Most SCSI drivers want to enable "clustering", that is merging of
segments so that they might span more than a single page. Remove the
ENABLE_CLUSTERING define, and require drivers to explicitly set
DISABLE_CLUSTERING to disable this feature.
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata
Pull libata updates from Tejun Heo:
"Nothing too interesting. Mostly ahci and ahci_platform changes, many
around power management"
* 'for-4.19' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: (22 commits)
ata: ahci_platform: enable to get and control reset
ata: libahci_platform: add reset control support
ata: add an extra argument to ahci_platform_get_resources()
ata: sata_rcar: Add r8a77965 support
ata: sata_rcar: exclude setting of PHY registers in Gen3
ata: sata_rcar: really mask all interrupts on Gen2 and later
Revert "ata: ahci_platform: allow disabling of hotplug to save power"
ata: libahci: Allow reconfigure of DEVSLP register
ata: libahci: Correct setting of DEVSLP register
ata: ahci: Enable DEVSLP by default on x86 with SLP_S0
ata: ahci: Support state with min power but Partial low power state
Revert "ata: ahci_platform: convert kcalloc to devm_kcalloc"
ata: sata_rcar: Add rudimentary Runtime PM support
ata: sata_rcar: Provide a short-hand for &pdev->dev
ata: Only output sg element mapped number in verbose debug
ata: Guard ata_scsi_dump_cdb() by ATA_VERBOSE_DEBUG
ata: ahci_platform: convert kzallloc to kcalloc
ata: ahci_platform: correct parameter documentation for ahci_platform_shutdown
libata: remove ata_sff_data_xfer_noirq()
Pull SCSI updates from James Bottomley:
"This is mostly updates to the usual drivers: mpt3sas, lpfc, qla2xxx,
hisi_sas, smartpqi, megaraid_sas, arcmsr.
In addition, with the continuing absence of Nic we have target updates
for tcmu and target core (all with reviews and acks).
The biggest observable change is going to be that we're (again) trying
to switch to mulitqueue as the default (a user can still override the
setting on the kernel command line).
Other major core stuff is the removal of the remaining Microchannel
drivers, an update of the internal timers and some reworks of
completion and result handling"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (203 commits)
scsi: core: use blk_mq_run_hw_queues in scsi_kick_queue
scsi: ufs: remove unnecessary query(DM) UPIU trace
scsi: qla2xxx: Fix issue reported by static checker for qla2x00_els_dcmd2_sp_done()
scsi: aacraid: Spelling fix in comment
scsi: mpt3sas: Fix calltrace observed while running IO & reset
scsi: aic94xx: fix an error code in aic94xx_init()
scsi: st: remove redundant pointer STbuffer
scsi: qla2xxx: Update driver version to 10.00.00.08-k
scsi: qla2xxx: Migrate NVME N2N handling into state machine
scsi: qla2xxx: Save frame payload size from ICB
scsi: qla2xxx: Fix stalled relogin
scsi: qla2xxx: Fix race between switch cmd completion and timeout
scsi: qla2xxx: Fix Management Server NPort handle reservation logic
scsi: qla2xxx: Flush mailbox commands on chip reset
scsi: qla2xxx: Fix unintended Logout
scsi: qla2xxx: Fix session state stuck in Get Port DB
scsi: qla2xxx: Fix redundant fc_rport registration
scsi: qla2xxx: Silent erroneous message
scsi: qla2xxx: Prevent sysfs access when chip is down
scsi: qla2xxx: Add longer window for chip reset
Currently when min_power policy is selected, the partial low power state
is not entered and link will try aggressively enter to only slumber state.
Add a new policy which still enable DEVSLP but also try to enter partial
low power state. This policy is presented as "min_power_with_partial".
For information the difference between partial and slumber
Partial – PHY logic is powered up, and in a reduced power state. The link
PM exit latency to active state maximum is 10 ns.
Slumber – PHY logic is powered up, and in a reduced power state. The link
PM exit latency to active state maximum is 10 ms.
Devslp – PHY logic is powered down. The link PM exit latency from this
state to active state maximum is 20 ms, unless otherwise specified by
DETO.
Suggested-and-reviewed-by: Hans de Goede <hdegoede@redhat.com>
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
ata_sff_data_xfer_noirq() is invoked via the ->sff_data_xfer hook. The
latter is invoked by ata_pio_sector(), atapi_send_cdb() and
__atapi_pio_bytes() which in turn is invoked by ata_sff_hsm_move().
The latter function requires that the "ap->lock" lock is held which
needs to be taken with disabled interrupts.
There is no need have to have ata_sff_data_xfer_noirq() which invokes
ata_sff_data_xfer32() with disabled interrupts because at this point the
interrupts are already disabled.
Remove the function and its references to it and replace all callers
with ata_sff_data_xfer32().
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
There have been several reports of LPM related hard freezes about once
a day on multiple Lenovo 50 series models. Strange enough these reports
where not disk model specific as LPM issues usually are and some users
with the exact same disk + laptop where seeing them while other users
where not seeing these issues.
It turns out that enabling LPM triggers a firmware bug somewhere, which
has been fixed in later BIOS versions.
This commit adds a new ahci_broken_lpm() function and a new ATA_FLAG_NO_LPM
for dealing with this.
The ahci_broken_lpm() function contains DMI match info for the 4 models
which are known to be affected by this and the DMI BIOS date field for
known good BIOS versions. If the BIOS date is older then the one in the
table LPM will be disabled and a warning will be printed.
Note the BIOS dates are for known good versions, some older versions may
work too, but we don't know for sure, the table is using dates from BIOS
versions for which users have confirmed that upgrading to that version
makes the problem go away.
Unfortunately I've been unable to get hold of the reporter who reported
that BIOS version 2.35 fixed the problems on the W541 for him. I've been
able to verify the DMI_SYS_VENDOR and DMI_PRODUCT_VERSION from an older
dmidecode, but I don't know the exact BIOS date as reported in the DMI.
Lenovo keeps a changelog with dates in their release notes, but the
dates there are the release dates not the build dates which are in DMI.
So I've chosen to set the date to which we compare to one day past the
release date of the 2.34 BIOS. I plan to fix this with a follow up
commit once I've the necessary info.
Cc: stable@vger.kernel.org
Commit 2623c7a5f2 ("libata: add refcounting to ata_host") v4.17+ introduced
refcounting to ata_host and will increase or decrease the refcount when
adding or deleting transport ATA port.
Now the ata host for libsas is embedded in domain_device, and the ->kref
member is not initialized. Afer we add ata transport class, ata_host_get()
will be called when adding transport ATA port and a warning will be
triggered as below:
refcount_t: increment on 0; use-after-free.
WARNING: CPU: 2 PID: 103 at
lib/refcount.c:153 refcount_inc+0x40/0x48 ...... Call trace:
ata_host_get+0x10/0x18
ata_tport_add+0x40/0x120
ata_sas_tport_add+0xc/0x14
sas_ata_init+0x7c/0xc8
sas_discover_domain+0x380/0x53c
process_one_work+0x12c/0x288
worker_thread+0x58/0x3f0
kthread+0xfc/0x128
ret_from_fork+0x10/0x18
And also when removing transport ATA port ata_host_put() will be called and
another similar warning will be triggered. If the refcount decreased to
zero, the ata host will be freed. But this ata host is only part of
domain_device, it cannot be freed directly.
So we have to change this embedded static ata host to a dynamically
allocated ata host and initialize the ->kref member. To use ata_host_get()
and ata_host_put() in libsas, we need to move the declaration of these
functions to the public libata.h and export them.
Fixes: b6240a4df018 ("scsi: libsas: add transport class for ATA devices")
Signed-off-by: Jason Yan <yanaijie@huawei.com>
CC: John Garry <john.garry@huawei.com>
CC: Taras Kondratiuk <takondra@cisco.com>
CC: Tejun Heo <tj@kernel.org>
Acked-by: Tejun Heo <tj@kernel.org>
Now that we have the internal tag as a special (higher) value tag,
it gets a bit tricky to iterate the internal commands as some loops
will exceed ATA_MAX_QUEUE. Add explicit helpers for iterating pending
commands, both inflight and internal.
"This is mostly updates to the usual drivers: ufs, qedf, mpt3sas, lpfc,
xfcp, hisi_sas, cxlflash, qla2xxx.
In the absence of Nic, we're also taking target updates which are
mostly minor except for the tcmu refactor.
The only real core change to worry about is the removal of high page
bouncing (in sas, storvsc and iscsi). This has been well tested and no
problems have shown up so far"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (268 commits)
scsi: lpfc: update driver version to 12.0.0.4
scsi: lpfc: Fix port initialization failure.
scsi: lpfc: Fix 16gb hbas failing cq create.
scsi: lpfc: Fix crash in blk_mq layer when executing modprobe -r lpfc
scsi: lpfc: correct oversubscription of nvme io requests for an adapter
scsi: lpfc: Fix MDS diagnostics failure (Rx < Tx)
scsi: hisi_sas: Mark PHY as in reset for nexus reset
scsi: hisi_sas: Fix return value when get_free_slot() failed
scsi: hisi_sas: Terminate STP reject quickly for v2 hw
scsi: hisi_sas: Add v2 hw force PHY function for internal ATA command
scsi: hisi_sas: Include TMF elements in struct hisi_sas_slot
scsi: hisi_sas: Try wait commands before before controller reset
scsi: hisi_sas: Init disks after controller reset
scsi: hisi_sas: Create a scsi_host_template per HW module
scsi: hisi_sas: Reset disks when discovered
scsi: hisi_sas: Add LED feature for v3 hw
scsi: hisi_sas: Change common allocation mode of device id
scsi: hisi_sas: change slot index allocation mode
scsi: hisi_sas: Introduce hisi_sas_phy_set_linkrate()
scsi: hisi_sas: fix a typo in hisi_sas_task_prep()
- libata has always been limiting the maximum queue depth to 31, with
one entry set aside mostly for historical reasons. This didn't use to
make much difference but Jens found out that modern hard drives can
actually perform measurably better with the extra one queue depth.
Jens updated libata core so that it can make use of full 32 queue
depth
- Damien updated command retry logic in error handling so that it
doesn't unnecessarily retry when upper layer (SCSI) is gonna handle
them
- A couple misc changes
* 'for-4.18' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata:
sata_fsl: use the right type for tag bitshift
ahci: enable full queue depth of 32
libata: don't clamp queue depth to ATA_MAX_QUEUE - 1
libata: add extra internal command
sata_nv: set host can_queue count appropriately
libata: remove assumption that ATA_MAX_QUEUE - 1 is the max
libata: use ata_tag_internal() consistently
libata: bump ->qc_active to a 64-bit type
libata: convert core and drivers to ->hw_tag usage
libata: introduce notion of separate hardware tags
libata: Fix command retry decision
libata: Honor RQF_QUIET flag
libata: Make ata_dev_set_mode() less verbose
libata: Fix ata_err_string()
libata: Fix comment typo in ata_eh_analyze_tf()
sata_nv: don't use block layer bounce buffer
ata: hpt37x: Convert to use match_string() helper
As far as I can tell this function can't even be called any more, given
that ATA implements its own eh_strategy_handler with ata_scsi_error, which
never calls ->eh_timed_out.
Reviewed-by: Hannes Reinecke <hare@suse.com>
Bump the internal tag to 32, instead of stealing the last tag in
our regular command space. This works just fine, since we don't
actually need a separate hardware tag for this. Internal commands
cannot coexist with NCQ commands.
As a bonus, we get rid of the special casing of what tag to use
for the internal command.
This is in preparation for utilizing all 32 commands for normal IO.
Some check for the value directly, use the provided helper instead.
Also make it return a bool, since that's what it does.
This is in preparation for allowing full usage of the tag space,
which means that our reserved error handling command will be
using an internal tag value of 32. This doesn't fit in a u32, so
move to a u64.
Rigth now these are the same, but drivers should be using ->hw_tag
for their command setup and issue.
Now ata devices attached with sas controller do not have transport
class, so that we can not see any information of these ata devices in
/sys/class/ata_port(or ata_link or ata_device).
Add transport class for the ata devices attached with sas controller.
The /sys/class directory will show the infomation of the ata devices
as follows:
localhost:/sys/class # ls ata*
ata_device:
dev1.0 dev2.0
ata_link:
link1 link2
ata_port:
ata1 ata2
No functional change of the device scanning and io path. The ata
transport class was deleted when destroying the sas devices.
CC: Dan Williams <dan.j.williams@intel.com>
After commit 9a6d6a2ddabb ("ata: make ata port as parent device of scsi
host") manual driver unbind/remove causes use-after-free.
Unbind unconditionally invokes devres_release_all() which calls
ata_host_release() and frees ata_host/ata_port memory while it is still
being referenced as a parent of SCSI host. When SCSI host is finally
released scsi_host_dev_release() calls put_device(parent) and accesses
freed ata_port memory.
Add reference counting to make sure that ata_host lives long enough.
Bug report: https://lkml.org/lkml/2017/11/1/945
Fixes: 9a6d6a2ddabb ("ata: make ata port as parent device of scsi host")
Cc: Tejun Heo <tj@kernel.org>
Cc: Lin Ming <minggr@gmail.com>
Cc: linux-ide@vger.kernel.org
Signed-off-by: Taras Kondratiuk <takondra@cisco.com>
As described by Matthew Garret quite a while back:
https://mjg59.dreamwidth.org/34868.html
Intel CPUs starting with the Haswell generation need SATA links to power
down for the "package" part of the CPU to reach low power-states like
PC7 / P8 which bring a significant power-saving with them.
The default max_performance lpm policy does not allow for these high
PC states, both the medium_power and min_power policies do allow this.
The min_power policy saves significantly more power, but there are some
reports of some disks / SSDs not liking min_power leading to system
crashes and in some cases even data corruption has been reported.
Matthew has found a document documenting the default settings of
Intel's IRST Windows driver with which most laptops ship:
https://www-ssl.intel.com/content/dam/doc/reference-guide/sata-devices-implementation-recommendations.pdf
Matthew wrote a patch changing med_power to match those defaults, but
that never got anywhere as some people where reporting issues with the
patch-set that patch was a part of.
This commit is another attempt to make the default IRST driver settings
available under Linux, but instead of changing medium_power and
potentially introducing regressions, this commit adds a new
med_power_with_dipm setting which is identical to the existing
medium_power accept that it enables dipm on top, which makes it match
the Windows IRST driver settings, which should hopefully be safe to
use on most devices.
The med_power_with_dipm setting is close to min_power, except that:
a) It does not use host-initiated slumber mode (ASP not set),
but it does allow device-initiated slumber
b) It does not enable DevSlp mode
On my T440s test laptop I get the following power savings when idle:
medium_power 0.9W
med_power_with_dipm 1.2W
min_power 1.2W
Suggested-by: Matthew Garrett <mjg59@srcf.ucam.org>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
The warning message "READ LOG DMA EXT failed, trying unqueued" in
ata_read_log_page() as well as the macro name ATA_HORKAGE_NO_NCQ_LOG
are confusing: the command READ LOG DMA EXT is not an queued NCQ command
unless it is encapsulated in a RECEIVE FPDMA QUEUED command.
From ACS-4 READ LOG DMA EXT description:
"The device processes the READ LOG DMA EXT command in the NCQ feature
set environment (see 4.13.6) if the READ LOG DMA EXT command is
encapsulated in a RECEIVE FPDMA QUEUED command (see 7.30) with the
inputs encapsulated as shown in 7.23.6."
To avoid confusion, fix the warning messsage to mention switching to PIO and
not "unqueued" and rename the macro ATA_HORKAGE_NO_NCQ_LOG to
ATA_HORKAGE_NO_DMA_LOG.
Signed-off-by: Damien Le Moal <damien.lemoal@wdc.com>
This allows us to use the generic OPAL code with ATA devices.
The libata documentation is now using ReST. Update references
to it to point to the new place.
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
Acked-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
- Bartlomiej added pata_falcon
- Christoph is trying to remove use of static 4k buf. It's still WIP
- config cleanup around HAS_DMA
- other fixes and driver-specific changes
* 'for-4.11' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: (29 commits)
ata: pata_of_platform: using of_property_read_u32() helper
pata_atiixp: Don't use unconnected secondary port on SB600/SB700
libata-sff: Don't scan disabled ports when checking for legacy mode.
pata_octeon_cf: remove unused local variables from octeon_cf_set_piomode()
ahci: qoriq: added ls2088a platforms support
ahci: qoriq: report error when ecc register address is missing in dts
ahci: qoriq: added a condition to enable dma coherence
Revert "libata: switch to dynamic allocation instead of ata_scsi_rbuf"
ahci: imx: fix building without hwmon or thermal
ata: add Atari Falcon PATA controller driver
ata: pass queued command to ->sff_data_xfer method
ata: allow subsystem to be used on m68k arch
libata: don't call ata_scsi_rbuf_fill for command without a response buffer
libata: call ->scsi_done from ata_scsi_simulate
libata: remove the done callback from ata_scsi_args
libata: move struct ata_scsi_args to libata-scsi.c
libata: avoid global response buffer in atapi_qc_complete
libata-eh: Use switch() instead of sparse array for protocol strings
ata: sata_mv: Convert to devm_ioremap_resource()
Instead define the timeout behavior purely based on the host_template
eh_timed_out method and wire up the existing transport implementations
in the host templates. This also clears up the confusion that the
transport template method overrides the host template one, so some
drivers have to re-override the transport template one.
Reviewed-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com>
For Atari Falcon PATA support we need to check the current command
in its ->sff_data_xfer method. Update core code and all users
accordingly.
There should be no functional changes caused by this patch.
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Add a sysfs entry to turn on priority information being passed
to a ATA device. By default this feature is turned off.
This patch depends on ata: Enabling ATA Command Priorities
tj: Renamed ncq_prio_on to ncq_prio_enable and removed trivial
ata_ncq_prio_on() and open-coded the test.
Signed-off-by: Adam Manzanares <adam.manzanares@hgst.com>
This patch checks to see if an ATA device supports NCQ command priorities.
If so and the user has specified an iocontext that indicates
IO_PRIO_CLASS_RT then we build a tf with a high priority command.
This is done to improve the tail latency of commands that are high
priority by passing priority to the device.
tj: Removed trivial ata_ncq_prio_enabled() and open-coded the test.
asm-generic is only intended for architecture defaults, and we can simply
kill it off by moving the two defintions directly to <linux/libata.h>.
This avoid the need to always translate between the two in ata_prot_flags
and generally cleans up the taskfile protocol usage.
Instead we can simply check for PIO or DMA in ata_is_data.
The only caller can just check for !ata_is_data instead.
Add a new taskfile protocol ATA_PROT_NCQ_NODATA to handle
ATA NCQ NO-DATA commands correctly.
And fixup ata_scsi_zbc_out_xlat() to use it.
Signed-off-by: Hannes Reinecke <hare@suse.com>
This way we don't have to worry about the exact bit postition of the
test to leak out and any crazy propagation effects in the callers.
Suggested-by: Tejun Heo <tj@kernel.org>
Byte 69 bits 0:1 in the IDENTIFY DEVICE data indicate a
host-aware ZAC device.
Host-managed ZAC devices have their own individual signature,
and to not set the bits in the IDENTIFY DEVICE data.
And whenever we detect a ZAC-compatible device we should
be displaying the zoned block characteristics VPD page.
Signed-off-by: Hannes Reinecke <hare@suse.de>
Add NCQ encapsulation for ZAC MANAGEMENT OUT and evaluate
NCQ Non-Data log pages to figure out if NCQ encapsulation
is supported.
ZAC drives implement a 'ZAC Management In' command template,
which maps onto the ZBC IN command.
libata device disabling is ... curious. So add the correct
definitions that we can disable ZAC devices properly.
ACS-4 defines an NCQ encapsulation for READ LOG DMA EXT.
Implement MODE SELECT for the control mode page to allow the OS
to switch to descriptor sense.
tj: Dropped s/sb/cmd->sense_buffer/ in ata_gen_ata_sense(). Added
@dev description to ata_msense_ctl_mode().
The id buffer in ata_device is a DMA target, but it isn't explicitly
cacheline aligned. Due to this, adjacent fields can be overwritten with
stale data from memory on non coherent architectures. As a result, the
kernel is sometimes unable to communicate with an ATA device.
Fix this by ensuring that the id buffer is cacheline aligned.
This issue is similar to that fixed by Commit 84bda12af31f
("libata: align ap->sector_buf").
Signed-off-by: Harvey Hunt <harvey.hunt@imgtec.com>
Cc: <stable@vger.kernel.org> # 2.6.18
The AHCI driver code stops and starts port DMA engines at will
without considering the power state of the particular port. The
AHCI specification isn't very clear on how to handle this scenario,
leaving implementation open to interpretation.
Broadcom's STB SATA host controller is unable to handle port DMA
controller restarts when the port in question is in low power mode.
When a port enters partial or slumber mode, its PHY is powered down.
When a controller restart is requested, the controller's internal
state machine expects the PHY to be brought back up by software which
never happens in this case, resulting in failures.
To avoid this situation, logic is added to manually wake up the port
just before its DMA engine is stopped, if the port happens to be in
a low power state. HBA initiated power management ensures that the port
eventually returns to its configured low power state, when the link is
idle (as per the conditions listed in the spec). A new host flag is also
added to ensure this logic is only exercised for hosts with the above
limitation.
tj: Formatting changes.
Signed-off-by: Danesh Petigara <dpetigara@broadcom.com>
Reviewed-by: Markus Mayer <mmayer@broadcom.com>
"Mostly low level driver specific changes.
Two changes are somewhat noteworthy. First, Dan's patchset to support
per-port msix interrupt handling for ahci, which was tried last cycle
but had to be backed out due to a couple issues, is back and seems to
be working fine. Second, libata exception handling now uses
usleep_range() instead of msleep() for sleeps < 20ms which can make
things snappier in some corner cases"
* 'for-4.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata:
libata: skip debounce delay on link resume
ata: ahci_brcmstb: disable DIPM support
ata: ahci_brcmstb: enable support for ALPM
drivers: libata-core: Use usleep_range() instead of msleep() for short sleeps (<20 ms)
sata_sx4: correctly handling failed allocation
ata: ahci_brcmstb: add support for MIPS-based platforms
ahci: qoriq: Adjust the default register values on ls1021a
ahci: qoriq: Update the default Rx watermark value
ahci: qoriq: Adjust the default register values on ls1043a
ahci: compile out msi/msix infrastructure
ata: core: fix irq description on AHCI single irq systems
ata: ahci_brcmstb: remove unused definitions
ata: ahci_brcmstb: add a quirk for MIPS-based platforms
ata: ahci_brcmstb: disable NCQ for MIPS-based platforms
ata: sata_rcar: Remove obsolete platform_device_id entries
sata_rcar: Add compatible string for r8a7795
ahci: kill 'intr_status'
ahci: switch from 'threaded' to 'hardirq' interrupt handling
ahci: per-port msix support
The link resume logic uses a 200msec delay while debouncing
the SControl register. The rationale behind that delay is
to accommodate some PHYs that behave badly if their SStatus/
SControl registers are pounded immediately on resume.
The Broadcom STB SATA PHY does not seem to have this issue.
This patch introduces a new link flag that allows platforms
to skip the debounce delay if it isn't needed.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
log page
Some controller lockup on a ata_read_log_page.
Add new ata port flag ATA_FLAG_NO_LOG_PAGE which can used
to blacklist a controller.
If this flag is set, any attempt to read a log page returns an error
without actually issuing the command.
Signed-off-by: Andreas Werner <andreas.werner@men.de>
If the AHCI ports' HPCP or ESP bits are set, the port
should be considered external (e.g. eSATA) and is marked
as removable. Userspace tools like udisks then treat it
like an usb drive.
With this patch applied, when I plug a drive into the esata port,
KDE pops up a window asking what to do with the drives(s), just
like it does for any random USB stick.
Removability is indicated to the upper layers by way of the
SCSI RMB bit, as I haven't found another way to signal
userspace to treat a sata disk like any usb stick.
Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com>
limit
Since no longer limiting max_sectors to BLK_DEF_MAX_SECTORS (commit 34b48db66e08),
data corruption may occur on ST380013AS drive configured on 82801JI (ICH10 Family)
SATA controller. This patch will allow the driver to limit max_sectors as before
# cat /sys/block/sdb/queue/max_sectors_kb
512
I was able to double the max_sectors_kb value up to 16384 on linux-4.2.0-rc2
before seeing corruption, but seems safer to use previous limit. Without this
patch max_sectors_kb will be 32767.
tj: Minor comment update.
Reported-by: Jeff Moyer <jmoyer@redhat.com>
Signed-off-by: David Milburn <dmilburn@redhat.com>
Cc: stable@vger.kernel.org # v3.19 and later
Fixes: 34b48db66e08 ("block: remove artifical max_hw_sectors cap")
Some devices lose data on TRIM whether queued or not. This patch adds
a horkage to disable TRIM.
tj: Collapsed unnecessary if() nesting.
Signed-off-by: Arne Fitzenreiter <arne_f@ipfire.org>
- a number of libata core changes to better support NCQ TRIM.
- ahci now supports MSI-X in single IRQ mode to support a new
controller which doesn't implement MSI or INTX.
- ahci now supports edge-triggered IRQ mode to support a new controller
which for some odd reason did edge-triggered IRQ.
- the usual controller support additions and changes.
* 'for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: (27 commits)
libata: Do not blacklist Micron M500DC
ata: ahci_mvebu: add suspend/resume support
ahci, msix: Fix build error for !PCI_MSI
ahci: Add support for Cavium's ThunderX host controller
ahci: Add generic MSI-X support for single interrupts to SATA PCI driver
libata: finally use __initconst in ata_parse_force_one()
drivers: ata: add support for Ceva sata host controller
devicetree:bindings: add devicetree bindings for ceva ahci
ahci: added support for Freescale AHCI sata
ahci: Store irq number in struct ahci_host_priv
ahci: Move interrupt enablement code to a separate function
Doc: libata: Fix spelling typo found in libata.xml
ata:sata_nv - Change 1 to true for bool type variable.
ata: add Broadcom AHCI SATA3 driver for STB chips
Documentation: devicetree: add Broadcom SATA binding
libata: Fix regression when the NCQ Send and Receive log page is absent
ata: hpt366: fix constant cast warning
ata: ahci_xgene: potential NULL dereference in probe
ata: ahci_xgene: Add AHCI Support for 2nd HW version of APM X-Gene SoC AHCI SATA Host controller.
libahci: Add support to handle HOST_IRQ_STAT as edge trigger latch.
"This is the usual grab bag of driver updates (lpfc, hpsa,
megaraid_sas, cxgbi, be2iscsi) plus an assortment of minor updates.
There is also one new driver: the Cisco snic. The advansys driver has
been rewritten to get rid of the warning about converting it to the
DMA API, the tape statistics patch got in and finally, there's a
resuffle of SCSI header files to separate more cleanly initiator from
target mode (and better share the common definitions)"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (156 commits)
snic: driver for Cisco SCSI HBA
qla2xxx: Fix indentation
qla2xxx: Comment out unreachable code
fusion: remove dead MTRR code
advansys: fix compilation errors and warnings when CONFIG_PCI is not set
mptsas: fix depth param in scsi_track_queue_full
megaraid: fix irq setup process regression
lpfc: Update version to 10.7.0.0 for upstream patch set.
lpfc: Fix to drop PLOGIs from fabric node till LOGO processing completes
lpfc: Fix scsi task management error message.
lpfc: Fix cq_id masking problem.
lpfc: Fix scsi prep dma buf error.
lpfc: Add support for using block multi-queue
lpfc: Devices are not discovered during takeaway/giveback testing
lpfc: Fix vport deletion failure.
lpfc: Check for active portpeerbeacon.
lpfc: Update driver version for upstream patch set 10.6.0.1.
lpfc: Change buffer pool empty message to miscellaneous category
lpfc: Fix incorrect log message reported for empty FCF record.
lpfc: Fix rport leak.
'0' is now used as the default cmd_per_lun value,
so there's no need to explicitly set it to '1' in the
host template.
Signed-off-by: James Bottomley <JBottomley@Odin.com>
Some devices advertise support for the READ/WRITE LOG DMA EXT commands
but fail when we try to issue them. This can lead to queued TRIM being
unintentionally disabled since the relevant feature flag is located in a
general purpose log page.
Fall back to unqueued READ LOG EXT if the DMA variant fails while
reading a log page.
Reviewed-by: Hannes Reinecke <hare@suse.de>
