn't seem to be worth the effort, since they're __initdata). Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-30Input: expand keycode spaceDmitry Torokhov
Expand the number of potential key codes from 512 to 768 since people are coming up with more and more keys. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-14[S390] css: Use css_device_id for bus matching.Cornelia Huck
css_device_id exists, so use it for determining the right driver (and add a match_flags which is always 1 for valid types). Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-07-14[S390] cio: Introduce modalias for css bus.Cornelia Huck
Add modalias and subchannel type attributes for all subchannels. I/O subchannel specific attributes are now created in io_subchannel_probe(). modalias and subchannel type are also added to the uevent for the css bus. Also make the css modalias known. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-05-26i2c: Align i2c_device_idJiri Slaby
Align i2c_device_id.driver_data to 8 bytes to not fail on crossbuilds. (Added in d2653e92732bd3911feff6bee5e23dbf959381db.) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-04-29i2c: Add support for device alias namesJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. This patch allows new-style i2c chip drivers to have alias names using the official kernel aliasing system and MODULE_DEVICE_TABLE(). At this point, the old i2c driver binding scheme (driver_name/type) is still supported. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jochen Friedrich <jochen@scram.de> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org>
2008-02-05sdio: fix module device table definition for m68kAl Viro
FATAL: drivers/bluetooth/btsdio: sizeof(struct sdio_device_id)=12 is not a modulo of the size of section __mod_sdio_device_table=30. Fix definition of struct sdio_device_id in mod_devicetable.h m68k has 16bit alignment for unsigned long. Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Pierre Ossman <drzeus@drzeus.cx> CC: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-23Virtio interfaceRusty Russell
This attempts to implement a "virtual I/O" layer which should allow common drivers to be efficiently used across most virtual I/O mechanisms. It will no-doubt need further enhancement. The virtio drivers add buffers to virtio queues; as the buffers are consumed the driver "interrupt" callbacks are invoked. There is also a generic implementation of config space which drivers can query to get setup information from the host. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Dor Laor <dor.laor@qumranet.com> Cc: Arnd Bergmann <arnd@arndb.de>
2007-10-13i2c: Kill struct i2c_device_idJean Delvare
I2C devices do not have any form of ID as PCI or USB devices have. No driver uses "MODULE_DEVICE_TABLE(i2c, ...)" because it doesn't make sense. So we can get rid of struct i2c_device_id and the associated support code. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Greg KH <greg@kroah.com>
2007-10-11Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (867 commits) [SKY2]: status polling loop (post merge) [NET]: Fix NAPI completion handling in some drivers. [TCP]: Limit processing lost_retrans loop to work-to-do cases [TCP]: Fix lost_retrans loop vs fastpath problems [TCP]: No need to re-count fackets_out/sacked_out at RTO [TCP]: Extract tcp_match_queue_to_sack from sacktag code [TCP]: Kill almost unused variable pcount from sacktag [TCP]: Fix mark_head_lost to ignore R-bit when trying to mark L [TCP]: Add bytes_acked (ABC) clearing to FRTO too [IPv6]: Update setsockopt(IPV6_MULTICAST_IF) to support RFC 3493, try2 [NETFILTER]: x_tables: add missing ip6t_modulename aliases [NETFILTER]: nf_conntrack_tcp: fix connection reopening [QETH]: fix qeth_main.c [NETLINK]: fib_frontend build fixes [IPv6]: Export userland ND options through netlink (RDNSS support) [9P]: build fix with !CONFIG_SYSCTL [NET]: Fix dev_put() and dev_hold() comments [NET]: make netlink user -> kernel interface synchronious [NET]: unify netlink kernel socket recognition [NET]: cleanup 3rd argument in netlink_sendskb ... Fix up conflicts manually in Documentation/feature-removal-schedule.txt and my new least favourite crap, the "mod_devicetable" support in the files include/linux/mod_devicetable.h and scripts/mod/file2alias.c. (The latter files seem to be explicitly _designed_ to get conflicts when different subsystems work with them - that have an absolutely horrid lack of subsystem separation!) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
