path: root/include/linux/mmc
2005-05-21[PATCH] MMC: Proper MMC command classes supportPierre Ossman
Defines for the different command classes as defined in the MMC and SD specifications. Removes the check for high command classes and instead checks that the command classes needed are present. Previous solution killed forward compatibility at no apparent gain. Signed-of-by: Pierre Ossman
2005-04-16[PATCH] fix u32 vs. pm_message_t in rest of the treePavel Machek
This fixes u32 vs. pm_message_t confusion in remaining places. Fortunately there's few of them. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
