path: root/include/linux/memcontrol.h
2009-12-16Merge branch 'hwpoison' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (34 commits) HWPOISON: Remove stray phrase in a comment HWPOISON: Try to allocate migration page on the same node HWPOISON: Don't do early filtering if filter is disabled HWPOISON: Add a madvise() injector for soft page offlining HWPOISON: Add soft page offline support HWPOISON: Undefine short-hand macros after use to avoid namespace conflict HWPOISON: Use new shake_page in memory_failure HWPOISON: Use correct name for MADV_HWPOISON in documentation HWPOISON: mention HWPoison in Kconfig entry HWPOISON: Use get_user_page_fast in hwpoison madvise HWPOISON: add an interface to switch off/on all the page filters HWPOISON: add memory cgroup filter memcg: add accessor to mem_cgroup.css memcg: rename and export try_get_mem_cgroup_from_page() HWPOISON: add page flags filter mm: export stable page flags HWPOISON: limit hwpoison injector to known page types HWPOISON: add fs/device filters HWPOISON: return 0 to indicate success reliably HWPOISON: make semantics of IGNORED/DELAYED clear ...
2009-12-16memcg: make memcg's file mapped consistent with global VMKAMEZAWA Hiroyuki
In global VM, FILE_MAPPED is used but memcg uses MAPPED_FILE. This makes grep difficult. Replace memcg's MAPPED_FILE with FILE_MAPPED And in global VM, mapped shared memory is accounted into FILE_MAPPED. But memcg doesn't. fix it. Note: page_is_file_cache() just checks SwapBacked or not. So, we need to check PageAnon. Cc: Balbir Singh <balbir@in.ibm.com> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16memcg: coalesce uncharge during unmap/truncateKAMEZAWA Hiroyuki
In massive parallel enviroment, res_counter can be a performance bottleneck. One strong techinque to reduce lock contention is reducing calls by coalescing some amount of calls into one. Considering charge/uncharge chatacteristic, - charge is done one by one via demand-paging. - uncharge is done by - in chunk at munmap, truncate, exit, execve... - one by one via vmscan/paging. It seems we have a chance to coalesce uncharges for improving scalability at unmap/truncation. This patch is a for coalescing uncharge. For avoiding scattering memcg's structure to functions under /mm, this patch adds memcg batch uncharge information to the task. A reason for per-task batching is for making use of caller's context information. We do batched uncharge (deleyed uncharge) when truncation/unmap occurs but do direct uncharge when uncharge is called by memory reclaim (vmscan.c). The degree of coalescing depends on callers - at invalidate/trucate... pagevec size - at unmap ....ZAP_BLOCK_SIZE (memory itself will be freed in this degree.) Then, we'll not coalescing too much. On x86-64 8cpu server, I tested overheads of memcg at page fault by running a program which does map/fault/unmap in a loop. Running a task per a cpu by taskset and see sum of the number of page faults in 60secs. [without memcg config] 40156968 page-faults # 0.085 M/sec ( +- 0.046% ) 27.67 cache-miss/faults [root cgroup] 36659599 page-faults # 0.077 M/sec ( +- 0.247% ) 31.58 miss/faults [in a child cgroup] 18444157 page-faults # 0.039 M/sec ( +- 0.133% ) 69.96 miss/faults [child with this patch] 27133719 page-faults # 0.057 M/sec ( +- 0.155% ) 47.16 miss/faults We can see some amounts of improvement. (root cgroup doesn't affected by this patch) Another patch for "charge" will follow this and above will be improved more. Changelog(since 2009/10/02): - renamed filed of memcg_batch (as pages to bytes, memsw to memsw_bytes) - some clean up and commentary/description updates. - added initialize code to copy_process(). (possible bug fix) Changelog(old): - fixed !CONFIG_MEM_CGROUP case. - rebased onto the latest mmotm + softlimit fix patches. - unified patch for callers - added commetns. - make ->do_batch as bool. - removed css_get() at el. We don't need it. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16memcg: add accessor to mem_cgroup.cssWu Fengguang
So that an outside user can free the reference count grabbed by try_get_mem_cgroup_from_page(). CC: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> CC: Hugh Dickins <hugh.dickins@tiscali.co.uk> CC: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> CC: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-16memcg: rename and export try_get_mem_cgroup_from_page()Wu Fengguang
So that the hwpoison injector can get mem_cgroup for arbitrary page and thus know whether it is owned by some mem_cgroup task(s). [AK: Merged with latest git tree] CC: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> CC: Hugh Dickins <hugh.dickins@tiscali.co.uk> CC: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> CC: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-09-24memory controller: soft limit reclaim on contentionBalbir Singh
Implement reclaim from groups over their soft limit Permit reclaim from memory cgroups on contention (via the direct reclaim path). memory cgroup soft limit reclaim finds the group that exceeds its soft limit by the largest number of pages and reclaims pages from it and then reinserts the cgroup into its correct place in the rbtree. Add additional checks to mem_cgroup_hierarchical_reclaim() to detect long loops in case all swap is turned off. The code has been refactored and the loop check (loop < 2) has been enhanced for soft limits. For soft limits, we try to do more targetted reclaim. Instead of bailing out after two loops, the routine now reclaims memory proportional to the size by which the soft limit is exceeded. The proportion has been empirically determined. [akpm@linux-foundation.org: build fix] [kamezawa.hiroyu@jp.fujitsu.com: fix softlimit css refcnt handling] [nishimura@mxp.nes.nec.co.jp: refcount of the "victim" should be decremented before exiting the loop] Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18memcg: add file-based RSS accountingBalbir Singh
Add file RSS tracking per memory cgroup We currently don't track file RSS, the RSS we report is actually anon RSS. All the file mapped pages, come in through the page cache and get accounted there. This patch adds support for accounting file RSS pages. It should 1. Help improve the metrics reported by the memory resource controller 2. Will form the basis for a future shared memory accounting heuristic that has been proposed by Kamezawa. Unfortunately, we cannot rename the existing "rss" keyword used in memory.stat to "anon_rss". We however, add "mapped_file" data and hope to educate the end user through documentation. [hugh.dickins@tiscali.co.uk: fix mem_cgroup_update_mapped_file_stat oops] Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.cn> Cc: Paul Menage <menage@google.com> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16vmscan: evict use-once pages firstRik van Riel
When the file LRU lists are dominated by streaming IO pages, evict those pages first, before considering evicting other pages. This should be safe from deadlocks or performance problems because only three things can happen to an inactive file page: 1) referenced twice and promoted to the active list 2) evicted by the pageout code 3) under IO, after which it will get evicted or promoted The pages freed in this way can either be reused for streaming IO, or allocated for something else. If the pages are used for streaming IO, this pageout pattern continues. Otherwise, we will fall back to the normal pageout pattern. Signed-off-by: Rik van Riel <riel@redhat.com> Reported-by: Elladan <elladan@eskimo.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-02memcg: fix mem_cgroup_shrink_usage()Daisuke Nishimura
Current mem_cgroup_shrink_usage() has two problems. 1. It doesn't call mem_cgroup_out_of_memory and doesn't update last_oom_jiffies, so pagefault_out_of_memory invokes global OOM. 2. Considering hierarchy, shrinking has to be done from the mem_over_limit, not from the memcg which the page would be charged to. mem_cgroup_try_charge_swapin() does all of these things properly, so we use it and call cancel_charge_swapin when it succeeded. The name of "shrink_usage" is not appropriate for this behavior, so we change it too. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.cn> Cc: Paul Menage <menage@google.com> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21memcg: use rcu_dereference to access mm->ownerKAMEZAWA Hiroyuki
mm->owner should be accessed with rcu_dereference(). Reported-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02memcg: remove mem_cgroup_reclaim_imbalance() remnantsKOSAKI Motohiro
commit 4f98a2fee8acdb4ac84545df98cccecfd130f8db (vmscan: split LRU lists into anon & file sets) removed mem_cgroup_reclaim_imbalance(), but there are some leftovers in memcontrol.h. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02memcg: remove mem_cgroup_calc_mapped_ratio()KOSAKI Motohiro
Currently, mem_cgroup_calc_mapped_ratio() is unused at all. it can be removed and KAMEZAWA-san suggested it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02memcg: show memcg information during OOMBalbir Singh
Add RSS and swap to OOM output from memcg Display memcg values like failcnt, usage and limit when an OOM occurs due to memcg. Thanks to Johannes Weiner, Li Zefan, David Rientjes, Kamezawa Hiroyuki, Daisuke Nishimura and KOSAKI Motohiro for review. Sample output ------------- Task in /a/x killed as a result of limit of /a memory: usage 1048576kB, limit 1048576kB, failcnt 4183 memory+swap: usage 1400964kB, limit 9007199254740991kB, failcnt 0 [akpm@linux-foundation.org: compilation fix] [akpm@linux-foundation.org: fix kerneldoc and whitespace] [akpm@linux-foundation.org: add printk facility level] Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: fix shmem's swap accountingKAMEZAWA Hiroyuki
Now, you can see following even when swap accounting is enabled. 1. Create Group 01, and 02. 2. allocate a "file" on tmpfs by a task under 01. 3. swap out the "file" (by memory pressure) 4. Read "file" from a task in group 02. 5. the charge of "file" is moved to group 02. This is not ideal behavior. This is because SwapCache which was loaded by read-ahead is not taken into account.. This is a patch to fix shmem's swapcache behavior. - remove mem_cgroup_cache_charge_swapin(). - Add SwapCache handler routine to mem_cgroup_cache_charge(). By this, shmem's file cache is charged at add_to_page_cache() with GFP_NOWAIT. - pass the page of swapcache to shrink_mem_cgroup. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: remove mem_cgroup_try_chargeDaisuke Nishimura
After previous patch, mem_cgroup_try_charge is not used by anyone, so we can remove it. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: fix calculation of active_ratioKOSAKI Motohiro
Currently, inactive_ratio of memcg is calculated at setting limit. because page_alloc.c does so and current implementation is straightforward porting. However, memcg introduced hierarchy feature recently. In hierarchy restriction, memory limit is not only decided memory.limit_in_bytes of current cgroup, but also parent limit and sibling memory usage. Then, The optimal inactive_ratio is changed frequently. So, everytime calculation is better. Tested-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: remove mem_cgroup_cal_reclaim()KOSAKI Motohiro
Now, get_scan_ratio() return correct value although memcg reclaim. Then, mem_cgroup_calc_reclaim() can be removed. So, memcg reclaim get the same capability of anon/file reclaim balancing as global reclaim now. Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: add zone_reclaim_statKOSAKI Motohiro
Introduce mem_cgroup_per_zone::reclaim_stat member and its statics collecting function. Now, get_scan_ratio() can calculate correct value on memcg reclaim. [hugh@veritas.com: avoid reclaim_stat oops when disabled] Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: add mem_cgroup_zone_nr_pages()KOSAKI Motohiro
Introduce mem_cgroup_zone_nr_pages(). It is called by zone_nr_pages() helper function. This patch doesn't have any behavior change. Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: add inactive_anon_is_low()KOSAKI Motohiro
The inactive_anon_is_low() is key component of active/inactive anon balancing on reclaim. However current inactive_anon_is_low() function only consider global reclaim. Therefore, we need following ugly scan_global_lru() condition. if (lru == LRU_ACTIVE_ANON && (!scan_global_lru(sc) || inactive_anon_is_low(zone))) { shrink_active_list(nr_to_scan, zone, sc, priority, file); return 0; it cause that memcg reclaim always deactivate pages when shrink_list() is called. To make mem_cgroup_inactive_anon_is_low() improve active/inactive anon balancing of memcgroup. Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: "Pekka Enberg" <penberg@cs.helsinki.fi> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: revert gfp mask fixKAMEZAWA Hiroyuki
My patch, memcg-fix-gfp_mask-of-callers-of-charge.patch changed gfp_mask of callers of charge to be GFP_HIGHUSER_MOVABLE for showing what will happen at memory reclaim. But in recent discussion, it's NACKed because it sounds ugly. This patch is for reverting it and add some clean up to gfp_mask of callers of charge. No behavior change but need review before generating HUNK in deep queue. This patch also adds explanation to meaning of gfp_mask passed to charge functions in memcontrol.h. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: avoid unnecessary system-wide-oom-killerKAMEZAWA Hiroyuki
Current mmtom has new oom function as pagefault_out_of_memory(). It's added for select bad process rathar than killing current. When memcg hit limit and calls OOM at page_fault, this handler called and system-wide-oom handling happens. (means kernel panics if panic_on_oom is true....) To avoid overkill, check memcg's recent behavior before starting system-wide-oom. And this patch also fixes to guarantee "don't accnout against process with TIF_MEMDIE". This is necessary for smooth OOM. [akpm@linux-foundation.org: build fix] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Jan Blunck <jblunck@suse.de> Cc: Hirokazu Takahashi <taka@valinux.co.jp> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcontrol: rcu_read_lock() to protect mm_match_cgroup()Lai Jiangshan
mm_match_cgroup() calls cgroup_subsys_state(). We must use rcu_read_lock() to protect cgroup_subsys_state(). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: add mem_cgroup_disabled()Hirokazu Takahashi
We check mem_cgroup is disabled or not by checking mem_cgroup_subsys.disabled. I think it has more references than expected, now. replacing if (mem_cgroup_subsys.disabled) with if (mem_cgroup_disabled()) give us good look, I think. [kamezawa.hiroyu@jp.fujitsu.com: fix typo] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: synchronized LRUKAMEZAWA Hiroyuki
A big patch for changing memcg's LRU semantics. Now, - page_cgroup is linked to mem_cgroup's its own LRU (per zone). - LRU of page_cgroup is not synchronous with global LRU. - page and page_cgroup is one-to-one and statically allocated. - To find page_cgroup is on what LRU, you have to check pc->mem_cgroup as - lru = page_cgroup_zoneinfo(pc, nid_of_pc, zid_of_pc); - SwapCache is handled. And, when we handle LRU list of page_cgroup, we do following. pc = lookup_page_cgroup(page); lock_page_cgroup(pc); .....................(1) mz = page_cgroup_zoneinfo(pc); spin_lock(&mz->lru_lock); .....add to LRU spin_unlock(&mz->lru_lock); unlock_page_cgroup(pc); But (1) is spin_lock and we have to be afraid of dead-lock with zone->lru_lock. So, trylock() is used at (1), now. Without (1), we can't trust "mz" is correct. This is a trial to remove this dirty nesting of locks. This patch changes mz->lru_lock to be zone->lru_lock. Then, above sequence will be written as spin_lock(&zone->lru_lock); # in vmscan.c or swap.c via global LRU mem_cgroup_add/remove/etc_lru() { pc = lookup_page_cgroup(page); mz = page_cgroup_zoneinfo(pc); if (PageCgroupUsed(pc)) { ....add to LRU } spin_lock(&zone->lru_lock); # in vmscan.c or swap.c via global LRU This is much simpler. (*) We're safe even if we don't take lock_page_cgroup(pc). Because.. 1. When pc->mem_cgroup can be modified. - at charge. - at account_move(). 2. at charge the PCG_USED bit is not set before pc->mem_cgroup is fixed. 3. at account_move() the page is isolated and not on LRU. Pros. - easy for maintenance. - memcg can make use of laziness of pagevec. - we don't have to duplicated LRU/Active/Unevictable bit in page_cgroup. - LRU status of memcg will be synchronized with global LRU's one. - # of locks are reduced. - account_move() is simplified very much. Cons. - may increase cost of LRU rotation. (no impact if memcg is not configured.) Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: mem+swap controller coreKAMEZAWA Hiroyuki
This patch implements per cgroup limit for usage of memory+swap. However there are SwapCache, double counting of swap-cache and swap-entry is avoided. Mem+Swap controller works as following. - memory usage is limited by memory.limit_in_bytes. - memory + swap usage is limited by memory.memsw_limit_in_bytes. This has following benefits. - A user can limit total resource usage of mem+swap. Without this, because memory resource controller doesn't take care of usage of swap, a process can exhaust all the swap (by memory leak.) We can avoid this case. And Swap is shared resource but it cannot be reclaimed (goes back to memory) until it's used. This characteristic can be trouble when the memory is divided into some parts by cpuset or memcg. Assume group A and group B. After some application executes, the system can be.. Group A -- very large free memory space but occupy 99% of swap. Group B -- under memory shortage but cannot use swap...it's nearly full. Ability to set appropriate swap limit for each group is required. Maybe someone wonder "why not swap but mem+swap ?" - The global LRU(kswapd) can swap out arbitrary pages. Swap-out means to move account from memory to swap...there is no change in usage of mem+swap. In other words, when we want to limit the usage of swap without affecting global LRU, mem+swap limit is better than just limiting swap. Accounting target information is stored in swap_cgroup which is per swap entry record. Charge is done as following. map - charge page and memsw. unmap - uncharge page/memsw if not SwapCache. swap-out (__delete_from_swap_cache) - uncharge page - record mem_cgroup information to swap_cgroup. swap-in (do_swap_page) - charged as page and memsw. record in swap_cgroup is cleared. memsw accounting is decremented. swap-free (swap_free()) - if swap entry is freed, memsw is uncharged by PAGE_SIZE. There are people work under never-swap environments and consider swap as something bad. For such people, this mem+swap controller extension is just an overhead. This overhead is avoided by config or boot option. (see Kconfig. detail is not in this patch.) TODO: - maybe more optimization can be don in swap-in path. (but not very safe.) But we just do simple accounting at this stage. [nishimura@mxp.nes.nec.co.jp: make resize limit hold mutex] [hugh@veritas.com: memswap controller core swapcache fixes] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: mem+swap controller KconfigKAMEZAWA Hiroyuki
Config and control variable for mem+swap controller. This patch adds CONFIG_CGROUP_MEM_RES_CTLR_SWAP (memory resource controller swap extension.) For accounting swap, it's obvious that we have to use additional memory to remember "who uses swap". This adds more overhead. So, it's better to offer "choice" to users. This patch adds 2 choices. This patch adds 2 parameters to enable swap extension or not. - CONFIG - boot option Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: simple migration handlingKAMEZAWA Hiroyuki
Now, management of "charge" under page migration is done under following manner. (Assume migrate page contents from oldpage to newpage) before - "newpage" is charged before migration. at success. - "oldpage" is uncharged at somewhere(unmap, radix-tree-replace) at failure - "newpage" is uncharged. - "oldpage" is charged if necessary (*1) But (*1) is not reliable....because of GFP_ATOMIC. This patch tries to change behavior as following by charge/commit/cancel ops. before - charge PAGE_SIZE (no target page) success - commit charge against "newpage". failure - commit charge against "oldpage". (PCG_USED bit works effectively to avoid double-counting) - if "oldpage" is obsolete, cancel charge of PAGE_SIZE. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: introduce charge-commit-cancel style of functionsKAMEZAWA Hiroyuki
There is a small race in do_swap_page(). When the page swapped-in is charged, the mapcount can be greater than 0. But, at the same time some process (shares it ) call unmap and make mapcount 1->0 and the page is uncharged. CPUA CPUB mapcount == 1. (1) charge if mapcount==0 zap_pte_range() (2) mapcount 1 => 0. (3) uncharge(). (success) (4) set page's rmap() mapcount 0=>1 Then, this swap page's account is leaked. For fixing this, I added a new interface. - charge account to res_counter by PAGE_SIZE and try to free pages if necessary. - commit register page_cgroup and add to LRU if necessary. - cancel uncharge PAGE_SIZE because of do_swap_page failure. CPUA (1) charge (always) (2) set page's rmap (mapcount > 0) (3) commit charge was necessary or not after set_pte(). This protocol uses PCG_USED bit on page_cgroup for avoiding over accounting. Usual mem_cgroup_charge_common() does charge -> commit at a time. And this patch also adds following function to clarify all charges. - mem_cgroup_newpage_charge() ....replacement for mem_cgroup_charge() called against newly allocated anon pages. - mem_cgroup_charge_migrate_fixup() called only from remove_migration_ptes(). we'll have to rewrite this later.(this patch just keeps old behavior) This function will be removed by additional patch to make migration clearer. Good for clarifying "what we do" Then, we have 4 following charge points. - newpage - swap-in - add-to-cache. - migration. [akpm@linux-foundation.org: add missing inline directives to stubs] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20memcg: allocate all page_cgroup at bootKAMEZAWA Hiroyuki
Allocate all page_cgroup at boot and remove page_cgroup poitner from struct page. This patch adds an interface as struct page_cgroup *lookup_page_cgroup(struct page*) All FLATMEM/DISCONTIGMEM/SPARSEMEM and MEMORY_HOTPLUG is supported. Remove page_cgroup pointer reduces the amount of memory by - 4 bytes per PAGE_SIZE. - 8 bytes per PAGE_SIZE if memory controller is disabled. (even if configured.) On usual 8GB x86-32 server, this saves 8MB of NORMAL_ZONE memory. On my x86-64 server with 48GB of memory, this saves 96MB of memory. I think this reduction makes sense. By pre-allocation, kmalloc/kfree in charge/uncharge are removed. This means - we're not necessary to be afraid of kmalloc faiulre. (this can happen because of gfp_mask type.) - we can avoid calling kmalloc/kfree. - we can avoid allocating tons of small objects which can be fragmented. - we can know what amount of memory will be used for this extra-lru handling. I added printk message as "allocated %ld bytes of page_cgroup" "please try cgroup_disable=memory option if you don't want" maybe enough informative for users. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20Unevictable LRU InfrastructureLee Schermerhorn
When the system contains lots of mlocked or otherwise unevictable pages, the pageout code (kswapd) can spend lots of time scanning over these pages. Worse still, the presence of lots of unevictable pages can confuse kswapd into thinking that more aggressive pageout modes are required, resulting in all kinds of bad behaviour. Infrastructure to manage pages excluded from reclaim--i.e., hidden from vmscan. Based on a patch by Larry Woodman of Red Hat. Reworked to maintain "unevictable" pages on a separate per-zone LRU list, to "hide" them from vmscan. Kosaki Motohiro added the support for the memory controller unevictable lru list. Pages on the unevictable list have both PG_unevictable and PG_lru set. Thus, PG_unevictable is analogous to and mutually exclusive with PG_active--it specifies which LRU list the page is on. The unevictable infrastructure is enabled by a new mm Kconfig option [CONFIG_]UNEVICTABLE_LRU. A new function 'page_evictable(page, vma)' in vmscan.c tests whether or not a page may be evictable. Subsequent patches will add the various !evictable tests. We'll want to keep these tests light-weight for use in shrink_active_list() and, possibly, the fault path. To avoid races between tasks putting pages [back] onto an LRU list and tasks that might be moving the page from non-evictable to evictable state, the new function 'putback_lru_page()' -- inverse to 'isolate_lru_page()' -- tests the "evictability" of a page after placing it on the LRU, before dropping the reference. If the page has become unevictable, putback_lru_page() will redo the 'putback', thus moving the page to the unevictable list. This way, we avoid "stranding" evictable pages on the unevictable list. [akpm@linux-foundation.org: fix fallout from out-of-order merge] [riel@redhat.com: fix UNEVICTABLE_LRU and !PROC_PAGE_MONITOR build] [nishimura@mxp.nes.nec.co.jp: remove redundant mapping check] [kosaki.motohiro@jp.fujitsu.com: unevictable-lru-infrastructure: putback_lru_page()/unevictable page handling rework] [kosaki.motohiro@jp.fujitsu.com: kill unnecessary lock_page() in vmscan.c] [kosaki.motohiro@jp.fujitsu.com: revert migration change of unevictable lru infrastructure] [kosaki.motohiro@jp.fujitsu.com: revert to unevictable-lru-infrastructure-kconfig-fix.patch] [kosaki.motohiro@jp.fujitsu.com: restore patch failure of vmstat-unevictable-and-mlocked-pages-vm-events.patch] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Debugged-by: Benjamin Kidwell <benjkidwell@yahoo.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20vmscan: split LRU lists into anon & file setsRik van Riel
Split the LRU lists in two, one set for pages that are backed by real file systems ("file") and one for pages that are backed by memory and swap ("anon"). The latter includes tmpfs. The advantage of doing this is that the VM will not have to scan over lots of anonymous pages (which we generally do not want to swap out), just to find the page cache pages that it should evict. This patch has the infrastructure and a basic policy to balance how much we scan the anon lists and how much we scan the file lists. The big policy changes are in separate patches. [lee.schermerhorn@hp.com: collect lru meminfo statistics from correct offset] [kosaki.motohiro@jp.fujitsu.com: prevent incorrect oom under split_lru] [kosaki.motohiro@jp.fujitsu.com: fix pagevec_move_tail() doesn't treat unevictable page] [hugh@veritas.com: memcg swapbacked pages active] [hugh@veritas.com: splitlru: BDI_CAP_SWAP_BACKED] [akpm@linux-foundation.org: fix /proc/vmstat units] [nishimura@mxp.nes.nec.co.jp: memcg: fix handling of shmem migration] [kosaki.motohiro@jp.fujitsu.com: adjust Quicklists field of /proc/meminfo] [kosaki.motohiro@jp.fujitsu.com: fix style issue of get_scan_ratio()] Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20vmscan: Use an indexed array for LRU variablesChristoph Lameter
Currently we are defining explicit variables for the inactive and active list. An indexed array can be more generic and avoid repeating similar code in several places in the reclaim code. We are saving a few bytes in terms of code size: Before: text data bss dec hex filename 4097753 573120 4092484 8763357 85b7dd vmlinux After: text data bss dec hex filename 4097729 573120 4092484 8763333 85b7c5 vmlinux Having an easy way to add new lru lists may ease future work on the reclaim code. Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25memcg: helper function for relcaim from shmem.KAMEZAWA Hiroyuki
A new call, mem_cgroup_shrink_usage() is added for shmem handling and relacing non-standard usage of mem_cgroup_charge/uncharge. Now, shmem calls mem_cgroup_charge() just for reclaim some pages from mem_cgroup. In general, shmem is used by some process group and not for global resource (like file caches). So, it's reasonable to reclaim pages from mem_cgroup where shmem is mainly used. [hugh@veritas.com: shmem_getpage release page sooner] [hugh@veritas.com: mem_cgroup_shrink_usage css_put] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: Paul Menage <menage@google.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25memcg: remove refcnt from page_cgroupKAMEZAWA Hiroyuki
memcg: performance improvements Patch Description 1/5 ... remove refcnt fron page_cgroup patch (shmem handling is fixed) 2/5 ... swapcache handling patch 3/5 ... add helper function for shmem's memory reclaim patch 4/5 ... optimize by likely/unlikely ppatch 5/5 ... remove redundunt check patch (shmem handling is fixed.) Unix bench result. == 2.6.26-rc2-mm1 + memory resource controller Execl Throughput 2915.4 lps (29.6 secs, 3 samples) C Compiler Throughput 1019.3 lpm (60.0 secs, 3 samples) Shell Scripts (1 concurrent) 5796.0 lpm (60.0 secs, 3 samples) Shell Scripts (8 concurrent) 1097.7 lpm (60.0 secs, 3 samples) Shell Scripts (16 concurrent) 565.3 lpm (60.0 secs, 3 samples) File Read 1024 bufsize 2000 maxblocks 1022128.0 KBps (30.0 secs, 3 samples) File Write 1024 bufsize 2000 maxblocks 544057.0 KBps (30.0 secs, 3 samples) File Copy 1024 bufsize 2000 maxblocks 346481.0 KBps (30.0 secs, 3 samples) File Read 256 bufsize 500 maxblocks 319325.0 KBps (30.0 secs, 3 samples) File Write 256 bufsize 500 maxblocks 148788.0 KBps (30.0 secs, 3 samples) File Copy 256 bufsize 500 maxblocks 99051.0 KBps (30.0 secs, 3 samples) File Read 4096 bufsize 8000 maxblocks 2058917.0 KBps (30.0 secs, 3 samples) File Write 4096 bufsize 8000 maxblocks 1606109.0 KBps (30.0 secs, 3 samples) File Copy 4096 bufsize 8000 maxblocks 854789.0 KBps (30.0 secs, 3 samples) Dc: sqrt(2) to 99 decimal places 126145.2 lpm (30.0 secs, 3 samples) INDEX VALUES TEST BASELINE RESULT INDEX Execl Throughput 43.0 2915.4 678.0 File Copy 1024 bufsize 2000 maxblocks 3960.0 346481.0 875.0 File Copy 256 bufsize 500 maxblocks 1655.0 99051.0 598.5 File Copy 4096 bufsize 8000 maxblocks 5800.0 854789.0 1473.8 Shell Scripts (8 concurrent) 6.0 1097.7 1829.5 ========= FINAL SCORE 991.3 == 2.6.26-rc2-mm1 + this set == Execl Throughput 3012.9 lps (29.9 secs, 3 samples) C Compiler Throughput 981.0 lpm (60.0 secs, 3 samples) Shell Scripts (1 concurrent) 5872.0 lpm (60.0 secs, 3 samples) Shell Scripts (8 concurrent) 1120.3 lpm (60.0 secs, 3 samples) Shell Scripts (16 concurrent) 578.0 lpm (60.0 secs, 3 samples) File Read 1024 bufsize 2000 maxblocks 1003993.0 KBps (30.0 secs, 3 samples) File Write 1024 bufsize 2000 maxblocks 550452.0 KBps (30.0 secs, 3 samples) File Copy 1024 bufsize 2000 maxblocks 347159.0 KBps (30.0 secs, 3 samples) File Read 256 bufsize 500 maxblocks 314644.0 KBps (30.0 secs, 3 samples) File Write 256 bufsize 500 maxblocks 151852.0 KBps (30.0 secs, 3 samples) File Copy 256 bufsize 500 maxblocks 101000.0 KBps (30.0 secs, 3 samples) File Read 4096 bufsize 8000 maxblocks 2033256.0 KBps (30.0 secs, 3 samples) File Write 4096 bufsize 8000 maxblocks 1611814.0 KBps (30.0 secs, 3 samples) File Copy 4096 bufsize 8000 maxblocks 847979.0 KBps (30.0 secs, 3 samples) Dc: sqrt(2) to 99 decimal places 128148.7 lpm (30.0 secs, 3 samples) INDEX VALUES TEST BASELINE RESULT INDEX Execl Throughput 43.0 3012.9 700.7 File Copy 1024 bufsize 2000 maxblocks 3960.0 347159.0 876.7 File Copy 256 bufsize 500 maxblocks 1655.0 101000.0 610.3 File Copy 4096 bufsize 8000 maxblocks 5800.0 847979.0 1462.0 Shell Scripts (8 concurrent) 6.0 1120.3 1867.2 ========= FINAL SCORE 1004.6 This patch: Remove refcnt from page_cgroup(). After this, * A page is charged only when !page_mapped() && no page_cgroup is assigned. * Anon page is newly mapped. * File page is added to mapping->tree. * A page is uncharged only when * Anon page is fully unmapped. * File page is removed from LRU. There is no change in behavior from user's view. This patch also removes unnecessary calls in rmap.c which was used only for refcnt mangement. [akpm@linux-foundation.org: fix warning] [hugh@veritas.com: fix shmem_unuse_inode charging] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: Paul Menage <menage@google.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25memcg: better migration handlingKAMEZAWA Hiroyuki
This patch changes page migration under memory controller to use a different algorithm. (thanks to Christoph for new idea.) Before: - page_cgroup is migrated from an old page to a new page. After: - a new page is accounted , no reuse of page_cgroup. Pros: - We can avoid compliated lock depndencies and races in migration. Cons: - new param to mem_cgroup_charge_common(). - mem_cgroup_getref() is added for handling ref_cnt ping-pong. This version simplifies complicated lock dependency in page migraiton under memory resource controller. new refcnt sequence is following. a mapped page: prepage_migration() ..... +1 to NEW page try_to_unmap() ..... all refs to OLD page is gone. move_pages() ..... +1 to NEW page if page cache. remap... ..... all refs from *map* is added to NEW one. end_migration() ..... -1 to New page. page's mapcount + (page_is_cache) refs are added to NEW one. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29cgroups: add an owner to the mm_structBalbir Singh
Remove the mem_cgroup member from mm_struct and instead adds an owner. This approach was suggested by Paul Menage. The advantage of this approach is that, once the mm->owner is known, using the subsystem id, the cgroup can be determined. It also allows several control groups that are virtually grouped by mm_struct, to exist independent of the memory controller i.e., without adding mem_cgroup's for each controller, to mm_struct. A new config option CONFIG_MM_OWNER is added and the memory resource controller selects this config option. This patch also adds cgroup callbacks to notify subsystems when mm->owner changes. The mm_cgroup_changed callback is called with the task_lock() of the new task held and is called just prior to changing the mm->owner. I am indebted to Paul Menage for the several reviews of this patchset and helping me make it lighter and simpler. This patch was tested on a powerpc box, it was compiled with both the MM_OWNER config turned on and off. After the thread group leader exits, it's moved to init_css_state by cgroup_exit(), thus all future charges from runnings threads would be redirected to the init_css_set's subsystem. Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelianov <xemul@openvz.org> Cc: Hugh Dickins <hugh@veritas.com> Cc: Sudhir Kumar <skumar@linux.vnet.ibm.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: Hirokazu Takahashi <taka@valinux.co.jp> Cc: David Rientjes <rientjes@google.com>, Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Reviewed-by: Paul Menage <menage@google.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04memcg: remove mem_cgroup_unchargeHugh Dickins
Nothing uses mem_cgroup_uncharge apart from mem_cgroup_uncharge_page, (a trivial wrapper around it) and mem_cgroup_end_migration (which does the same as mem_cgroup_uncharge_page). And it often ends up having to lock just to let its caller unlock. Remove it (but leave the silly locking until a later patch). Moved mem_cgroup_cache_charge next to mem_cgroup_charge in memcontrol.h. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: David Rientjes <rientjes@google.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hirokazu Takahashi <taka@valinux.co.jp> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04memcg: bad page if page_cgroup when freeHugh Dickins
Replace free_hot_cold_page's VM_BUG_ON(page_get_page_cgroup(page)) by a "Bad page state" and clear: most users don't have CONFIG_DEBUG_VM on, and if it were set here, it'd likely cause corruption when the page is reused. Don't use page_assign_page_cgroup to clear it: that should be private to memcontrol.c, and always called with the lock taken; and memmap_init_zone doesn't need it either - like page->mapping and other pointers throughout the kernel, Linux assumes pointers in zeroed structures are NULL pointers. Instead use page_reset_bad_cgroup, added to memcontrol.h for this only. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: David Rientjes <rientjes@google.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hirokazu Takahashi <taka@valinux.co.jp> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04memcg: move_lists on page not page_cgroupHugh Dickins
Each caller of mem_cgroup_move_lists is having to use page_get_page_cgroup: it's more convenient if it acts upon the page itself not the page_cgroup; and in a later patch this becomes important to handle within memcontrol.c. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: David Rientjes <rientjes@google.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hirokazu Takahashi <taka@valinux.co.jp> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04memcg: mm_match_cgroup not vm_match_cgroupHugh Dickins
vm_match_cgroup is a perverse name for a macro to match mm with cgroup: rename it mm_match_cgroup, matching mm_init_cgroup and mm_free_cgroup. Signed-off-by: Hugh Dickins <hugh@veritas.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hirokazu Takahashi <taka@valinux.co.jp> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04Memory controller: rename to Memory Resource ControllerBalbir Singh
Rename Memory Controller to Memory Resource Controller. Reflect the same changes in the CONFIG definition for the Memory Resource Controller. Group together the config options for Resource Counters and Memory Resource Controller. Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-23sparc: fix buildDavid Rientjes
Fix build failure on sparc: In file included from include/linux/mm.h:39, from include/linux/memcontrol.h:24, from include/linux/swap.h:8, from include/linux/suspend.h:7, from init/do_mounts.c:6: include/asm/pgtable.h:344: warning: parameter names (without types) in function declaration include/asm/pgtable.h:345: warning: parameter names (without types) in function declaration include/asm/pgtable.h:346: error: expected '=', ',', ';', 'asm' or '__attribute__' before '___f___swp_entry' viro sayeth: I've run allmodconfig builds on a bunch of target, FWIW (essentially the same patch). Note that these includes are recent addition caused by added inline function that had since then become a define. So while I agree with your comments in general, in _this_ case it's pretty safe. The commit that had done it is 3062fc67dad01b1d2a15d58c709eff946389eca4 ("memcontrol: move mm_cgroup to header file") and the switch to #define is in commit 60c12b1202a60eabb1c61317e5d2678fcea9893f ("memcontrol: add vm_match_cgroup()") (BTW, that probably warranted mentioning in the changelog of the latter). Cc: Adrian Bunk <bunk@kernel.org> Cc: Robert Reif <reif@earthlink.net> Signed-off-by: David Rientjes <rientjes@google.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-09memcontrol: add vm_match_cgroup()David Rientjes
mm_cgroup() is exclusively used to test whether an mm's mem_cgroup pointer is pointing to a specific cgroup. Instead of returning the pointer, we can just do the test itself in a new macro: vm_match_cgroup(mm, cgroup) returns non-zero if the mm's mem_cgroup points to cgroup. Otherwise it returns zero. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Memory controller remove control_type featureBalbir Singh
Based on the discussion at http://lkml.org/lkml/2007/12/20/383, it was felt that control_type might not be a good thing to implement right away. We can add this flexibility at a later point when required. Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07per-zone and reclaim enhancements for memory controller: calculate the ↵KAMEZAWA Hiroyuki
number of pages to be scanned per cgroup Define function for calculating the number of scan target on each Zone/LRU. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Paul Menage <menage@google.com> Cc: Pavel Emelianov <xemul@openvz.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07per-zone and reclaim enhancements for memory controller: remember reclaim ↵KAMEZAWA Hiroyuki
priority in memory cgroup Functions to remember reclaim priority per cgroup (as zone->prev_priority) [akpm@linux-foundation.org: build fixes] [akpm@linux-foundation.org: more build fixes] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Paul Menage <menage@google.com> Cc: Pavel Emelianov <xemul@openvz.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07per-zone and reclaim enhancements for memory controller: calculate ↵KAMEZAWA Hiroyuki
active/inactive imbalance per cgroup Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Paul Menage <menage@google.com> Cc: Pavel Emelianov <xemul@openvz.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
mapper_ratio per cgroup Define function for calculating mapped_ratio in memory cgroup. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Paul Menage <menage@google.com> Cc: Pavel Emelianov <xemul@openvz.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07bugfix for memory cgroup controller: migration under memory controller fixKAMEZAWA Hiroyuki
While using memory control cgroup, page-migration under it works as following. == 1. uncharge all refs at try to unmap. 2. charge regs again remove_migration_ptes() == This is simple but has following problems. == The page is uncharged and charged back again if *mapped*. - This means that cgroup before migration can be different from one after migration - If page is not mapped but charged as page cache, charge is just ignored (because not mapped, it will not be uncharged before migration) This is memory leak. == This patch tries to keep memory cgroup at page migration by increasing one refcnt during it. 3 functions are added. mem_cgroup_prepare_migration() --- increase refcnt of page->page_cgroup mem_cgroup_end_migration() --- decrease refcnt of page->page_cgroup mem_cgroup_page_migration() --- copy page->page_cgroup from old page to new page. During migration - old page is under PG_locked. - new page is under PG_locked, too. - both old page and new page is not on LRU. These 3 facts guarantee that page_cgroup() migration has no race. Tested and worked well in x86_64/fake-NUMA box. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelianov <xemul@openvz.org> Cc: Paul Menage <menage@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Kirill Korotaev <dev@sw.ru> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: David Rientjes <rientjes@google.com> Cc: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
