The only thing left in i2c-sensor.h are module parameter definition
macros. It's only an extension of what i2c.h offers, and this extension
is not sensors-specific. As a matter of fact, a few non-sensors drivers
use them. So we better merge them in i2c.h, and get rid of i2c-sensor.h
altogether.
Signed-off-by: Jean Delvare <khali@linux-fr>
The i2c_detect function has no more user, delete it.
We now have two identical structures, i2c_address_data in i2c-sensor.h
and i2c_client_address_data in i2c.h. We can kill one of them, I choose
to keep the one in i2c.h as it makes more sense (this structure is not
specific to sensors.)
The way i2c-sensor handles forced addresses could be optimized. It
defines a structure (i2c_force_data) to associate a module parameter
with a given kind value, but in fact this kind value is always the
index of the structure in each array it is used in. So this additional
value can be omitted, and still be deduced in the code handling these
arrays.
Move SENSORS_LIMIT from i2c-sensor.h to hwmon.h, as it is in no way
related to i2c.
Kill normal_isa in header files, documentation and all chip drivers, as
it is no more used.
normal_i2c could be renamed to normal, but I decided not to do so at the
moment, so as to limit the number of changes. This might be done later
as part of the i2c_probe/i2c_detect merge.
infrastructure for it.
Let it rip!
