path: root/include/linux/mfd/rtsx_pci.h
2014-12-08mfd: rtsx: Add func to split u32 into registerMicky Ching
Add helper function to write u32 to registers, if we want to put u32 value to 4 continuous register, this can help us reduce tedious work. Signed-off-by: Micky Ching <micky_ching@realsil.com.cn> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-11-25mfd: rtsx: Fix PM suspend for 5227 & 5249Micky Ching
Fix rts5227&5249 failed send buffer cmd after suspend, PM_CTRL3 should reset before send any buffer cmd after suspend. Otherwise, buffer cmd will failed, this will lead resume fail. Signed-off-by: Micky Ching <micky_ching@realsil.com.cn> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-07-09mfd: rtsx: Add dma transfer functionMicky Ching
rtsx driver using a single function for transfer data, dma map/unmap are placed in one fix function. We need map/unmap dma in different place(for mmc async driver), so add three function for dma map, dma transfer and dma unmap. Signed-off-by: Micky Ching <micky_ching@realsil.com.cn> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-05-08mmc: rtsx: Revert "mmc: rtsx: add support for pre_req and post_req"Micky Ching
This reverts commit c42deffd5b53c9e583d83c7964854ede2f12410d. commit <mmc: rtsx: add support for pre_req and post_req> did use mutex_unlock() in tasklet, but mutex_unlock() can't be used in tasklet(atomic context). The driver needs to use mutex to avoid concurrency, so we can't use tasklet here, the patch need to be removed. The spinlock host->lock and pcr->lock may deadlock, one way to solve the deadlock is remove host->lock in sd_isr_done_transfer(), but if using workqueue the we can avoid using the spinlock and also avoid the problem. Signed-off-by: Micky Ching <micky_ching@realsil.com.cn> Acked-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-02-22mmc: rtsx: add support for pre_req and post_reqMicky Ching
Add support for non-blocking request, pre_req() runs dma_map_sg() and post_req() runs dma_unmap_sg(). This patch can increase card read/write speed, especially for high speed card and slow CPU(for some embedded platform). Users can get a great benefit from this patch. if CPU frequency is 800MHz, SDR104 or DDR50 card read/write speed may increase more than 15%. test results: intel i3(800MHz - 2.3GHz), SD card clock 208MHz performance mode(2.3GHz): Before: dd if=/dev/mmcblk0p1 of=/dev/null bs=64k count=1024 67108864 bytes (67 MB) copied, 1.18191 s, 56.8 MB/s After: dd if=/dev/mmcblk0p1 of=/dev/null bs=64k count=1024 67108864 bytes (67 MB) copied, 1.09276 s, 61.4 MB/s powersave mode(800MHz): Before: dd if=/dev/mmcblk0p1 of=/dev/null bs=64k count=1024 67108864 bytes (67 MB) copied, 1.29569 s, 51.8 MB/s After: dd if=/dev/mmcblk0p1 of=/dev/null bs=64k count=1024 67108864 bytes (67 MB) copied, 1.11218 s, 60.3 MB/s Signed-off-by: Micky Ching <micky_ching@realsil.com.cn> Signed-off-by: Chris Ball <chris@printf.net>
2014-02-22mmc: rtsx: modify phase searching method for tuningMicky Ching
The new phase searching method is more concise and easier to understand. Signed-off-by: Micky Ching <micky_ching@realsil.com.cn> Signed-off-by: Chris Ball <chris@printf.net>
2013-10-23mfd: rtsx: Modify rts5249_optimize_phyWei WANG
In some platforms, specially Thinkpad series, rts5249 won't be initialized properly. So we need adjust some phy parameters to improve the compatibility issue. It is a little different between simulation and real chip. We have no idea about which configuration is better before tape-out. We set default settings according to simulation, but need to tune these parameters after getting the real chip. I can't explain every change in detail here. The below information is just a rough description: PHY_REG_REV: Disable internal clkreq_tx, enable rx_pwst PHY_BPCR: No change, just turn the magic number to macro definitions PHY_PCR: Change OOBS sensitivity, from 60mV to 90mV PHY_RCR2: Control charge-pump current automatically PHY_FLD4: Use TX cmu reference clock PHY_RDR: Change RXDSEL from 30nF to 1.9nF PHY_RCR1: Change the duration between adp_st and asserting cp_en from 0.32 us to 0.64us PHY_FLD3: Adjust internal timers PHY_TUNE: Fine tune the regulator12 output voltage Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2013-08-30mfd: mmc: rtsx: Change default tx phaseWei WANG
The default phase can meet most cards' requirement, but it is not the optimal one. In some extreme situation, the rx phase point produced by the following tuning process will drift quite a distance. Before tuning UHS card, this patch will set a more proper initial tx phase point, which is calculated from statistic data, and can achieve a much better tx signal quality. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Acked-by: Lee Jones <lee.jones@linaro.org> Acked-by: Chris Ball <cjb@laptop.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-08-20mfd: rtsx: Copyright modificationsWei WANG
Update copyright date, remove author address and add Roger Tseng. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-08-20mfd: rtsx: Configure to enter a deeper power-saving mode in S3Wei WANG
Set a bit to enable rts5227 and rts5249 to enter a deeper internal power-saving mode in S3, and recover it after resuming. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-08-20mfd: rtsx: Clear hardware PFM mode in rtl8411bWei WANG
Clear hw_pfm_en to disable hardware PFM mode, to fix a bug that in some situation registers in 0xFDxx domain can't be accessed. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-08-20mfd: rtsx: Add shutdown callback in rtsx_pci_driverWei WANG
Some actions to clear power state should be handled in .shutdown callback in rtsx_pci_driver. This patch adopts the following measures to catch this goal: 1. Add a function rtsx_pci_power_off to abstract the common ops in .shutdown and .suspend 2. Add pcr->ops->force_power_down to fulfill the individual action for each reader model Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-08-20mfd: rtsx: Read vendor setting from config spaceWei WANG
Normally OEMs will set vendor setting to the config space of Realtek card reader in BIOS stage. This patch reads the setting at the first, and configure the internal registers according to it, to improve card reader's compatibility condition. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-06-11mfd: rtsx: Add support for RTL8411BRoger Tseng
Adding support of model RTL8411B. Since the model is similar to RTL8411, differences are implemented in rtl8411.c. Signed-off-by: Roger Tseng <rogerable@realtek.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-04-19mfd: rtsx: Support RTS5249Wei WANG
RTS5249 supports SD UHS-II interface. In order to support SD UHS-II,the definitions of some internal registers of RTS5249 have to be modified and are different from its predecessors. So we need this patch to ensure RTS5249 can work, even SD/MMC stack doesn't support UHS-II interface. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-02-14mfd: rtsx: Fix issue that booting OS with SD card insertedWei WANG
Realtek card reader supports both SD and MS card. According to the settings of rtsx MFD driver, SD host will be probed before MS host. If we boot/reboot Linux with SD card inserted, the resetting flow of SD card will succeed, and the following resetting flow of MS is sure to fail. Then MS upper-level driver will ask rtsx driver to turn power off. This request leads to the result that the following SD commands fail and SD card can't be accessed again. In this commit, Realtek's SD and MS host driver will check whether the card that upper driver requesting is the one existing in the slot. If not, Realtek's host driver will refuse the operation to make sure the exlusive accessing at the same time. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-02-14mfd: rtsx: Support RTS5227Roger Tseng
Support new model RTS5227. Signed-off-by: Roger Tseng <rogerable@realtek.com> Reviewed-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-02-14mfd: rtsx: Fix typo in commentWei WANG
Fix a misspelling word in comment Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-01-27mfd: rtsx: Add clock divider hookWei WANG
Add callback function conv_clk_and_div_n to convert between SSC clock and its divider N. For rtl8411, the formula to calculate SSC clock divider N is different with the other card reader models. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-01-27mfd: rtsx: Add output voltage switch hookWei WANG
Different card reader has different method to switch output voltage, add this callback to let the card reader implement its individual switch function. This is needed as rtl8411 has a specific switch output voltage procedure. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-11-15drivers/mfd: Add realtek pcie card reader driverWei WANG
Realtek PCI-E card reader driver adapts requests from upper-level sdmmc/memstick layer to the real physical card reader. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Borislav Petkov <bp@alien8.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
