path: root/include/linux/inetdevice.h
2010-12-06__in_dev_get_rtnl() can use rtnl_dereference()Eric Dumazet
If caller holds RTNL, we dont need a memory barrier (smp_read_barrier_depends) included in rcu_dereference(). Just use rtnl_dereference() to properly document the assertions. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-17inet: Define IPV4_DEVCONF_MAXThomas Graf
Define IPV4_DEVCONF_MAX to get rid of MAX - 1 notation. Signed-off-by: Thomas Graf <tgraf@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-12igmp: RCU conversion of in_dev->mc_listEric Dumazet
in_dev->mc_list is protected by one rwlock (in_dev->mc_list_lock). This can easily be converted to a RCU protection. Writers hold RTNL, so mc_list_lock is removed, not replaced by a spinlock. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Cypher Wu <cypher.w@gmail.com> Cc: Américo Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-30ipv4: introduce __ip_dev_find()Eric Dumazet
ip_dev_find(net, addr) finds a device given an IPv4 source address and takes a reference on it. Introduce __ip_dev_find(), taking a third argument, to optionally take the device reference. Callers not asking the reference to be taken should be in an rcu_read_lock() protected section. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-15ipv4: ip_ptr cleanupsEric Dumazet
dev->ip_ptr is protected by rtnl and rcu. Yet some places dont use appropriate primitives and/or locking rules. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16net ipv4: Decouple ipv4 interface parameters from binary sysctl numbersEric W. Biederman
Stop using the binary sysctl enumeartion in sysctl.h as an index into a per interface array. This leads to unnecessary binary sysctl number allocation, and a fragility in data structure and implementation because of unnecessary coupling. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-10Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/benet/be_cmds.h include/linux/sysctl.h
2010-01-07net: RFC3069, private VLAN proxy arp supportJesper Dangaard Brouer
This is to be used together with switch technologies, like RFC3069, that where the individual ports are not allowed to communicate with each other, but they are allowed to talk to the upstream router. As described in RFC 3069, it is possible to allow these hosts to communicate through the upstream router by proxy_arp'ing. This patch basically allow proxy arp replies back to the same interface (from which the ARP request/solicitation was received). Tunable per device via proc "proxy_arp_pvlan": /proc/sys/net/ipv4/conf/*/proxy_arp_pvlan This switch technology is known by different vendor names: - In RFC 3069 it is called VLAN Aggregation. - Cisco and Allied Telesyn call it Private VLAN. - Hewlett-Packard call it Source-Port filtering or port-isolation. - Ericsson call it MAC-Forced Forwarding (RFC Draft). Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-25net: restore ip source validationJamal Hadi Salim
when using policy routing and the skb mark: there are cases where a back path validation requires us to use a different routing table for src ip validation than the one used for mapping ingress dst ip. One such a case is transparent proxying where we pretend to be the destination system and therefore the local table is used for incoming packets but possibly a main table would be used on outbound. Make the default behavior to allow the above and if users need to turn on the symmetry via sysctl src_valid_mark Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03ipv4 05/05: add sysctl to accept packets with local source addressesPatrick McHardy
commit 8ec1e0ebe26087bfc5c0394ada5feb5758014fc8 Author: Patrick McHardy <kaber@trash.net> Date: Thu Dec 3 12:16:35 2009 +0100 ipv4: add sysctl to accept packets with local source addresses Change fib_validate_source() to accept packets with a local source address when the "accept_local" sysctl is set for the incoming inet device. Combined with the previous patches, this allows to communicate between multiple local interfaces over the wire. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-04net: cleanup include/linuxEric Dumazet
This cleanup patch puts struct/union/enum opening braces, in first line to ease grep games. struct something { becomes : struct something { Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-27ip: fix logic of reverse path filter sysctlStephen Hemminger
Even though reverse path filter was changed from simple boolean to trinary control, the loose mode only works if both all and device are configured because of this logic error. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01net: add ARP notify option for devicesStephen Hemminger
This adds another inet device option to enable gratuitous ARP when device is brought up or address change. This is handy for clusters or virtualization. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-07ipv4: add mc_count to in_device.Rami Rosen
This patch add mc_count to struct in_device and updates increment/decrement/initilaize of this field in IPv4 and in IPv6. - Also printing the vfs /proc entry (/proc/net/igmp) is adjusted to use the new mc_count. Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-03route: Remove unused ifa_anycast fieldThomas Graf
The field was supposed to allow the creation of an anycast route by assigning an anycast address to an address prefix. It was never implemented so this field is unused and serves no purpose. Remove it. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-02-28[NETNS]: Process devinet ioctl in the correct namespace.Denis V. Lunev
Add namespace parameter to devinet_ioctl and locate device inside it for state changes. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[IPV4]: Make struct ipv4_devconf static.Adrian Bunk
struct ipv4_devconf can now become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add namespace parameter to ip_dev_find.Denis V. Lunev
in_dev_find() need a namespace to pass it to fib_get_table(), so add an argument. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add netns parameter to inetdev_by_index.Denis V. Lunev
2008-01-28[IPV4]: Remove extra argument from arp_ignore.Denis V. Lunev
arp_ignore has two arguments: dev & in_dev. dev is used for inet_confirm_addr calling only. inet_confirm_addr, in turn, either gets in_dev from the device passed or iterates over all network devices if the device passed is NULL. It seems logical to directly pass in_dev into inet_confirm_addr. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV4]: Switch users of ipv4_devconf(_all) to use the pernet onePavel Emelyanov
These are scattered over the code, but almost all the "critical" places already have the proper struct net at hand except for snmp proc showing function and routing rtnl handler. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV4]: Cleanup IN_DEV_MFORWARD macroPavel Emelyanov
This is essentially IN_DEV_ANDCONF with proper arguments. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[INET]: Merge sys.net.ipv4.ip_forward and sys.net.ipv4.conf.all.forwardingPavel Emelyanov
AFAIS these two entries should do the same thing - change the forwarding state on ipv4_devconf and on all the devices. I propose to merge the handlers together using ctl paths. The inet_forward_change() is static after this and I move it higher to be closer to other "propagation" helpers and to avoid diff making patches based on { and } matching :) i.e. - make them easier to read. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-22[IPV4]: include sysctl.h from inetdevice.hSatyam Sharma
When CONFIG_INET=y and CONFIG_SYSCTL=n: In file included from net/core/netpoll.c:16: include/linux/inetdevice.h:15: error: '__NET_IPV4_CONF_MAX' undeclared here (not in a function) make[2]: *** [net/core/netpoll.o] Error 1 make[1]: *** [net/core] Error 2 make: *** [net] Error 2 So #include sysctl.h from inetdevice.h. Signed-off-by: Satyam Sharma <satyam.sharma@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-07[IPV4]: Restore old behaviour of default config valuesHerbert Xu
Previously inet devices were only constructed when addresses are added (or rarely in ipmr). Therefore the default config values they get are the ones at the time of these operations. Now that we're creating inet devices earlier, this changes the behaviour of default config values in an incompatible way (see bug #8519). This patch creates a compromise by setting the default values at the same point as before but only for those that have not been explicitly set by the user since the inet device's creation. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-07[IPV4]: Add default config support after inetdev_initHerbert Xu
Previously once inetdev_init has been called on a device any changes made to ipv4_devconf_dflt would have no effect on that device's configuration. This creates a problem since we have moved the point where inetdev_init is called from when an address is added to where the device is registered. This patch is the first half of a set that tries to mimic the old behaviour while still calling inetdev_init. It propagates any changes to ipv4_devconf_dflt to those devices that have not had the corresponding attribute set. The next patch will forcibly set all values at the point where inetdev_init was previously called. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-07[IPV4]: Convert IPv4 devconf to an arrayHerbert Xu
This patch converts the ipv4_devconf config members (everything except sysctl) to an array. This allows easier manipulation which will be needed later on to provide better management of default config values. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[IPV6]: Assorted trivial endianness annotations.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: annotate inetdev.h helpersAl Viro
inet_confirm_addr(), inet_ifa_byprefix(), ip_dev_find(), inet_make_mask() and inet_ifa_match() annotated, along with inferred net-endian variables Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: annotate struct in_ifaddrAl Viro
ifa_local, ifa_address, ifa_mask, ifa_broadcast and ifa_anycast are net-endian. Annotated them and variables that are inferred to be net-endian. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: inet_addr_onlink() annotatedAl Viro
2006-09-28[IPV4]: inet_select_addr() annotationsAl Viro
argument and return value are net-endian. Annotated function and inferred net-endian variables in callers. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[IPV4] ARP: Alloc acceptance of unsolicited ARP via netdevice sysctl.Neil Horman
Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-03[IPV4]: Replace __in_dev_get with __in_dev_get_rcu/rtnlHerbert Xu
The following patch renames __in_dev_get() to __in_dev_get_rtnl() and introduces __in_dev_get_rcu() to cover the second case. 1) RCU with refcnt should use in_dev_get(). 2) RCU without refcnt should use __in_dev_get_rcu(). 3) All others must hold RTNL and use __in_dev_get_rtnl(). There is one exception in net/ipv4/route.c which is in fact a pre-existing race condition. I've marked it as such so that we remember to fix it. This patch is based on suggestions and prior work by Suzanne Wood and Paul McKenney. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-29[IPV4]: Primary and secondary addressesHarald Welte
Add an option to make secondary IP addresses get promoted when primary IP addresses are removed from the device. It defaults to off to preserve existing behavior. Signed-off-by: Harald Welte <laforge@gnumonks.org> Signed-off-by: David S. Miller <davem@davemloft.net>
