path: root/include/linux/ieee80211.h
2009-08-28mac80211: Update mesh config IE to 11s draft 3.02Javier Cardona
The mesh config information element has changed significantly since draft 1.08 This patch brings it up to date. Thanks to Sam Leffler and Rui Paulo for identifying this. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-27mac80211: Add a few 802.11n defines for AMPDU parametersSujith
Signed-off-by: Sujith <Sujith.Manoharan@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10wireless: define AKM suitesJohannes Berg
We'll need these values for some drivers using connect API and for wext compat code, so let's define them. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03cfg80211: use key size constantsJohannes Berg
Instead of hardcoding the key length for validation, use the constants Zhu Yi recently added and add one for AES_CMAC too. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-22wireless: move some utility functions from mac80211 to cfg80211Zhu Yi
The patch moves some utility functions from mac80211 to cfg80211. Because these functions are doing generic 802.11 operations so they are not mac80211 specific. The moving allows some fullmac drivers to be also benefit from these utility functions. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: Samuel Ortiz <samuel.ortiz@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-11mac80211: Robust Action frame categories for MFPJouni Malinen
IEEE 802.11w/D9.0 introduces a mechanism for Action field Category values to be used to select which Action frames are Robust. Public and Vendor-specific categories are marked as not Robust in IEEE 802.11w; HT will be marked not Robust in IEEE 802.11n. A new Vendor-specific Protected category is allocated for Robust vendor-specific Action frames. Another new category, Protected Dual of Action, is introduced for protecting some existing Public Action frames (e.g., IEEE 802.11y protected enablement). Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-06mac80211: Update SA Query transaction id lengthJouni Malinen
IEEE 802.11w/D8.0 changed the length of the SA Query transaction identifier from 16 to 2 octets. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22mac80211: validate TIM IE length (redux)Johannes Berg
The TIM IE must not be shorter than 4 bytes, so verify that when parsing it and use the proper type. To ease that adjust struct ieee80211_tim_ie to have a virtual bitmap of size at least 1. Also check that the TIM IE is actually present before trying to parse it! Because other people may need the function, make it a static inline in ieee80211.h. (The original "mac80211: validate TIM IE length" was a minimal fix for 2.6.30. This purports to be the full, correct fix. -- JWL) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22mac80211: disable powersave if pm_qos asks for low latencyJohannes Berg
When an application asks for a latency lower than the beacon interval there's nothing we can do -- we need to stay awake and not have the AP buffer frames for us. Add code to automatically calculate this constraint in mac80211 so drivers need not concern themselves with it. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27nl80211: Add MLME primitives to support external SMEJouni Malinen
This patch adds new nl80211 commands to allow user space to request authentication and association (and also deauthentication and disassociation). The commands are structured to allow separate authentication and association steps, i.e., the interface between kernel and user space is similar to the MLME SAP interface in IEEE 802.11 standard and an user space application takes the role of the SME. The patch introduces MLME-AUTHENTICATE.request, MLME-{,RE}ASSOCIATE.request, MLME-DEAUTHENTICATE.request, and MLME-DISASSOCIATE.request primitives. The authentication and association commands request the actual operations in two steps (assuming the driver supports this; if not, separate authentication step is skipped; this could end up being a separate "connect" command). The initial implementation for mac80211 uses the current net/mac80211/mlme.c for actual sending and processing of management frames and the new nl80211 commands will just stop the current state machine from moving automatically from authentication to association. Future cleanup may move more of the MLME operations into cfg80211. The goal of this design is to provide more control of authentication and association process to user space without having to move the full MLME implementation. This should be enough to allow IEEE 802.11r FT protocol and 802.11s SAE authentication to be implemented. Obviously, this will also bring the extra benefit of not having to use WEXT for association requests with mac80211. An example implementation of a user space SME using the new nl80211 commands is available for wpa_supplicant. This patch is enough to get IEEE 802.11r FT protocol working with over-the-air mechanism (over-the-DS will need additional MLME primitives for handling the FT Action frames). Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27ieee80211: document DS bit usageJohannes Berg
I keep needing this because I'm too stupid to remember it. Everybody else can probably remember, but who knows :) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: Fix MFP Association Comeback to use Timeout Interval IEJouni Malinen
The separate Association Comeback Time IE was removed from IEEE 802.11w and the Timeout Interval IE (from IEEE 802.11r) is used instead. The editing on this is still somewhat incomplete in IEEE 802.11w/D7.0, but still, the use of Timeout Interval IE is the expected mechanism. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: 802.11w - Implement Association Comeback processingJouni Malinen
When MFP is enabled, the AP does not allow a STA to associate if an existing security association exists without first going through SA Query process. When this happens, the association request is denied with a new status code ("temporarily rejected") ans Association Comeback IE is used to notify when the association may be tried again (i.e., when the SA Query procedure has timed out). Use the comeback time to update the mac80211 client MLME timer for next association attempt to minimize waiting time if association is temporarily rejected. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: 802.11w - SA Query processingJouni Malinen
Process SA Query Requests for client mode in mac80211. AP side processing of SA Query Response frames is in user space (hostapd). Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: 802.11w - Use BIP (AES-128-CMAC)Jouni Malinen
Add mechanism for managing BIP keys (IGTK) and integrate BIP into the TX/RX paths. Signed-off-by: Jouni Malinen <j@w1.fi> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: 802.11w - Add BIP (AES-128-CMAC)Jouni Malinen
Implement Broadcast/Multicast Integrity Protocol for management frame protection. This patch adds the needed definitions for the new information element (MMIE) and implementation for the new "encryption" type (though, BIP is actually not encrypting data, it provides only integrity protection). These routines will be used by a follow-on patch that enables BIP for multicast/broadcast robust management frames. Signed-off-by: Jouni Malinen <j@w1.fi> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: 802.11w - CCMP for management framesJouni Malinen
Extend CCMP to support encryption and decryption of unicast management frames. Signed-off-by: Jouni Malinen <j@w1.fi> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29wireless: Add channel/frequency conversions to ieee80211.hDavid Kilroy
Added mappings for FHSS, DSSS and OFDM channels - with macros to point HR DSSS and ERP to the DSSS mappings. Currently just static inline functions. Use the new functions in the older fullmac drivers. This eliminates a number of const static buffers and removes a couple of range checks that are now redundant. Signed-off-by: David Kilroy <kilroyd@googlemail.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Richard Farina <sidhayn@gmail.com> Acked-by: Jeroen Vreeken <pe1rxq@amsat.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-12-12wireless: Incorrect LEAP authentication algorithm identifier.Senthil Balasubramanian
This patch fixes a regression introduced by "wireless: avoid some net/ieee80211.h vs. linux/ieee80211.h conflicts" LEAP authentication algorithm identifier should be 128. Signed-off-by: Senthil Balasubramanian <senthilkumar@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-25cfg80211/mac80211: Add 802.11d supportLuis R. Rodriguez
This adds country IE parsing to mac80211 and enables its usage within the new regulatory infrastructure in cfg80211. We parse the country IEs only on management beacons for the BSSID you are associated to and disregard the IEs when the country and environment (indoor, outdoor, any) matches the already processed country IE. To avoid following misinformed or outdated APs we build and use a regulatory domain out of the intersection between what the AP provides us on the country IE and what CRDA is aware is allowed on the same country. A secondary device is allowed to follow only the same country IE as it make no sense for two devices on a system to be in two different countries. In the case the AP is using country IEs for an incorrect country the user may help compliance further by setting the regulatory domain before or after the IE is parsed and in that case another intersection will be performed. CONFIG_WIRELESS_OLD_REGULATORY is supported but requires CRDA present. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-10mac80211_hwsim: Add support for client PS modeJouni Malinen
This introduces a debugfs file (ieee80211/phy#/hwsim/ps) that can be used to force a simulated radio into power save mode. Following values can be written into this file to change PS mode: 0 = power save disabled (constantly awake) 1 = power save enabled (drop all frames; do not send PS-Poll) 2 = power save enabled (send PS-Poll frames automatically to receive buffered unicast frames); not yet fully implemented 3 = manual PS-Poll trigger (send a single PS-Poll frame) Two different behavior for power save mode processing can be tested: - move between modes 1 and 0 (i.e., receive all buffered frames at a time) - move to mode 1 and use manual PS-Poll frames (write 3 to the 'ps' debugfs file) to fetch power save buffered frames one at a time Mode 2 (automatic PS-Poll) does not yet parse Beacon frames, but eventually, it should take a look at TIM IE and send PS-Poll if a traffic bit is set for our AID. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-10wireless: move mesh config length constantJohannes Berg
This is a constant from the 802.11 specification. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31wireless: avoid some net/ieee80211.h vs. linux/ieee80211.h conflictsJohn W. Linville
There is quite a lot of overlap in definitions between these headers... Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31wireless: use individual buffers for printing ssid valuesJohn W. Linville
Also change escape_ssid to print_ssid to match print_mac semantics. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31802.11: clean up/fix HT supportJohannes Berg
This patch cleans up a number of things: * the unusable definition of the HT capabilities/HT information information elements * variable names that are hard to understand * mac80211: move ieee80211_handle_ht to ht.c and remove the unused enable_ht parameter * mac80211: fix bug with MCS rate 32 in ieee80211_handle_ht * mac80211: fix bug with casting the result of ieee80211_bss_get_ie to an information element _contents_ rather than the whole element, add size checking (another out-of-bounds access bug fixed!) * mac80211: remove some unused return values in favour of BUG_ON checking * a few minor other things Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-24mac80211: mesh portal functionality supportYanBo
Currently the mesh code doesn't support bridging mesh point interfaces with wired ethernet or AP to construct an MPP or MAP. This patch adds code to support the "6 address frame format packet" functionality to mesh point interfaces. Now the mesh network can be used as backhaul for end to end communication. Signed-off-by: Li YanBo <dreamfly281@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-11mac80211: move some HT code out of mlme.cJohannes Berg
Some of the HT code in mlme.c is misplaced: * constants/definitions belong to the ieee80211.h header * code being used in other modes as well shouldn't be there Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-11mac80211: change MIMO_PS to SM_PSTomas Winkler
This patch follows 11n spec naming more rigorously replacing MIMO_PS with SM_PS (Spatial Multiplexing Power Save). (Originally submitted as 4 patches, "mac80211: change MIMO_PS to SM_PS", "iwlwifi: change MIMO_PS to SM_PS", "ath9k: change MIMO_PS to SM_PS", and "iwlwifi: remove double definition of SM PS". -- JWL) Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-29mac80211: Add an 802.11n definitionSujith
This patch adds a HT Capability (DSSS/CCK Mode in 40MHz BSS) definition to ieee80211.h Signed-off-by: Sujith Manoharan <Sujith.Manoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-04mac80211: pass dtim_period to low level driverEmmanuel Grumbach
This patch adds the dtim_period in ieee80211_bss_conf, this allows the low level driver to know the dtim_period, and to plan power save accordingly. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-08mac80211: move QOS control helpers into ieee80211.hHarvey Harrison
Also remove the WLAN_IS_QOS_DATA inline after removing the last two users. This starts moving away from using rx->fc to using the header frame_control directly. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-08mac80211: add block ack request capabilityRon Rindjunsky
This patch adds block ack request capability Signed-off-by: Ester Kummer <ester.kummer@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-26mac80211: 11h - Handling measurement requestAssaf Krauss
This patch handles the 11h measurement request information element. This is minimal requested implementation - refuse measurement. Signed-off-by: Assaf Krauss <assaf.krauss@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-26mac80211: 11h Infrastructure - ParsingAssaf Krauss
This patch introduces parsing of 11h and 11d related elements from incoming management frames. Signed-off-by: Assaf Krauss <assaf.krauss@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-14mac80211: remove ieee80211_get_morefragHarvey Harrison
Replaced by the new helper ieee80211_has_morefrags which is more consistent with the intent of the function. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-14mac80211: add helpers for frame control testingHarvey Harrison
A few general categories: 1) ieee80211_has_* tests if particular fctl bits are set, the helpers are de in the same order as the fctl defines: A combined _has_a4 was also added to test when both FROMDS and TODS are set. 2) ieee80211_is_* is meant to test whether the frame control is of a certain ftype - data, mgmt, ctl, and two special helpers _is_data_qos, _is_data_pres which also test a subset of the stype space. When testing for a particular stype applicable only to one ftype, functions like ieee80211_is_ack have been added. Note that the ftype is also being checked in these helpers. They have been added for all mgmt and ctl stypes in the same order as the STYPE defines. 3) ieee80211_get_* is meant to take a struct ieee80211_hdr * and returns a pointer to somewhere in the struct, see get_SA, get_DA, get_qos_ctl. The intel wireless drivers had helpers that used this namespace, convert the all to use the new helpers and remove the byteshifting as they were defined in cpu-order rather than little-endian. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-14iwlwifi: remove redundant flags regarding to FAT channelEmmanuel Grumbach
This patch removes redundant flags regarding to FAT channel. Use mac80211's flag instead. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-03mac80211: allow disable FAT in specific configurationsEmmanuel Grumbach
This patch allows to disable FAT channel in specific configurations. For example the configuration (8, +1), (primary channel 8, extension channel 12) isn't permitted in U.S., but (8, -1), (primary channel 8, extension channel 4) is. When FAT channel configuration is not permitted, FAT channel should be reported as not supported in the capabilities of the HT IE in association request. And sssociation is performed on 20Mhz channel. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21mac80211: separate Tx and Rx MCS when configuring HTRon Rindjunsky
This patch follows the 11n spec in separation between Tx and Rx MCS capabilities. Up until now, when configuring the HT possible set of Tx MCS only Rx MCS were considered, assuming they are the same as the Tx MCS. This patch fixed this by looking at low level driver Tx capabilities. Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-14mac80211: remove unnecessary byteshifts in frame control testingHarvey Harrison
Byteswap the constants rather than the frame_control member. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-30mac80211: use 4-byte mesh sequence numberLuis Carlos Cobo
This follows the new 802.11s/D2.0 draft. Signed-off-by: Luis Carlos Cobo <luisca@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-23mac80211: update mesh EID valuesLuis Carlos Cobo
This patch updates mesh EID values, some of which where conflicting with already-approved 11h EIDs (pointed out by Tomas Winkler). I wanted to use the values suggested in the last available 802.11 draft (2.0) but it assigns 50 to MESH_CONFIG, the same value than EXT_SUPP_RATES. Using the values proposed in the draft incremented by one. Signed-off-by: Luis Carlos Cobo <luisca@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-06wireless: various definitions for mesh networkingLuis Carlos Cobo
Signed-off-by: Luis Carlos Cobo <luisca@cozybit.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-01iwlwifi: Fix MIMO PS modeTomas Winkler
This patch setups correctly MIMO PS mode flags Signed-off-by: Guy Cohen <guy.cohen@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28mac80211: fixing ieee80211_bar typesRon Rindjunsky
This patch changes ieee80211_bar control and start_seq_num to match the proper bitwise attribute expected from ieee 802.11 frame Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28mac80211: A-MPDU Rx adding basic functionalityRon Rindjunsky
This patch adds the basic needed abilities and functions for A-MPDU Rx session changed functions: - ieee80211_sta_process_addba_request - Rx A-MPDU initialization enabled - ieee80211_stop - stops all A-MPDU Rx in case interface goes down added functions: - ieee80211_send_delba - used for sending out Del BA in A-MPDU sessions - ieee80211_sta_stop_rx_BA_session - stopping Rx A-MPDU session - sta_rx_agg_session_timer_expired - stops A-MPDU Rx use if load is too low Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28mac80211: adding 802.11n definitions in ieee80211.hRon Rindjunsky
This patch adds several structs and definitions to ieee80211.h to support 802.11n draft specifications. As 802.11n depends on and extends the 802.11e standard in several issues, there are also several definitions that belong to 802.11e. Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28ieee80211: Add IEEE80211_MAX_FRAME_LEN to linux/ieee80211.hMichael Wu
This patch adds IEEE80211_MAX_FRAME_LEN which is useful for drivers trying to determine how much to allocate for their RX buffers. It also updates the comment on IEEE80211_MAX_DATA_LEN based on revisions in 802.11e. IEEE80211_MAX_FRAG_THRESHOLD and IEEE80211_MAX_RTS_THRESHOLD are also revised due to the new maximum frame size. Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[PATCH] wireless networking: move frame inline functions to generic headerJohannes Berg
These inlines are generally useful, not just with mac80211. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-07-12[PATCH] mac80211: ERP IE handling improvementsDaniel Drake
The "protection needed" flag is currently parsed out of the ERP IE in beacons. This patch allows the ERP IE to be available at assocation time and causes the appropriate actions to be performed earlier. It is slightly complicated by the fact that most APs don't include the ERP IE in association responses. To work around this, we store ERP values in the ieee80211_sta_bss structure. Also added some WLAN_ERP defines for use by upcoming patches. Signed-off-by: Jiri Benc <jbenc@suse.cz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
