path: root/include/linux/lockd/bind.h
2008-12-23NLM: allow lockd requests from an unprivileged portChuck Lever
If the admin has specified the "noresvport" option for an NFS mount point, the kernel's NFS client uses an unprivileged source port for the main NFS transport. The kernel's lockd client should use an unprivileged port in this case as well. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-04NLM: Remove "proto" argument from lockd_up()Chuck Lever
Clean up: Now that lockd_up() starts listeners for both transports, the "proto" argument is no longer needed. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-10-03nfsd: common grace period controlJ. Bruce Fields
Rewrite grace period code to unify management of grace period across lockd and nfsd. The current code has lockd and nfsd cooperate to compute a grace period which is satisfactory to them both, and then individually enforce it. This creates a slight race condition, since the enforcement is not coordinated. It's also more complicated than necessary. Here instead we have lockd and nfsd each inform common code when they enter the grace period, and when they're ready to leave the grace period, and allow normal locking only after both of them are ready to leave. We also expect the locks_start_grace()/locks_end_grace() interface here to be simpler to build on for future cluster/high-availability work, which may require (for example) putting individual filesystems into grace, or enforcing grace periods across multiple cluster nodes. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-01-30NLM: Introduce an arguments structure for nlmclnt_init()Chuck Lever
Clean up: pass 5 arguments to nlmclnt_init() in a structure similar to the new nfs_client_initdata structure. Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
2008-01-30NLM/NFS: Use cached nlm_host when calling nlmclnt_proc()Chuck Lever
Now that each NFS mount point caches its own nlm_host structure, it can be passed to nlmclnt_proc() for each lock request. By pinning an nlm_host for each mount point, we trade the overhead of looking up or creating a fresh nlm_host struct during every NLM procedure call for a little extra memory. We also restrict the nlmclnt_proc symbol to limit the use of this call to in-tree modules. Note that nlm_lookup_host() (just removed from the client's per-request NLM processing) could also trigger an nlm_host garbage collection. Now client-side nlm_host garbage collection occurs only during NFS mount processing. Since the NFS client now holds a reference on these nlm_host structures, they wouldn't have been affected by garbage collection anyway. Given that nlm_lookup_host() reorders the global nlm_host chain after every successful lookup, and that a garbage collection could be triggered during the call, we've removed a significant amount of per-NLM-request CPU processing overhead. Sidebar: there are only a few remaining references to the internals of NFS inodes in the client-side NLM code. The only references I found are related to extracting or comparing the inode's file handle via NFS_FH(). One is in nlmclnt_grant(); the other is in nlmclnt_setlockargs(). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NLM: Introduce external nlm_host set-up and tear-down functionsChuck Lever
We would like to remove the per-lock-operation nlm_lookup_host() call from nlmclnt_proc(). The new architecture pins an nlm_host structure to each NFS client superblock that has the "lock" mount option set. The NFS client passes in the pinned nlm_host structure during each call to nlmclnt_proc(). NFS client unmount processing "puts" the nlm_host so it can be garbage- collected later. This patch introduces externally callable NLM functions that handle mount-time nlm_host set up and tear-down. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-17knfsd: lockd: nfsd4: use same grace period for lockd and nfsd4Marc Eshel
Both lockd and (in the nfsv4 case) nfsd enforce a "grace period" after reboot, during which clients may reclaim locks from the previous server instance, but may not acquire new locks. Currently the lockd and nfsd enforce grace periods of different lengths. This may cause problems when we reboot a server with both v2/v3 and v4 clients. For example, if the lockd grace period is shorter (as is likely the case), then a v3 client might acquire a new lock that conflicts with a lock already held (but not yet reclaimed) by a v4 client. This patch calculates a lease time that lockd and nfsd can both use. Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-13[PATCH] lockd endianness annotationsAl Viro
Annotated, all places switched to keeping status net-endian. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-17[PATCH] knfsd: Allow lockd to drop replies as appropriateNeilBrown
It is possible for the ->fopen callback from lockd into nfsd to find that an answer cannot be given straight away (an upcall is needed) and so the request has to be 'dropped', to be retried later. That error status is not currently propagated back. So: Change nlm_fopen to return nlm error codes (rather than a private protocol) and define a new nlm_drop_reply code. Cause nlm_drop_reply to cause the rpc request to get rpc_drop_reply when this error comes back. Cause svc_process to drop a request which returns a status of rpc_drop_reply. [akpm@osdl.org: fix warning storm] Cc: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] knfsd: be more selective in which sockets lockd listens onNeilBrown
Currently lockd listens on UDP always, and TCP if CONFIG_NFSD_TCP is set. However as lockd performs services of the client as well, this is a problem. If CONFIG_NfSD_TCP is not set, and a tcp mount is used, the server will not be able to call back to lockd. So: - add an option to lockd_up saying which protocol is needed - Always open sockets for which an explicit port was given, otherwise only open a socket of the type required - Change nfsd to do one lockd_up per socket rather than one per thread. This - removes the dependancy on CONFIG_NFSD_TCP - means that lockd may open sockets other than at startup - means that lockd will *not* listen on UDP if the only mounts are TCP mount (and nfsd hasn't started). The latter is the only one that concerns me at all - I don't know if this might be a problem with some servers. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
