path: root/include/linux/mmc
2011-01-14mmc: sh_mmcif: Convert to __raw_xxx() I/O accessors.Paul Mundt
When using the I/O accessors in raw mode from the boot stubs we don't want to bother with any of the complexity associated with readl/writel and friends. Furthermore, utilization within the context of the host driver itself is all performed on an ioremapped window, so using the __raw variants there doesn't pose any problem either. If and when barriers need to be added in the future, these will need to be explicitly written out, but this is so far not a concern for any of the affected CPUs in question. This fixes up the link error introduced by the ARM tree via its barrier refactoring: arch/arm/boot/compressed/mmcif-sh7372.o: In function `mmcif_loader': mmcif-sh7372.c:(.text+0x9e8): undefined reference to `outer_cache Following the change in: http://www.arm.linux.org.uk/developer/patches/viewpatch.php?id=6275/1 Reported-by: Simon Horman <horms@verge.net.au> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-12Merge branch 'sh/sdio' into sh-latestPaul Mundt
2011-01-11Merge branches 'sh/memchunk' and 'common/mmcif' into sh-latestPaul Mundt
2011-01-08mmc: dw_mmc: Add Synopsys DesignWare mmc host driver.Will Newton
This adds the mmc host driver for the Synopsys DesignWare mmc host controller, found in a number of embedded SoC designs. Signed-off-by: Will Newton <will.newton@imgtec.com> Reviewed-by: Matt Fleming <matt@console-pimps.org> Reviewed-by: Chris Ball <cjb@laptop.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: sdhci: add quirk for max len ADMA descriptorsOlof Johansson
Some controllers misparse segment length 0 as being 0, not 65536. Add a quirk to deal with it. Signed-off-by: Olof Johansson <olof@lixom.net> Reviewed-by: Chris Ball <cjb@laptop.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: Test bus-width for old MMC devicesAries Lee
Some old MMC devices fail with the 4/8 bits the driver tries to use exclusively. This patch adds a test for the given bus setup and falls back to the lower bit mode (until 1-bit mode) when the test fails. [Major rework and refactoring by tiwai] [Quirk addition and many fixes by prakity] Signed-off-by: Aries Lee <arieslee@jmicron.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Philip Rakity <prakity@marvell.com> Tested-by: Philip Rakity <prakity@marvell.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: sdio: don't reinitialize nonremovable powered-resumed cardsOhad Ben-Cohen
Upon system resume, SDIO core must reinitialize cards that were powered off during suspend. If the card had its power kept during suspend (and thus it is 'powered-resumed'), SDIO core performs only a limited reinitializing, mainly needed to make sure that the card wasn't removed/replaced. If a __nonremovable__ card is powered-resumed, we can safely skip the reinitializing phase. Note: 9b966aa (mmc: sdio: fully reconfigure oldcard on resume) removed the bus width reconfiguration since mmc_sdio_init_card already does it. It is brought back now in case mmc_sdio_init_card is skipped. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: Add support for JMicron 388 SD/MMC controllerTakashi Iwai
JMicron 388 SD/MMC combo controller supports the 1.8V low-voltage for SD, but MMC doesn't work with the low-voltage, resulting in an error at probing. This patch adds the support for multiple voltage mask per device type, so that SD works with 1.8V while MMC forces 3.3V. Here new ocr_avail_* fields for each device are introduced, so that the actual OCR mask is switched dynamically. Also, the restriction of low-voltage in core/sd.c is removed when the bit is allowed explicitly via ocr_avail_sd mask. This patch was rewritten from scratch based on Aries' original code. Signed-off-by: Aries Lee <arieslee@jmicron.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Reviewed-by: Chris Ball <cjb@laptop.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-01-08mmc: Aggressive clock gating frameworkLinus Walleij
This patch modifies the MMC core code to optionally call the set_ios() operation on the driver with the clock frequency set to 0 (gate) after a grace period of at least 8 MCLK cycles, then restore it (ungate) before any new request. This gives the driver the option to shut down the MCI clock to the MMC/SD card when the clock frequency is 0, i.e. the core has stated that the MCI clock does not need to be generated. It is inspired by existing clock gating code found in the OMAP and Atmel drivers and brings this up to the host abstraction. Gating is performed before and after any MMC request. This patchset implements this for the MMCI/PL180 MMC/SD host controller, but it should be simple to switch OMAP/Atmel over to using this instead. mmc_set_{gated,ungated}() add variable protection to the state holders for the clock gating code. This is particularly important when ordinary .set_ios() calls would race with the .set_ios() call resulting from a delayed gate operation. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Reviewed-by: Chris Ball <cjb@laptop.org> Tested-by: Chris Ball <cjb@laptop.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-12-21Merge branch 'rmobile/urgent' into rmobile-latestPaul Mundt
Conflicts: arch/arm/mach-shmobile/include/mach/entry-macro.S Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-12-08mmc, sh: Remove sh_mmcif_boot_slurp()Simon Horman
As the only caller of sh_mmcif_boot_do_read() is sh_mmcif_boot_slurp() the configuration portion of sh_mmcif_boot_slurp() can be merged into sh_mmcif_boot_do_read(). Once this is done sh_mmcif_boot_slurp() is only a call to sh_mmcif_boot_do_read() with platform specific information - the offset that images are stored on MMC. So make the sh_mmcif_boot_do_read() call directly from platform code and remove sh_mmcif_boot_slurp() altogether. Cc: Magnus Damm <magnus.damm@gmail.com> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-12-08mmc, sh: Move MMCIF_PROGRESS_* into sh_mmcif.hSimon Horman
Allow MMCIF_PROGRESS_* to be shared. Cc: Magnus Damm <magnus.damm@gmail.com> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-30Merge branch 'common/mmcif' into rmobile/mmcifPaul Mundt
2010-11-29sh, mmc: Use defines when setting CE_CLK_CTRLSimon Horman
The 16-19th bits of CE_CLK_CTRL set the MMC clock frequency. Cc: Yusuke Goda <yusuke.goda.sx@renesas.com> Cc: Magnus Damm <magnus.damm@gmail.com> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-29mmc, sh: Correct value for resetSimon Horman
This resolves a regression that I introduced in "mmc, sh: Move constants to sh_mmcif.h". Having examined the manual and tested the code on an AP4EVB board it seems that the correct sequence is. 1) Write 1 to bit 31 and zeros to all other bits 2) Write zero to all bits Cc: Yusuke Goda <yusuke.goda.sx@renesas.com> Cc: Magnus Damm <magnus.damm@gmail.com> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: mmc: sdhci: 8-bit bus width changes mmc: sdio: fix runtime PM anomalies by introducing MMC_CAP_POWER_OFF_CARD mmc: sdio: fix nasty oops in mmc_sdio_detect mmc: omap4: hsmmc: Fix improper card detection while booting mmc: fix rmmod race for hosts using card-detection polling mmc: sdhci: Fix crash on boot with C0 stepping Moorestown platforms mmc: sdhci-esdhc-imx: enable QUIRK_NO_MULTIBLOCK only for i.MX25 and i.MX35 mmc: sdhci-esdhc-imx: fix timeout on i.MX's sdhci mmc: sdhci: Properly enable SDIO IRQ wakeups mmc: ushc: Return proper error code for ushc_probe() mmc: Fix printing of card DDR type
2010-11-25mmc: sh_mmcif: add DMA supportGuennadi Liakhovetski
The MMCIF controller on sh-mobile platforms can use the DMA controller for data transfers. Interface to the SH dmaengine driver to enable DMA. We also have to lower the maximum number of segments to match with the number od DMA descriptors on SuperH, this doesn't significantly affect driver's PIO performance. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-19mmc: sdio: fix runtime PM anomalies by introducing MMC_CAP_POWER_OFF_CARDOhad Ben-Cohen
Some board/card/host configurations are not capable of powering off the card after boot. To support such configurations, and to allow smoother transition to runtime PM behavior, MMC_CAP_POWER_OFF_CARD is added, so hosts need to explicitly indicate whether it's OK to power off their cards after boot. SDIO core will enable runtime PM for a card only if that cap is set. As a result, the card will be powered down after boot, and will only be powered up again when a driver is loaded (and then it's up to the driver to decide whether power will be kept or not). This will prevent sdio_bus_probe() failures with setups that do not support powering off the card. Reported-and-tested-by: Daniel Drake <dsd@laptop.org> Reported-and-tested-by: Arnd Hannemann <arnd@arndnet.de> Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-11-10mmc, sh: Move constants to sh_mmcif.hSimon Horman
This moves some constants from sh_mmcif.c to sh_mmcif.h so that they can be used in sh_mmcif_boot_init(). It also alters the definition of SOFT_RST_OFF from (0 << 31) to ~SOFT_RST_ON (= ~(1 << 31)). The former seems bogus. The latter is consistent with the code in sh_mmcif_boot_init(). Cc: Yusuke Goda <yusuke.goda.sx@renesas.com> Cc: Magnus Damm <magnus.damm@gmail.com> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-04mmc: sh_mmcif: Convert extern inline to static inline.Paul Mundt
Presently the extern inline case results in a compiler warning on ARM due to the memory barrier definition used in the I/O routines. These ultimately all want to be static inline anyways, so just convert them all in place. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-10-29mmc: Allow the platform to specify the sh_mmcif get_cd handlerArnd Hannemann
In some platforms (e.g. AP4EVB) the card detect pin of a slot is not directly connected to the sh_mmcif controller, so that polling needs to be used. To overcome the overhead induced by querying the controller on each poll cycle, card detection can be handled in the platform code more efficiently. This patch exposes a get_cd hook for that purpose. Signed-off-by: Arnd Hannemann <arnd@arndnet.de> Tested-by: Yusuke Goda <yusuke.goda.sx@renesas.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (66 commits) mmc: add new sdhci-pxa driver for Marvell SoCs mmc: make number of mmcblk minors configurable mmc_spi: Recover from CRC errors for r/w operation over SPI. mmc: sdhci-pltfm: add -pltfm driver for imx35/51 mmc: sdhci-of-esdhc: factor out common stuff mmc: sdhci_pltfm: pass more data on custom init call mmc: sdhci: introduce get_ro private write-protect hook mmc: sdhci-pltfm: move .h file into appropriate subdir mmc: sdhci-pltfm: Add structure for host-specific data mmc: fix cb710 kconfig dependency warning mmc: cb710: remove debugging printk (info duplicated from mmc-core) mmc: cb710: clear irq handler on init() error path mmc: cb710: remove unnecessary msleep() mmc: cb710: implement get_cd() callback mmc: cb710: partially demystify clock selection mmc: add a file to debugfs for changing host clock at runtime mmc: sdhci: allow for eMMC 74 clock generation by controller mmc: sdhci: highspeed: check for mmc as well as sd cards mmc: sdhci: Add Moorestown device support mmc: sdhci: Intel Medfield support ...
2010-10-23mmc: sdhci_pltfm: pass more data on custom init callWolfram Sang
The custom init call may need more data to perform its job, so we pass it a pointer to pdata, too. Also, always use the platform_id specific data even if platform_data is present. Doing that, platform_data can additionally be parsed by init() for board-specific information (via sdhci->mmc->parent). (Note: the old behaviour was that you could override the platform_id specific data with your own. However, one can still do this by using the "sdhci" id instead of "sdhci-<something>".) Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Tested-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-10-23mmc: sdhci-pltfm: move .h file into appropriate subdirWolfram Sang
Make use of the include/linux/mmc directory. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Tested-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-10-23mmc: propagate power save/restore ops return valueOhad Ben-Cohen
Allow power save/restore and their relevant mmc_bus_ops handlers exit with a return value. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Tested-by: Luciano Coelho <luciano.coelho@nokia.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-10-23mmc: sdhci: split up sdhci.h for sdhci-pltfm usersGiuseppe Cavallaro
Some platforms based on sdhci-pltfm need to set their own quirks. Previously to this patch, the quirks were in drivers/mmc/host/sdhci.h. This patch splits drivers/mmc/host/sdhci.h into two parts: * drivers/mmc/host/sdhci.h includes the HC registers and I/O accessors. * include/linux/mmc/sdhci.h includes the sdhci structure and quirks. Instead of including drivers/mmc/host/sdhci.h, -pltfm drivers should now include include/linux/mmc/sdhci.h and include/linux/sdhci-pltfm.h. This patch avoids adding/changing the calls/flags in the sdhci_pltfm_data structure. It has been tested on STM platforms (e.g. STx7106, STx7108, STx5206) where the driver is configured and used as shown in the example below: [snip] static int mmc_pad_resources(struct sdhci_host *sdhci) { if (!devm_stm_pad_claim(sdhci->mmc->parent, &stx7108_mmc_pad_config, dev_name(sdhci->mmc->parent))) return -ENODEV; return 0; } static struct sdhci_pltfm_data stx7108_mmc_platform_data = { .init = mmc_pad_resources, .quirks = SDHCI_QUIRK_NO_ENDATTR_IN_NOPDESC, }; static struct platform_device stx7108_mmc_device = { .name = "sdhci", [snip] Note: drivers/mmc/host/sdhci.h now also includes linux/mmc/sdhci.h, and no modifications should be needed on other sdhci-<XXX> drivers. Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-10-23mmc: refine DDR supportAdrian Hunter
One flaw with DDR support is that MMC core does not inform the driver which DDR mode it has selected. This patch expands the ios->ddr flag to do that. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-10-23mmc: Fixes for Dual Data Rate (DDR) supportAdrian Hunter
The DDR support patch needs the following fixes: - The block driver does not need to know about DDR, any more than it needs to know about bus width. - Not only the card must be switched to DDR mode. The host controller must also be configured, which is done through the 'set_ios()' function. - Do not set the DDR mode state until after the switch command is successful. - Setting block length is not supported in DDR mode. Make that a core function and change the other place it is used (mmc_test) also. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-10-23mmc: MMC 4.4 DDR supportHanumath Prasad
Add support for Dual Data Rate MMC cards as defined in the 4.4 specification. Signed-off-by: Hanumath Prasad <hanumath.prasad@stericsson.com> Cc: linux-mmc@vger.kernel.org Acked-by: Linus Walleij <linus.walleij@stericsson.com> Tested-by Zhangfei Gao <zhangfei.gao@marvell.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-10-23mmc: Move regulator handling closer to coreLinus Walleij
After discovering a problem in regulator reference counting I took Mark Brown's advice to move the reference count into the MMC core by making the regulator status a member of struct mmc_host. I took this opportunity to also implement NULL versions of the regulator functions so as to rid the driver code from some ugly #ifdef CONFIG_REGULATOR clauses. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Cc: Tony Lindgren <tony@atomide.com> Cc: Adrian Hunter <adrian.hunter@nokia.com> Cc: Robert Jarzmik <robert.jarzmik@free.fr> Cc: Sundar Iyer <sundar.iyer@stericsson.com> Cc: Daniel Mack <daniel@caiaq.de> Cc: Pierre Ossman <pierre@ossman.eu> Cc: Matt Fleming <matt@console-pimps.org> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Cliff Brake <cbrake@bec-systems.com> Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-10-23mmc: Make ID freq configurableHein Tibosch
In the latest releases of the mmc driver, the freq during initialization is set to a fixed 400 Khz. This was reportedly too fast for several users. As there doesn't seem to be an ideal frequency which-works-for-all, Pierre suggested to let the driver try several frequencies. This patch implements that idea. It will try mmc-initialization using several frequencies from an array 400, 300, 200 and 100. In case SDIO is broken, it'll still try to detect SDMEM, also at different freqs. Signed-off-by: Hein Tibosch <hein_tibosch@yahoo.es> Cc: Pierre Ossman <pierre@ossman.eu> Reviewed-by: Chris Ball <cjb@laptop.org> Tested-by: Chris Ball <cjb@laptop.org> Cc: Ben Nizette <bn@niasdigital.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Adrian Hunter <adrian.hunter@nokia.com> Cc: Matt Fleming <matt@console-pimps.org> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-10-23mmc: Add helper function to check if a card is removableMatt Fleming
There are two checks that need to be made when determining whether a card is removable. A host controller may set MMC_CAP_NONREMOVABLE if the controller does not support removing cards (e.g. eMMC), in which case the card is physically non-removable. Also the 'mmc_assume_removable' module parameter can be configured at module load time, in which case the card may be logically non-removable. A helper function keeps the logic in one place so that code always checks both conditions. Because this new function is likely to be called from modules we now need to export the mmc_assume_removable symbol. Signed-off-by: Matt Fleming <matt@console-pimps.org> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Tested-by: Jaehoon Chung <jh80.chung@samsung.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-10-23mmc: rename dev_to_mmc_card() to mmc_dev_to_card()Andy Shevchenko
Global symbols should use their subsystem name in a prefixed fashion. Signed-off-by: Andy Shevchenko <ext-andriy.shevchenko@nokia.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-10-23mmc: make mmc_dev_to_card() macro publicAndy Shevchenko
Conversion from struct device to struct mmc_card is used more than in one place. Due to this it's better to have public macro for such thing. Signed-off-by: Andy Shevchenko <ext-andriy.shevchenko@nokia.com> Cc: Adrian Hunter <adrian.hunter@nokia.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-10-23mmc: Remove distinction between hw and phys segmentsMartin K. Petersen
We have deprecated the distinction between hardware and physical segments in the block layer. Consolidate the two limits into one in drivers/mmc/. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-10-12Bluetooth: Support SDIO devices that are AMP controllersDavid Vrabel
Signed-off-by: David Vrabel <david.vrabel@csr.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2010-09-09mmc: avoid getting CID on SDIO-only cardsDavid Vrabel
The introduction of support for SD combo cards breaks the initialization of all CSR SDIO chips. The GO_IDLE (CMD0) in mmc_sd_get_cid() causes CSR chips to be reset (this is non-standard behavior). When initializing an SDIO card check for a combo card by using the memory present bit in the R4 response to IO_SEND_OP_COND (CMD5). This avoids the call to mmc_sd_get_cid() on an SDIO-only card. Signed-off-by: David Vrabel <david.vrabel@csr.com> Acked-by: Michal Mirolaw <mirq-linux@rere.qmqm.pl> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-12mmc: add erase, secure erase, trim and secure trim operationsAdrian Hunter
SD/MMC cards tend to support an erase operation. In addition, eMMC v4.4 cards can support secure erase, trim and secure trim operations that are all variants of the basic erase command. SD/MMC device attributes "erase_size" and "preferred_erase_size" have been added. "erase_size" is the minimum size, in bytes, of an erase operation. For MMC, "erase_size" is the erase group size reported by the card. Note that "erase_size" does not apply to trim or secure trim operations where the minimum size is always one 512 byte sector. For SD, "erase_size" is 512 if the card is block-addressed, 0 otherwise. SD/MMC cards can erase an arbitrarily large area up to and including the whole card. When erasing a large area it may be desirable to do it in smaller chunks for three reasons: 1. A single erase command will make all other I/O on the card wait. This is not a problem if the whole card is being erased, but erasing one partition will make I/O for another partition on the same card wait for the duration of the erase - which could be a several minutes. 2. To be able to inform the user of erase progress. 3. The erase timeout becomes too large to be very useful. Because the erase timeout contains a margin which is multiplied by the size of the erase area, the value can end up being several minutes for large areas. "erase_size" is not the most efficient unit to erase (especially for SD where it is just one sector), hence "preferred_erase_size" provides a good chunk size for erasing large areas. For MMC, "preferred_erase_size" is the high-capacity erase size if a card specifies one, otherwise it is based on the capacity of the card. For SD, "preferred_erase_size" is the allocation unit size specified by the card. "preferred_erase_size" is in bytes. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Acked-by: Jens Axboe <axboe@kernel.dk> Cc: Kyungmin Park <kmpark@infradead.org> Cc: Madhusudhan Chikkature <madhu.cr@ti.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Ben Gardiner <bengardiner@nanometrics.ca> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11sdio: allow non-standard SDIO cardsGrazvydas Ignotas
There are some chips (like TI WL12xx series) that can be interfaced over SDIO but don't support the SDIO specification, meaning that they are missing CIA (Common I/O Area) with all it's registers. Current Linux SDIO implementation relies on those registers to identify and configure the card, so non-standard cards can not function and cause lots of warnings from the core when it reads invalid data from non-existent registers. After this patch, init_card() host callback can now set new quirk MMC_QUIRK_NONSTD_SDIO, which means that SDIO core should not try to access any standard SDIO registers and rely on init_card() to fill all SDIO structures instead. As those cards are usually embedded chips, all the required information can be obtained from machine board files by the host driver when it's called through init_card() callback. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Cc: Adrian Hunter <adrian.hunter@nokia.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Bob Copeland <me@bobcopeland.com> Cc: Kalle Valo <kvalo@adurom.com> Cc: Madhusudhan Chikkature <madhu.cr@ti.com> Cc: Kishore Kadiyala <kishore.kadiyala@ti.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11mmc: fix all hangs related to mmc/sd card insert/removal during suspend/resumeMaxim Levitsky
If you don't use CONFIG_MMC_UNSAFE_RESUME, as soon as you attempt to suspend, the card will be removed, therefore this patch doesn't change the behavior of this option. However the removal will be done by pm notifier, which runs while userspace is still not frozen and thus can freely use del_gendisk, without the risk of deadlock which would happen otherwise. Card detect workqueue is now disabled while userspace is frozen, Therefore if you do use CONFIG_MMC_UNSAFE_RESUME, and remove the card during suspend, the removal will be detected as soon as userspace is unfrozen, again at the moment it is safe to call del_gendisk. Tested with and without CONFIG_MMC_UNSAFE_RESUME with suspend and hibernate. [akpm@linux-foundation.org: clean up function prototype] [akpm@linux-foundation.org: fix CONFIG_PM-n linkage, small cleanups] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com> Cc: David Brownell <david-b@pacbell.net> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11mmc: implement SD-combo (IO+mem) supportMichal Miroslaw
Signed-off-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl> Cc: Adrian Hunter <adrian.hunter@nokia.com> Cc: Chris Ball <cjb@laptop.org> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11mmc: recognize CSD structureKyungmin Park
The eMMC spec 4.4 and 4.3 + additional feature chips has CSD structure version 3 and version 3 have to check the CSD_STRUCTURE byte in the EXT_CSD register. Also fix EXT_CSD revision message. [akpm@linux-foundation.org: fix comment, per Chris Ball] Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Adrian Hunter <adrian.hunter@nokia.com> Cc: Chris Ball <cjb@laptop.org> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-31sh: add boot code to MMCIF driver headerMagnus Damm
This patch adds a set of MMCIF functions for the romImage boot loader that allows the kernel to be booted directly from an MMC card. Thanks to Jeremy Baker for the initial prototype. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-31sh: prepare MMCIF driver header fileMagnus Damm
Update the MMCIF driver to include register information and register access functions in the header file. The MMCIF boot code builds on top of this. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-27sdhci-spear: ST SPEAr based SDHCI controller glueViresh KUMAR
Add a glue layer to support the sdhci driver on the ST SPEAr platform. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Cc: <shiraz.hashim@st.com> Cc: Linus Walleij <linus.ml.walleij@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27sdio: add new function for RAW (Read after Write) operationGrazvydas Ignotas
SDIO specification allows RAW (Read after Write) operation using IO_RW_DIRECT command (CMD52) by setting the RAW bit. This operation is similar to ordinary read/write commands, except that both write and read are performed using single command/response pair. The Linux SDIO layer already supports this internaly, only external function is missing for drivers to make use, which is added by this patch. This type of command is required to implement proper power save mode support in wl1251 wifi driver. Android has similar patch for G1 in it's tree for the same reason: http://android.git.kernel.org/?p=kernel/common.git;a=commitdiff;h=74a47786f6ecbe6c1cf9fb15efe6a968451deb52 Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Acked-by: Kalle Valo <kalle.valo@iki.fi> Cc: Dmitry Shmidt <dimitrysh@google.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27mmc: remove the "state" argument to mmc_suspend_host()Matt Fleming
Even though many mmc host drivers pass a pm_message_t argument to mmc_suspend_host() that argument isn't used the by MMC core. As host drivers are converted to dev_pm_ops they'll have to construct pm_message_t's (as they won't be passed by the PM subsystem any more) just to appease the mmc suspend interface. We might as well just delete the unused paramter. Signed-off-by: Matt Fleming <matt@console-pimps.org> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Acked-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl>ZZ Acked-by: Sascha Sommer <saschasommer@freenet.de> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27mmc: add support MMCIF for SuperHYusuke Goda
MMCIF is the MMC Host Interface in SuperH. Signed-off-by: Yusuke Goda <yusuke.goda.sx@renesas.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (103 commits) ARM: 6141/1: Add audio support part in arch/arm/mach-w90x900 ARM: 5939/1: ARM: Add option CMDLINE_FORCE to force usage of the in-kernel cmdline ARM: 6140/1: silence a bogus sparse warning in unwind.c ARM: mach-at91: duplicated include ARM: arch/arm/nwfpe/fpsr.h: Checkpatch cleanup ARM: arch/arm/mach-shark/pci.c: Checkpatch cleanup ARM: arch/arm/nwfpe/ChangeLog: Checkpatch cleanup ARM: arch/arm/mach-sa1100/leds.c: Checkpatch cleanup ARM: arch/arm/mach-h720x/common.h: Checkpatch cleanup ARM: arch/arm/mach-footbridge/ebsa285-pci.c: Checkpatch cleanup ARM: arch/arm/mach-clps711x/Makefile.boot: Checkpatch cleanup ARM: arch/arm/boot/bootp/bootp.lds: Checkpatch cleanup ARM: SPEAR6xx: remove duplicated #include ARM: s3c6400_defconfig: Add NAND driver ARM: s3c6400_defconfig: enable sound as modules ARM: s3c6400_defconfig: enable power management ARM: s5pv210_defconfig: Update s5pv210_defconfig to v2.6.34 ARM: s5pc110_defconfig: Update s5pc110_defconfig to v2.6.34 ARM: s5p6442_defconfig: Update s5p6442_defconfig to v2.6.34 ARM: s5p6440_defconfig: Update s5p6440_defconfig to v2.6.34 ...
2010-04-15Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: Documentation/feature-removal-schedule.txt drivers/net/wireless/ath/ath5k/phy.c drivers/net/wireless/wl12xx/wl1271_main.c
