path: root/include/linux/if_pppox.h
2009-01-15include of <linux/types.h> is preferred over <asm/types.h>Jaswinder Singh Rajput
Impact: fix 15 make headers_check warnings: include of <linux/types.h> is preferred over <asm/types.h> Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-18include: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. It's possible that they (or some user of them) rely on it dragging in some unrelated header file, but I can't build all these files, so we'll have to fix any build failures as they come up. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-10-10pppoe: endiannessAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Make socket creation namespace safe.Eric W. Biederman
This patch passes in the namespace a new socket should be created in and has the socket code do the appropriate reference counting. By virtue of this all socket create methods are touched. In addition the socket create methods are modified so that they will fail if you attempt to create a socket in a non-default network namespace. Failing if we attempt to create a socket outside of the default network namespace ensures that as we incrementally make the network stack network namespace aware we will not export functionality that someone has not audited and made certain is network namespace safe. Allowing us to partially enable network namespaces before all of the exotic protocols are supported. Any protocol layers I have missed will fail to compile because I now pass an extra parameter into the socket creation code. [ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[L2TP]: Changes to existing ppp and socket kernel headers for L2TPJames Chapman
Add struct sockaddr_pppol2tp to carry L2TP-specific address information for the PPPoX (PPPoL2TP) socket. Unfortunately we can't use the union inside struct sockaddr_pppox because the L2TP-specific data is larger than the current size of the union and we must preserve the size of struct sockaddr_pppox for binary compatibility. Also add a PPPIOCGL2TPSTATS ioctl to allow userspace to obtain L2TP counters and state from the kernel. Add new if_pppol2tp.h header. [ Modified to use aligned_u64 in statistics structure -DaveM ] Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETFILTER]: bridge-nf: filter bridged IPv4/IPv6 encapsulated in pppoe trafficMichael Milner
The attached patch by Michael Milner adds support for using iptables and ip6tables on bridged traffic encapsulated in ppoe frames, similar to what's already supported for vlan. Signed-off-by: Michael Milner <milner@blissisland.ca> Signed-off-by: Bart De Schuymer <bdschuym@pandora.be> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_network_header()Arnaldo Carvalho de Melo
For the places where we need a pointer to the network header, it is still legal to touch skb->nh.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[PPPOE]: Introduce pppoe_hdr()Arnaldo Carvalho de Melo
For consistency with all the other skb->nh.raw accessors. Also do some really obvious simplifications in pppoe_recvmsg, well the kfree_skb one is not so obvious, but free() and kfree() have the same behaviour (hint :-) ). Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-05[PPPOE]: Use ifindex instead of device pointer in key lookups.Florian Zumbiehl
Otherwise we can potentially try to dereference a NULL device pointer in some cases. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[PPPOX]: Fix assignment into const proto_ops.David S. Miller
And actually, with this, the whole pppox layer can basically be removed and subsumed into pppoe.c, no other pppox sub-protocol implementation exists and we've had this thing for at least 4 years. Signed-off-by: David S. Miller <davem@davemloft.net>
