path: root/include/linux/intel-iommu.h
2014-01-09iommu/vt-d: keep shared resources when failed to initialize iommu devicesJiang Liu
Data structure drhd->iommu is shared between DMA remapping driver and interrupt remapping driver, so DMA remapping driver shouldn't release drhd->iommu when it failed to initialize IOMMU devices. Otherwise it may cause invalid memory access to the interrupt remapping driver. Sample stack dump: [ 13.315090] BUG: unable to handle kernel paging request at ffffc9000605a088 [ 13.323221] IP: [<ffffffff81461bac>] qi_submit_sync+0x15c/0x400 [ 13.330107] PGD 82f81e067 PUD c2f81e067 PMD 82e846067 PTE 0 [ 13.336818] Oops: 0002 [#1] SMP [ 13.340757] Modules linked in: [ 13.344422] CPU: 0 PID: 4 Comm: kworker/0:0 Not tainted 3.13.0-rc1-gerry+ #7 [ 13.352474] Hardware name: Intel Corporation LH Pass ........../SVRBD-ROW_T, BIOS SE5C600.86B.99.99.x059.091020121352 09/10/2012 [ 13.365659] Workqueue: events work_for_cpu_fn [ 13.370774] task: ffff88042ddf00d0 ti: ffff88042ddee000 task.ti: ffff88042dde e000 [ 13.379389] RIP: 0010:[<ffffffff81461bac>] [<ffffffff81461bac>] qi_submit_sy nc+0x15c/0x400 [ 13.389055] RSP: 0000:ffff88042ddef940 EFLAGS: 00010002 [ 13.395151] RAX: 00000000000005e0 RBX: 0000000000000082 RCX: 0000000200000025 [ 13.403308] RDX: ffffc9000605a000 RSI: 0000000000000010 RDI: ffff88042ddb8610 [ 13.411446] RBP: ffff88042ddef9a0 R08: 00000000000005d0 R09: 0000000000000001 [ 13.419599] R10: 0000000000000000 R11: 000000000000005d R12: 000000000000005c [ 13.427742] R13: ffff88102d84d300 R14: 0000000000000174 R15: ffff88042ddb4800 [ 13.435877] FS: 0000000000000000(0000) GS:ffff88043de00000(0000) knlGS:00000 00000000000 [ 13.445168] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 13.451749] CR2: ffffc9000605a088 CR3: 0000000001a0b000 CR4: 00000000000407f0 [ 13.459895] Stack: [ 13.462297] ffff88042ddb85d0 000000000000005d ffff88042ddef9b0 0000000000000 5d0 [ 13.471147] 00000000000005c0 ffff88042ddb8000 000000000000005c 0000000000000 015 [ 13.480001] ffff88042ddb4800 0000000000000282 ffff88042ddefa40 ffff88042ddef ac0 [ 13.488855] Call Trace: [ 13.491771] [<ffffffff8146848d>] modify_irte+0x9d/0xd0 [ 13.497778] [<ffffffff8146886d>] intel_setup_ioapic_entry+0x10d/0x290 [ 13.505250] [<ffffffff810a92a6>] ? trace_hardirqs_on_caller+0x16/0x1e0 [ 13.512824] [<ffffffff810346b0>] ? default_init_apic_ldr+0x60/0x60 [ 13.519998] [<ffffffff81468be0>] setup_ioapic_remapped_entry+0x20/0x30 [ 13.527566] [<ffffffff8103683a>] io_apic_setup_irq_pin+0x12a/0x2c0 [ 13.534742] [<ffffffff8136673b>] ? acpi_pci_irq_find_prt_entry+0x2b9/0x2d8 [ 13.544102] [<ffffffff81037fd5>] io_apic_setup_irq_pin_once+0x85/0xa0 [ 13.551568] [<ffffffff8103816f>] ? mp_find_ioapic_pin+0x8f/0xf0 [ 13.558434] [<ffffffff81038044>] io_apic_set_pci_routing+0x34/0x70 [ 13.565621] [<ffffffff8102f4cf>] mp_register_gsi+0xaf/0x1c0 [ 13.572111] [<ffffffff8102f5ee>] acpi_register_gsi_ioapic+0xe/0x10 [ 13.579286] [<ffffffff8102f33f>] acpi_register_gsi+0xf/0x20 [ 13.585779] [<ffffffff81366b86>] acpi_pci_irq_enable+0x171/0x1e3 [ 13.592764] [<ffffffff8146d771>] pcibios_enable_device+0x31/0x40 [ 13.599744] [<ffffffff81320e9b>] do_pci_enable_device+0x3b/0x60 [ 13.606633] [<ffffffff81322248>] pci_enable_device_flags+0xc8/0x120 [ 13.613887] [<ffffffff813222f3>] pci_enable_device+0x13/0x20 [ 13.620484] [<ffffffff8132fa7e>] pcie_port_device_register+0x1e/0x510 [ 13.627947] [<ffffffff810a92a6>] ? trace_hardirqs_on_caller+0x16/0x1e0 [ 13.635510] [<ffffffff810a947d>] ? trace_hardirqs_on+0xd/0x10 [ 13.642189] [<ffffffff813302b8>] pcie_portdrv_probe+0x58/0xc0 [ 13.648877] [<ffffffff81323ba5>] local_pci_probe+0x45/0xa0 [ 13.655266] [<ffffffff8106bc44>] work_for_cpu_fn+0x14/0x20 [ 13.661656] [<ffffffff8106fa79>] process_one_work+0x369/0x710 [ 13.668334] [<ffffffff8106fa02>] ? process_one_work+0x2f2/0x710 [ 13.675215] [<ffffffff81071d56>] ? worker_thread+0x46/0x690 [ 13.681714] [<ffffffff81072194>] worker_thread+0x484/0x690 [ 13.688109] [<ffffffff81071d10>] ? cancel_delayed_work_sync+0x20/0x20 [ 13.695576] [<ffffffff81079c60>] kthread+0xf0/0x110 [ 13.701300] [<ffffffff8108e7bf>] ? local_clock+0x3f/0x50 [ 13.707492] [<ffffffff81079b70>] ? kthread_create_on_node+0x250/0x250 [ 13.714959] [<ffffffff81574d2c>] ret_from_fork+0x7c/0xb0 [ 13.721152] [<ffffffff81079b70>] ? kthread_create_on_node+0x250/0x250 Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2014-01-09iommu/vt-d: mark internal functions as staticJiang Liu
Functions alloc_iommu() and parse_ioapics_under_ir() are only used internally, so mark them as static. [Joerg: Made detect_intel_iommu() non-static again for IA64] Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2014-01-07iommu/vt-d: use dedicated bitmap to track remapping entry allocation statusJiang Liu
Currently Intel interrupt remapping drivers uses the "present" flag bit in remapping entry to track whether an entry is allocated or not. It works as follow: 1) allocate a remapping entry and set its "present" flag bit to 1 2) compose other fields for the entry 3) update the remapping entry with the composed value The remapping hardware may access the entry between step 1 and step 3, which then observers an entry with the "present" flag set but random values in all other fields. This patch introduces a dedicated bitmap to track remapping entry allocation status instead of sharing the "present" flag with hardware, thus eliminate the race window. It also simplifies the implementation. Tested-and-reviewed-by: Yijing Wang <wangyijing@huawei.com> Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-09-24x86/iommu: correct ICS register offsetLi, Zhen-Hua
According to Intel Vt-D specs, the offset of Invalidation complete status register should be 0x9C, not 0x98. See Intel's VT-d spec, Revision 1.3, Chapter 10.4, Page 98; Signed-off-by: Li, Zhen-Hua <zhen-hual@hp.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2012-06-08iommu/dmar: Reserve mmio space used by the IOMMU, if the BIOS forgets toDonald Dutile
Intel-iommu initialization doesn't currently reserve the memory used for the IOMMU registers. This can allow the pci resource allocator to assign a device BAR to the same address as the IOMMU registers. This can cause some not so nice side affects when the driver ioremap's that region. Introduced two helper functions to map & unmap the IOMMU registers as well as simplify the init and exit paths. Signed-off-by: Donald Dutile <ddutile@redhat.com> Acked-by: Chris Wright <chrisw@redhat.com> Cc: iommu@lists.linux-foundation.org Cc: suresh.b.siddha@intel.com Cc: dwmw2@infradead.org Link: http://lkml.kernel.org/r/1338845342-12464-3-git-send-email-ddutile@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2011-10-26Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (27 commits) rtmutex: Add missing rcu_read_unlock() in debug_rt_mutex_print_deadlock() lockdep: Comment all warnings lib: atomic64: Change the type of local lock to raw_spinlock_t locking, lib/atomic64: Annotate atomic64_lock::lock as raw locking, x86, iommu: Annotate qi->q_lock as raw locking, x86, iommu: Annotate irq_2_ir_lock as raw locking, x86, iommu: Annotate iommu->register_lock as raw locking, dma, ipu: Annotate bank_lock as raw locking, ARM: Annotate low level hw locks as raw locking, drivers/dca: Annotate dca_lock as raw locking, powerpc: Annotate uic->lock as raw locking, x86: mce: Annotate cmci_discover_lock as raw locking, ACPI: Annotate c3_lock as raw locking, oprofile: Annotate oprofilefs lock as raw locking, video: Annotate vga console lock as raw locking, latencytop: Annotate latency_lock as raw locking, timer_stats: Annotate table_lock as raw locking, rwsem: Annotate inner lock as raw locking, semaphores: Annotate inner lock as raw locking, sched: Annotate thread_group_cputimer as raw ... Fix up conflicts in kernel/posix-cpu-timers.c manually: making cputimer->cputime a raw lock conflicted with the ABBA fix in commit bcd5cff7216f ("cputimer: Cure lock inversion").
2011-09-21iommu: Rename the DMAR and INTR_REMAP config optionsSuresh Siddha
Change the CONFIG_DMAR to CONFIG_INTEL_IOMMU to be consistent with the other IOMMU options. Rename the CONFIG_INTR_REMAP to CONFIG_IRQ_REMAP to match the irq subsystem name. And define the CONFIG_DMAR_TABLE for the common ACPI DMAR routines shared by both CONFIG_INTEL_IOMMU and CONFIG_IRQ_REMAP. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: yinghai@kernel.org Cc: youquan.song@intel.com Cc: joerg.roedel@amd.com Cc: tony.luck@intel.com Cc: dwmw2@infradead.org Link: http://lkml.kernel.org/r/20110824001456.558630224@sbsiddha-desk.sc.intel.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-09-13locking, x86, iommu: Annotate qi->q_lock as rawThomas Gleixner
The qi->q_lock lock can be taken in atomic context and therefore cannot be preempted on -rt - annotate it. In mainline this change documents the low level nature of the lock - otherwise there's no functional difference. Lockdep and Sparse checking will work as usual. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-09-13locking, x86, iommu: Annotate iommu->register_lock as rawThomas Gleixner
The iommu->register_lock can be taken in atomic context and therefore must not be preempted on -rt - annotate it. In mainline this change documents the low level nature of the lock - otherwise there's no functional difference. Lockdep and Sparse checking will work as usual. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-05dmar: support for parsing Remapping Hardware Static Affinity structureSuresh Siddha
Add support for parsing Remapping Hardware Static Affinity (RHSA) structure. This enables identifying the association between remapping hardware units and the corresponding proximity domain. This enables to allocate transalation structures closer to the remapping hardware unit. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-11intel-iommu: Fix kernel hang if interrupt remapping disabled in BIOSYouquan Song
BIOS clear DMAR table INTR_REMAP flag to disable interrupt remapping. Current kernel only check interrupt remapping(IR) flag in DRHD's extended capability register to decide interrupt remapping support or not. But IR flag will not change when BIOS disable/enable interrupt remapping. When user disable interrupt remapping in BIOS or BIOS often defaultly disable interrupt remapping feature when BIOS is not mature.Though BIOS disable interrupt remapping but intr_remapping_supported function will always report to OS support interrupt remapping if VT-d2 chipset populated. On this cases, kernel will continue enable interrupt remapping and result kernel panic. This bug exist on almost all platforms with interrupt remapping support. This patch add DMAR table INTR_REMAP flag check before enable interrupt remapping. Signed-off-by: Youquan Song <youquan.song@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-05-18VT-d: support the device IOTLBYu Zhao
Enable the device IOTLB (i.e. ATS) for both the bare metal and KVM environments. Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-05-18VT-d: add device IOTLB invalidation supportYu Zhao
Support device IOTLB invalidation to flush the translation cached in the Endpoint. Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-05-18VT-d: parse ATSR in DMA Remapping Reporting StructureYu Zhao
Parse the Root Port ATS Capability Reporting Structure in the DMA Remapping Reporting Structure ACPI table. Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-05-10intel-iommu: Clean up handling of "caching mode" vs. IOTLB flushing.David Woodhouse
As we just did for context cache flushing, clean up the logic around whether we need to flush the iotlb or just the write-buffer, depending on caching mode. Fix the same bug in qi_flush_iotlb() that qi_flush_context() had -- it isn't supposed to be returning an error; it's supposed to be returning a flag which triggers a write-buffer flush. Remove some superfluous conditional write-buffer flushes which could never have happened because they weren't for non-present-to-present mapping changes anyway. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-05-10intel-iommu: Clean up handling of "caching mode" vs. context flushing.David Woodhouse
It really doesn't make a lot of sense to have some of the logic to handle caching vs. non-caching mode duplicated in qi_flush_context() and __iommu_flush_context(), while the return value indicates whether the caller should take other action which depends on the same thing. Especially since qi_flush_context() thought it was returning something entirely different anyway. This patch makes qi_flush_context() and __iommu_flush_context() both return void, removes the 'non_present_entry_flush' argument and makes the only call site which _set_ that argument to 1 do the right thing. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-29Intel IOMMU Pass Through SupportFenghua Yu
The patch adds kernel parameter intel_iommu=pt to set up pass through mode in context mapping entry. This disables DMAR in linux kernel; but KVM still runs on VT-d and interrupt remapping still works. In this mode, kernel uses swiotlb for DMA API functions but other VT-d functionalities are enabled for KVM. KVM always uses multi level translation page table in VT-d. By default, pass though mode is disabled in kernel. This is useful when people don't want to enable VT-d DMAR in kernel but still want to use KVM and interrupt remapping for reasons like DMAR performance concern or debug purpose. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Acked-by: Weidong Han <weidong@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-03intel-iommu: set compatibility format interruptHan, Weidong
When extended interrupt mode (x2apic mode) is not supported in a system, it must set compatibility format interrupt to bypass interrupt remapping, otherwise compatibility format interrupts will be blocked. This will be used when interrupt remapping is enabled while x2apic is not supported. Signed-off-by: Weidong Han <weidong.han@intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-03Intel IOMMU Suspend/Resume Support - DMARFenghua Yu
This patch implements the suspend and resume feature for Intel IOMMU DMAR. It hooks to kernel suspend and resume interface. When suspend happens, it saves necessary hardware registers. When resume happens, it restores the registers and restarts IOMMU by enabling translation, setting up root entry, and re-enabling queued invalidation. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-03Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: intel-iommu: Fix address wrap on 32-bit kernel. intel-iommu: Enable DMAR on 32-bit kernel. intel-iommu: fix PCI device detach from virtual machine intel-iommu: VT-d page table to support snooping control bit iommu: Add domain_has_cap iommu_ops intel-iommu: Snooping control support Fixed trivial conflicts in arch/x86/Kconfig and drivers/pci/intel-iommu.c
2009-03-30Merge branch 'iommu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (60 commits) dma-debug: make memory range checks more consistent dma-debug: warn of unmapping an invalid dma address dma-debug: fix dma_debug_add_bus() definition for !CONFIG_DMA_API_DEBUG dma-debug/x86: register pci bus for dma-debug leak detection dma-debug: add a check dma memory leaks dma-debug: add checks for kernel text and rodata dma-debug: print stacktrace of mapping path on unmap error dma-debug: Documentation update dma-debug: x86 architecture bindings dma-debug: add function to dump dma mappings dma-debug: add checks for sync_single_sg_* dma-debug: add checks for sync_single_range_* dma-debug: add checks for sync_single_* dma-debug: add checking for [alloc|free]_coherent dma-debug: add add checking for map/unmap_sg dma-debug: add checking for map/unmap_page/single dma-debug: add core checking functions dma-debug: add debugfs interface dma-debug: add kernel command line parameters dma-debug: add initialization code ... Fix trivial conflicts due to whitespace changes in arch/x86/kernel/pci-nommu.c
2009-03-24intel-iommu: Snooping control supportSheng Yang
Snooping control enabled IOMMU to guarantee DMA cache coherency and thus reduce software effort (VMM) in maintaining effective memory type. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-03-17x86, dmar: routines for disabling queued invalidation and intr remappingSuresh Siddha
Impact: new interfaces (not yet used) Routines for disabling queued invalidation and interrupt remapping. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2009-03-17x86, x2apic: enable fault handling for intr-remappingSuresh Siddha
Impact: interface augmentation (not yet used) Enable fault handling flow for intr-remapping aswell. Fault handling code now shared by both dma-remapping and intr-remapping. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2009-03-05Merge branch 'linus' into core/iommuIngo Molnar
2009-02-09VT-d: handle Invalidation Queue Error to avoid system hangYu Zhao
When hardware detects any error with a descriptor from the invalidation queue, it stops fetching new descriptors from the queue until software clears the Invalidation Queue Error bit in the Fault Status register. Following fix handles the IQE so the kernel won't be trapped in an infinite loop. Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-01-29intel-iommu: make dma mapping functions staticFUJITA Tomonori
The dma ops unification enables X86 and IA64 to share intel_dma_ops so we can make dma mapping functions static. This also remove unused intel_map_single(). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-06x86, ia64: convert to use generic dma_map_ops structFUJITA Tomonori
This converts X86 and IA64 to use include/linux/dma-mapping.h. It's a bit large but pretty boring. The major change for X86 is converting 'int dir' to 'enum dma_data_direction dir' in DMA mapping operations. The major changes for IA64 is using map_page and unmap_page instead of map_single and unmap_single. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-03VT-d: remove now unused intel_iommu_found functionJoerg Roedel
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-01-03VT-d: adapt domain iova_to_phys function for IOMMU APIJoerg Roedel
2009-01-03VT-d: adapt domain map and unmap functions for IOMMU APIJoerg Roedel
2009-01-03VT-d: adapt device attach and detach functions for IOMMU APIJoerg Roedel
2009-01-03VT-d: adapt domain init and destroy functions for IOMMU APIJoerg Roedel
2009-01-03Change intel iommu APIs of virtual machine domainWeidong Han
These APIs are used by KVM to use VT-d Signed-off-by: Weidong Han <weidong.han@intel.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-01-03calculate agaw for each iommuWeidong Han
"SAGAW" capability may be different across iommus. Use a default agaw, but if default agaw is not supported in some iommus, choose a less supported agaw. Signed-off-by: Weidong Han <weidong.han@intel.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-01-03intel-iommu: remove some unused struct intel_iommu fieldsMark McLoughlin
The seg, saved_msg and sysdev fields appear to be unused since before the code was first merged. linux/msi.h is not needed in linux/intel-iommu.h anymore since there is no longer a reference to struct msi_msg. The MSI code in drivers/pci/intel-iommu.c still has linux/msi.h included via linux/dmar.h. linux/sysdev.h isn't needed because there is no reference to struct sys_device. Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-10-18intel-iommu: IA64 supportFenghua Yu
The current Intel IOMMU code assumes that both host page size and Intel IOMMU page size are 4KiB. The first patch supports variable page size. This provides support for IA64 which has multiple page sizes. This patch also adds some other code hooks for IA64 platform including DMAR_OPERATION_TIMEOUT definition. [dwmw2: some cleanup] Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-10-17dmar: Use queued invalidation interface for IOTLB and context invalidationYouquan Song
If queued invalidation interface is available and enabled, queued invalidation interface will be used instead of the register based interface. According to Vt-d2 specification, when queued invalidation is enabled, invalidation command submit works only through invalidation queue and not through the command registers interface. Signed-off-by: Youquan Song <youquan.song@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-10-17dmar: context cache and IOTLB invalidation using queued invalidationYouquan Song
Implement context cache invalidate and IOTLB invalidation using queued invalidation interface. This interface will be used by DMA remapping, when queued invalidation is supported. Signed-off-by: Youquan Song <youquan.song@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-10-15VT-d: Changes to support KVMKay, Allen M
This patch extends the VT-d driver to support KVM [Ben: fixed memory pinning] [avi: move dma_remapping.h as well] Signed-off-by: Kay, Allen M <allen.m.kay@intel.com> Signed-off-by: Weidong Han <weidong.han@intel.com> Signed-off-by: Ben-Ami Yassour <benami@il.ibm.com> Signed-off-by: Amit Shah <amit.shah@qumranet.com> Acked-by: Mark Gross <mgross@linux.intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
