path: root/include/linux/input.h
2007-07-10Input: convert from class devices to standard devicesDmitry Torokhov
2007-06-29Input: document some of keycodesDmitry Torokhov
Document some of keycodes, based on USB HUT 1.12 and current mapping in HID driver. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-06-29Input: add a new EV_SW SW_RADIO event, for radio switches on laptopsHenrique de Moraes Holschuh
Many laptops have rf-kill physical switches that are not keys, but slider or rocker switches. Often (like in all ThinkPads with a radio kill slider switch), they have both a slider/rocker switch and a hot key. Trying to kludge a real switch to act like a key is not a very smart thing to do if you can help it, and it gets specially bad when you are going to have both in the same machine. So, we do the right thing and add an input EV_SW event for radio kill switches. The EV_SW SW_RADIO event is defined with positive logic, i.e. when the switch is active, the radios are to be enabled. When the switch is inactive, the radios are to be disabled. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-05-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (38 commits) kconfig: fix mconf segmentation fault kbuild: enable use of code from a different dir kconfig: error out if recursive dependencies are found kbuild: scripts/basic/fixdep segfault on pathological string-o-death kconfig: correct minor typo in Kconfig warning message. kconfig: fix path to modules.txt in Kconfig help usr/Kconfig: fix typo kernel-doc: alphabetically-sorted entries in index.html of 'htmldocs' kbuild: be more explicit on missing .config file kbuild: clarify the creation of the LOCALVERSION_AUTO string. kbuild: propagate errors from find in scripts/gen_initramfs_list.sh kconfig: refer to qt3 if we cannot find qt libraries kbuild: handle compressed cpio initramfs-es kbuild: ignore section mismatch warning for references from .paravirtprobe to .init.text kbuild: remove stale comment in modpost.c kbuild/mkuboot.sh: allow spaces in CROSS_COMPILE kbuild: fix make mrproper for Documentation/DocBook/man kbuild: remove kconfig binaries during make mrproper kconfig/menuconfig: do not hardcode '.config' kbuild: override build timestamp & version ...
2007-05-04Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/dtor/input: (65 commits) Input: gpio_keys - add support for switches (EV_SW) Input: cobalt_btns - convert to use polldev library Input: add skeleton for simple polled devices Input: update some documentation Input: wistron - fix typo in keymap for Acer TM610 Input: add input_set_capability() helper Input: i8042 - add Fujitsu touchscreen/touchpad PNP IDs Input: i8042 - add Panasonic CF-29 to nomux list Input: lifebook - split into 2 devices Input: lifebook - add signature of Panasonic CF-29 Input: lifebook - activate 6-byte protocol on select models Input: lifebook - work properly on Panasonic CF-18 Input: cobalt buttons - separate device and driver registration Input: ati_remote - make button repeat sensitivity configurable Input: pxa27x - do not use deprecated SA_INTERRUPT flag Input: ucb1400 - make delays configurable Input: misc devices - switch to using input_dev->dev.parent Input: joysticks - switch to using input_dev->dev.parent Input: touchscreens - switch to using input_dev->dev.parent Input: mice - switch to using input_dev->dev.parent ... Fixed up conflicts with core device model removal of "struct subsystem" manually. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04m68k: Atari keyboard and mouse support.Michael Schmitz
Atari keyboard and mouse support. (reformating and Kconfig fixes by Roman Zippel) Signed-off-by: Michael Schmitz <schmitz@debian.org> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02kbuild: remove dependency on input.h from file2aliasSam Ravnborg
Almost all definitions used by file2alias was already present in mod_devicetable.h. Added the last definition and killed the input.h usage. The errornous include was pointed out by: Jan Engelhardt <jengelh@linux01.gwdg.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Cc: Deepak Saxena <dsaxena@plexity.net>
2007-04-25Input: add input_set_capability() helperDmitry Torokhov
Add input_set_capability() helper used to indicate that an input device supports a certain event without need to manipulate bitmaps directly. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-04-12Input: prepare to switching to struct deviceDmitry Torokhov
In preparation to switching to struct device and class device going away provide an alias to allow drivers that create devices to use either input_dev->cdev.dev or input_dev->dev.parent to put them into sysfs tree. The former will go away once conversion to struct device is complete. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-04-12Input: add input_{get|set}_drvdata() helpersDmitry Torokhov
Add helpers to set up and access driver-specific data in input device structure. Once conversion to struct driver is complete we will drop input_dev->private and will use dev_get_drvdata() and dev_set_drvdata(). Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-04-12Input: wistron - add acerhk laptop databaseEric Piel
Acerhk supports already a lot of laptops. Lets import its database so that everyone can benefit of the work of Olaf Tauber. Only the "tm_new" laptops were imported. "tm_old" laptops could be possible but requires more testing and probably only few laptops are still alive. "dritek" laptops should probably be imported into a different driver. Also compress the keymaps by fitting each entry on an int. Most of the dmi matching was written based on google searches, so it's rather prone to errors. That's why I'm asking people to confirm it works. Support to generate switch input events was added as some laptops indicate lid open/close through this interface. This adds the following hardware: Acer TravelMate 370 Acer TravelMate 380 Acer TravelMate C300 Acer TravelMate C100 Acer TravelMate C110 Acer TravelMate 250 Acer TravelMate 350 Acer TravelMate 620 Acer TravelMate 630 Acer TravelMate 220 Acer TravelMate 230 Acer TravelMate 260 Acer TravelMate 280 Acer TravelMate 360 Acer TravelMate 2100 Acer TravelMate 2410 Acer Aspire 1500 Acer Aspire 1600 Acer Aspire 3020 Acer Aspire 5020 Medion MD 2900 Medion MD 40100 Medion MD 95400 Medion MD 96500 Fujitsu Siemens Amilo 7820 Signed-off-by: Eric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-04-12Input: rework handle creation codeDmitry Torokhov
- consolidate code for binding handlers to a device - return error codes from handlers connect() methods back to input core and log failures Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-03-14Input: add getkeycode and setkeycode methodsMarvin Raaijmakers
Allow drivers to implement their own get and set keycode methods. This will allow drivers to change their keymaps without allocating huge tables covering entire range of possible scancodes. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-12-14input/hid: Supporting more keys from the HUT Consumer PageFlorian Festi
On USB keyboards lots of hot/internet keys are not working. This patch adds support for a number of keys from the USB HID Usage Table (http://www.usb.org/developers/devclass_docs/Hut1_12.pdf). It also adds several new key codes. Most of them are used on real world keyboards I know. I added some others (KEY_+ EDITOR, GRAPHICSEDITOR, DATABASE, NEWS, VOICEMAIL, VIDEOPHONE) to avoid "holes". I also added KEY_ZOOMRESET as it is possible to have a inet keyboard and a remote control in parallel and it makes sense to have them behave differently. Signed-off-by: Florian Festi <ffesti@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2006-11-24Input: add to kernel-api docbookRandy Dunlap
Add input subsystem to kernel-api docbook. Enhance some function and parameter comments. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-19Input: add KEY_BLUETOOTH and KEY_WLAN definitionsLennart Poettering
Some laptops have separate "rfkill" buttons for disabling/enabling Bluetooth and WLAN. Signed-off-by: Lennart Poettering <mzxreary@0pointer.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-09-19Input: add new BUS_VIRTUAL bus typeMichael Hanselmann
BUS_VIRTUAL can be used when creating virtual devices using uinput driver. Note that when uinput is used to drive a real piece of hardware "real" bus type (such as BUS_USB, BUS_BLUETOOTH) should be specified. Signed-off-by: Michael Hanselmann <linux-kernel@hansmi.ch> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-09-14Input: make input_register_handler() return error codesDmitry Torokhov
2006-09-14Input: remove cruft that was needed for transition to sysfsDmitry Torokhov
2006-09-14Input: constify input coreDmitry Torokhov
2006-07-19Input: update the force feedback documentationAnssi Hannula
Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-07-19Input: drop remnants of the old force-feedback interfaceAnssi Hannula
2006-07-19Input: unified force feedback support for memoryless devicesAnssi Hannula
Consolidate core implementing memoryless devices in one module; added support for gain and envelopes and periodic => rumble conversion. Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-07-19Input: implement new force feedback interfaceAnssi Hannula
Implement a new force feedback interface, in which all non-driver-specific operations are separated to a common module. This includes handling effect type validations, locking, etc. The effects are now file descriptor specific instead of the previous strange half-process half-fd specific behaviour. The effect memory of devices is not emptied if the root user opens and closes the device while another user is using effects. This is a minor change and most likely no force feedback aware programs are affected by this negatively. Otherwise the userspace interface is left unaltered. Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-07-06Input: introduce input_inject_event() functionDmitry Torokhov
Create input_inject_event() function which is to be used by input handlers as opposed to input_event() which is reserved for drivers implementing input devices. The difference is that if device is "grabbed" by some process input_inject_event() will ignore events unless sent from the handle that is currently owns the device. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-07-06Input: add start() method to input handlersDmitry Torokhov
The new start() method is called immediately after connect() and also when "grabbed" device is released by its owner. This will allow input handlers to re-synchronize state of once-grabbed device with the rest of devices. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-07-06Input: remove accept method from input_devDmitry Torokhov
This method used to enforce exclusive access to iforce devices, but presenlty there are no known users of this method. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-06-26Input: fix misspelling of Hangeul keyJerome Pinot
Fix a mispelling of the korean alphabet name in the input subsystem. See http://en.wikipedia.org/wiki/Hangeul#Names for more details. KEY_HANGUEL left to not break people Signed-off-by: Jerome Pinot <ngc891@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-06-26Input: reset name, phys and uniq when unregisteringDmitry Torokhov
Name, phys and uniq are quite often constant strings in moules implementing particular input device. If a module unregisters input device and then gets unloaded, the device could still be present in memory (pinned via sysfs), but aforementioned members would point to some random memory. Set them all to NULL when unregistering so sysfs handlers won't try dereferencing them. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-06-20Merge git://git.infradead.org/hdrcleanup-2.6Linus Torvalds
* git://git.infradead.org/hdrcleanup-2.6: (63 commits) [S390] __FD_foo definitions. Switch to __s32 types in joystick.h instead of C99 types for consistency. Add <sys/types.h> to headers included for userspace in <linux/input.h> Move inclusion of <linux/compat.h> out of user scope in asm-x86_64/mtrr.h Remove struct fddi_statistics from user view in <linux/if_fddi.h> Move user-visible parts of drivers/s390/crypto/z90crypt.h to include/asm-s390 Revert include/media changes: Mauro says those ioctls are only used in-kernel(!) Include <linux/types.h> and use __uXX types in <linux/cramfs_fs.h> Use __uXX types in <linux/i2o_dev.h>, include <linux/ioctl.h> too Remove private struct dx_hash_info from public view in <linux/ext3_fs.h> Include <linux/types.h> and use __uXX types in <linux/affs_hardblocks.h> Use __uXX types in <linux/divert.h> for struct divert_blk et al. Use __u32 for elf_addr_t in <asm-powerpc/elf.h>, not u32. It's user-visible. Remove PPP_FCS from user view in <linux/ppp_defs.h>, remove __P mess entirely Use __uXX types in user-visible structures in <linux/nbd.h> Don't use 'u32' in user-visible struct ip_conntrack_old_tuple. Use __uXX types for S390 DASD volume label definitions which are user-visible S390 BIODASDREADCMB ioctl should use __u64 not u64 type. Remove unneeded inclusion of <linux/time.h> from <linux/ufs_fs.h> Fix private integer types used in V4L2 ioctls. ... Manually resolve conflict in include/linux/mtd/physmap.h
2006-06-01Add <sys/types.h> to headers included for userspace in <linux/input.h>David Woodhouse
Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Vojtech Pavlik <vojtech@suse.cz>
2006-05-29Input: change from numbered to named switchesRichard Purdie
Remove the numbered SW_* entries from the input system and assign names to the existing users. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-05-29Input: add KEY_BATTERY keycodeMatthew Garrett
2006-04-29Input: ressurect EVIOCGREP and EVIOCSREPDmitry Torokhov
While writing to an event device allows to set repeat rate for an individual input device there is no way to retrieve current settings so we need to ressurect EVIOCGREP. Also ressurect EVIOCSREP so we have a symmetrical interface. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-04-26Input: move input_device_id to mod_devicetable.hDmitry Torokhov
2006-04-26Input: allow passing NULL to input_free_device()Dmitry Torokhov
Many drivers rely on input_free_device() behaving like kfree(). Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-04-02Input: add support for Braille devicesSamuel Thibault
- Add KEY_BRL_* input keys and K_BRL_* keycodes; - Add emulation of how braille keyboards usually combine braille dots to the console keyboard driver; - Add handling of unicode U+28xy diacritics. Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-04-02Manual merge with Linus.Dmitry Torokhov
Conflicts: arch/powerpc/kernel/setup-common.c drivers/input/keyboard/hil_kbd.c drivers/input/mouse/hil_ptr.c
2006-03-28[PATCH] mark f_ops const in the inodeArjan van de Ven
Mark the f_ops members of inodes as const, as well as fix the ripple-through this causes by places that copy this f_ops and then "do stuff" with it. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-14Input: fix input_free_device() implementationDmitry Torokhov
input_free_device can't just call kfree because if input_register_device fails after successfully registering corresponding class device there is a chance that someone could get a reference to it. We need to use input_put_device() to make sure that we don't delete input device until last reference to it was dropped. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-02-19Input: input core - semaphore to mutex conversionJes Sorensen
Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-01-04[PATCH] Input: fix add modalias support build errorRusty Russell
Fix build when scripts/mod/file2alias.c includes linux/input.h, which tries to include /usr/include/linux/mod_devicetable.h: In file included from scripts/mod/file2alias.c:40: include/linux/input.h:21:35: linux/mod_devicetable.h: No such file or directory make[2]: *** [scripts/mod/file2alias.o] Error 1 Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] Input: add modalias supportRusty Russell
Here's the patch for modalias support for input classes. It uses comma-separated numbers, and doesn't describe all the potential keys (no module currently cares, and that would make the strings huge). The changes to input.h are to move the definitions needed by file2alias outside __KERNEL__. I chose not to move those definitions to mod_devicetable.h, because there are so many that it might break compile of something else in the kernel. The rest is fairly straightforward. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> CC: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-02Input: do not register statically allocated devicesDmitry Torokhov
Do not register statically allocated input devices to prevent OOPS when attaching input interfaces since it requires class device to be properly initialized. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-10-28Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
2005-10-28[PATCH] INPUT: rename input_dev_class to input_class to be correct.Greg Kroah-Hartman
2005-10-28[PATCH] INPUT: remove the input_class structure, as it is unused.Greg Kroah-Hartman
2005-10-28[PATCH] INPUT: export input_dev_class so that input drivers can use it.Greg Kroah-Hartman
2005-10-28[PATCH] Input: prepare to sysfs integrationDmitry Torokhov
Input: prepare to sysfs integration Add struct class_device to input_dev; add input_allocate_dev() to dynamically allocate input devices; dynamically allocated devices are automatically registered with sysfs. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
