path: root/include/linux/ieee80211.h
2014-05-28wireless: add missing WLAN_EID_BSS_INTOLERANT_CHL_REPORTJes Sorensen
Signed-off-by: Jes Sorensen <Jes.Sorensen@redhat.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-03-20Merge branch 'for-john' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
2014-03-19wireless: max MSDU size for DMG networksVladimir Kondratiev
In the 802.11ad, aka DMG (Dynamic Multi-Gigabit), aka 60Ghz spec, maximum MSDU size extended to 7920 bytes. add #define for this. Signed-off-by: Vladimir Kondratiev <qca_vkondrat@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-28ieee80211: remove function ieee80211_{dsss_chan_to_freq, freq_to_dsss_chan}Zhao, Gang
Function ieee80211_{dsss_chan_to_freq, freq_to_dsss_chan} have been replaced with ieee80211_{channel_to_frequency, frequency_to_channel}. There should be no users of the two functions now. So remove them. Cc: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Zhao, Gang <gamerh2o@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-02-05wireless: sort and extend element ID listJohannes Berg
The element ID list is currently almost sorted by amendment or similar topic, but the order is difficult to maintain and not very transparent. Sort the list by ID instead, and add a lot of missing IDs. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-04mac80211: fix bufferable MMPDU RX handlingJohannes Berg
Action, disassoc and deauth frames are bufferable, and as such don't have the PM bit in the frame control field reserved which means we need to react to the bit when receiving in such a frame. Fix this by introducing a new helper ieee80211_is_bufferable_mmpdu() and using it for the RX path that currently ignores the PM bit in any non-data frames for doze->wake transitions, but listens to it in all frames for wake->doze transitions, both of which are wrong. Also use the new helper in the TX path to clean up the code. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-04mac80211: add length check in ieee80211_is_robust_mgmt_frame()Johannes Berg
A few places weren't checking that the frame passed to the function actually has enough data even though the function clearly documents it must have a payload byte. Make this safer by changing the function to take an skb and checking the length inside. The old version is preserved for now as the rtl* drivers use it and don't have a correct skb. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-01-10ieee80211: add definition for SMS4 key lenAvinash Patil
Add SMS4 key length definition to ieee80211_key_len enum. It's used by WAPI. Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-01-10ieee80211: add definition for TDLS wide band extended capabilityAvinash Patil
Seventh bit of 8th byte of extended capabilities specifies wide bandwidth support for TDLS links. Add this definition to ieee80211. Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-11-25mac80211: enable easier manipulation of VHT beamforming capsEyal Shapira
Introduce shift and mask defines for beamformee STS cap and number of sounding dimensions cap as these can take any 3 bit value. While at it also cleanup an unrequired parenthesis. Signed-off-by: Eyal Shapira <eyal@wizery.com> Reviewed-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-10-28mac80211: process the CSA frame for mesh accordinglyChun-Yeow Yeoh
Process the CSA frame according to the procedures define in IEEE Std 802.11-2012 section 10.9.8.4.3 as follow: * The mesh channel switch parameters element (MCSP) must be availabe. * If the MCSP's TTL is 1, drop the frame but still process the CSA. * If the MCSP's precedence value is less than or equal to the current precedence value, drop the frame and do not process the CSA. * The CSA frame is forwarded after TTL is decremented by 1 and the initiator field is set to 0. Transmit restrict field and others are maintained as is. * No beacon or probe response frame are handled here. Also, introduce the debug message used for mesh CSA purpose. Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@cozybit.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-10-01ieee80211: fix vht cap definitionsEliad Peller
VHT_CAP_BEAMFORMER_ANTENNAS cap is actually defined in the draft as VHT_CAP_BEAMFORMEE_STS_MAX, and its size is 3 bits long. VHT_CAP_SOUNDING_DIMENSIONS is also 3 bits long. Fix the definitions and change the cap masking accordingly. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-08-29Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem Conflicts: drivers/net/wireless/iwlwifi/pcie/trans.c
2013-08-12Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem Conflicts: drivers/net/ethernet/broadcom/Kconfig
2013-08-06wireless: make TU conversion macros availableJohannes Berg
A few places in the code (mac80211 and iwlmvm) use the same TU_TO_JIFFIES() macro and could use TU_TO_EXP_TIME() that mac80211 has. Make these available to everyone and use them. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-08-02include: Convert ethernet mac address declarations to use ETH_ALENJoe Perches
It's convenient to have ethernet mac addresses use ETH_ALEN to be able to grep for them a bit easier and also to ensure that the addresses are __aligned(2). Add #include <linux/if_ether.h> as necessary. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Mauro Carvalho Chehab <m.chehab@samsung.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-01ieee80211: add definition for 802.11ac information elementsFred Zhou
Add element IDs for Extended BSS Load, VHT TX Power Envelope, AID, and Quiet Channel. Signed-off-by: Fred Zhou <fred.zy@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-08-01ieee80211: add definition for interworking supportAvinash Patil
IEEE802.11u interworking support is advertised via extended capabilities IE bit 31. This is 7th bit of 4th byte of extended capabilities. Signed-off-by: Avinash Patil <patila@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-06-03mac80211: set mesh formation field properlyJacob Minshall
Cap max peerings at 63 in accordance with IEEE-2012 8.4.2.100.7. Triggers a beacon regeneration every time the number of peerings changes. Previously this would only happen if the "accepting peerings" bit changed. Signed-off-by: Jacob Minshall <jacob@cozybit.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-16wireless: move crypto constants to ieee80211.hJohannes Berg
mac80211 and the Intel drivers all define crypto constants, move them to ieee80211.h instead. Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-16mac80211: parse VHT channel switch IEsJohannes Berg
VHT introduces multiple IEs that need to be parsed for a wide bandwidth channel switch. Two are (currently) needed in mac80211: * wide bandwidth channel switch element * channel switch wrapper element The former is contained in the latter for beacons and probe responses, but not for the spectrum management action frames so the IE parser needs a new argument to differentiate them. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-16mac80211: handle extended channel switch announcementJohannes Berg
Handle the (public) extended channel switch announcement action frames. Parts of the data in these frames isn't really in IEs, but put it into the elems struct anyway to simplify the handling. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-16mac80211: support secondary channel offset in CSAJohannes Berg
Add support for the secondary channel offset IE in channel switch announcements. This is necessary for proper handling of CSA on HT access points. For this to work it is also necessary to convert everything here to use chandef structs instead of just channels. The driver updates aren't really correct though. In particular, the TI wl18xx driver update can't possibly be right since it just ignores the new channel width for lack of firmware API. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-16mac80211: support extended channel switchJohannes Berg
Support extended channel switch when the operating class is one of the global operating classes as defined in Annex E of 802.11-2012. If it isn't, disconnect from the AP instead. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-16mac80211: unify CSA action frame/beacon processingJohannes Berg
CSA action frame content should be processed as variable IEs rather than fixed to make it extensible. Unify the code and process them just like CSA in beacons to make it easier to extend for HT/VHT. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-08mac80211: parse Timeout Interval Element using a structJohannes Berg
Instead of open-coding the accesses and length check do the length check in the IE parser and assign a struct pointer for use in the remaining code. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-03-22cfg80211: add P2P Notice of Absence attributeJanusz Dziedzic
Add P2P Notice of Absence attribute structure. Signed-off-by: Janusz Dziedzic <janusz.dziedzic@tieto.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-03-06mac80211: restrict peer's VHT capabilities to ownJohannes Berg
Implement restricting peer VHT capabilities to the device's own capabilities. This is useful when a single driver supports more than one device and the devices have different capabilities (often they will differ in the number of spatial streams), but in particular is also necessary for VHT capability overrides to work correctly -- otherwise it'd be possible to e.g. advertise, due to overrides, that TX-STBC is not supported, but then still use it to TX to the AP because it supports RX-STBC. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-03-06wireless: remove unused VHT MCS definesJohannes Berg
There's an enum with the same values (but slightly different names except for NOT_SUPPORTED) that is actually used, so remove the defines. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-03-06ieee80211: mark 802.11 related structs as being 2-byte alignedFelix Fietkau
Regardless of what header features they use, or if they align the IP header or not, 802.11 packets from all drivers guarantee a 2-byte alignment (and there's a debug WARN_ON in case they don't). Annotate packet structs with __aligned(2) to allow the compiler to use 16-bit load/store operations on platforms with extremely inefficient unaligned access (e.g. MIPS). This reduces code size and improves performance on affected platforms and causes no binary code change on others. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-03-06wireless: move sequence number arithmetic to ieee80211.hJohannes Berg
Move the sequence number arithmetic code from mac80211 to ieee80211.h so others can use it. Also rename the functions from _seq to _sn, they operate on the sequence number, not the sequence_control field. Also move macros to convert the sequence control to/from the sequence number value from various drivers. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-02-15mac80211: advertise operating mode notification capabilityJohannes Berg
Use the new extended capabilities advertising to advertise the fact that operating mode notification is supported. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-02-15mac80211: constify IE parsingJohannes Berg
Make all the parsed IE pointers const, and propagate the change to all the users etc. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-02-15mac80211: handle VHT operating mode notificationJohannes Berg
Handle the operating mode notification action frame. When the supported streams or the bandwidth change let the driver and rate control algorithm know. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-02-15wireless: define operating mode action frameJohannes Berg
Define the action frame format, the VHT category and its action types and the field format and EID for operating mode notifications. The frame may be used outside of VHT context as well, so don't include "VHT" in the names. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-02-04mac80211: mesh power save basicsMarco Porsch
Add routines to - maintain a PS mode for each peer and a non-peer PS mode - indicate own PS mode in transmitted frames - track neighbor STAs power modes - buffer frames when neighbors are in PS mode - add TIM and Awake Window IE to beacons - release frames in Mesh Peer Service Periods Add local_pm to sta_info to represent the link-specific power mode at this station towards the remote station. When a peer link is established, use the default power mode stored in mesh config. Update the PS status if the peering status of a neighbor changes. Maintain a mesh power mode for non-peer mesh STAs. Set the non-peer power mode to active mode during peering. Authenticated mesh peering is currently not working when either node is configured to be in power save mode. Indicate the current power mode in transmitted frames. Use QoS Nulls to indicate mesh power mode transitions. For performance reasons, calls to the function setting the frame flags are placed in HWMP routing routines, as there the STA pointer is already available. Add peer_pm to sta_info to represent the peer's link-specific power mode towards the local station. Add nonpeer_pm to represent the peer's power mode towards all non-peer stations. Track power modes based on received frames. Add the ps_data structure to ieee80211_if_mesh (for TIM map, PS neighbor counter and group-addressed frame buffer). Set WLAN_STA_PS flag for STA in PS mode to use the unicast frame buffering routines in the tx path. Update num_sta_ps to buffer and release group-addressed frames after DTIM beacons. Announce the awake window duration in beacons if in light or deep sleep mode towards any peer or non-peer. Create a TIM IE similarly to AP mode and add it to mesh beacons. Parse received Awake Window IEs and check TIM IEs for buffered frames. Release frames towards peers in mesh Peer Service Periods. Use the corresponding trigger frames and monitor the MPSP status. Append a QoS Null as trigger frame if neccessary to properly end the MPSP. Currently, in HT channels MPSPs behave imperfectly and show large delay spikes and frame losses. Signed-off-by: Marco Porsch <marco@cozybit.com> Signed-off-by: Ivan Bezyazychnyy <ivan.bezyazychnyy@gmail.com> Signed-off-by: Mike Krinkin <krinkin.m.u@gmail.com> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-01-24ieee80211: define AKM suite selectors type 5, 6 and 7Bing Zhao
Reference: IEEE 802.11-2012 8.4.2.27.3 "AKM suites" Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-01-03mac80211: support HT notify channel width actionJohannes Berg
Support the HT notify channel width action frame to update the rate scaling about the bandwidth the peer can receive in. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-01-03wireless: use __packed in ieee80211.hJohannes Berg
Use __packed instead of __attribute__((packed)). Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-01-03wireless: more 'capability info' bitsVladimir Kondratiev
define bits for 'capability info', as in recent spec edition IEEE802.11-2012 Also, add mask for 2-bit field 'bss type', as it is in 802.11ad Signed-off-by: Vladimir Kondratiev <qca_vkondrat@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-12-06wireless: fix VHT max AMPDU exponent definitionJohannes Berg
This is really a 3-bit field, not a single bit, so declare a mask and shift. Also fix hwsim, it advertises the maximum possible. While at it reindent all the defines using tabs instead of spaces. Change-Id: I7cd81c0d72f76deb5010aba5bfa3dd312006e898 Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-11-27mac80211: support VHT associationJohannes Berg
Determine the VHT channel from the AP's VHT operation IE (if present) and configure the hardware to that channel if it is supported. If channel contexts cause a channel to not be usable, try a smaller bandwidth. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-11-26wireless: add definitions for VHT MCS supportJohannes Berg
Add definitions for the VHT MCS support values that are used to indicate, for each number of streams (1 through 8) which MCSes are supported. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-11-26mac80211: move Mesh Capability field definition to ieee80211.hMarco Porsch
Signed-off-by: Marco Porsch <marco.porsch@etit.tu-chemnitz.de> [prefix with IEEE80211_] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-11-19mac80211: introduce IEEE80211_NUM_TIDS and use itJohannes Berg
Introduce IEEE80211_NUM_TIDS in the generic 802.11 header file and use it in place of STA_TID_NUM and NUM_RX_DATA_QUEUES which are both really the number of TIDs. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-11-05wireless: add peer-to-peer related definitionsArend van Spriel
The Peer-to-Peer IE is vendor-specific IE identified by WiFi Alliance OUI and specific P2P OUI type. The payload of this IE consists of so-called P2P attributes. This patch adds definitions for processing these attributes. Reviewed-by: Hante Meuleman <meuleman@broadcom.com> Reviewed-by: Pieter-Paul Giesberts <pieterpg@broadcom.com> Reviewed-by: Franky (Zhenhui) Lin <frankyl@broadcom.com> Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-10-18wireless: remove duplicate enum ieee80211_eid definitionsArend van Spriel
WLAN_EID_WPA and WLAN_EID_GENERIC mapped to the same value as WLAN_EID_VENDOR_SPECIFIC. The last one being more in line with the standard specification. Removing WLAN_EID_WPA and WLAN_EID_GENERIC as there are no longer drivers using these. Cc: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-10-17ieee80211: Rename VHT cap structMahesh Palivela
Rename struct ieee80211_vht_capabilities to ieee80211_vht_cap and renamed its member vht_capabilities_info to vht_cap_info. Signed-off-by: Mahesh Palivela <maheshp@posedge.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-09-06wireless: remove obsolete chan no/center freq conversion functionsJohannes Berg
There are a number of functions that shouldn't really be used when modern functions that take the band are available in cfg80211. Remove these, but for now keep * ieee80211_freq_to_dsss_chan and * ieee80211_dsss_chan_to_freq as they're used in older drivers. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-02wireless: 60g protocol constantsVladimir Kondratiev
Provide various constants as defined by the 802.11ad: frame types, IE's, capability bits, action categories Introduce GCMP cipher, mandatory by 802.11ad Signed-off-by: Vladimir Kondratiev <qca_vkondrat@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
