path: root/include/linux/linkage.h
2007-10-22add WEAK() for creating weak asm labelsRusty Russell
Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-26[PATCH] x86: error_code is not safe for kprobesPrasanna S.P
This patch moves the entry.S:error_entry to .kprobes.text section, since code marked unsafe for kprobes jumps directly to entry.S::error_entry, that must be marked unsafe as well. This patch also moves all the ".previous.text" asm directives to ".previous" for kprobes section. AK: Following a similar i386 patch from Chuck Ebbert AK: Also merged Jeremy's fix in. +From: Jeremy Fitzhardinge <jeremy@goop.org> KPROBE_ENTRY does a .section .kprobes.text, and expects its users to do a .previous at the end of the function. Unfortunately, if any code within the function switches sections, for example .fixup, then the .previous ends up putting all subsequent code into .fixup. Worse, any subsequent .fixup code gets intermingled with the code its supposed to be fixing (which is also in .fixup). It's surprising this didn't cause more havok. The fix is to use .pushsection/.popsection, so this stuff nests properly. A further cleanup would be to get rid of all .section/.previous pairs, since they're inherently fragile. +From: Chuck Ebbert <76306.1226@compuserve.com> Because code marked unsafe for kprobes jumps directly to entry.S::error_code, that must be marked unsafe as well. The easiest way to do that is to move the page fault entry point to just before error_code and let it inherit the same section. Also moved all the ".previous" asm directives for kprobes sections to column 1 and removed ".text" from them. Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-24[PATCH] abstract type/size specification for assemblyJan Beulich
Provide abstraction for generating type and size information of assembly routines and data, while permitting architectures to override these defaults. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: "Russell King" <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: "Andi Kleen" <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Kprobes: prevent possible race conditions genericPrasanna S Panchamukhi
There are possible race conditions if probes are placed on routines within the kprobes files and routines used by the kprobes. For example if you put probe on get_kprobe() routines, the system can hang while inserting probes on any routine such as do_fork(). Because while inserting probes on do_fork(), register_kprobes() routine grabs the kprobes spin lock and executes get_kprobe() routine and to handle probe of get_kprobe(), kprobes_handler() gets executed and tries to grab kprobes spin lock, and spins forever. This patch avoids such possible race conditions by preventing probes on routines within the kprobes file and routines used by kprobes. I have modified the patches as per Andi Kleen's suggestion to move kprobes routines and other routines used by kprobes to a seperate section .kprobes.text. Also moved page fault and exception handlers, general protection fault to .kprobes.text section. These patches have been tested on i386, x86_64 and ppc64 architectures, also compiled on ia64 and sparc64 architectures. Signed-off-by: Prasanna S Panchamukhi <prasanna@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
