path: root/include/linux/ktime.h
2007-05-09declare struct ktimeAndrew Morton
Some smarty went and inflicted ktime_t as a typedef upon us, so we cannot forward declare it. Create a new `union ktime', map ktime_t onto that. Now we need to kill off this ktime_t thing. Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-25[TCP]: Fix linkage errors on i386.YOSHIFUJI Hideaki
To avoid raw division, use ktime_to_timeval() to get usec. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-16[PATCH] fix MTIME_SEC_MAX on 32-bitThomas Gleixner
The maximum seconds value we can handle on 32bit is LONG_MAX. Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] hrtimers: add high resolution timer supportThomas Gleixner
Implement high resolution timers on top of the hrtimers infrastructure and the clockevents / tick-management framework. This provides accurate timers for all hrtimer subsystem users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Numerous fixes to kernel-doc info in source files.Robert P. J. Day
A variety of (mostly) innocuous fixes to the embedded kernel-doc content in source files, including: * make multi-line initial descriptions single line * denote some function names, constants and structs as such * change erroneous opening '/*' to '/**' in a few places * reword some text for clarity Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] ktime: Fix signed / unsigned mismatch in ktime_to_nsThomas Gleixner
The 32 bit implementation of ktime_to_ns returns unsigned value, while the 64 bit version correctly returns an signed value. There is no current user affected by this, but it has to be fixed, as ktime values can be negative. Pointed-out-by: Helmut Duregger <Helmut.Duregger@student.uibk.ac.at> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-06[PATCH] prevent timespec/timeval to ktime_t overflowThomas Gleixner
Frank v. Waveren pointed out that on 64bit machines the timespec to ktime_t conversion might overflow. This is also true for timeval to ktime_t conversions. This breaks a "sleep inf" on 64bit machines. While a timespec/timeval with tx.sec = MAX_LONG is valid by specification the internal representation of ktime_t is based on nanoseconds. The conversion of seconds to nanoseconds overflows for seconds values >= (MAX_LONG / NSEC_PER_SEC). Check the seconds argument to the conversion and limit it to the maximum time which can be represented by ktime_t. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Frank v Waveren <fvw@var.cx> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ktime/hrtimer: fix kernel-doc commentsRandy Dunlap
Fix kernel-doc formatting in ktime.h and hrtimer.[ch] files. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] hrtimers: remove DEFINE_KTIME and ktime_to_clock_t()Roman Zippel
Now that it_real_value is gone, the last user of DEFINE_KTIME and ktime_to_clock_t are also gone, so remove it before someone starts using it again. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-15[PATCH] hrtimer: fix multiple macro argument expansionRoman Zippel
For two macros the arguments were expanded twice, change them to inline functions to avoid it. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] hrtimers: add back lost credit linesThomas Gleixner
At some point we added credits to people who actively helped to bring k/hr-timers along. This was lost in the big code revamp. Add it back. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[hrtimer] Change resolution storage to ktime_t formatThomas Gleixner
Change the storage format of the per base resolution to ktime_t to make it easier accessible in the hrtimers code. Change the resolution from (NSEC_PER_SEC/HZ) to TICK_NSEC as Roman pointed out. TICK_NSEC is closer to the real resolution. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-01-10[PATCH] hrtimer: hrtimer core codeThomas Gleixner
hrtimer subsystem core. It is initialized at bootup and expired by the timer interrupt, but is otherwise not utilized by any other subsystem yet. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: introduce ktime_t time formatThomas Gleixner
- introduce ktime_t: nanosecond-resolution time format. - eliminate the plain s64 scalar type, and always use the union. This simplifies the arithmetics. Idea from Roman Zippel. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
