path: root/include/linux/libata.h
2015-06-25Merge branch 'for-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata updates from Tejun Heo: - a number of libata core changes to better support NCQ TRIM. - ahci now supports MSI-X in single IRQ mode to support a new controller which doesn't implement MSI or INTX. - ahci now supports edge-triggered IRQ mode to support a new controller which for some odd reason did edge-triggered IRQ. - the usual controller support additions and changes. * 'for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: (27 commits) libata: Do not blacklist Micron M500DC ata: ahci_mvebu: add suspend/resume support ahci, msix: Fix build error for !PCI_MSI ahci: Add support for Cavium's ThunderX host controller ahci: Add generic MSI-X support for single interrupts to SATA PCI driver libata: finally use __initconst in ata_parse_force_one() drivers: ata: add support for Ceva sata host controller devicetree:bindings: add devicetree bindings for ceva ahci ahci: added support for Freescale AHCI sata ahci: Store irq number in struct ahci_host_priv ahci: Move interrupt enablement code to a separate function Doc: libata: Fix spelling typo found in libata.xml ata:sata_nv - Change 1 to true for bool type variable. ata: add Broadcom AHCI SATA3 driver for STB chips Documentation: devicetree: add Broadcom SATA binding libata: Fix regression when the NCQ Send and Receive log page is absent ata: hpt366: fix constant cast warning ata: ahci_xgene: potential NULL dereference in probe ata: ahci_xgene: Add AHCI Support for 2nd HW version of APM X-Gene SoC AHCI SATA Host controller. libahci: Add support to handle HOST_IRQ_STAT as edge trigger latch. ...
2015-06-23Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI updates from James Bottomley: "This is the usual grab bag of driver updates (lpfc, hpsa, megaraid_sas, cxgbi, be2iscsi) plus an assortment of minor updates. There is also one new driver: the Cisco snic. The advansys driver has been rewritten to get rid of the warning about converting it to the DMA API, the tape statistics patch got in and finally, there's a resuffle of SCSI header files to separate more cleanly initiator from target mode (and better share the common definitions)" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (156 commits) snic: driver for Cisco SCSI HBA qla2xxx: Fix indentation qla2xxx: Comment out unreachable code fusion: remove dead MTRR code advansys: fix compilation errors and warnings when CONFIG_PCI is not set mptsas: fix depth param in scsi_track_queue_full megaraid: fix irq setup process regression lpfc: Update version to 10.7.0.0 for upstream patch set. lpfc: Fix to drop PLOGIs from fabric node till LOGO processing completes lpfc: Fix scsi task management error message. lpfc: Fix cq_id masking problem. lpfc: Fix scsi prep dma buf error. lpfc: Add support for using block multi-queue lpfc: Devices are not discovered during takeaway/giveback testing lpfc: Fix vport deletion failure. lpfc: Check for active portpeerbeacon. lpfc: Update driver version for upstream patch set 10.6.0.1. lpfc: Change buffer pool empty message to miscellaneous category lpfc: Fix incorrect log message reported for empty FCF record. lpfc: Fix rport leak. ...
2015-05-31scsi: Do not set cmd_per_lun to 1 in the host templateHannes Reinecke
'0' is now used as the default cmd_per_lun value, so there's no need to explicitly set it to '1' in the host template. Signed-off-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-05-05libata: Fall back to unqueued READ LOG EXT if the DMA variant failsMartin K. Petersen
Some devices advertise support for the READ/WRITE LOG DMA EXT commands but fail when we try to issue them. This can lead to queued TRIM being unintentionally disabled since the relevant feature flag is located in a general purpose log page. Fall back to unqueued READ LOG EXT if the DMA variant fails while reading a log page. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-04-25libata: Ignore spurious PHY event on LPM policy changeGabriele Mazzotta
When the LPM policy is set to ATA_LPM_MAX_POWER, the device might generate a spurious PHY event that cuases errors on the link. Ignore this event if it occured within 10s after the policy change. The timeout was chosen observing that on a Dell XPS13 9333 these spurious events can occur up to roughly 6s after the policy change. Link: http://lkml.kernel.org/g/3352987.ugV1Ipy7Z5@xps13 Signed-off-by: Gabriele Mazzotta <gabriele.mzt@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2015-04-25libata: Add helper to determine when PHY events should be ignoredGabriele Mazzotta
This is a preparation commit that will allow to add other criteria according to which PHY events should be dropped. Signed-off-by: Gabriele Mazzotta <gabriele.mzt@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2015-04-13Merge branch 'for-4.1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata updates from Tejun Heo: - Hannes's patchset implements support for better error reporting introduced by the new ATA command spec. - the deperecated pci_ dma API usages have been replaced by dma_ ones. - a bunch of hardware specific updates and some cleanups. * 'for-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: ata: remove deprecated use of pci api ahci: st: st_configure_oob must be called after IP is clocked. ahci: st: Update the ahci_st DT documentation ahci: st: Update the DT example for how to obtain the PHY. sata_dwc_460ex: indent an if statement libata: Add tracepoints libata-eh: Set 'information' field for autosense libata: Implement support for sense data reporting libata: Implement NCQ autosense libata: use status bit definitions in ata_dump_status() ide,ata: Rename ATA_IDX to ATA_SENSE libata: whitespace fixes in ata_to_sense_error() libata: whitespace cleanup in ata_get_cmd_descript() libata: use READ_LOG_DMA_EXT libata: remove ATA_FLAG_LOWTAG sata_dwc_460ex: re-use hsdev->dev instead of dwc_dev sata_dwc_460ex: move to generic DMA driver sata_dwc_460ex: join messages back sata: xgene: add ACPI support for APM X-Gene SATA ports ata: sata_mv: add proper definitions for LP_PHY_CTL register values
2015-03-24libata: remove ATA_FLAG_LOWTAGTejun Heo
sata_sil24 for some reason pukes when tags are allocated round-robin which helps tag ordered controllers. To work around the issue, 72dd299d5039 ("libata: allow sata_sil24 to opt-out of tag ordered submission") introduced ATA_FLAG_LOWTAG which tells libata tag allocation to do lowest-first. However, with the recent switch to blk-mq tag allocation, the liata tag allocation code path is no longer used and the workaround is now implemented in the block layer and selected by setting scsi_host_template->tag_alloc_policy to BLK_TAG_ALLOC_FIFO. See 9269e23496dd ("libata: make sata_sil24 use fifo tag allocator"). This leaves ATA_FLAG_LOWTAG withoout any actual user. Remove it. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Shaohua Li <shli@fb.com> Cc: Dan Williams <dan.j.williams@intel.com>
2015-03-19ata: Add a new flag to destinguish sas controllerShaohua Li
SAS controller has its own tag allocation, which doesn't directly match to ATA tag, so SAS and SATA have different code path for ata tags. Originally we use port->scsi_host (98bd4be1) to destinguish SAS controller, but libsas set ->scsi_host too, so we can't use it for the destinguish, we add a new flag for this purpose. Without this patch, the following oops can happen because scsi-mq uses a host-wide tag map shared among all devices with some integer tag values >= ATA_MAX_QUEUE. These unexpectedly high tag values cause __ata_qc_from_tag() to return NULL, which is then dereferenced in ata_qc_new_init(). BUG: unable to handle kernel NULL pointer dereference at 0000000000000058 IP: [<ffffffff804fd46e>] ata_qc_new_init+0x3e/0x120 PGD 32adf0067 PUD 32adf1067 PMD 0 Oops: 0002 [#1] SMP DEBUG_PAGEALLOC Modules linked in: iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi igb i2c_algo_bit ptp pps_core pm80xx libsas scsi_transport_sas sg coretemp eeprom w83795 i2c_i801 CPU: 4 PID: 1450 Comm: cydiskbench Not tainted 4.0.0-rc3 #1 Hardware name: Supermicro X8DTH-i/6/iF/6F/X8DTH, BIOS 2.1b 05/04/12 task: ffff8800ba86d500 ti: ffff88032a064000 task.ti: ffff88032a064000 RIP: 0010:[<ffffffff804fd46e>] [<ffffffff804fd46e>] ata_qc_new_init+0x3e/0x120 RSP: 0018:ffff88032a067858 EFLAGS: 00010046 RAX: 0000000000000000 RBX: ffff8800ba0d2230 RCX: 000000000000002a RDX: ffffffff80505ae0 RSI: 0000000000000020 RDI: ffff8800ba0d2230 RBP: ffff88032a067868 R08: 0000000000000201 R09: 0000000000000001 R10: 0000000000000000 R11: 0000000000000000 R12: ffff8800ba0d0000 R13: ffff8800ba0d2230 R14: ffffffff80505ae0 R15: ffff8800ba0d0000 FS: 0000000041223950(0063) GS:ffff88033e480000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000000000058 CR3: 000000032a0a3000 CR4: 00000000000006e0 Stack: ffff880329eee758 ffff880329eee758 ffff88032a0678a8 ffffffff80502dad ffff8800ba167978 ffff880329eee758 ffff88032bf9c520 ffff8800ba167978 ffff88032bf9c520 ffff88032bf9a290 ffff88032a0678b8 ffffffff80506909 Call Trace: [<ffffffff80502dad>] ata_scsi_translate+0x3d/0x1b0 [<ffffffff80506909>] ata_sas_queuecmd+0x149/0x2a0 [<ffffffffa0046650>] sas_queuecommand+0xa0/0x1f0 [libsas] [<ffffffff804ea544>] scsi_dispatch_cmd+0xd4/0x1a0 [<ffffffff804eb50f>] scsi_queue_rq+0x66f/0x7f0 [<ffffffff803e5098>] __blk_mq_run_hw_queue+0x208/0x3f0 [<ffffffff803e54b8>] blk_mq_run_hw_queue+0x88/0xc0 [<ffffffff803e5c74>] blk_mq_insert_request+0xc4/0x130 [<ffffffff803e0b63>] blk_execute_rq_nowait+0x73/0x160 [<ffffffffa0023fca>] sg_common_write+0x3da/0x720 [sg] [<ffffffffa0025100>] sg_new_write+0x250/0x360 [sg] [<ffffffffa0025feb>] sg_write+0x13b/0x450 [sg] [<ffffffff8032ec91>] vfs_write+0xd1/0x1b0 [<ffffffff8032ee54>] SyS_write+0x54/0xc0 [<ffffffff80689932>] system_call_fastpath+0x12/0x17 tj: updated description. Fixes: 12cb5ce101ab ("libata: use blk taging") Reported-and-tested-by: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-02-12Merge branch 'for-3.20/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block driver changes from Jens Axboe: "This contains: - The 4k/partition fixes for brd from Boaz/Matthew. - A few xen front/back block fixes from David Vrabel and Roger Pau Monne. - Floppy changes from Takashi, cleaning the device file creation. - Switching libata to use the new blk-mq tagging policy, removing code (and a suboptimal implementation) from libata. This will throw you a merge conflict, since a bug in the original libata tagging code was fixed since this code was branched. Trivial. From Shaohua. - Conversion of loop to blk-mq, from Ming Lei. - Cleanup of the io_schedule() handling in bsg from Peter Zijlstra. He claims it improves on unreadable code, which will cost him a beer. - Maintainer update or NDB, now handled by Markus Pargmann. - NVMe: - Optimization from me that avoids a kmalloc/kfree per IO for smaller (<= 8KB) IO. This cuts about 1% of high IOPS CPU overhead. - Removal of (now) dead RCU code, a relic from before NVMe was converted to blk-mq" * 'for-3.20/drivers' of git://git.kernel.dk/linux-block: xen-blkback: default to X86_32 ABI on x86 xen-blkfront: fix accounting of reqs when migrating xen-blkback,xen-blkfront: add myself as maintainer block: Simplify bsg complete all floppy: Avoid manual call of device_create_file() NVMe: avoid kmalloc/kfree for smaller IO MAINTAINERS: Update NBD maintainer libata: make sata_sil24 use fifo tag allocator libata: move sas ata tag allocation to libata-scsi.c libata: use blk taging NVMe: within nvme_free_queues(), delete RCU sychro/deferred free null_blk: suppress invalid partition info brd: Request from fdisk 4k alignment brd: Fix all partitions BUGs axonram: Fix bug in direct_access loop: add blk-mq.h include block: loop: don't handle REQ_FUA explicitly block: loop: introduce lo_discard() and lo_req_flush() block: loop: say goodby to bio block: loop: improve performance via blk-mq
2015-02-09Merge branch 'for-3.19-fixes' of ↵Tejun Heo
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata into for-3.20 09c32aaa3683 ("ahci_xgene: Fix the dma state machine lockup for the ATA_CMD_SMART PIO mode command.") missed 3.19 release. Fold it into for-3.20. Signed-off-by: Tejun Heo <tj@kernel.org>
2015-01-28ata: ahci_platform: fix owner module reference mismatch for scsi hostAkinobu Mita
The owner module reference of the ahci platform's scsi_host is initialized to libahci_platform's one, because these drivers use a scsi_host_template defined in libahci_platform. So these drivers can be unloaded even if the scsi device is being accessed. This fixes it by pushing the scsi_host_template from libahci_platform to all leaf drivers. The scsi_host_template is passed through a new argument of ahci_platform_init_host(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Cc: linux-ide@vger.kernel.org Cc: linux-scsi@vger.kernel.org
2015-01-23libata: use blk tagingShaohua Li
libata uses its own tag management which is duplication and the implementation is poor. And if we switch to blk-mq, tag is build-in. It's time to switch to generic taging. The SAS driver has its own tag management, and looks we can't directly map the host controler tag to SATA tag. So I just bypassed the SAS case. I changed the code/variable name for the tag management of libata to make it self contained. Only sas will use it. Later if libsas implements its tag management, the tag management code in libata can be deleted easily. Cc: Jens Axboe <axboe@fb.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Shaohua Li <shli@fb.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-01-19libata: allow sata_sil24 to opt-out of tag ordered submissionDan Williams
Ronny reports: https://bugzilla.kernel.org/show_bug.cgi?id=87101 "Since commit 8a4aeec8d "libata/ahci: accommodate tag ordered controllers" the access to the harddisk on the first SATA-port is failing on its first access. The access to the harddisk on the second port is working normal. When reverting the above commit, access to both harddisks is working fine again." Maintain tag ordered submission as the default, but allow sata_sil24 to continue with the old behavior. Cc: <stable@vger.kernel.org> Cc: Tejun Heo <tj@kernel.org> Reported-by: Ronny Hegewald <Ronny.Hegewald@online.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-01-08libata: Whitelist SSDs that are known to properly return zeroes after TRIMMartin K. Petersen
As defined, the DRAT (Deterministic Read After Trim) and RZAT (Return Zero After Trim) flags in the ATA Command Set are unreliable in the sense that they only define what happens if the device successfully executed the DSM TRIM command. TRIM is only advisory, however, and the device is free to silently ignore all or parts of the request. In practice this renders the DRAT and RZAT flags completely useless and because the results are unpredictable we decided to disable discard in MD for 3.18 to avoid the risk of data corruption. Hardware vendors in the real world obviously need better guarantees than what the standards bodies provide. Unfortuntely those guarantees are encoded in product requirements documents rather than somewhere we can key off of them programatically. So we are compelled to disabling discard_zeroes_data for all devices unless we explicitly have data to support whitelisting them. This patch whitelists SSDs from a few of the main vendors. None of the whitelists are based on written guarantees. They are purely based on empirical evidence collected from internal and external users that have tested or qualified these drives in RAID deployments. The whitelist is only meant as a starting point and is by no means comprehensive: - All intel SSD models except for 510 - Micron M5?0/M600 - Samsung SSDs - Seagate SSDs Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-12-11Merge branch 'for-3.19' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata changes from Tejun Heo: "The only interesting piece is the support for shingled drives. The changes in libata layer are minimal. All it does is identifying the new class of device and report upwards accordingly" * 'for-3.19' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: libata: Remove FIXME comment in atapi_request_sense() sata_rcar: Document deprecated "renesas,rcar-sata" sata_rcar: Add clocks to sata_rcar bindings ahci_sunxi: Make AHCI_HFLAG_NO_PMP flag configurable with a module option libata-scsi: Update SATL for ZAC drives libata: Implement ATA_DEV_ZAC libsas: use ata_dev_classify()
2014-11-24scsi: drop reason argument from ->change_queue_depthChristoph Hellwig
Drop the now unused reason argument from the ->change_queue_depth method. Also add a return value to scsi_adjust_queue_depth, and rename it to scsi_change_queue_depth now that it can be used as the default ->change_queue_depth implementation. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Reviewed-by: Hannes Reinecke <hare@suse.de>
2014-11-05libata: Implement ATA_DEV_ZACHannes Reinecke
Add new ATA device type for ZAC devices. Acked-by: Christoph Hellwig <hch@lst.de> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-09-23libata: change ata_<foo>_printk routines to return voidJoe Perches
The return value is not used by callers of these functions nor by uses of all macros so change the functions to return void. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-23libata: introduce ata_host->n_tags to avoid oops on SAS controllersTejun Heo
1871ee134b73 ("libata: support the ata host which implements a queue depth less than 32") directly used ata_port->scsi_host->can_queue from ata_qc_new() to determine the number of tags supported by the host; unfortunately, SAS controllers doing SATA don't initialize ->scsi_host leading to the following oops. BUG: unable to handle kernel NULL pointer dereference at 0000000000000058 IP: [<ffffffff814e0618>] ata_qc_new_init+0x188/0x1b0 PGD 0 Oops: 0002 [#1] SMP Modules linked in: isci libsas scsi_transport_sas mgag200 drm_kms_helper ttm CPU: 1 PID: 518 Comm: udevd Not tainted 3.16.0-rc6+ #62 Hardware name: Intel Corporation S2600CO/S2600CO, BIOS SE5C600.86B.02.02.0002.122320131210 12/23/2013 task: ffff880c1a00b280 ti: ffff88061a000000 task.ti: ffff88061a000000 RIP: 0010:[<ffffffff814e0618>] [<ffffffff814e0618>] ata_qc_new_init+0x188/0x1b0 RSP: 0018:ffff88061a003ae8 EFLAGS: 00010012 RAX: 0000000000000001 RBX: ffff88000241ca80 RCX: 00000000000000fa RDX: 0000000000000020 RSI: 0000000000000020 RDI: ffff8806194aa298 RBP: ffff88061a003ae8 R08: ffff8806194a8000 R09: 0000000000000000 R10: 0000000000000000 R11: ffff88000241ca80 R12: ffff88061ad58200 R13: ffff8806194aa298 R14: ffffffff814e67a0 R15: ffff8806194a8000 FS: 00007f3ad7fe3840(0000) GS:ffff880627620000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000058 CR3: 000000061a118000 CR4: 00000000001407e0 Stack: ffff88061a003b20 ffffffff814e96e1 ffff88000241ca80 ffff88061ad58200 ffff8800b6bf6000 ffff880c1c988000 ffff880619903850 ffff88061a003b68 ffffffffa0056ce1 ffff88061a003b48 0000000013d6e6f8 ffff88000241ca80 Call Trace: [<ffffffff814e96e1>] ata_sas_queuecmd+0xa1/0x430 [<ffffffffa0056ce1>] sas_queuecommand+0x191/0x220 [libsas] [<ffffffff8149afee>] scsi_dispatch_cmd+0x10e/0x300 [<ffffffff814a3bc5>] scsi_request_fn+0x2f5/0x550 [<ffffffff81317613>] __blk_run_queue+0x33/0x40 [<ffffffff8131781a>] queue_unplugged+0x2a/0x90 [<ffffffff8131ceb4>] blk_flush_plug_list+0x1b4/0x210 [<ffffffff8131d274>] blk_finish_plug+0x14/0x50 [<ffffffff8117eaa8>] __do_page_cache_readahead+0x198/0x1f0 [<ffffffff8117ee21>] force_page_cache_readahead+0x31/0x50 [<ffffffff8117ee7e>] page_cache_sync_readahead+0x3e/0x50 [<ffffffff81172ac6>] generic_file_read_iter+0x496/0x5a0 [<ffffffff81219897>] blkdev_read_iter+0x37/0x40 [<ffffffff811e307e>] new_sync_read+0x7e/0xb0 [<ffffffff811e3734>] vfs_read+0x94/0x170 [<ffffffff811e43c6>] SyS_read+0x46/0xb0 [<ffffffff811e33d1>] ? SyS_lseek+0x91/0xb0 [<ffffffff8171ee29>] system_call_fastpath+0x16/0x1b Code: 00 00 00 88 50 29 83 7f 08 01 19 d2 83 e2 f0 83 ea 50 88 50 34 c6 81 1d 02 00 00 40 c6 81 17 02 00 00 00 5d c3 66 0f 1f 44 00 00 <89> 14 25 58 00 00 00 Fix it by introducing ata_host->n_tags which is initialized to ATA_MAX_QUEUE - 1 in ata_host_init() for SAS controllers and set to scsi_host_template->can_queue in ata_host_register() for !SAS ones. As SAS hosts are never registered, this will give them the same ATA_MAX_QUEUE - 1 as before. Note that we can't use scsi_host->can_queue directly for SAS hosts anyway as they can go higher than the libata maximum. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Mike Qiu <qiudayu@linux.vnet.ibm.com> Reported-by: Jesse Brandeburg <jesse.brandeburg@gmail.com> Reported-by: Peter Hurley <peter@hurleysoftware.com> Reported-by: Peter Zijlstra <peterz@infradead.org> Tested-by: Alexey Kardashevskiy <aik@ozlabs.ru> Fixes: 1871ee134b73 ("libata: support the ata host which implements a queue depth less than 32") Cc: Kevin Hao <haokexin@gmail.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: stable@vger.kernel.org
2014-04-18libata/ahci: accommodate tag ordered controllersDan Williams
The AHCI spec allows implementations to issue commands in tag order rather than FIFO order: 5.3.2.12 P:SelectCmd HBA sets pSlotLoc = (pSlotLoc + 1) mod (CAP.NCS + 1) or HBA selects the command to issue that has had the PxCI bit set to '1' longer than any other command pending to be issued. The result is that commands posted sequentially (time-wise) may play out of sequence when issued by hardware. This behavior has likely been hidden by drives that arrange for commands to complete in issue order. However, it appears recent drives (two from different vendors that we have found so far) inflict out-of-order completions as a matter of course. So, we need to take care to maintain ordered submission, otherwise we risk triggering a drive to fall out of sequential-io automation and back to random-io processing, which incurs large latency and degrades throughput. This issue was found in simple benchmarks where QD=2 seq-write performance was 30-50% *greater* than QD=32 seq-write performance. Tagging for -stable and making the change globally since it has a low risk-to-reward ratio. Also, word is that recent versions of an unnamed OS also does it this way now. So, drives in the field are already experienced with this tag ordering scheme. Cc: <stable@vger.kernel.org> Cc: Dave Jiang <dave.jiang@intel.com> Cc: Ed Ciechanowski <ed.ciechanowski@intel.com> Reviewed-by: Matthew Wilcox <matthew.r.wilcox@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-03-19libata: remove unused ata_sas_port_async_resume() stubDan Williams
Commit bc6e7c4b0d1a "libata, libsas: kill pm_result and related cleanup" renamed ata_sas_port_async_resume() to ata_sas_port_resume(), but missed a CONFIG_PM=n stub conversion. Randy fixed that up in commit a5a6569959fc "libata.h: add stub for ata_sas_port_resume", but missed the deletion of the now unused ata_sas_port_async_resume() routine. Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-03-19libata.h: add stub for ata_sas_port_resumeRandy Dunlap
Fix build error when CONFIG_PM is not enabled by adding a stub function in <linux/libata.h>. drivers/scsi/libsas/sas_ata.c: In function 'sas_resume_sata': drivers/scsi/libsas/sas_ata.c:756:3: error: implicit declaration of function 'ata_sas_port_resume' [-Werror=implicit-function-declaration] Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Reported-by: Jim Davis <jim.epost@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Dan Williams <dan.j.williams@intel.com>
2014-03-18libata, libsas: kill pm_result and related cleanupDan Williams
Tejun says: "At least for libata, worrying about suspend/resume failures don't make whole lot of sense. If suspend failed, just proceed with suspend. If the device can't be woken up afterwards, that's that. There isn't anything we could have done differently anyway. The same for resume, if spinup fails, the device is dud and the following commands will invoke EH actions and will eventually fail. Again, there really isn't any *choice* to make. Just making sure the errors are handled gracefully (ie. don't crash) and the following commands are handled correctly should be enough." The only libata user that actually cares about the result from a suspend operation is libsas. However, it only cares about whether queuing a new operation collides with an in-flight one. All libsas does with the error is retry, but we can just let libata wait for the previous operation before continuing. Other cleanups include: 1/ Unifying all ata port pm operations on an ata_port_pm_ prefix 2/ Marking all ata port pm helper routines as returning void, only ata_port_pm_ entry points need to fake a 0 return value. 3/ Killing ata_port_{suspend|resume}_common() in favor of calling ata_port_request_pm() directly 4/ Killing the wrappers that just do a to_ata_port() conversion 5/ Clearly marking the entry points that do async operations with an _async suffix. Reference: http://marc.info/?l=linux-scsi&m=138995409532286&w=2 Cc: Phillip Susi <psusi@ubuntu.com> Cc: Alan Stern <stern@rowland.harvard.edu> Suggested-by: Tejun Heo <tj@kernel.org> Signed-off-by: Todd Brandt <todd.e.brandt@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-01-16libata: disable LPM for some WD SATA-I devicesTejun Heo
For some reason, some early WD drives spin up and down drives erratically when the link is put into slumber mode which can reduce the life expectancy of the device significantly. Unfortunately, we don't have full list of devices and given the nature of the issue it'd be better to err on the side of false positives than the other way around. Let's disable LPM on all WD devices which match one of the known problematic model prefixes and are SATA-I. As horkage list doesn't support matching SATA capabilities, this is implemented as two horkages - WD_BROKEN_LPM and NOLPM. The former is set for the known prefixes and sets the latter if the matched device is SATA-I. Note that this isn't optimal as this disables all LPM operations and partial link power state reportedly works fine on these; however, the way LPM is implemented in libata makes it difficult to precisely map libata LPM setting to specific link power state. Well, these devices are already fairly outdated. Let's just disable whole LPM for now. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-and-tested-by: Nikos Barkas <levelwol@gmail.com> Reported-and-tested-by: Ioannis Barkas <risc4all@yahoo.com> References: https://bugzilla.kernel.org/show_bug.cgi?id=57211 Cc: stable@vger.kernel.org
2013-12-17libata: implement ATA_HORKAGE_NO_NCQ_TRIM and apply it to Micro M500 SSDsMarc Carino
Certain drives cannot handle queued TRIM commands properly, even though support is indicated in the IDENTIFY DEVICE buffer. This patch allows for disabling the commands for the affected drives and apply it to the Micron/Crucial M500 SSDs which exhibit incorrect protocol behavior when issued queued TRIM commands, which could lead to silent data corruption. tj: Merged two unnecessarily split patches and made minor edits including shortening horkage name. Signed-off-by: Marc Carino <marc.ceeeee@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Link: http://lkml.kernel.org/g/1387246554-7311-1-git-send-email-marc.ceeeee@gmail.com Cc: stable@vger.kernel.org # 3.12+
2013-08-25libata: Add support for queued DSM TRIMMarc Carino
Some new SSDs support the queued version of the DSM TRIM command. Let the driver use the new command if supported. Signed-off-by: Marc Carino <marc.ceeeee@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-08-25libata: Add support for SEND/RECEIVE FPDMA QUEUEDMarc Carino
Add support for the following ATA opcodes, which are present in SATA 3.1 and T13 ATA ACS-3: SEND FPDMA QUEUED RECEIVE FPDMA QUEUED Signed-off-by: Marc Carino <marc.ceeeee@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-08-25libata: Add H2D FIS "auxiliary" port flagMarc Carino
Add a new port flag, ATA_FLAG_FPDMA_AUX, used to indicate support for transmission of the H2D FIS 'auxiliary' field. Signed-off-by: Marc Carino <marc.ceeeee@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-08-25libata: Populate host-to-device FIS "auxiliary" fieldMarc Carino
SATA 3.1 added an "auxiliary" field to the host-to-device FIS. Populate the host-to-device FIS with the new field via the taskfile struct. Signed-off-by: Marc Carino <marc.ceeeee@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-08-23ata: acpi: rework the ata acpi bind supportAaron Lu
Binding ACPI handle to SCSI device has several drawbacks, namely: 1 During ATA device initialization time, ACPI handle will be needed while SCSI devices are not created yet. So each time ACPI handle is needed, instead of retrieving the handle by ACPI_HANDLE macro, a namespace scan is performed to find the handle for the corresponding ATA device. This is inefficient, and also expose a restriction on calling path not holding any lock. 2 The binding to SCSI device tree makes code complex, while at the same time doesn't bring us any benefit. All ACPI handlings are still done in ATA module, not in SCSI. Rework the ATA ACPI binding code to bind ACPI handle to ATA transport devices(ATA port and ATA device). The binding needs to be done only once, since the ATA transport devices do not go away with hotplug. And due to this, the flush_work call in hotplug handler for ATA bay is no longer needed. Tested on an Intel test platform for binding and runtime power off for ODD(ZPODD) and hard disk; on an ASUS S400C for binding and normal boot and S3, where its SATA port node has _SDD and _GTF control methods when configured as an AHCI controller and its PATA device node has _GTF control method when configured as an IDE controller. SATA PMP binding and ATA hotplug is not tested. Signed-off-by: Aaron Lu <aaron.lu@intel.com> Tested-by: Dirk Griesbach <spamthis@freenet.de> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-07-16libata: move 'struct ata_taskfile' and friends from ata.h to libata.hSergei Shtylyov
Move 'struct ata_taskfile', ata_prot_flags() and their friends from <linux/ata.h> to <linux/libata.h>. They were misplaced from the beginning, as <linux/ata.h> should cover ATA/ATAPI and related standards only -- to which the aforementioned structure and function have only remote relation. I would have moved 'enum ata_tf_protocols' closely related to 'struct ata_taskfile' but it unfortunately gets used by 'drivers/ide/ide-ioctls.c'... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-06-06ahci: make ahci_transmit_led_message into a function pointerMark Langsdorf
Create a new ata_port_operations function pointer called transmit_led_message and give it the default value of ahci_transmit_led_message. This allows AHCI controllers with non-standard LED interfaces to use the existing em_ interface. Signed-off-by: Mark Langsdorf <mark.langsdorf@calxeda.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-05-22libata: Add atapi_dmadir force flagVincent Pelletier
Some device require DMADIR to be enabled, but are not detected as such by atapi_id_dmadir. One such example is "Asus Serillel 2" SATA-host-to-PATA-device bridge: the bridge itself requires DMADIR, even if the bridged device does not. As atapi_dmadir module parameter can cause problems with some devices (as per Tejun Heo's memory), enabling it globally may not be possible depending on the hardware. This patch adds atapi_dmadir in the form of a "force" horkage value, allowing global, per-bus and per-device control. Signed-off-by: Vincent Pelletier <plr.vincent@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-05-14libata: export ata_port port_no attribute via /sysDavid Milburn
While registering host controller track port number based upon number of ports available on the controller, export port_no attribute through /sys. This patch is needed by udev for composing persistent links in /dev/disk/by-path. /sys/devices/pci0000:00/0000:00:1f.2/ata8/ata_port/ata8 total 0 lrwxrwxrwx. 1 root root 0 Mar 6 12:43 device -> ../../../ata8 -r--r--r--. 1 root root 4096 Mar 6 12:43 idle_irq -r--r--r--. 1 root root 4096 Mar 6 12:43 nr_pmp_links -r--r--r--. 1 root root 4096 Mar 6 12:43 port_no drwxr-xr-x. 2 root root 0 Mar 6 12:42 power lrwxrwxrwx. 1 root root 0 Mar 6 12:41 subsystem -> ../../../../../../class/ata_port -rw-r--r--. 1 root root 4096 Mar 6 12:40 uevent 1 Signed-off-by: David Milburn <dmilburn@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-04-03libata: Set max sector to 65535 for Slimtype DVD A DS8A8SH driveShan Hai
The Slimtype DVD A DS8A8SH drive locks up when max sector is smaller than 65535, and the blow backtrace is observed on locking up: INFO: task flush-8:32:1130 blocked for more than 120 seconds. "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. flush-8:32 D ffffffff8180cf60 0 1130 2 0x00000000 ffff880273aef618 0000000000000046 0000000000000005 ffff880273aee000 ffff880273aee000 ffff880273aeffd8 ffff880273aee010 ffff880273aee000 ffff880273aeffd8 ffff880273aee000 ffff88026e842ea0 ffff880274a10000 Call Trace: [<ffffffff8168fc2d>] schedule+0x5d/0x70 [<ffffffff8168fccc>] io_schedule+0x8c/0xd0 [<ffffffff81324461>] get_request+0x731/0x7d0 [<ffffffff8133dc60>] ? cfq_allow_merge+0x50/0x90 [<ffffffff81083aa0>] ? wake_up_bit+0x40/0x40 [<ffffffff81320443>] ? bio_attempt_back_merge+0x33/0x110 [<ffffffff813248ea>] blk_queue_bio+0x23a/0x3f0 [<ffffffff81322176>] generic_make_request+0xc6/0x120 [<ffffffff81322308>] submit_bio+0x138/0x160 [<ffffffff811d7596>] ? bio_alloc_bioset+0x96/0x120 [<ffffffff811d1f61>] submit_bh+0x1f1/0x220 [<ffffffff811d48b8>] __block_write_full_page+0x228/0x340 [<ffffffff811d3650>] ? attach_nobh_buffers+0xc0/0xc0 [<ffffffff811d8960>] ? I_BDEV+0x10/0x10 [<ffffffff811d8960>] ? I_BDEV+0x10/0x10 [<ffffffff811d4ab6>] block_write_full_page_endio+0xe6/0x100 [<ffffffff811d4ae5>] block_write_full_page+0x15/0x20 [<ffffffff811d9268>] blkdev_writepage+0x18/0x20 [<ffffffff81142527>] __writepage+0x17/0x40 [<ffffffff811438ba>] write_cache_pages+0x34a/0x4a0 [<ffffffff81142510>] ? set_page_dirty+0x70/0x70 [<ffffffff81143a61>] generic_writepages+0x51/0x80 [<ffffffff81143ab0>] do_writepages+0x20/0x50 [<ffffffff811c9ed6>] __writeback_single_inode+0xa6/0x2b0 [<ffffffff811ca861>] writeback_sb_inodes+0x311/0x4d0 [<ffffffff811caaa6>] __writeback_inodes_wb+0x86/0xd0 [<ffffffff811cad43>] wb_writeback+0x1a3/0x330 [<ffffffff816916cf>] ? _raw_spin_lock_irqsave+0x3f/0x50 [<ffffffff811b8362>] ? get_nr_inodes+0x52/0x70 [<ffffffff811cb0ac>] wb_do_writeback+0x1dc/0x260 [<ffffffff8168dd34>] ? schedule_timeout+0x204/0x240 [<ffffffff811cb232>] bdi_writeback_thread+0x102/0x2b0 [<ffffffff811cb130>] ? wb_do_writeback+0x260/0x260 [<ffffffff81083550>] kthread+0xc0/0xd0 [<ffffffff81083490>] ? kthread_worker_fn+0x1b0/0x1b0 [<ffffffff8169a3ec>] ret_from_fork+0x7c/0xb0 [<ffffffff81083490>] ? kthread_worker_fn+0x1b0/0x1b0 The above trace was triggered by "dd if=/dev/zero of=/dev/sr0 bs=2048 count=32768" It was previously working by accident, since another bug introduced by 4dce8ba94c7 (libata: Use 'bool' return value for ata_id_XXX) caused all drives to use maxsect=65535. Cc: stable@vger.kernel.org Signed-off-by: Shan Hai <shan.hai@windriver.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2013-01-25Revert "libata: export host controller number thru /sys"Jeff Garzik
This reverts commit 1757d902b029a29dfcef63609964385cf8865b5a. Discussion continues upstream.
2013-01-21libata: identify and init ZPODD devicesAaron Lu
The ODD can be enabled for ZPODD if the following three conditions are satisfied: 1 The ODD supports device attention; 2 The platform can runtime power off the ODD through ACPI; 3 The ODD is either slot type or drawer type. For such ODDs, zpodd_init is called and a new structure is allocated for it to store ZPODD related stuffs. And the zpodd_dev_enabled function is used to test if ZPODD is currently enabled for this ODD. A new config CONFIG_SATA_ZPODD is added to selectively build ZPODD code. Signed-off-by: Aaron Lu <aaron.lu@intel.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2013-01-14libata: export host controller number thru /sysDavid Milburn
As low-level drivers register their host controller(s), keep track of the number of controllers and export thru /sys in a <host.port> format so that udev can better match up port numbers with a specific controller. # pwd /sys/devices/pci0000:00 # find . -name 'ata*' -print (2nd controller with port multiplier attached) ./0000:00:1e.0/0000:05:01.0/ata2.7 ./0000:00:1e.0/0000:05:01.0/ata2.7/link7/dev7.0/ata_device ./0000:00:1e.0/0000:05:01.0/ata2.7/link7/ata_link ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.0/dev7.0.0/ata_device ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.0/ata_link ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.1/dev7.1.0/ata_device ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.1/ata_link ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.2/dev7.2.0/ata_device ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.2/ata_link ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.3/dev7.3.0/ata_device ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.3/ata_link ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.4/dev7.4.0/ata_device ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.4/ata_link ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.5/dev7.5.0/ata_device ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.5/ata_link ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.6/dev7.6.0/ata_device ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.6/ata_link ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.7/dev7.7.0/ata_device ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.7/ata_link ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.8/dev7.8.0/ata_device ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.8/ata_link ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.9/dev7.9.0/ata_device ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.9/ata_link ./0000:00:1e.0/0000:05:01.0/ata2.7/ata_port ./0000:00:1e.0/0000:05:01.0/ata2.7/ata_port/ata2.7 ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.10/dev7.10.0/ata_device ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.10/ata_link ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.11/dev7.11.0/ata_device ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.11/ata_link ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.12/dev7.12.0/ata_device ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.12/ata_link ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.13/dev7.13.0/ata_device ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.13/ata_link ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.14/dev7.14.0/ata_device ./0000:00:1e.0/0000:05:01.0/ata2.7/link7.14/ata_link ./0000:00:1e.0/0000:05:01.0/ata2.8 ./0000:00:1e.0/0000:05:01.0/ata2.8/link8/dev8.0/ata_device ./0000:00:1e.0/0000:05:01.0/ata2.8/link8/ata_link ./0000:00:1e.0/0000:05:01.0/ata2.8/ata_port ./0000:00:1e.0/0000:05:01.0/ata2.8/ata_port/ata2.8 (1st controller) ./0000:00:1f.2/ata1.1 ./0000:00:1f.2/ata1.1/link1/dev1.0/ata_device ./0000:00:1f.2/ata1.1/link1/ata_link ./0000:00:1f.2/ata1.1/ata_port ./0000:00:1f.2/ata1.1/ata_port/ata1.1 ./0000:00:1f.2/ata1.2 ./0000:00:1f.2/ata1.2/link2/dev2.0/ata_device ./0000:00:1f.2/ata1.2/link2/ata_link ./0000:00:1f.2/ata1.2/ata_port ./0000:00:1f.2/ata1.2/ata_port/ata1.2 ./0000:00:1f.2/ata1.3 ./0000:00:1f.2/ata1.3/link3/dev3.0/ata_device ./0000:00:1f.2/ata1.3/link3/ata_link ./0000:00:1f.2/ata1.3/ata_port ./0000:00:1f.2/ata1.3/ata_port/ata1.3 ./0000:00:1f.2/ata1.4 ./0000:00:1f.2/ata1.4/link4/dev4.0/ata_device ./0000:00:1f.2/ata1.4/link4/ata_link ./0000:00:1f.2/ata1.4/ata_port ./0000:00:1f.2/ata1.4/ata_port/ata1.4 ./0000:00:1f.2/ata1.5 ./0000:00:1f.2/ata1.5/link5/dev5.0/ata_device ./0000:00:1f.2/ata1.5/link5/ata_link ./0000:00:1f.2/ata1.5/ata_port ./0000:00:1f.2/ata1.5/ata_port/ata1.5 ./0000:00:1f.2/ata1.6 ./0000:00:1f.2/ata1.6/link6/dev6.0/ata_device ./0000:00:1f.2/ata1.6/link6/ata_link ./0000:00:1f.2/ata1.6/ata_port ./0000:00:1f.2/ata1.6/ata_port/ata1.6 Signed-off-by: David Milburn <dmilburn@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2013-01-14[libata] replace sata_settings with devslp_timingShane Huang
NCQ capability was used to check availability of SATA Settings page from Identify Device Data Log, which contains DevSlp timing variables. It does not work on some HDDs and leads to error messages. IDENTIFY word 78 bit 5(Hardware Feature Control) can't work either because it is only the sufficient condition of Identify Device data log, not the necessary condition. This patch replaced ata_device->sata_settings with ->devslp_timing to only save DevSlp timing variables(8 bytes), instead of the whole SATA Settings page(512 bytes). Addresses https://bugzilla.kernel.org/show_bug.cgi?id=51881 Reported-by: Borislav Petkov <bp@alien8.de> Signed-off-by: Shane Huang <shane.huang@amd.com> Cc: stable@vger.kernel.org Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-12-03libata: implement ata_platform_remove_one()Brian Norris
This relatively simple boiler-plate code is repeated in several platform drivers. We should implement a common version in libata. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-12-03libata: restore acpi disable functionalityAaron Lu
Commit 66fa7f215 "libata-acpi: improve ACPI disabling" introdcued the behaviour of disabling ATA ACPI if ata_acpi_on_devcfg failed the 2nd time, but commit 30dcf76ac dropped this behaviour and this caused problem for Dimitris Damigos, where his laptop can not resume correctly. The bugzilla page for it is: https://bugzilla.kernel.org/show_bug.cgi?id=49331 The problem is, ata_dev_push_id will fail the 2nd time it is invoked, and due to disabling ACPI code is dropped, ata_acpi_on_devcfg which calls ata_dev_push_id will keep failing and eventually made the device disabled. This patch restores the original behaviour, if acpi failed the 2nd time, disable acpi functionality for the device(and we do not event need to add a debug message for this as it is still there ;-). Reported-by: Dimitris Damigos <damigos@freemail.gr> Signed-off-by: Aaron Lu <aaron.lu@intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-10-02Merge tag 'scsi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull first round of SCSI updates from James Bottomley: "This is a large set of updates, mostly for drivers (qla2xxx [including support for new 83xx based card], qla4xxx, mpt2sas, bfa, zfcp, hpsa, be2iscsi, isci, lpfc, ipr, ibmvfc, ibmvscsi, megaraid_sas). There's also a rework for tape adding virtually unlimited numbers of tape drives plus a set of dif fixes for sd and a fix for a live lock on hot remove of SCSI devices. This round includes a signed tag pull of isci-for-3.6 Signed-off-by: James Bottomley <JBottomley@Parallels.com>" Fix up trivial conflict in drivers/scsi/qla2xxx/qla_nx.c due to new PCI helper function use in a function that was removed by this pull. * tag 'scsi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (198 commits) [SCSI] st: remove st_mutex [SCSI] sd: Ensure we correctly disable devices with unknown protection type [SCSI] hpsa: gen8plus Smart Array IDs [SCSI] qla4xxx: Update driver version to 5.03.00-k1 [SCSI] qla4xxx: Disable generating pause frames for ISP83XX [SCSI] qla4xxx: Fix double clearing of risc_intr for ISP83XX [SCSI] qla4xxx: IDC implementation for Loopback [SCSI] qla4xxx: update copyrights in LICENSE.qla4xxx [SCSI] qla4xxx: Fix panic while rmmod [SCSI] qla4xxx: Fail probe_adapter if IRQ allocation fails [SCSI] qla4xxx: Prevent MSI/MSI-X falling back to INTx for ISP82XX [SCSI] qla4xxx: Update idc reg in case of PCI AER [SCSI] qla4xxx: Fix double IDC locking in qla4_8xxx_error_recovery [SCSI] qla4xxx: Clear interrupt while unloading driver for ISP83XX [SCSI] qla4xxx: Print correct IDC version [SCSI] qla4xxx: Added new mbox cmd to pass driver version to FW [SCSI] scsi_dh_alua: Enable STPG for unavailable ports [SCSI] scsi_remove_target: fix softlockup regression on hot remove [SCSI] ibmvscsi: Fix host config length field overflow [SCSI] ibmvscsi: Remove backend abstraction ...
2012-09-13ahci: implement aggressive SATA device sleep supportShane Huang
Device Sleep is a feature as described in AHCI 1.3.1 Technical Proposal. This feature enables an HBA and SATA storage device to enter the DevSleep interface state, enabling lower power SATA-based systems. Aggressive Device Sleep enables the HBA to assert the DEVSLP signal as soon as there are no commands outstanding to the device and the port specific Device Sleep idle timer has expired. This enables autonomous entry into the DevSleep interface state without waiting for software in power sensitive systems. This patch enables Aggressive Device Sleep only if both host controller and device support it. Tested on AMD reference board together with Device Sleep supported device sample. Signed-off-by: Shane Huang <shane.huang@amd.com> Reviewed-by: Aaron Lu <aaron.lwe@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-08-24[SCSI] libsas, ipr: cleanup ata_host flags initialization via ata_host_initDan Williams
libsas and ipr pass flags to ata_host_init that are meant for the port. ata_host flags: ATA_HOST_SIMPLEX = (1 << 0), /* Host is simplex, one DMA channel per host only */ ATA_HOST_STARTED = (1 << 1), /* Host started */ ATA_HOST_PARALLEL_SCAN = (1 << 2), /* Ports on this host can be scanned in parallel */ ATA_HOST_IGNORE_ATA = (1 << 3), /* Ignore ATA devices on this host. */ flags passed by libsas: ATA_FLAG_SATA = (1 << 1), ATA_FLAG_PIO_DMA = (1 << 7), /* PIO cmds via DMA */ ATA_FLAG_NCQ = (1 << 10), /* host supports NCQ */ The only one that aliases is ATA_HOST_STARTED which is a 'don't care' in the libsas and ipr cases since ata_hosts from these sources are not registered with libata. Reported-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Brian King <brking@us.ibm.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-08-24[SCSI] libata: export ata_port suspend/resume infrastructure for sasDan Williams
Reuse ata_port_{suspend|resume}_common for sas. This path is chosen over adding coordination between ata-tranport and sas-transport because libsas wants to revalidate the domain at resume-time at the host level. It can not validate links have resumed properly until libata has had a chance to perform its revalidation, and any sane placing of an ata_port in the sas-transport model would delay it's resumption until after the host. Export the common portion of port suspend/resume (bypass pm_runtime), and allow sas to perform these operations asynchronously (similar to the libsas async-ata probe implmentation). Async operation is determined by having an external, rather than stack based, location for storing the result of the operation. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Reviewed-by: Jacek Danecki <jacek.danecki@intel.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-08-24[SCSI] libata: reset onceDan Williams
Hotplug testing with libsas currently encounters a 55 second wait for link recovery to give up. In the case where the user trusts the response time of their devices permit the recovery attempts to be limited to one. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-07-25Merge branch 'master' [vanilla Linus master] into libata-dev.git/upstreamJeff Garzik
Two bits were appended to the end of the bitfield list in struct scsi_device. Resolve that conflict by including both bits. Conflicts: include/scsi/scsi_device.h
2012-07-20[SCSI] libata, libsas: introduce sched_eh and end_eh port opsDan Williams
When managing shost->host_eh_scheduled libata assumes that there is a 1:1 shost-to-ata_port relationship. libsas creates a 1:N relationship so it needs to manage host_eh_scheduled cumulatively at the host level. The sched_eh and end_eh port port ops allow libsas to track when domain devices enter/leave the "eh-pending" state under ha->lock (previously named ha->state_lock, but it is no longer just a lock for ha->state changes). Since host_eh_scheduled indicates eh without backing commands pinning the device it can be deallocated at any time. Move the taking of the domain_device reference under the port_lock to guarantee that the ata_port stays around for the duration of eh. Reviewed-by: Jacek Danecki <jacek.danecki@intel.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-06-29libata: detect Device Attention supportLin Ming
Add a new flag ATA_DFLAG_DA to indicate that device supports "Device Attention". Acked-by: Aaron Lu <aaron.lu@amd.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
