path: root/include/linux/i2c-algo-pcf.h
2006-12-10i2c: Discard the i2c algo del_bus wrappersJean Delvare
They are all only calling i2c_del_adapter, so we may as well do it directly. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-12-10i2c: Whitespace cleanupsDavid Brownell
Remove extraneous whitespace from various i2c headers and core files, like space-before-tab and whitespace at end of line. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-09-26i2c-algo-pcf: Discard the mdelay data struct memberAdrian Bunk
i2c-algo-pcf: Discard the mdelay data struct member Just as i2c-algo-bit, i2c-algo-pcf has an unused mdelay struct member, which we can get rid of to spare some code and memory. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] i2c: Drop unused per-i2c-algorithm adapter maxJean Delvare
There are no more per-i2c-algorithm adapter max. Last time there were was in July 1999. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] i2c: Drop useless CVS revision IDsJean Delvare
CVS revision IDs are totally useless and irrelevant by now. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
