path: root/include/linux/ide.h
2008-05-14cs5520: disable VDMABartlomiej Zolnierkiewicz
Disable Virtual DMA support for now (it causes system hangs). Thanks to TAKADA Yoshihito for the help with debugging the problem. Reported-by: TAKADA Yoshihito <takada@mbf.nifty.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-05-14make ide-iops.c:SELECT_MASK() staticAdrian Bunk
SELECT_MASK() can now become static. [bart: remove space between function name and open parenthesis] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-28ide: remove ->dma_prdtable field from ide_hwif_tBartlomiej Zolnierkiewicz
* Use 'hwif->dma_base + {4,8}' instead of hwif->dma_prdtable in {ide,scc}_dma_setup(). * Remove no longer needed ->dma_prdtable field from ide_hwif_t. While at it: * Use ATA_DMA_TABLE_OFS define. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-28ide: remove ->dma_vendor{1,3} fields from ide_hwif_tBartlomiej Zolnierkiewicz
* Use 'hwif->dma_base + {1,3}' instead of hwif->dma_vendor{1,3} in pdc202xx_new host driver. * Remove no longer needed ->dma_vendor{1,3} fields from ide_hwif_t. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-28ide: add ide_pad_transfer() helperBartlomiej Zolnierkiewicz
* Add ide_pad_transfer() helper (which uses ->{in,out}put_data methods internally so the transfer is also padded to drive+host requirements) and use it instead of ide_atapi_{write_zeros,discard_data}(). * Remove no longer needed ide_atapi_{write_zeros,discard_data}(). Cc: Borislav Petkov <petkovbb@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-28ide: remove ->INW and ->OUTW methodsBartlomiej Zolnierkiewicz
* Remove no longer used ->INW and ->OUTW methods. While at it: * scc_pata.c: scc_ide_{out,in}w() is called only in scc_tf_{load,read}() so inline it there. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-28ide: add ->tf_load and ->tf_read methodsBartlomiej Zolnierkiewicz
* Add ->tf_load and ->tf_read methods to ide_hwif_t and set the default methods in default_hwif_transport(). * Use ->tf_{load,read} instead o calling ide_tf_{load,read}() directly. * Make ide_tf_{load,read}() static. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-28ide: factor out debugging code from ide_tf_load()Bartlomiej Zolnierkiewicz
Factor out debugging code from ide_tf_load() to ide_tf_dump() helper and update ide_tf_load() users accordingly. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-28ide: add ide_execute_pkt_cmd() helperBartlomiej Zolnierkiewicz
Add ide_execute_pkt_cmd() helper for executing PACKET command, then convert ATAPI device drivers to use it. As a nice side-effect this fixes ide-{floppy,tape,scsi} w.r.t. ide_lock taking (ide-cd was OK). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-28ide: remove ->INS{W,L} and ->OUTS{W,L} methodsBartlomiej Zolnierkiewicz
* Use ins{w,l}()/outs{w,l}() and __ide_mm_ins{w,l}()/__ide_mm_outs{w,l}() directly in ata_{in,out}put_data() (by using IDE_HFLAG_MMIO host flag to decide which I/O ops are required). * Remove no longer needed ->INS{W,L} and ->OUTS{W,L} methods (ide-h8300, au1xxx-ide and scc_pata implement their own ->{in,out}put_data methods). There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-28ide: add IDE_HFLAG_MMIO host flag (take 2)Bartlomiej Zolnierkiewicz
* Add IDE_HFLAG_MMIO host flag and set it for hosts which use default_hwif_mmiops(). v2: * Fix kernel panic in pmac host driver (',' should be '|'). Thanks to Kamalesh for reporting it + testing the fix and to Andrew for hinting me about the source of the issue. Cc: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-28ide: merge ->atapi_*put_bytes and ->ata_*put_data methodsBartlomiej Zolnierkiewicz
* Merge ->atapi_{in,out}put_bytes and ->ata_{in,out}put_data methods into new ->{in,out}put_data methods which take number of bytes to transfer as an argument and always do padding. While at it: * Use 'hwif' or 'drive->hwif' instead of 'HWIF(drive)'. There should be no functional changes caused by this patch (all users of ->ata_{in,out}put_data methods were using multiply-of-4 word counts). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-28falconide/q40ide: add ->atapi_*put_bytes and ->ata_*put_data methods (take 2)Bartlomiej Zolnierkiewicz
* Add ->atapi_{in,out}put_bytes and ->ata_{in,out}put_data methods to falconide and q40ide host drivers (->ata_* methods are implemented on top of ->atapi_* methods so they also do byte-swapping now). * Cleanup atapi_{in,out}put_bytes(). v2: * Add 'struct request *rq' argument to ->ata_{in,out}put_data methods and don't byte-swap disk fs requests (we shouldn't un-swap fs requests because fs itself is stored byte-swapped on the disk) - this is how things were done before the patch (ideally device mapper should be used instead but it would break existing setups and would have some performance impact). Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michael Schmitz <schmitz@debian.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Richard Zidlicky <rz@linux-m68k.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide: remove now unused ide_pci_create_host_proc()Alexey Dobriyan
It creates files in proc with obsoleted ->get_info interface. Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Cc: Andrew Morton <akpm@osdl.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide: add struct ide_io_ports (take 3)Bartlomiej Zolnierkiewicz
* Add struct ide_io_ports and use it instead of `unsigned long io_ports[]` in ide_hwif_t. * Rename io_ports[] in hw_regs_t to io_ports_array[]. * Use un-named union for 'unsigned long io_ports_array[]' and 'struct ide_io_ports io_ports' in hw_regs_t. * Remove IDE_*_OFFSET defines. v2: * scc_pata.c build fix from Stephen Rothwell. v3: * Fix ctl_adrr typo in Sparc-specific part of ns87415.c. (Noticed by Andrew Morton) Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide: make ide_unregister() take 'ide_hwif_t *' as an argument (take 2)Bartlomiej Zolnierkiewicz
* Make ide_unregister() take 'ide_hwif_t *hwif' instead of 'unsigned int index' (hwif->index) as an argument and update all users accordingly. While at it: * Remove unnecessary checks for hwif != NULL from ide-pnp.c::idepnp_remove() and delkin_cb.c::delkin_cb_remove(). * Remove needless hwif->chipset assignment from scc_pata.c::scc_remove(). v2: * Fixup ide_unregister() documentation. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide: add "noacpi" / "acpigtf" / "acpionboot" parametersBartlomiej Zolnierkiewicz
* Rename ide_noacpi{tfs,onboot} to ide_acpi{gtf,onboot} (+ reverse logic). * Move ide_*acpi* variables to ide-acpi.c and remove unnecessary initializers. * Add "noacpi" / "acpigtf" / "acpionboot" parameters. * Obsolete "ide=noacpi" / "ide=acpigtf" / "ide=acpionboot" kernel parameters. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide: remove obsoleted "hdx=autotune" kernel parameterBartlomiej Zolnierkiewicz
* Remove obsoleted "hdx=autotune" kernel parameter (we always auto-tune PIO if possible nowadays). * Remove no longer needed ide_drive_t.autotune flag. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide: remove IDE_HFLAG_NO_AUTOTUNE host flagBartlomiej Zolnierkiewicz
* Don't set IDE_HFLAG_NO_AUTOTUNE host flag in sgiioc4 and icside host drivers - there is no need for it as they don't implement ->set_pio_mode method. * Remove no longer needed IDE_HFLAG_NO_AUTOTUNE host flag. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide: add "vlb|pci_clock=" parameterBartlomiej Zolnierkiewicz
* Add "vlb_clock=" parameter for specifying VLB clock frequency (in MHz). * Add "pci_clock=" parameter for specifying PCI bus clock frequency (in MHz). While at it: * qd65xx.c: rename {active,recovery}_cycle variables to {act,rec}_cyc. Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide: remove obsoleted "hdx=noautotune" kernel parameterBartlomiej Zolnierkiewicz
Remove obsoleted "hdx=noautotune" kernel parameter (it has been obsoleted since 1 Nov 2004). Then make ide_hwif_t.autotune a single bit flag and remove no longer needed IDE_TUNE_* defines. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide: remove obsoleted "idex=reset" kernel parameterBartlomiej Zolnierkiewicz
Remove obsoleted "idex=reset" kernel parameter (it has been obsoleted since 1 Nov 2004). Then remove corresponding code from ide_probe_port() and no longer used ->reset field from ide_hwif_t. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide: add "ignore_cable" parameter (take 2)Bartlomiej Zolnierkiewicz
Add "ignore_cable" parameter: * "ide_core.ignore_cable=[interface_number]" boot option if IDE is built-in (i.e. "ide_core.ignore_cable=1" to force ignoring cable for "ide1") * "ignore_cable=[interface_number]" module parameter (for ide_core module) if IDE is compiled as module v2: * Add ide_port_apply_params() helper - use it in ide_device_add_all() and ide_scan_port(). * Make it possible to later disable ignoring cable detection by passing "[interface_number]:0" to /sys/module/ide_core/parameters/ignore_cable (however sysfs interface is not enabled yet since it needs some other IDE changes to make it work reliable). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: constify struct ide_dma_opsBartlomiej Zolnierkiewicz
* Export ide_dma_exec_cmd() and __ide_dma_test_irq(). * Constify struct ide_dma_ops. * Always set hwif->dma_ops to &sff_dma_ops in ide_setup_dma() (it is later overriden by ide_init_port() if needed) and drop 'const struct ide_port_info *d' argument. While at it: * Rename __ide_dma_test_irq() to ide_dma_test_irq(). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: add struct ide_dma_ops (take 3)Bartlomiej Zolnierkiewicz
Add struct ide_dma_ops and convert core code + drivers to use it. While at it: * Drop "ide_" prefix from ->ide_dma_end and ->ide_dma_test_irq methods. * Drop "ide_" "infixes" from DMA methods. * au1xxx-ide.c: - use auide_dma_{test_irq,end}() directly in auide_dma_timeout() * pdc202xx_old.c: - drop "old_" "infixes" from DMA methods * siimage.c: - add siimage_dma_test_irq() helper - print SATA warning in siimage_init_one() * Remove no longer needed ->init_hwif implementations. v2: * Changes based on review from Sergei: - s/siimage_ide_dma_test_irq/siimage_dma_test_irq/ - s/drive->hwif/hwif/ in idefloppy_pc_intr(). - fix patch description w.r.t. au1xxx-ide changes - fix au1xxx-ide build - fix naming for cmd64*_dma_ops - drop "ide_" and "old_" infixes - s/hpt3xxx_dma_ops/hpt37x_dma_ops/ - s/hpt370x_dma_ops/hpt370_dma_ops/ - use correct DMA ops for HPT302/N, HPT371/N and HPT374 - s/it821x_smart_dma_ops/it821x_pass_through_dma_ops/ v3: * Two bugs slipped in v2 (noticed by Sergei): - use correct DMA ops for HPT374 (for real this time) - handle HPT370/HPT370A properly Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: add IDE_HFLAG_SERIALIZE_DMA host flagBartlomiej Zolnierkiewicz
* Add IDE_HFLAG_SERIALIZE_DMA host flag to serialize ports if DMA is available and handle it in ide_init_port(). * Convert sl82c105 host driver to use this new flag. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: do complete DMA setup in ->init_dma method (take 2)Bartlomiej Zolnierkiewicz
* Make ide_hwif_setup_dma() return an error value. * Pass 'const struct ide_port_info *d' instead of 'unsigned long dmabase' to ->init_dma method and make it return an error value. * Rename ide_get_or_set_dma_base() to ide_pci_dma_base(), change ordering of its arguments and then export it. * Export ide_pci_set_master(). * Do complete DMA setup inside ->init_dma method and update ->init_dma users accordingly. * Sanitize code for DMA setup in ide_init_port(). v2: * Fix for CONFIG_BLK_DEV_IDEDMA_PCI=n configs (from Jiri Slaby <jirislaby@gmail.com>): Fix following compiler warning by returning EINVAL: In file included from ANYTHING-INCLUDING-IDE.H:45: include/linux/ide.h: In function ‘ide_hwif_setup_dma’: include/linux/ide.h:1022: warning: no return statement in function returning non-void Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: export ide_allocate_dma_engine()Bartlomiej Zolnierkiewicz
Export ide_allocate_dma_engine() and use it in trm290 host driver. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: remove ->cds field from ide_hwif_t (take 2)Bartlomiej Zolnierkiewicz
* Use hwif->name instead of cds->name in ide_allocate_dma_engine(). * Use pci_name(dev) instead of cds->name in init_dma_pdc202xx(). * Remove no longer needed ->cds field from ide_hwif_t. v2: * scc_pata.c also needs to be updated now (noticed by Stephen Rothwell). There should be no functional changes caused by this patch. Cc: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Cc: Akira Iguchi <akira2.iguchi@toshiba.co.jp> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: remove ->extra field from struct ide_port_infoBartlomiej Zolnierkiewicz
Always setup hwif->extra_base in ide_iomio_dma() and remove no longer needed ->extra field from struct ide_port_info. There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: remove ide_hwif_request_regions()Bartlomiej Zolnierkiewicz
Remove no longer used ide_hwif_request_regions() and hwif_request_region(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: manage resources for PCI devices in ide_pci_enable() (take 3)Bartlomiej Zolnierkiewicz
* Reserve PCI BARs 0-3 (0-1 for single port controllers) in ide_pci_enable() and remove ide_hwif_request_regions() call from ide_device_add_all() (also cleanup resource management in scc_pata host driver). * Fix handling of PCI BAR 4 in ide_pci_enable(), then cleanup ide_iomio_dma() (+ init_hwif_trm290() in trm290 host driver) and remove ide_release[_iomio]_dma(). v2: * Fixup trm290 host driver. v3: * Because of scc_pata host driver changes we need to call pci_request_selected_regions() also in setup_mmio_scc(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: remove ide_hwif_release_regions()Bartlomiej Zolnierkiewicz
All host drivers using ide_unregister()/module_exit() have been fixed to manage resources themselves so this function can be removed now. There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: use ide_legacy_device_add() for qd65xx (take 2)Bartlomiej Zolnierkiewicz
* Add 'unsigned long config' argument to ide_legacy_device_add() for setting hwif->config_data. * Use ide_find_port_slot() instead of ide_find_port() in ide_legacy_device_add(). * Handle IDE_HFLAG_QD_2ND_PORT and IDE_HFLAG_SINGLE host flags in ide_legacy_device_add(). * Convert qd65xx host driver to use ide_legacy_device_add(). v2: * Update ali14xx, dtc2278, ht6560b and umc8672 host drivers. There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: add ide_legacy_device_add() helperBartlomiej Zolnierkiewicz
Add ide_legacy_device_add() helper for use by legacy VLB host drivers (+ convert them to use it). There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: remove ->noprobe field from ide_hwif_tBartlomiej Zolnierkiewicz
Update IDE PMAC host driver to use drive->noprobe instead of hwif->noprobe and remove hwif->noprobe completely (it is always set to zero now). There should be no functional changes caused by this patch. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: add struct ide_port_ops (take 2)Bartlomiej Zolnierkiewicz
* Move hooks for port/host specific methods from ide_hwif_t to 'struct ide_port_ops'. * Add 'const struct ide_port_ops *port_ops' to 'struct ide_port_info' and ide_hwif_t. * Update host drivers and core code accordingly. While at it: * Rename ata66_*() cable detect functions to *_cable_detect() to match the standard naming. (Suggested by Sergei Shtylyov) v2: * Fix build for bast-ide. (Noticed by Andrew Morton) Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: remove hwif->straight8 flagBartlomiej Zolnierkiewicz
All host drivers now either set hwif->mmio or reserve continuous I/O resources so remove no longer needed hwif->straight8 flag and never reached code for 'hwif->straight8 == 0' case. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: remove IDE_HFLAG_CY82C693 host flagBartlomiej Zolnierkiewicz
Sergei suggested that it shouldn't be necessary + it had no effect anyway since ide_id_dma_bug() is called earlier in ide_tune_dma(). Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: use ide_find_port() in legacy VLB host drivers (take 2)Bartlomiej Zolnierkiewicz
* Add IDE_HFLAG_QD_2ND_PORT host flag to indicate the need of skipping first ide_hwifs[] slot for the second port of QD65xx controller. * Handle this new host flag in ide_find_port_slot(). * Convert legacy VLB host drivers to use ide_find_port(). While at it: * Fix couple of printk()-s in qd65xx host driver to not use hwif->name. v2: * Fix qd65xx. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: merge ide_match_hwif() and ide_find_port()Bartlomiej Zolnierkiewicz
* Change ide_match_hwif() argument from 'u8 bootable' to 'struct ide_port_info *d'. * Move ide_match_hwif() to ide-probe.c from setup-pci.c and rename it to ide_find_port_slot(). Update some comments while at it. * ide_find_port() can be now just a wrapper for ide_find_port_slot(). There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: remove PIO "downgrade" quirkBartlomiej Zolnierkiewicz
No need for it nowadays so remove quirk code from ide_get_best_pio_mode() and IDE_HFLAG_PIO_DOWNGRADE host flag. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: IDE_HFLAG_BOOTABLE -> IDE_HFLAG_NON_BOOTABLEBartlomiej Zolnierkiewicz
"bootable" should be the default behavior so replace IDE_HFLAG_BOOTABLE host flag with IDE_HFLAG_NON_BOOTABLE. There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: cleanup ide_find_port()Bartlomiej Zolnierkiewicz
Remove no longer needed matching against I/O base and 'base' argument. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18include: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. It's possible that they (or some user of them) rely on it dragging in some unrelated header file, but I can't build all these files, so we'll have to fix any build failures as they come up. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-04-18ide: add CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS (take 2)Bartlomiej Zolnierkiewicz
* Add CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS to drivers/ide/Kconfig and use it instead of defining IDE_ARCH_OBSOLETE_DEFAULTS in <arch/ide.h>. v2: * Define ide_default_irq() in ide-probe.c/ns87415.c if not already defined and drop defining ide_default_irq() for CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS=n. [ Thanks to Stephen Rothwell and David Miller for noticing the problem. ] Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: David Miller <davem@davemloft.net> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: use generic ATAPI packet command flags in ide-{floppy,tape}Borislav Petkov
Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: add generic packet command representation ide_atapi_pcBorislav Petkov
This new struct unifies ide{-floppy,-tape,-scsi}'s view of a packet command. For now, it represents the common denominator between the three drivers while adding driver- specific members at the end of the struct which will be merged/simplified into the generic ATAPI handling code in later steps, or removed completely. Bart: - move struct ide_atapi_pc outside of #ifdef/#endif CONFIG_IDE_PROC_FS Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: remove IDE_*_REG macrosBartlomiej Zolnierkiewicz
* Add IDE_{ALTSTATUS,IREASON,BCOUNTL,BCOUNTH}_OFFSET defines. * Remove IDE_*_REG macros - this results in more readable and slightly smaller code. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: add ide_atapi_{discard_data,write_zeros} inline helpersBartlomiej Zolnierkiewicz
Add ide_atapi_{discard_data,write_zeros} inline helpers to <linux/ide.h> and use them instead of home-brewn helpers in ide-{floppy,tape,scsi}. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
