The current hyper-optimized functions are overkill if you simply want to
allocate an id for a device. Create versions which use an internal
lock.
In followup patches, numerous drivers are converted to use this
interface.
Thanks to Tejun for feedback.
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
Add idr/ida to kernel-api docbook.
Fix typos and kernel-doc notation.
Cc: Naohiro Aota <naota@elisp.net>
Cc: Jiri Kosina <jkosina@suse.cz>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
IDA_BITMAP_LONGS value is calculated take into account struct ida_bitmap
not to waste memory space. Comment it.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Cc: Manfred Spraul <manfred@colorfullife.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Patch for Per-CSS(Cgroup Subsys State) ID and private hierarchy code.
This patch attaches unique ID to each css and provides following.
- css_lookup(subsys, id)
returns pointer to struct cgroup_subysys_state of id.
- css_get_next(subsys, id, rootid, depth, foundid)
returns the next css under "root" by scanning
When cgroup_subsys->use_id is set, an id for css is maintained.
The cgroup framework only parepares
- css_id of root css for subsys
- id is automatically attached at creation of css.
- id is *not* freed automatically. Because the cgroup framework
don't know lifetime of cgroup_subsys_state.
free_css_id() function is provided. This must be called by subsys.
There are several reasons to develop this.
- Saving space .... For example, memcg's swap_cgroup is array of
pointers to cgroup. But it is not necessary to be very fast.
By replacing pointers(8bytes per ent) to ID (2byes per ent), we can
reduce much amount of memory usage.
- Scanning without lock.
CSS_ID provides "scan id under this ROOT" function. By this, scanning
css under root can be written without locks.
ex)
do {
rcu_read_lock();
next = cgroup_get_next(subsys, id, root, &found);
/* check sanity of next here */
css_tryget();
rcu_read_unlock();
id = found + 1
} while(...)
Characteristics:
- Each css has unique ID under subsys.
- Lifetime of ID is controlled by subsys.
- css ID contains "ID" and "Depth in hierarchy" and stack of hierarchy
- Allowed ID is 1-65535, ID 0 is UNUSED ID.
Design Choices:
- scan-by-ID v.s. scan-by-tree-walk.
As /proc's pid scan does, scan-by-ID is robust when scanning is done
by following kind of routine.
scan -> rest a while(release a lock) -> conitunue from interrupted
memcg's hierarchical reclaim does this.
- When subsys->use_id is set, # of css in the system is limited to
65535.
[bharata@linux.vnet.ibm.com: remove rcu_read_lock() from css_get_next()]
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: Paul Menage <menage@google.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Balbir Singh <balbir@in.ibm.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Signed-off-by: Bharata B Rao <bharata@linux.vnet.ibm.com>
2nd part of the fixes needed for
http://bugzilla.kernel.org/show_bug.cgi?id=11796.
When the idr tree is either grown or shrunk, then the update to the number
of layers and the top pointer were not atomic. This race caused crashes.
The attached patch fixes that by replicating the layers counter in each
layer, thus idr_find doesn't need idp->layers anymore.
Signed-off-by: Manfred Spraul <manfred@colorfullife.com>
Cc: Clement Calmels <cboulte@gmail.com>
Cc: Nadia Derbey <Nadia.Derbey@bull.net>
Cc: Pierre Peiffer <peifferp@gmail.com>
Cc: <stable@kernel.org>
Make idr_find rcu-safe: it can now be called inside an rcu_read critical
section.
Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net>
Reviewed-by: "Paul E. McKenney" <paulmck@us.ibm.com>
Cc: Jim Houston <jim.houston@comcast.net>
Do some code factorization in the return code analysis.
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
After scalability problems have been detected when using the sysV ipcs, I have
proposed to use an RCU based implementation of the IDR api instead (see
threads http://lkml.org/lkml/2008/4/11/212 and
http://lkml.org/lkml/2008/4/29/295).
This resulted in many people asking to convert the idr API and make it rcu
safe (because most of the code was duplicated and thus unmaintanable and
unreviewable).
So here is a first attempt.
The important change wrt to the idr API itself is during idr removes: idr
layers are freed after a grace period, instead of being moved to the free
list.
The important change wrt to ipcs, is that idr_find() can now be called
locklessly inside a rcu read critical section.
Here are the results I've got for the pmsg test sent by Manfred:
2.6.25-rc3-mm1 2.6.25-rc3-mm1+ 2.6.25-mm1 Patched 2.6.25-mm1
1 1168441 1064021 876000 947488
2 1094264 921059 1549592 1730685
3 2082520 1738165 1694370 2324880
4 2079929 1695521 404553 2400408
5 2898758 406566 391283 3246580
6 2921417 261275 263249 3752148
7 3308761 126056 191742 4243142
8 3329456 100129 141722 4275780
1st column: stock 2.6.25-rc3-mm1
2nd column: 2.6.25-rc3-mm1 + ipc patches (store ipcs into idrs)
3nd column: stock 2.6.25-mm1
4th column: 2.6.25-mm1 + this pacth series.
This patch:
Add an rcu_head to the idr_layer structure in order to free it after a grace
period.
Avoid a possible kmem_cache_create() failure by creating idr_layer_cache
unconditionary at boot time rather than creating it on-demand when idr_init()
is called the first time.
This change also enables us to eliminate the check every time idr_init() is
called.
[akpm@linux-foundation.org: rename init_id_cache() to idr_init_cache()]
[akpm@linux-foundation.org: fix alpha build]
Remove all ids from the given idr tree. idr_destroy() only frees up
unused, cached idp_layers, but this function will remove all id mappings
and leave all idp_layers unused.
A typical clean-up sequence for objects stored in an idr tree, will use
idr_for_each() to free all objects, if necessay, then idr_remove_all() to
remove all ids, and idr_destroy() to free up the cached idr_layers.
Signed-off-by: Kristian Hoegsberg <krh@redhat.com>
Cc: Tejun Heo <htejun@gmail.com>
Cc: Dave Airlie <airlied@linux.ie>
This patch adds an iterator function for the idr data structure. Compared
to just iterating through the idr with an integer and idr_find, this
iterator is (almost, but not quite) linear in the number of elements, as
opposed to the number of integers in the range covered by the idr. This
makes a difference for sparse idrs, but more importantly, it's a nicer way
to iterate through the elements.
The drm subsystem is moving to idr for tracking contexts and drawables, and
with this change, we can use the idr exclusively for tracking these
resources.
[akpm@linux-foundation.org: fix comment]
Implement idr based id allocator. ida is used the same way idr is
used but lacks id -> ptr translation and thus consumes much less
memory. struct ida_bitmap is attached as leaf nodes to idr tree which
is managed by the idr code. Each ida_bitmap is 128bytes long and
contains slightly less than a thousand slots.
ida is more aggressive with releasing extra resources acquired using
ida_pre_get(). After every successful id allocation, ida frees one
reserved idr_layer if possible. Reserved ida_bitmap is not freed
automatically but only one ida_bitmap is reserved and it's almost
always used right away. Under most circumstances, ida won't hold on
to memory for too long which isn't actively used.
Signed-off-by: Tejun Heo <htejun@gmail.com>
Locking init improvement:
- introduce and use __SPIN_LOCK_UNLOCKED for array initializations,
to pass in the name string of locks, used by debugging
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
This patch adds idr_replace() to replace an existing pointer in a single
operation.
Device-mapper will use this to update the pointer it stored against a given
id.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
This patch encloses the idr.h header file in
#ifndef __IDR_H__ macro.
Signed-off-by: Luben Tuikov <luben_tuikov@adaptec.com>
Fix a bug which was reported and diagnosed by
Stefan Jones <stefan.jones@churchillrandoms.co.uk>
IDR trees include a cache of idr_layer objects. There's no way to destroy
this cache, so when we discard an overall idr tree we end up leaking some
memory.
Add and use idr_destroy() for this. v9fs and infiniband also need to use
idr_destroy() to avoid leaks.
Or, we make the cache global, like radix_tree_preload(). Which is probably
better. Later.
Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: Robert Love <rml@novell.com>
Cc: John McCutchan <ttb@tentacle.dhs.org>
infrastructure for it.
Let it rip!
