path: root/include/linux/if.h
2011-08-15net: add IFF_SKB_TX_SHARED flag to priv_flagsNeil Horman
[ Upstream commit d8873315065f1f527c7c380402cf59b1e1d0ae36 ] Pktgen attempts to transmit shared skbs to net devices, which can't be used by some drivers as they keep state information in skbs. This patch adds a flag marking drivers as being able to handle shared skbs in their tx path. Drivers are defaulted to being unable to do so, but calling ether_setup enables this flag, as 90% of the drivers calling ether_setup touch real hardware and can handle shared skbs. A subsequent patch will audit drivers to ensure that the flag is set properly Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Reported-by: Jiri Pirko <jpirko@redhat.com> CC: Robert Olsson <robert.olsson@its.uu.se> CC: Eric Dumazet <eric.dumazet@gmail.com> CC: Alexey Dobriyan <adobriyan@gmail.com> CC: David S. Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-27netpoll: remove IFF_IN_NETPOLL flagAmerigo Wang
V4: rebase to net-next-2.6 This patch removes the flag IFF_IN_NETPOLL, we don't need it any more since we have netpoll_tx_running() now. Signed-off-by: WANG Cong <amwang@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-29net: fix datapath typoSimon Horman
Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-23net: increase the size of priv_flags and add IFF_OVS_DATAPATHSimon Horman
IFF_OVS_DATAPATH is a place-holder for the Open vSwitch datapath which I am preparing to submit for merging. As all 16 bits of priv_flags are already assigned flags, also increase the size of priv_flags to 32 bits. Unfortunately, by my calculations this increases the size of struct net_device by 4 bytes on 32bit architectures and 8 bytes on 64 bit architectures. I couldn't see an obvious way to avoid that. Cc: Jesse Gross <jesse@nicira.com> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-15bridge: use rx_handler_data pointer to store net_bridge_port pointerJiri Pirko
Register net_bridge_port pointer as rx_handler data pointer. As br_port is removed from struct net_device, another netdev priv_flag is added to indicate the device serves as a bridge port. Also rcuized pointers are now correctly dereferenced in br_fdb.c and in netfilter parts. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-15macvlan: use rx_handler_data pointer to store macvlan_port pointer V2Jiri Pirko
Register macvlan_port pointer as rx_handler data pointer. As macvlan_port is removed from struct net_device, another netdev priv_flag is added to indicate the device serves as a macvlan port. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-06netpoll: add generic support for bridge and bonding devicesWANG Cong
This whole patchset is for adding netpoll support to bridge and bonding devices. I already tested it for bridge, bonding, bridge over bonding, and bonding over bridge. It looks fine now. To make bridge and bonding support netpoll, we need to adjust some netpoll generic code. This patch does the following things: 1) introduce two new priv_flags for struct net_device: IFF_IN_NETPOLL which identifies we are processing a netpoll; IFF_DISABLE_NETPOLL is used to disable netpoll support for a device at run-time; 2) introduce one new method for netdev_ops: ->ndo_netpoll_cleanup() is used to clean up netpoll when a device is removed. 3) introduce netpoll_poll_dev() which takes a struct net_device * parameter; export netpoll_send_skb() and netpoll_poll_dev() which will be used later; 4) hide a pointer to struct netpoll in struct netpoll_info, ditto. 5) introduce ->real_dev for struct netpoll. 6) introduce a new status NETDEV_BONDING_DESLAE, which is used to disable netconsole before releasing a slave, to avoid deadlocks. Cc: David Miller <davem@davemloft.net> Cc: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-19cfg80211: disallow bridging managed/adhoc interfacesJohannes Berg
A number of people have tried to add a wireless interface (in managed mode) to a bridge and then complained that it doesn't work. It cannot work, however, because in 802.11 networks all packets need to be acknowledged and as such need to be sent to the right address. Promiscuous doesn't help here. The wireless address format used for these links has only space for three addresses, the * transmitter, which must be equal to the sender (origin) * receiver (on the wireless medium), which is the AP in the case of managed mode * the recipient (destination), which is on the APs local network segment In an IBSS, it is similar, but the receiver and recipient must match and the third address is used as the BSSID. To avoid such mistakes in the future, disallow adding a wireless interface to a bridge. Felix has recently added a four-address mode to the AP and client side that can be used (after negotiating that it is possible, which must happen out-of-band by setting up both sides) for bridging, so allow that case. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-04net: cleanup include/linuxEric Dumazet
This cleanup patch puts struct/union/enum opening braces, in first line to ease grep games. struct something { becomes : struct something { Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-18net: release dst entry in dev_hard_start_xmit()Eric Dumazet
One point of contention in high network loads is the dst_release() performed when a transmited skb is freed. This is because NIC tx completion calls dev_kree_skb() long after original call to dev_queue_xmit(skb). CPU cache is cold and the atomic op in dst_release() stalls. On SMP, this is quite visible if one CPU is 100% handling softirqs for a network device, since dst_clone() is done by other cpus, involving cache line ping pongs. It seems right place to release dst is in dev_hard_start_xmit(), for most devices but ones that are virtual, and some exceptions. David Miller suggested to define a new device flag, set in alloc_netdev_mq() (so that most devices set it at init time), and carefuly unset in devices which dont want a NULL skb->dst in their ndo_start_xmit(). List of devices that must clear this flag is : - loopback device, because it calls netif_rx() and quoting Patrick : "ip_route_input() doesn't accept loopback addresses, so loopback packets already need to have a dst_entry attached." - appletalk/ipddp.c : needs skb->dst in its xmit function - And all devices that call again dev_queue_xmit() from their xmit function (as some classifiers need skb->dst) : bonding, vlan, macvlan, eql, ifb, hdlc_fr Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21WAN: Generic HDLC now uses IFF_WAN_HDLC private flag.Krzysztof Hałasa
Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03bonding, net: Move last_rx update into bonding recv logicJay Vosburgh
The only user of the net_device->last_rx field is bonding. This patch adds a conditional update of last_rx to the bonding special logic in skb_bond_should_drop, causing last_rx to only be updated when the ARP monitor is running. This frees network device drivers from the necessity of updating last_rx, which can have cache line thrash issues. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22net: network device name ifalias supportStephen Hemminger
This patch add support for keeping an additional character alias associated with an network interface. This is useful for maintaining the SNMP ifAlias value which is a user defined value. Routers use this to hold information like which circuit or line it is connected to. It is just an arbitrary text label on the network device. There are two exposed interfaces with this patch, the value can be read/written either via netlink or sysfs. This could be maintained just by the snmp daemon, but it is more generally useful for other management tools, and the kernel is good place to act as an agreed upon interface to store it. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV6]: Add RFC4214 supportFred L. Templin
This patch includes support for the Intra-Site Automatic Tunnel Addressing Protocol (ISATAP) per RFC4214. It uses the SIT module, and is configured using extensions to the "iproute2" utility. The diffs are specific to the Linux 2.6.24-rc2 kernel distribution. This version includes the diff for ./include/linux/if.h which was missing in the v2.4 submission and is needed to make the patch compile. The patch has been installed, compiled and tested in a clean 2.6.24-rc2 kernel build area. Signed-off-by: Fred L. Templin <fred.l.templin@boeing.com> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[CAN]: Allocate protocol numbers for PF_CANOliver Hartkopp
This patch adds a protocol/address family number, ARP hardware type, ethernet packet type, and a line discipline number for the SocketCAN implementation. Signed-off-by: Oliver Hartkopp <oliver.hartkopp@volkswagen.de> Signed-off-by: Urs Thuermann <urs.thuermann@volkswagen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[NET]: Move netlink interface bits to linux/if_link.h.YOSHIFUJI Hideaki
Moving netlink interface bits to linux/if.h is rather troublesome for applications including both linux/if.h (which was changed to be included from linux/rtnetlink.h automatically) and net/if.h. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-25[PATCH] bonding: Validate probe replies in ARP monitorJay Vosburgh
Add logic to check ARP request / reply packets used for ARP monitor link integrity checking. The current method simply examines the slave device to see if it has sent and received traffic; this can be fooled by extraneous traffic. For example, if multiple hosts running bonding are behind a common switch, the probe traffic from the multiple instances of bonding will update the tx/rx times on each other's slave devices. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-25[PATCH] bonding: Add priv_flag to avoid event mishandlingJay Vosburgh
Add priv_flag to specifically identify bonding-involved devices. Needed because IFF_MASTER is an unreliable identifier (vlan interfaces above bonding will inherit IFF_MASTER). Misidentification of devices would cause notifier events for other devices to be erroneously processed by bonding, causing various havoc. Bug discovered by Martin Papik <martin.papik@ipsec.info>; this patch is modified from his original. Signed-off-by: Martin Papik <martin.papik@ipsec.info> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-22[NET]: Move netlink interface bits to linux/if.hThomas Graf
Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NET] core: add RFC2863 operstateStefan Rompf
this patch adds a dormant flag to network devices, RFC2863 operstate derived from these flags and possibility for userspace interaction. It allows drivers to signal that a device is unusable for user traffic without disabling queueing (and therefore the possibility for protocol establishment traffic to flow) and a userspace supplicant (WPA, 802.1X) to mark a device unusable without changes to the driver. It is the result of our long discussion. However I must admit that it represents what Jamal and I agreed on with compromises towards Krzysztof, but Thomas and Krzysztof still disagree with some parts. Anyway I think it should be applied. Signed-off-by: Stefan Rompf <stefan@loplof.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-03[PATCH] bonding: suppress duplicate packetsJay Vosburgh
Originally submitted by Kenzo Iwami; his original description is: The current bonding driver receives duplicate packets when broadcast/ multicast packets are sent by other devices or packets are flooded by the switch. In this patch, new flags are added in priv_flags of net_device structure to let the bonding driver discard duplicate packets in dev.c:skb_bond(). Modified by Jay Vosburgh to change a define name, update some comments, rearrange the new skb_bond() for clarity, clear all bonding priv_flags on slave release, and update the driver version. Signed-off-by: Kenzo Iwami <k-iwami@cj.jp.nec.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2005-05-12[netdrvrs] Use netif_carrier_* instead of IFF_RUNNING
2005-05-05[PATCH] update Ross Biro bouncing email addressJesper Juhl
Ross moved. Remove the bad email address so people will find the correct one in ./CREDITS. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
