path: root/include/linux/ide.h
2012-01-03switch procfs to umode_t useAl Viro
both proc_dir_entry ->mode and populating functions Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-08ide: Use linux/mutex.hAnton Blanchard
The IDE code is still including asm/mutex.h instead of linux/mutex.h Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-16Merge branch 'master' into for-nextJiri Kosina
2010-06-16fix typos concerning "management"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/ide-2.6: cmd640: fix kernel oops in test_irq() method pdc202xx_old: ignore "FIFO empty" bit in test_irq() method pdc202xx_old: wire test_irq() method for PDC2026x IDE: pass IRQ flags to the IDE core ide: fix comment typo in ide.h
2010-05-21block,ide: simplify bdops->set_capacity() to ->unlock_native_capacity()Tejun Heo
bdops->set_capacity() is unnecessarily generic. All that's required is a simple one way notification to lower level driver telling it to try to unlock native capacity. There's no reason to pass in target capacity or return the new capacity. The former is always the inherent native capacity and the latter can be handled via the usual device resize / revalidation path. In fact, the current API is always used that way. Replace ->set_capacity() with ->unlock_native_capacity() which take only @disk and doesn't return anything. IDE which is the only current user of the API is converted accordingly. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-15ide: fix comment typo in ide.hSergei Shtylyov
Fix typo in the comment to the 'dma_mode' field of the 'struct ide_drive_s' introduced by the commit 3fccaa192b9501e79a57e02e62b6bf420d2b461e (ide: add drive->dma_mode field). Whilt at it, convert spaces to a tab in the declaration of the neighbouring 'dn' field... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-01ide: Requeue request after DMA timeoutHerbert Xu
I noticed that my KVM virtual machines were experiencing IDE issues resulting in processes stuck on waiting for buffers to complete. The root cause is of course race conditions in the ancient qemu backend that I'm using. However, the fact that the guest isn't recovering is a bug. I've tracked it down to the change made last year to dequeue requests at the start rather than at the end in the IDE layer. commit 8f6205cd572fece673da0255d74843680f67f879 Author: Tejun Heo <tj@kernel.org> Date: Fri May 8 11:53:59 2009 +0900 ide: dequeue in-flight request The problem is that the function ide_dma_timeout_retry does not requeue the current request, causing one request to be lost for each DMA timeout. This patch fixes this by requeueing the request. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19ide: make ide_get_best_pio_mode() staticBartlomiej Zolnierkiewicz
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19ide: change ->set_dma_mode method parametersBartlomiej Zolnierkiewicz
Change ->set_dma_mode method parameters to match ->set_dmamode method used in struct ata_port_operations. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2010-01-19ide: change ->set_pio_mode method parametersBartlomiej Zolnierkiewicz
Change ->set_pio_mode method parameters to match ->set_piomode method used in struct ata_port_operations. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19ide: add drive->dma_mode fieldBartlomiej Zolnierkiewicz
Add dma_mode field to ide_drive_t matching dma_mode field used in struct ata_device. The validity of the field is restricted to ->dma_pio_mode method only currently in IDE subsystem. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19ide: add drive->pio_mode fieldBartlomiej Zolnierkiewicz
Add pio_mode field to ide_drive_t matching pio_mode field used in struct ata_device. The validity of the field is restricted to ->set_pio_mode method only currently in IDE subsystem. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02ide: Increase WAIT_DRQ to accomodate some CF cards and SSD drives.David S. Miller
Based upon a patch by Philippe De Muyter, and feedback from Mark Lord and Robert Hancock. As noted by Mark Lord, the outdated ATA1 spec specifies a 20msec timeout for setting DRQ but lots of common devices overshoot this. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01ide: convert to ->proc_fopsAlexey Dobriyan
->read_proc, ->write_proc are going away, ->proc_fops should be used instead. The only tricky place is IDENTIFY handling: if for some reason taskfile_lib_get_identify() fails, buffer _is_ changed and at least first byte is overwritten. Emulate old behaviour with returning that first byte to userspace and reporting length=1 despite overall -E. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-07ide: fix races in handling of user-space SET XFER commandsBartlomiej Zolnierkiewicz
* Make cmd->tf_flags field 'u16' and add IDE_TFLAG_SET_XFER taskfile flag. * Update ide_finish_cmd() to set xfer / re-read id if the new flag is set. * Convert set_xfer_rate() (write handler for /proc/ide/hd?/current_speed) and ide_cmd_ioctl() (HDIO_DRIVE_CMD ioctl handler) to use the new flag. * Remove no longer needed disable_irq_nosync() + enable_irq() from ide_config_drive_speed(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-07ide: allow ide_dev_read_id() to be called from the IRQ contextBartlomiej Zolnierkiewicz
* Un-static __ide_wait_stat(). * Allow ide_dev_read_id() helper to be called from the IRQ context by adding irq_ctx flag and using mdelay()/__ide_wait_stat() when needed. * Switch ide_driveid_update() to set irq_ctx flag. This change is needed for the consecutive patch which fixes races in handling of user-space SET XFER commands but for improved bisectability and clarity it is better to do it in a separate patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-29ide: fix resume for CONFIG_BLK_DEV_IDEACPI=yBartlomiej Zolnierkiewicz
commit 2f0d0fd2a605666d38e290c5c0d2907484352dc4 ("ide-acpi: cleanup do_drive_get_GTF()") didn't account for the lack of hwif->acpidata check in generic_ide_suspend() [ indirect user of do_drive_get_GTF() through ide_acpi_exec_tfs() ] resulting in broken resume when ACPI support is enabled but ACPI data is unavailable. Fix it by adding ide_port_acpi() helper for checking if port needs ACPI handling and cleaning generic_ide_{suspend,resume}() to use it instead of hiding hwif->acpidata and ide_noacpi checks in IDE ACPI helpers (this should help in preventing similar bugs in the future). While at it: - kill superfluous debugging printks in ide_acpi_{get,push}_timing() Reported-and-tested-by: Etienne Basset <etienne.basset@numericable.fr> Also-reported-and-tested-by: Jeff Chua <jeff.chua.linux@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-25ide: always kill the whole request on errorBartlomiej Zolnierkiewicz
* Use blk_rq_bytes() instead of obsolete ide_rq_bytes() in ide_kill_rq() and ide_floppy_do_request() for failed requests. [ bugfix part ] * Use blk_rq_bytes() instead of obsolete ide_rq_bytes() in ide_do_devset() and ide_complete_drive_reset(). Then remove ide_rq_bytes(). [ cleanup part ] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-24ide: relax DMA info validity checkingBartlomiej Zolnierkiewicz
There are some broken devices that report multiple DMA xfer modes enabled at once (ATA spec doesn't allow it) but otherwise work fine with DMA so just delete ide_id_dma_bug(). [ As discovered by detective work by Frans and Bart, due to how handling of the ID block was handled before commit c419993 ("ide-iops: only clear DMA words on setting DMA mode") this check was always seeing zeros in the fields or other similar garbage. Therefore this check wasn't actually checking anything. Now that the tests actually check the real bits, all we see are devices that trigger the check yet work perfectly fine, therefore killing this useless check is the best thing to do. -DaveM ] Reported-by: Frans Pop <elendil@planet.nl> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-15ide: do not access ide_drive_t 'drive_data' field directlyJoao Ramos
Change ide_drive_t 'drive_data' field from 'unsigned int' type to 'void *' type, allowing a wider range of values/types to be stored in this field. Added 'ide_get_drivedata' and 'ide_set_drivedata' helpers to get and set the 'drive_data' field. Fixed all host drivers to maintain coherency with the change in the 'drive_data' field type. Signed-off-by: Joao Ramos <joao.ramos@inov.pt> [bart: fix qd65xx build, cast to 'unsigned long', minor Coding Style fixups] Acked-by: Sergei Shtylyov <sshtylyov@ru.montavista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-15ide: move ack_intr() method into 'struct ide_port_ops' (take 2)Sergei Shtylyov
Move the ack_intr() method into 'struct ide_port_ops', also renaming it to test_irq() while at it... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-15ide: don't enable IORDY at a probe timeBartlomiej Zolnierkiewicz
* Add 'unsigned long port_flags' field to ide_hwif_t. * Add IDE_PFLAG_PROBING port flag and keep it set during probing. * Fix ide_pio_need_iordy() to not enable IORDY at a probe time (IORDY may lead to controller lock up on certain controllers if the port is not occupied). Loosely based on the recent libata's fix by Tejun, thanks to Alan for the hint that IDE may also need it. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-15ide: IORDY handling fixesBartlomiej Zolnierkiewicz
Add ide_pio_need_iordy() helper and convert host drivers to use it. This fixes it8172, it8213, pdc202xx_old, piix, slc90e66 and siimage host drivers to handle IORDY correctly. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-13Merge branch 'bp-remove-pc-buf' into for-nextBartlomiej Zolnierkiewicz
Conflicts: drivers/ide/ide-tape.c
2009-06-07ide: add IDE_DFLAG_NIEN_QUIRK device flagBartlomiej Zolnierkiewicz
Add IDE_DFLAG_NIEN_QUIRK device flag and use it instead of drive->quirk_list. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-07ide: respect quirk_drives[] list on all controllersBartlomiej Zolnierkiewicz
* Add ide_check_nien_quirk_list() helper to the core code and then use it in ide_port_tune_devices(). * Remove no longer needed ->quirkproc methods from hpt366.c and pdc202xx_{new,old}.c. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-07Merge branch 'for-linus' into for-nextBartlomiej Zolnierkiewicz
2009-06-07ide: preserve Host Protected Area by default (v2)Bartlomiej Zolnierkiewicz
From the perspective of most users of recent systems, disabling Host Protected Area (HPA) can break vendor RAID formats, GPT partitions and risks corrupting firmware or overwriting vendor system recovery tools. Unfortunately the original (kernels < 2.6.30) behavior (unconditionally disabling HPA and using full disk capacity) was introduced at the time when the main use of HPA was to make the drive look small enough for the BIOS to allow the system to boot with large capacity drives. Thus to allow the maximum compatibility with the existing setups (using HPA and partitioned with HPA disabled) we automically disable HPA if any partitions overlapping HPA are detected. Additionally HPA can also be disabled using the "nohpa" module parameter (i.e. "ide_core.nohpa=0.0" to disable HPA on /dev/hda). v2: Fix ->resume HPA support. While at it: - remove stale "idebus=" entry from Documentation/kernel-parameters.txt Cc: Robert Hancock <hancockrwd@gmail.com> Cc: Frans Pop <elendil@planet.nl> Cc: "Andries E. Brouwer" <Andries.Brouwer@cwi.nl> Cc: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> [patch description was based on input from Alan Cox and Frans Pop] Emphatically-Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-07ide-gd: implement block device ->set_capacity method (v2)Bartlomiej Zolnierkiewicz
* Use ->probed_capacity to store native device capacity for ATA disks. * Add ->set_capacity method to struct ide_disk_ops. * Implement disk device ->set_capacity method for ATA disks. * Implement block device ->set_capacity method. v2: * Check if LBA and HPA are supported in ide_disk_set_capacity(). * According to the spec the SET MAX ADDRESS command shall be immediately preceded by a READ NATIVE MAX ADDRESS command. * Add ide_disk_hpa_{get_native,set}_capacity() helpers. Together with the previous patch adding ->set_capacity block device method this allows automatic disabling of Host Protected Area (HPA) if any partitions overlapping HPA are detected. Cc: Robert Hancock <hancockrwd@gmail.com> Cc: Frans Pop <elendil@planet.nl> Cc: "Andries E. Brouwer" <Andries.Brouwer@cwi.nl> Cc: Al Viro <viro@zeniv.linux.org.uk> Emphatically-Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-05-22Merge branch 'for-linus' into for-nextBartlomiej Zolnierkiewicz
2009-05-22ide: report timeouts in ide_busy_sleep()Bartlomiej Zolnierkiewicz
* change 'hwif' argument to 'drive' * report an error on timeout Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-05-17ide: remove hw_regs_t typedefBartlomiej Zolnierkiewicz
Remove hw_regs_t typedef and rename struct hw_regs_s to struct ide_hw. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-05-17ide: pass number of ports to ide_host_{alloc,add}() (v2)Bartlomiej Zolnierkiewicz
Pass number of ports to ide_host_{alloc,add}() and then update all users accordingly. v2: - drop no longer needed NULL initializers in buddha.c, cmd640.c and gayle.c (noticed by Sergei) There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-05-17ide: remove chipset field from hw_regs_tBartlomiej Zolnierkiewicz
* Convert host drivers that still use hw_regs_t's chipset field to use the one in struct ide_port_info instead. * Move special handling of ide_pci chipset type from ide_hw_configure() to ide_init_port(). * Remove chipset field from hw_regs_t. While at it: - remove stale comment in delkin_cb.c There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-05-17ide: replace special_t typedef by IDE_SFLAG_* flagsBartlomiej Zolnierkiewicz
Replace: - special_t typedef by IDE_SFLAG_* flags - 'special_t special' ide_drive_t's field by 'u8 special_flags' one There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-05-15ide: unify interrupt reason checkingBorislav Petkov
Add ide_check_ireason() function that handles all ATAPI devices. Reorganize all unlikely cases in ireason checking further down in the code path. In addition, add PFX for printks originating from ide-atapi. Finally, remove ide_cd_check_ireason. Signed-off-by: Borislav Petkov <petkovbb@gmail.com>
2009-05-15ide-atapi: remove pc->bufBorislav Petkov
Now after all users of pc->buf have been converted, remove the 64B buffer embedded in each packet command. There should be no functional change resulting from this patch. Signed-off-by: Borislav Petkov <petkovbb@gmail.com>
2009-05-15ide-atapi: add a buffer-arg to ide_queue_pc_tailBorislav Petkov
This is in preparation of removing ide_atapi_pc. Expose the buffer as an argument to ide_queue_pc_tail with later replacing it with local buffer or even kmalloc'ed one if needed due to stack usage constraints. Also, add the possibility of passing a NULL-ptr buffer for cmds which don't transfer data besides the cdb. While at it, switch to local buffer in idetape_get_mode_sense_results(). There should be no functional change resulting from this patch. Signed-off-by: Borislav Petkov <petkovbb@gmail.com>
2009-05-15ide-atapi: add a len-parameter to ide_queue_pc_tailBorislav Petkov
This is in preparation for removing ide_atapi_pc. There should be no functional change resulting from this patch. Signed-off-by: Borislav Petkov <petkovbb@gmail.com>
2009-05-15ide-atapi: switch to rq->resid_lenBorislav Petkov
Now that we have rq->resid_len, use it to account partial completion amount during the lifetime of an rq, decrementing it on each successful transfer. As a result, get rid of now unused pc->xferred. While at it, remove noisy debug call in ide_prep_sense. Signed-off-by: Borislav Petkov <petkovbb@gmail.com>
2009-04-28ide-atapi: kill unused fields and callbacksTejun Heo
Impact: remove fields and code paths which are no longer necessary Now that ide-tape uses standard mechanisms to transfer data, special case handling for bh handling can be dropped from ide-atapi. Drop the followings. * pc->cur_pos, b_count, bh and b_data * drive->pc_update_buffers() and pc_io_buffers(). Signed-off-by: Tejun Heo <tj@kernel.org>
2009-04-28ide-cd,atapi: use bio for internal commandsTejun Heo
Impact: unify request data buffer handling rq->data is used mostly to pass kernel buffer through request queue without using bio. There are only a couple of places which still do this in kernel and converting to bio isn't difficult. This patch converts ide-cd and atapi to use bio instead of rq->data for request sense and internal pc commands. With previous change to unify sense request handling, this is relatively easily achieved by adding blk_rq_map_kern() during sense_rq prep and PC issue. If blk_rq_map_kern() fails for sense, the error is deferred till sense issue and aborts the failed command which triggered the sense. Note that this is a slim possibility as sense prep is done on each command issue, so for the above condition to actually trigger, all preps since the last sense issue till the issue of the request which would require a sense should fail. * do_request functions might sleep now. This should be okay as ide request_fn - do_ide_request() - is invoked only from make_request and plug work. Make sure this is the case by adding might_sleep() to do_ide_request(). * Functions which access the read sense data before the sense request is complete now should access bio_data(sense_rq->bio) as the sense buffer might have been copied during blk_rq_map_kern(). * ide-tape updated to map sg. * cdrom_do_block_pc() now doesn't have to deal with REQ_TYPE_ATA_PC special case. Simplified. * tp_ops->output/input_data path dropped from ide_pc_intr(). Signed-off-by: Tejun Heo <tj@kernel.org>
2009-04-28ide-atapi: convert ide-{floppy,tape} to using preallocated sense bufferBorislav Petkov
Since we're issuing REQ_TYPE_SENSE now we need to allow those types of rqs in the ->do_request callbacks. As a future improvement, sense_len assignment might be unified across all ATAPI devices. Borislav to check with specs and test. As a result, get rid of ide_queue_pc_head() and drive->request_sense_rq. tj: * Init request sense ide_atapi_pc from sense request. In the longer timer, it would probably better to fold ide_create_request_sense_cmd() into its only current user - ide_floppy_get_format_progress(). * ide_retry_pc() no longer takes @disk. CC: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> CC: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2009-04-28ide: add helpers for preparing sense requestsBorislav Petkov
This is in preparation of removing the queueing of a sense request out of the IRQ handler path. Use struct request_sense as a general sense buffer for all ATAPI devices ide-{floppy,tape,cd}. tj: * blk_get_request(__GFP_WAIT) can't be called from do_request() as it can cause deadlock. Converted to use inline struct request and blk_rq_init(). * Added xfer / cdb len selection depending on device type. * All sense prep logics folded into ide_prep_sense() which never fails. * hwif->rq clearing and sense_rq used handling moved into ide_queue_sense_rq(). * blk_rq_map_kern() conversion is moved to later patch. CC: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> CC: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2009-04-28ide kill unused ide_cmd->specialTejun Heo
Impact: removal of unused field No one uses ide_cmd->special anymore. Kill it. Signed-off-by: Tejun Heo <tj@kernel.org>
2009-04-19ide-atapi: kill unused fields and callbacksTejun Heo
2009-04-19ide-cd,atapi: use bio for internal commandsTejun Heo
2009-04-19ide-atapi: convert ide-{floppy,tape} to using preallocated sense bufferBorislav Petkov
2009-04-19ide: add helpers for preparing sense requestsBorislav Petkov
