path: root/include/linux/inet_diag.h
2011-10-12net-netlink: Add a new attribute to expose TOS values via netlinkMurali Raja
This patch exposes the tos value for the TCP sockets when the TOS flag is requested in the ext_flags for the inet_diag request. This would mainly be used to expose TOS values for both for TCP and UDP sockets. Currently it is supported for TCP. When netlink support for UDP would be added the support to expose the TOS values would alse be done. For IPV4 tos value is exposed and for IPV6 tclass value is exposed. Signed-off-by: Murali Raja <muralira@google.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-30headers_check fix: linux/inet_diag.hJaswinder Singh Rajput
fix the following 'make headers_check' warning: usr/include/linux/inet_diag.h:16: found __[us]{8,16,32,64} type without #include <linux/types.h> Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
2006-09-28[IPV4]: inet_diag annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET_DIAG]: Rename tcp_diag.[ch] to inet_diag.[ch]Arnaldo Carvalho de Melo
Next changeset will introduce net/ipv4/tcp_diag.c, moving the code that was put transitioanlly in inet_diag.c. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
