path: root/include/linux/interrupt.h
2008-04-17[S390] genirq/clockevents: move irq affinity prototypes/inlines to interrupt.hRussell King
> Generic code is not supposed to include irq.h. Replace this include > by linux/hardirq.h instead and add/replace an include of linux/irq.h > in asm header files where necessary. > This change should only matter for architectures that make use of > GENERIC_CLOCKEVENTS. > Architectures in question are mips, x86, arm, sh, powerpc, uml and sparc64. > > I did some cross compile tests for mips, x86_64, arm, powerpc and sparc64. > This patch fixes also build breakages caused by the include replacement in > tick-common.h. I generally dislike adding optional linux/* includes in asm/* includes - I'm nervous about this causing include loops. However, there's a separate point to be discussed here. That is, what interfaces are expected of every architecture in the kernel. If generic code wants to be able to set the affinity of interrupts, then that needs to become part of the interfaces listed in linux/interrupt.h rather than linux/irq.h. So what I suggest is this approach instead (against Linus' tree of a couple of days ago) - we move irq_set_affinity() and irq_can_set_affinity() to linux/interrupt.h, change the linux/irq.h includes to linux/interrupt.h and include asm/irq_regs.h where needed (asm/irq_regs.h is supposed to be rarely used include since not much touches the stacked parent context registers.) Build tested on ARM PXA family kernels and ARM's Realview platform kernels which both use genirq. [ tglx@linutronix.de: add GENERIC_HARDIRQ dependencies ] Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-02-13include/linux: Remove all users of FASTCALL() macroHarvey Harrison
FASTCALL() is always expanded to empty, remove it. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06proper show_interrupts() prototypeAdrian Bunk
Add a proper prototype for show_interrupts() in include/linux/interrupt.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-25Preempt-RCU: Use softirq instead of tasklets forDipankar Sarma
This patch makes RCU use softirq instead of tasklets. It also adds a memory barrier after raising the softirq inorder to ensure that the cpu sees the most recently updated value of rcu->cur while processing callbacks. The discussion of the related theoretical race pointed out by James Huang can be found here --> http://lkml.org/lkml/2007/11/20/603 Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Reviewed-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-17Completely remove deprecated IRQ flags (SA_*)Ahmed S. Darwish
Only very little files use the deprecated SA_* IRQ flags in latest pull. This patch series removes such macros from the tree and transfrom old code to the new IRQF_* flags. I've grepped the whole tree to make sure that no more files than the patched ones use such deprecated macros. I hope this series won't introduce build errors. Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16provide stubs for enable_irq_wake() and disable_irq_wake()Guennadi Liakhovetski
Provide {enable,disable}_irq_wakeup dummies for undefined cross-compilers for platforms without CONFIG_GENERIC_IRQ. Needed by wake-up-from-a-serial-port.patch Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-28rip some includes from linux/interrupt.hAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-22take declarations of enable_irq() et.al. to linux/interrupt.hAl Viro
Now that the last inlined instances are gone, all that is left to do is turning disable_irq_nosync on arm26 and m68k from defines to aliases and we are all set - we can make these externs in linux/interrupt.h uncoditional and kill remaining instances in asm/irq.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11Add hard_irq_disable()Benjamin Herrenschmidt
Some architectures, like powerpc, implement lazy disabling of interrupts. That means that on those, local_irq_disable() doesn't actually disable interrupts on the CPU, but only sets some per CPU flag which cause them to be disabled only if an interrupt actually occurs. However, in some cases, such as stop_machine, we really want interrupts to be fully disabled. For example, I have code using stop machine to do ECC error injection, used to verify operations of the ECC hardware, that sort of thing. It really needs to make sure that nothing is actually writing to memory while the injection happens. Similar examples can be found in other low level bits and pieces. This patch implements a generic hard_irq_disable() function which is meant to be called -after- local_irq_disable() and ensures that interrupts are fully disabled on that CPU. The default implementation is a nop, though powerpc does already provide an appropriate one. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Add IRQF_IRQPOLL flag (common code)Bernhard Walle
irqpoll is broken on some architectures that don't use the IRQ 0 for the timer interrupt like IA64. This patch adds a IRQF_IRQPOLL flag. Each architecture is handled in a separate pach. As I left the irq == 0 as condition, this should not break existing architectures that use timer_irq == 0 and that I did't address with that patch (because I don't know). This patch: This patch adds a IRQF_IRQPOLL flag that the interrupt registration code could use for the interrupt it wants to use for IRQ polling. Because this must not be the timer interrupt, an additional flag was added instead of re-using the IRQF_TIMER constant. Until all architectures will have an IRQF_IRQPOLL interrupt, irq == 0 will stay as alternative as it should not break anything. Also, note_interrupt() is called on CPU-specific interrupts to be used as interrupt source for IRQ polling. Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Grant Grundler <grundler@google.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Deprecate SA_xxx interrupt flags -V2Thomas Gleixner
The deprecation of the SA_xxx interrupt flags did not emit deprecated warnings. Andrew said about the removal of the deprecated flag defines: > This is going to break a lot of external stuff. We should have found > a way to make usage of SA_* emit deprecated warnings (or _some_ > warning) to warn people of impending doom. But I can't immediately > find a way of doing that. if we _can_ find a way of doing this, I > suspect we'll need to do it, and give people another six months. It's > going to get ugly out there. We shall see... Define the deprecated flags as a call to a __deprecated inline function so a warning is emitted on compile time. Extend the reprieve of out of tree drivers to 9/2007. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08IRQ: add __must_check to request_irqMonakhov Dmitriy
This could help to find buggy drivers where request_irq return value wasn't checked. There's just no reason to ignore errors which can and do occur. Anyone who got warning during compilation have to realise what it is't realy safe code. Signed-off-by: Monakhov Dmitriy <dmonakhov@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04lockdep: Add missing disable/enable irq variantRoman Zippel
Add missing disable/enable irq variant Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-19[PATCH] Declare init_irq_proc before we use it.Andrew Morton
powerpc gets: init/main.c: In function `do_basic_setup': init/main.c:714: warning: implicit declaration of function `init_irq_proc' but we cannot include linux/irq.h in generic code. Fix it by moving the declaration into linux/interrupt.h instead. And make sure all code that defines init_irq_proc() is including linux/interrupt.h. And nuke an ifdef-in-C Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] hrtimers: add high resolution timer supportThomas Gleixner
Implement high resolution timers on top of the hrtimers infrastructure and the clockevents / tick-management framework. This provides accurate timers for all hrtimer subsystem users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] Add irq flag to disable balancing for an interruptThomas Gleixner
Add a flag so we can prevent the irq balancing of an interrupt. Move the bits, so we have room for more :) Necessary for the ability to setup clocksources more flexible (e.g. use the different HPET channels per CPU) Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09devres: device resource managementTejun Heo
Implement device resource management, in short, devres. A device driver can allocate arbirary size of devres data which is associated with a release function. On driver detach, release function is invoked on the devres data, then, devres data is freed. devreses are typed by associated release functions. Some devreses are better represented by single instance of the type while others need multiple instances sharing the same release function. Both usages are supported. devreses can be grouped using devres group such that a device driver can easily release acquired resources halfway through initialization or selectively release resources (e.g. resources for port 1 out of 4 ports). This patch adds devres core including documentation and the following managed interfaces. * alloc/free : devm_kzalloc(), devm_kzfree() * IO region : devm_request_region(), devm_release_region() * IRQ : devm_request_irq(), devm_free_irq() * DMA : dmam_alloc_coherent(), dmam_free_coherent(), dmam_declare_coherent_memory(), dmam_pool_create(), dmam_pool_destroy() * PCI : pcim_enable_device(), pcim_pin_device(), pci_is_managed() * iomap : devm_ioport_map(), devm_ioport_unmap(), devm_ioremap(), devm_ioremap_nocache(), devm_iounmap(), pcim_iomap_table(), pcim_iomap(), pcim_iounmap() Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-10[PATCH] sched: use softirq for load balancingChristoph Lameter
Call rebalance_tick (renamed to run_rebalance_domains) from a newly introduced softirq. We calculate the earliest time for each layer of sched domains to be rescanned (this is the rescan time for idle) and use the earliest of those to schedule the softirq via a new field "next_balance" added to struct rq. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Peter Williams <pwil3058@bigpond.net.au> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Christoph Lameter <clameter@sgi.com> Cc: "Siddha, Suresh B" <suresh.b.siddha@intel.com> Cc: "Chen, Kenneth W" <kenneth.w.chen@intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] add bottom_half.hAndrew Morton
With CONFIG_SMP=n: drivers/input/ff-memless.c:384: warning: implicit declaration of function 'local_bh_disable' drivers/input/ff-memless.c:393: warning: implicit declaration of function 'local_bh_enable' Really linux/spinlock.h should include linux/interrupt.h. But interrupt.h includes sched.h which will need spinlock.h. So the patch breaks the _bh declarations out into a separate header and includes it in both interrupt.h and spinlock.h. Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Andi Kleen <ak@suse.de> Cc: <stable@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-05IRQ: Typedef the IRQ handler function typeDavid Howells
Typedef the IRQ handler function type. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1356d1e5fd256997e3d3dce0777ab787d0515c7a commit)
2006-09-29[PATCH] lockdep: core, add enable/disable_irq_irqsave/irqrestore() APIsArjan van de Ven
Introduce the disable_irq_nosync_lockdep_irqsave() and enable_irq_lockdep_irqrestore() APIs. These are needed for NE2000; basically NE2000 calls disable_irq and enable_irq as locking against the IRQ handler, but both in cases where interrupts are on and off. This means that lockdep needs to track the old state of the virtual irq flags on disable_irq, and restore these at enable_irq time. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: irqtrace subsystem, coreIngo Molnar
Accurate hard-IRQ-flags and softirq-flags state tracing. This allows us to attach extra functionality to IRQ flags on/off events (such as trace-on/off). Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: add local_irq_enable_in_hardirq() APIIngo Molnar
Introduce local_irq_enable_in_hardirq() API. It is currently aliased to local_irq_enable(), hence has no functional effects. This API will be used by lockdep, but even without lockdep this will better document places in the kernel where a hardirq context enables hardirqs. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: add disable/enable_irq_lockdep() APIIngo Molnar
lockdep wants to use the disable_irq()/enable_irq() prototypes before they are provied by the platform's asm/irq.h. So move them out of the CONFIG_GENERIC_HARDIRQS define - all architectures have a common prototype for this anyway. Add special lockdep variants of irq line disabling/enabling. These should be used for locking constructs that know that a particular irq context which is disabled, and which is the only irq-context user of a lock, that it's safe to take the lock in the irq-disabled section without disabling hardirqs. [akpm@osdl.org: build fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] genirq:fixup missing SA_PERCPU replacementThomas Gleixner
The irqflags consolidation converted SA_PERCPU_IRQ to IRQF_PERCPU but did not define the new constant. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: consolidate flags for request_irqThomas Gleixner
The recent interrupt rework introduced bit value conflicts with sparc. Instead of introducing new architecture flags mess, move the interrupt SA_ flags out of the signal namespace and replace them by interrupt related flags. This allows to remove the obsolete SA_INTERRUPT flag and clean up the bit field values. This patch: Move the interrupt related SA_ flags out of linux/signal.h and rename them to IRQF_ . This moves the interrupt related flags out of the signal namespace and allows to remove the architecture dependencies. SA_INTERRUPT is not needed by userspace and glibc so it can be removed safely. The existing SA_ constants are kept for easy transition and will be removed after a 6 month grace period. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Greg KH <greg@kroah.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Jeff Garzik <jeff@garzik.org> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Karsten Keil <kkeil@suse.de> Cc: Jody McIntyre <scjody@modernduck.com> Cc: Ben Collins <bcollins@debian.org> Cc: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Dave Airlie <airlied@linux.ie> Cc: Jens Axboe <axboe@suse.de> Cc: Chris Zankel <chris@zankel.net> Cc: Andi Kleen <ak@muc.de> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: David Howells <dhowells@redhat.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: add irq-wake (power-management) supportThomas Gleixner
Enable platforms to set the irq-wake (power-management) properties of an IRQ. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] adjust handle_IRR_event() return typeJan Beulich
Correct the return type of handle_IRQ_event() (inconsistency noticed during Xen development), and remove redundant declarations. The return type adjustment required breaking out the definition of irqreturn_t into a separate header, in order to satisfy current include order dependencies. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-01-09[SCSI] Kill the SCSI softirq handlingJens Axboe
This patch moves the SCSI softirq handling to the block layer version. There should be no functional changes. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-09[BLOCK] ll_rw_blk: Enable out-of-order request completions through softirqJens Axboe
Request completion can be a quite heavy process, since it needs to iterate through the entire request and complete the bio's it holds. This patch adds blk_complete_request() which moves this processing into a dedicated block softirq. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-08[PATCH] remove semicolons from save_flags()Andrew Morton
2005-11-13[PATCH] m68k: thread_info header cleanupAl Viro
a) in smp_lock.h #include of sched.h and spinlock.h moved under #ifdef CONFIG_LOCK_KERNEL. b) interrupt.h now explicitly pulls sched.h (not via smp_lock.h from hardirq.h as it used to) c) in three more places we need changes to compensate for (a) - one place in arch/sparc needs string.h now, hardirq.h needs forward declaration of task_struct and preempt.h needs direct include of thread_info.h. d) thread_info-related helpers in sched.h and thread_info.h put under ifndef __HAVE_THREAD_FUNCTIONS. Obviously safe. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-12[PATCH] x86-64: Some cleanup and optimization to the processor data area.Andi Kleen
- Remove unused irqrsp field - Remove pda->me - Optimize set_softirq_pending slightly Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
