path: root/include/linux/in.h
2006-10-04[XFRM]: BEET modeDiego Beltrami
This patch introduces the BEET mode (Bound End-to-End Tunnel) with as specified by the ietf draft at the following link: http://www.ietf.org/internet-drafts/draft-nikander-esp-beet-mode-06.txt The patch provides only single family support (i.e. inner family = outer family). Signed-off-by: Diego Beltrami <diego.beltrami@gmail.com> Signed-off-by: Miika Komu <miika@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Abhinav Pathak <abhinav.pathak@hiit.fi> Signed-off-by: Jeff Ahrenholz <ahrenholz@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: annotate ipv4 address fields in struct ip_msfilter and struct ↵Al Viro
ip_mreq_source Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV4]: Make struct sockaddr_in::sin_port __be16Alexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV4]: Make struct in_addr::s_addr __be32Alexey Dobriyan
There will be relatively small increase in sparse endian warnings, but this (and sin_port) patch is a first step to make networking code endian clean. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SECURITY]: TCP/UDP getpeersecCatherine Zhang
This patch implements an application of the LSM-IPSec networking controls whereby an application can determine the label of the security association its TCP or UDP sockets are currently connected to via getsockopt and the auxiliary data mechanism of recvmsg. Patch purpose: This patch enables a security-aware application to retrieve the security context of an IPSec security association a particular TCP or UDP socket is using. The application can then use this security context to determine the security context for processing on behalf of the peer at the other end of this connection. In the case of UDP, the security context is for each individual packet. An example application is the inetd daemon, which could be modified to start daemons running at security contexts dependent on the remote client. Patch design approach: - Design for TCP The patch enables the SELinux LSM to set the peer security context for a socket based on the security context of the IPSec security association. The application may retrieve this context using getsockopt. When called, the kernel determines if the socket is a connected (TCP_ESTABLISHED) TCP socket and, if so, uses the dst_entry cache on the socket to retrieve the security associations. If a security association has a security context, the context string is returned, as for UNIX domain sockets. - Design for UDP Unlike TCP, UDP is connectionless. This requires a somewhat different API to retrieve the peer security context. With TCP, the peer security context stays the same throughout the connection, thus it can be retrieved at any time between when the connection is established and when it is torn down. With UDP, each read/write can have different peer and thus the security context might change every time. As a result the security context retrieval must be done TOGETHER with the packet retrieval. The solution is to build upon the existing Unix domain socket API for retrieving user credentials. Linux offers the API for obtaining user credentials via ancillary messages (i.e., out of band/control messages that are bundled together with a normal message). Patch implementation details: - Implementation for TCP The security context can be retrieved by applications using getsockopt with the existing SO_PEERSEC flag. As an example (ignoring error checking): getsockopt(sockfd, SOL_SOCKET, SO_PEERSEC, optbuf, &optlen); printf("Socket peer context is: %s\n", optbuf); The SELinux function, selinux_socket_getpeersec, is extended to check for labeled security associations for connected (TCP_ESTABLISHED == sk->sk_state) TCP sockets only. If so, the socket has a dst_cache of struct dst_entry values that may refer to security associations. If these have security associations with security contexts, the security context is returned. getsockopt returns a buffer that contains a security context string or the buffer is unmodified. - Implementation for UDP To retrieve the security context, the application first indicates to the kernel such desire by setting the IP_PASSSEC option via getsockopt. Then the application retrieves the security context using the auxiliary data mechanism. An example server application for UDP should look like this: toggle = 1; toggle_len = sizeof(toggle); setsockopt(sockfd, SOL_IP, IP_PASSSEC, &toggle, &toggle_len); recvmsg(sockfd, &msg_hdr, 0); if (msg_hdr.msg_controllen > sizeof(struct cmsghdr)) { cmsg_hdr = CMSG_FIRSTHDR(&msg_hdr); if (cmsg_hdr->cmsg_len <= CMSG_LEN(sizeof(scontext)) && cmsg_hdr->cmsg_level == SOL_IP && cmsg_hdr->cmsg_type == SCM_SECURITY) { memcpy(&scontext, CMSG_DATA(cmsg_hdr), sizeof(scontext)); } } ip_setsockopt is enhanced with a new socket option IP_PASSSEC to allow a server socket to receive security context of the peer. A new ancillary message type SCM_SECURITY. When the packet is received we get the security context from the sec_path pointer which is contained in the sk_buff, and copy it to the ancillary message space. An additional LSM hook, selinux_socket_getpeersec_udp, is defined to retrieve the security context from the SELinux space. The existing function, selinux_socket_getpeersec does not suit our purpose, because the security context is copied directly to user space, rather than to kernel space. Testing: We have tested the patch by setting up TCP and UDP connections between applications on two machines using the IPSec policies that result in labeled security associations being built. For TCP, we can then extract the peer security context using getsockopt on either end. For UDP, the receiving end can retrieve the security context using the auxiliary data mechanism of recvmsg. Signed-off-by: Catherine Zhang <cxzhang@watson.ibm.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[DCCP]: Initial implementationArnaldo Carvalho de Melo
Development to this point was done on a subversion repository at: http://oops.ghostprotocols.net:81/cgi-bin/viewcvs.cgi/dccp-2.6/ This repository will be kept at this site for the foreseable future, so that interested parties can see the history of this code, attributions, etc. If I ever decide to take this offline I'll provide the full history at some other suitable place. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
