path: root/include/linux/libata.h
2013-01-14[libata] replace sata_settings with devslp_timingShane Huang
NCQ capability was used to check availability of SATA Settings page from Identify Device Data Log, which contains DevSlp timing variables. It does not work on some HDDs and leads to error messages. IDENTIFY word 78 bit 5(Hardware Feature Control) can't work either because it is only the sufficient condition of Identify Device data log, not the necessary condition. This patch replaced ata_device->sata_settings with ->devslp_timing to only save DevSlp timing variables(8 bytes), instead of the whole SATA Settings page(512 bytes). Addresses https://bugzilla.kernel.org/show_bug.cgi?id=51881 Reported-by: Borislav Petkov <bp@alien8.de> Signed-off-by: Shane Huang <shane.huang@amd.com> Cc: stable@vger.kernel.org Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-12-03libata: implement ata_platform_remove_one()Brian Norris
This relatively simple boiler-plate code is repeated in several platform drivers. We should implement a common version in libata. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-12-03libata: restore acpi disable functionalityAaron Lu
Commit 66fa7f215 "libata-acpi: improve ACPI disabling" introdcued the behaviour of disabling ATA ACPI if ata_acpi_on_devcfg failed the 2nd time, but commit 30dcf76ac dropped this behaviour and this caused problem for Dimitris Damigos, where his laptop can not resume correctly. The bugzilla page for it is: https://bugzilla.kernel.org/show_bug.cgi?id=49331 The problem is, ata_dev_push_id will fail the 2nd time it is invoked, and due to disabling ACPI code is dropped, ata_acpi_on_devcfg which calls ata_dev_push_id will keep failing and eventually made the device disabled. This patch restores the original behaviour, if acpi failed the 2nd time, disable acpi functionality for the device(and we do not event need to add a debug message for this as it is still there ;-). Reported-by: Dimitris Damigos <damigos@freemail.gr> Signed-off-by: Aaron Lu <aaron.lu@intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-10-02Merge tag 'scsi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull first round of SCSI updates from James Bottomley: "This is a large set of updates, mostly for drivers (qla2xxx [including support for new 83xx based card], qla4xxx, mpt2sas, bfa, zfcp, hpsa, be2iscsi, isci, lpfc, ipr, ibmvfc, ibmvscsi, megaraid_sas). There's also a rework for tape adding virtually unlimited numbers of tape drives plus a set of dif fixes for sd and a fix for a live lock on hot remove of SCSI devices. This round includes a signed tag pull of isci-for-3.6 Signed-off-by: James Bottomley <JBottomley@Parallels.com>" Fix up trivial conflict in drivers/scsi/qla2xxx/qla_nx.c due to new PCI helper function use in a function that was removed by this pull. * tag 'scsi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (198 commits) [SCSI] st: remove st_mutex [SCSI] sd: Ensure we correctly disable devices with unknown protection type [SCSI] hpsa: gen8plus Smart Array IDs [SCSI] qla4xxx: Update driver version to 5.03.00-k1 [SCSI] qla4xxx: Disable generating pause frames for ISP83XX [SCSI] qla4xxx: Fix double clearing of risc_intr for ISP83XX [SCSI] qla4xxx: IDC implementation for Loopback [SCSI] qla4xxx: update copyrights in LICENSE.qla4xxx [SCSI] qla4xxx: Fix panic while rmmod [SCSI] qla4xxx: Fail probe_adapter if IRQ allocation fails [SCSI] qla4xxx: Prevent MSI/MSI-X falling back to INTx for ISP82XX [SCSI] qla4xxx: Update idc reg in case of PCI AER [SCSI] qla4xxx: Fix double IDC locking in qla4_8xxx_error_recovery [SCSI] qla4xxx: Clear interrupt while unloading driver for ISP83XX [SCSI] qla4xxx: Print correct IDC version [SCSI] qla4xxx: Added new mbox cmd to pass driver version to FW [SCSI] scsi_dh_alua: Enable STPG for unavailable ports [SCSI] scsi_remove_target: fix softlockup regression on hot remove [SCSI] ibmvscsi: Fix host config length field overflow [SCSI] ibmvscsi: Remove backend abstraction ...
2012-09-13ahci: implement aggressive SATA device sleep supportShane Huang
Device Sleep is a feature as described in AHCI 1.3.1 Technical Proposal. This feature enables an HBA and SATA storage device to enter the DevSleep interface state, enabling lower power SATA-based systems. Aggressive Device Sleep enables the HBA to assert the DEVSLP signal as soon as there are no commands outstanding to the device and the port specific Device Sleep idle timer has expired. This enables autonomous entry into the DevSleep interface state without waiting for software in power sensitive systems. This patch enables Aggressive Device Sleep only if both host controller and device support it. Tested on AMD reference board together with Device Sleep supported device sample. Signed-off-by: Shane Huang <shane.huang@amd.com> Reviewed-by: Aaron Lu <aaron.lwe@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-08-24[SCSI] libsas, ipr: cleanup ata_host flags initialization via ata_host_initDan Williams
libsas and ipr pass flags to ata_host_init that are meant for the port. ata_host flags: ATA_HOST_SIMPLEX = (1 << 0), /* Host is simplex, one DMA channel per host only */ ATA_HOST_STARTED = (1 << 1), /* Host started */ ATA_HOST_PARALLEL_SCAN = (1 << 2), /* Ports on this host can be scanned in parallel */ ATA_HOST_IGNORE_ATA = (1 << 3), /* Ignore ATA devices on this host. */ flags passed by libsas: ATA_FLAG_SATA = (1 << 1), ATA_FLAG_PIO_DMA = (1 << 7), /* PIO cmds via DMA */ ATA_FLAG_NCQ = (1 << 10), /* host supports NCQ */ The only one that aliases is ATA_HOST_STARTED which is a 'don't care' in the libsas and ipr cases since ata_hosts from these sources are not registered with libata. Reported-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Brian King <brking@us.ibm.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-08-24[SCSI] libata: export ata_port suspend/resume infrastructure for sasDan Williams
Reuse ata_port_{suspend|resume}_common for sas. This path is chosen over adding coordination between ata-tranport and sas-transport because libsas wants to revalidate the domain at resume-time at the host level. It can not validate links have resumed properly until libata has had a chance to perform its revalidation, and any sane placing of an ata_port in the sas-transport model would delay it's resumption until after the host. Export the common portion of port suspend/resume (bypass pm_runtime), and allow sas to perform these operations asynchronously (similar to the libsas async-ata probe implmentation). Async operation is determined by having an external, rather than stack based, location for storing the result of the operation. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Reviewed-by: Jacek Danecki <jacek.danecki@intel.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-08-24[SCSI] libata: reset onceDan Williams
Hotplug testing with libsas currently encounters a 55 second wait for link recovery to give up. In the case where the user trusts the response time of their devices permit the recovery attempts to be limited to one. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-07-25Merge branch 'master' [vanilla Linus master] into libata-dev.git/upstreamJeff Garzik
Two bits were appended to the end of the bitfield list in struct scsi_device. Resolve that conflict by including both bits. Conflicts: include/scsi/scsi_device.h
2012-07-20[SCSI] libata, libsas: introduce sched_eh and end_eh port opsDan Williams
When managing shost->host_eh_scheduled libata assumes that there is a 1:1 shost-to-ata_port relationship. libsas creates a 1:N relationship so it needs to manage host_eh_scheduled cumulatively at the host level. The sched_eh and end_eh port port ops allow libsas to track when domain devices enter/leave the "eh-pending" state under ha->lock (previously named ha->state_lock, but it is no longer just a lock for ha->state changes). Since host_eh_scheduled indicates eh without backing commands pinning the device it can be deallocated at any time. Move the taking of the domain_device reference under the port_lock to guarantee that the ata_port stays around for the duration of eh. Reviewed-by: Jacek Danecki <jacek.danecki@intel.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-06-29libata: detect Device Attention supportLin Ming
Add a new flag ATA_DFLAG_DA to indicate that device supports "Device Attention". Acked-by: Aaron Lu <aaron.lu@amd.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-06-29libata: migrate ACPI code over to new bindingsMatthew Garrett
Now that we have the ability to directly glue the ACPI namespace to the driver model in libata, we don't need the custom code to handle the same thing. Remove it and migrate the functions over to the new code. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Holger Macht <holger@homac.de> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-05-07libata: add a host flag to ignore detected ATA devicesAndy Whitcroft
Where devices are visible via more than one host we sometimes wish to indicate that cirtain devices should be ignored on a specific host. Add a host flag indicating that this host wishes to ignore ATA specific devices. Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-04-23[SCSI] libsas, libata: fix start of life for a sas ata_portDan Williams
This changes the ordering of initialization and probing events from: 1/ allocate rphy in PORTE_BYTES_DMAED, DISCE_REVALIDATE_DOMAIN 2/ allocate ata_port and schedule port probe in DISCE_PROBE ...to: 1/ allocate ata_port in PORTE_BYTES_DMAED, DISCE_REVALIDATE_DOMAIN 2/ allocate rphy in PORTE_BYTES_DMAED, DISCE_REVALIDATE_DOMAIN 3/ schedule port probe in DISCE_PROBE This ordering prevents PHYE_SIGNAL_LOSS_EVENTS from sneaking in to destrory ata devices before they have been fully initialized: BUG: unable to handle kernel paging request at 0000000000003b10 IP: [<ffffffffa0053d7e>] sas_ata_end_eh+0x12/0x5e [libsas] ... [<ffffffffa004d1af>] sas_unregister_common_dev+0x78/0xc9 [libsas] [<ffffffffa004d4d4>] sas_unregister_dev+0x4f/0xad [libsas] [<ffffffffa004d5b1>] sas_unregister_domain_devices+0x7f/0xbf [libsas] [<ffffffffa004c487>] sas_deform_port+0x61/0x1b8 [libsas] [<ffffffffa004bed0>] sas_phye_loss_of_signal+0x29/0x2b [libsas] ...and kills the awkward "sata domain_device briefly existing in the domain without an ata_port" state. Reported-by: Michal Kosciowski <michal.kosciowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-29[SCSI] libsas: async ata scanningDan Williams
libsas ata error handling is already async but this does not help the scan case. Move initial link recovery out from under host->scan_mutex, and delay synchronization with eh until after all port probe/recovery work has been queued. Device ordering is maintained with scan order by still calling sas_rphy_add() in order of domain discovery. Since we now scan the domain list when invoking libata-eh we need to be careful to check for fully initialized ata ports. Acked-by: Jack Wang <jack_wang@usish.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-19[SCSI] libsas: execute transport link resets with libata-eh via host workqueueDan Williams
Link resets leave ata affiliations intact, so arrange for libsas to make an effort to avoid dropping the device due to a slow-to-recover link. Towards this end carry out reset in the host workqueue so that it can check for ata devices and kick the reset request to libata. Hard resets, in contrast, bypass libata since they are meant for associating an ata device with another initiator in the domain (tears down affiliations). Need to add a new transport_sas_phy_reset() since the current sas_phy_reset() is a utility function to libsas lldds. They are not prepared for it to loop back into eh. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-10-31treewide: use __printf not __attribute__((format(printf,...)))Joe Perches
Standardize the style for compiler based printf format verification. Standardized the location of __printf too. Done via script and a little typing. $ grep -rPl --include=*.[ch] -w "__attribute__" * | \ grep -vP "^(tools|scripts|include/linux/compiler-gcc.h)" | \ xargs perl -n -i -e 'local $/; while (<>) { s/\b__attribute__\s*\(\s*\(\s*format\s*\(\s*printf\s*,\s*(.+)\s*,\s*(.+)\s*\)\s*\)\s*\)/__printf($1, $2)/g ; print; }' [akpm@linux-foundation.org: revert arch bits] Signed-off-by: Joe Perches <joe@perches.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-02[SCSI] libsas,libata: fix ->change_queue_{depth|type} for sata devicesDan Williams
Pass queue_depth change requests to libata, and prevent queue_type changes for ATA devices. Otherwise: 1/ we do not honor the libata specific restrictions on the queue depth 2/ libsas drivers that do not set sdev->tagged_supported are unable to change the queue_depth of ata devices via sysfs Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-23ata: Add and use ata_print_version_onceJoe Perches
Use a single mechanism to show driver version. Reduces text a tiny bit too. Remove uses of static int printed_version Add and use ata_print_version(const struct device *, const char *ver) and ata_print_version_once. $ size drivers/ata/built-in.* text data bss dec hex filename 544969 73893 116584 735446 b38d6 drivers/ata/built-in.allyesconfig.ata.o 543870 73893 116592 734355 b34ad drivers/ata/built-in.allyesconfig.print_once.o 141328 14689 4220 160237 271ed drivers/ata/built-in.defconfig.ata.o 141212 14689 4220 160121 27179 drivers/ata/built-in.defconfig.print_once.o Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-07-23ata: Convert ata_<foo>_printk(KERN_<LEVEL> to ata_<foo>_<level>Joe Perches
Saves text by removing nearly duplicated text format strings by creating ata_<foo>_printk functions and printf extension %pV. ata defconfig size shrinks ~5% (~8KB), allyesconfig ~2.5% (~13KB) Format string duplication comes from: #define ata_link_printk(link, lv, fmt, args...) do { \ if (sata_pmp_attached((link)->ap) || (link)->ap->slave_link) \ printk("%sata%u.%02u: "fmt, lv, (link)->ap->print_id, \ (link)->pmp , ##args); \ else \ printk("%sata%u: "fmt, lv, (link)->ap->print_id , ##args); \ } while(0) Coalesce long formats. $ size drivers/ata/built-in.* text data bss dec hex filename 544969 73893 116584 735446 b38d6 drivers/ata/built-in.allyesconfig.ata.o 558429 73893 117864 750186 b726a drivers/ata/built-in.allyesconfig.dev_level.o 141328 14689 4220 160237 271ed drivers/ata/built-in.defconfig.ata.o 149567 14689 4220 168476 2921c drivers/ata/built-in.defconfig.dev_level.o Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-05-19libata: Power off empty portsKristen Carlson Accardi
Give users the option of completely powering off unoccupied SATA ports using the existing min_power link_power_management_policy option. When the use selects this option on an empty port, we will power the port off by setting DET to off. For occupied ports, behavior is unchanged. Signed-off-by: Kristen Carlson Accardi <kristen@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-04-24libata: Implement ATA_FLAG_NO_DIPM and apply it to mcp65Tejun Heo
NVIDIA mcp65 familiy of controllers cause command timeouts when DIPM is used. Implement ATA_FLAG_NO_DIPM and apply it. This problem was reported by Stefan Bader in the following thread. http://thread.gmane.org/gmane.linux.ide/48841 stable: applicable to 2.6.37 and 38. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Stefan Bader <stefan.bader@canonical.com> Cc: stable@kernel.org Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-04-24libata: Kill unused ATA_DFLAG_{H|D}IPM flagsTejun Heo
ATA_DFLAG_{H|D}IPM flags are no longer used. Kill them. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-03-14libata-sff: add ata_sff_queue_work() & ata_sff_queue_delayed_work()Viresh Kumar
This patch adds ata_sff_queue_work() & ata_sff_queue_delayed_work() routine in libata-sff.c file. This routine can be used by ata drivers to use ata_sff_wq. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-03-02libata: remove ATA_FLAG_LPMSergei Shtylyov
Commit 6b7ae9545ad9875a289f4191c0216b473e313cb9 (libata: reimplement link power management) removed the check of ATA_FLAG_LPM but neglected to remove the flag itself. Do it now... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-03-02libata: remove ATA_FLAG_NO_LEGACYSergei Shtylyov
All checks of ATA_FLAG_NO_LEGACY have been removed by the commits c791c30670ea61f19eec390124128bf278e854fe ([libata] minor PCI IDE probe fixes and cleanups) and f0d36efdc624beb3d9e29b9ab9e9537bf0f25d5b (libata: update libata core layer to use devres), so I think it's time to finally get rid of this flag... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-03-02libata: remove ATA_FLAG_MMIOSergei Shtylyov
Commit 0d5ff566779f894ca9937231a181eb31e4adff0e (libata: convert to iomap) removed all checks of ATA_FLAG_MMIO but neglected to remove the flag itself. Do it now, at last... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-03-02libata: remove ATA_FLAG_{SRST|SATA_RESET}Sergei Shtylyov
These flags are marked as obsolete and the checks for them have been removed by commit 294440887b32c58d220fb54b73b7a58079b78f20 (libata-sff: kill unused ata_bus_reset()), so I think it's time to finally get rid of them... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-03-02libata: separate error handler into usable componentsJames Bottomley
Right at the moment, the libata error handler is incredibly monolithic. This makes it impossible to use from composite drivers like libsas and ipr which have to handle error themselves in the first instance. The essence of the change is to split the monolithic error handler into two components: one which handles a queue of ata commands for processing and the other which handles the back end of readying a port. This allows the upper error handler fine grained control in calling libsas functions (and making sure they only get called for ATA commands whose lower errors have been fixed up). Signed-off-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-01-05[libata] avoid needlessly passing around ptr to SCSI completion funcJeff Garzik
It's stored in struct scsi_cmnd->scsi_done, making several 'done' parameters to functions redundant. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-11-16SCSI host lock push-downJeff Garzik
Move the mid-layer's ->queuecommand() invocation from being locked with the host lock to being unlocked to facilitate speeding up the critical path for drivers who don't need this lock taken anyway. The patch below presents a simple SCSI host lock push-down as an equivalent transformation. No locking or other behavior should change with this patch. All existing bugs and locking orders are preserved. Additionally, add one parameter to queuecommand, struct Scsi_Host * and remove one parameter from queuecommand, void (*done)(struct scsi_cmnd *) Scsi_Host* is a convenient pointer that most host drivers need anyway, and 'done' is redundant to struct scsi_cmnd->scsi_done. Minimal code disturbance was attempted with this change. Most drivers needed only two one-line modifications for their host lock push-down. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-21include/linux/libata.h: fix typoAndrea Gelmini
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-10-21libata: reorder ata_queued_cmd to remove alignment padding on 64 bit buildsRichard Kennedy
Reorder structure ata_queued_cmd to remove 8 bytes of alignment padding on 64 bit builds & therefore reduce the size of structure ata_port by 256 bytes. Overall this will have little impact, other than reducing the amount of memory that is cleared when allocating ata_ports. Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-10-21libata: implement cross-port EH exclusionTejun Heo
In libata, the non-EH code paths should always take and release ap->lock explicitly when accessing hardware or shared data structures. However, once EH is active, it's assumed that the port is owned by EH and EH methods don't explicitly take ap->lock unless race from irq handler or other code paths are expected. However, libata EH didn't guarantee exclusion among EHs for ports of the same host. IOW, multiple EHs may execute in parallel on multiple ports of the same controller. In many cases, especially in SATA, the ports are completely independent of each other and this doesn't cause problems; however, there are cases where different ports share the same resource, which lead to obscure timing related bugs such as the one fixed by commit 213373cf (ata_piix: fix locking around SIDPR access). This patch implements exclusion among EHs of the same host. When EH begins, it acquires per-host EH ownership by calling ata_eh_acquire(). When EH finishes, the ownership is released by calling ata_eh_release(). EH ownership is also released whenever the EH thread goes to sleep from ata_msleep() or explicitly and reacquired after waking up. This ensures that while EH is actively accessing the hardware, it has exclusive access to it while allowing EHs to interleave and progress in parallel as they hit waiting stages, which dominate the time spent in EH. This achieves cross-port EH exclusion without pervasive and fragile changes while still allowing parallel EH for the most part. This was first reported by yuanding02@gmail.com more than three years ago in the following bugzilla. :-) https://bugzilla.kernel.org/show_bug.cgi?id=8223 Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Reported-by: yuanding02@gmail.com Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-10-21libata: add @ap to ata_wait_register() and introduce ata_msleep()Tejun Heo
Add optional @ap argument to ata_wait_register() and replace msleep() calls with ata_msleep() which take optional @ap in addition to the duration. These will be used to implement EH exclusion. This patch doesn't cause any behavior difference. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-10-21libata: reimplement link power managementTejun Heo
The current LPM implementation has the following issues. * Operation order isn't well thought-out. e.g. HIPM should be configured after IPM in SControl is properly configured. Not the other way around. * Suspend/resume paths call ata_lpm_enable/disable() which must only be called from EH context directly. Also, ata_lpm_enable/disable() were called whether LPM was in use or not. * Implementation is per-port when it should be per-link. As a result, it can't be used for controllers with slave links or PMP. * LPM state isn't managed consistently. After a link reset for whatever reason including suspend/resume the actual LPM state would be reset leaving ap->lpm_policy inconsistent. * Generic/driver-specific logic boundary isn't clear. Currently, libahci has to mangle stuff which libata EH proper should be handling. This makes the implementation unnecessarily complex and fragile. * Tied to ALPM. Doesn't consider DIPM only cases and doesn't check whether the device allows HIPM. * Error handling isn't implemented. Given the extent of mismatch with the rest of libata, I don't think trying to fix it piecewise makes much sense. This patch reimplements LPM support. * The new implementation is per-link. The target policy is still port-wide (ap->target_lpm_policy) but all the mechanisms and states are per-link and integrate well with the rest of link abstraction and can work with slave and PMP links. * Core EH has proper control of LPM state. LPM state is reconfigured when and only when reconfiguration is necessary. It makes sure that LPM state is reset when probing for new device on the link. Controller agnostic logic is now implemented in libata EH proper and driver implementation only has to deal with controller specifics. * Proper error handling. LPM config failure is attributed to the device on the link and LPM is disabled for the link if it fails repeatedly. * ops->enable/disable_pm() are replaced with single ops->set_lpm() which takes @policy and @hints. This simplifies driver specific implementation. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-10-21libata: implement sata_link_scr_lpm() and make ata_dev_set_feature() globalTejun Heo
Link power management is about to be reimplemented. Prepare for it. * Implement sata_link_scr_lpm(). * Drop static from ata_dev_set_feature() and make it available to other libata files. * Trivial whitespace adjustments. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-10-21libata: clean up lpm related symbols and sysfs show/store functionsTejun Heo
Link power management related symbols are in confusing state w/ mixed usages of lpm, ipm and pm. This patch cleans up lpm related symbols and sysfs show/store functions as follows. * lpm states - NOT_AVAILABLE, MIN_POWER, MAX_PERFORMANCE and MEDIUM_POWER are renamed to ATA_LPM_UNKNOWN and ATA_LPM_{MIN|MAX|MED}_POWER. * Pre/postfixes are unified to lpm. * sysfs show/store functions for link_power_management_policy were curiously named get/put and unnecessarily complex. Renamed to show/store and simplified. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-10-21[libata] Add ATA transport classGwendal Grignou
This is a scheleton for libata transport class. All information is read only, exporting information from libata: - ata_port class: one per ATA port - ata_link class: one per ATA port or 15 for SATA Port Multiplier - ata_device class: up to 2 for PATA link, usually one for SATA. Signed-off-by: Gwendal Grignou <gwendal@google.com> Reviewed-by: Grant Grundler <grundler@google.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-09-09libata-sff: Reenable Port Multiplier after libata-sff remodeling.Gwendal Grignou
Keep track of the link on the which the current request is in progress. It allows support of links behind port multiplier. Not all libata-sff is PMP compliant. Code for native BMDMA controller does not take in accound PMP. Tested on Marvell 7042 and Sil7526. Signed-off-by: Gwendal Grignou <gwendal@google.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-09-09libata: skip EH autopsy and recovery during suspendTejun Heo
For some mysterious reason, certain hardware reacts badly to usual EH actions while the system is going for suspend. As the devices won't be needed until the system is resumed, ask EH to skip usual autopsy and recovery and proceed directly to suspend. Signed-off-by: Tejun Heo <tj@kernel.org> Tested-by: Stephan Diestelhorst <stephan.diestelhorst@amd.com> Cc: stable@kernel.org Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-07-02libata: take advantage of cmwq and remove concurrency limitationsTejun Heo
libata has two concurrency related limitations. a. ata_wq which is used for polling PIO has single thread per CPU. If there are multiple devices doing polling PIO on the same CPU, they can't be executed simultaneously. b. ata_aux_wq which is used for SCSI probing has single thread. In cases where SCSI probing is stalled for extended period of time which is possible for ATAPI devices, this will stall all probing. #a is solved by increasing maximum concurrency of ata_wq. Please note that polling PIO might be used under allocation path and thus needs to be served by a separate wq with a rescuer. #b is solved by using the default wq instead and achieving exclusion via per-port mutex. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Jeff Garzik <jgarzik@pobox.com>
2010-06-02libata: implement on-demand HPA unlockingTejun Heo
Implement ata_scsi_unlock_native_capacity() which will be called through SCSI layer when block layer notices that partitions on a device extend beyond the end of the device. It requests EH to unlock HPA, waits for completion and returns the current device capacity. This allows libata to unlock HPA on demand instead of having to decide whether to unlock upfront. Unlocking on demand is safer than unlocking by upfront because some BIOSes write private data to the area beyond HPA limit. This was suggested by Ben Hutchings. Signed-off-by: Tejun Heo <tj@kernel.org> Suggested-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-25libata: implement dump_id force paramTejun Heo
Add dump_id libata.force parameter. If specified, libata dumps full IDENTIFY data during device configuration. This is to aid debugging. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Larry Baker <baker@usgs.gov> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-25libata-sff: make BMDMA optionalTejun Heo
Make BMDMA optional depending on new config variable CONFIG_ATA_BMDMA. In Kconfig, drivers are grouped into five groups - non-SFF native, SFF w/ custom DMA interface, SFF w/ BMDMA, PIO-only SFF, and generic fallback / legacy ones. Kconfig and Makefile are reorganized according to the groups and ordered alphabetically inside each group. ata_ioports.bmdma_addr and ata_port.bmdma_prd[_dma] are put into CONFIG_ATA_BMDMA, as are all bmdma related ops, variables and functions. This increase the binary size slightly when BMDMA is enabled but on both native-only and PIO-only configurations the size is slightly reduced. Either way, the size difference is insignificant. This change is more meaningful to signify the separation between SFF and BMDMA and as a tool to verify the separation. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-25libata-sff: separate out BMDMA initTejun Heo
Separate out ata_pci_bmdma_prepare_host() and ata_pci_bmdma_init_one() from their SFF counterparts. SFF ones no longer try to initialize BMDMA or set PCI master. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-25libata-sff: separate out BMDMA irq handlerTejun Heo
Separate out BMDMA irq handler from SFF irq handler. The misnamed host_intr() functions are renamed to ata_sff_port_intr() and ata_bmdma_port_intr(). Common parts are factored into __ata_sff_port_intr() and __ata_sff_interrupt() and used by sff and bmdma interrupt routines. All BMDMA drivers now use ata_bmdma_interrupt() or ata_bmdma_port_intr() while all non-BMDMA SFF ones use ata_sff_interrupt() or ata_sff_port_intr(). For now, ata_pci_sff_init_one() uses ata_bmdma_interrupt() as it's used by both SFF and BMDMA drivers. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-25libata-sff: ata_sff_irq_clear() is BMDMA specificTejun Heo
ata_sff_irq_clear() is BMDMA specific. Rename it to ata_bmdma_irq_clear(), move it to ata_bmdma_port_ops and make ->sff_irq_clear() optional. Note: ata_bmdma_irq_clear() is actually only needed by ata_piix and possibly by sata_sil. This should be moved to respective low level drivers later. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-19libata-sff: separate out BMDMA qc_issueTejun Heo
Separate out ata_bmdma_qc_issue() from ata_sff_qc_issue() such that ata_sff_qc_issue() only deals with non-BMDMA SFF protocols (PIO and nodata) while ata_bmdma_qc_issue() deals with the BMDMA protocols and uses ata_sff_qc_issue() for non-DMA commands. All the users are updated accordingly. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
