path: root/include/linux/hyperv.h
2014-04-16Drivers: hv: vmbus: Negotiate version 3.0 when running on ws2012r2 hostsK. Y. Srinivasan
Only ws2012r2 hosts support the ability to reconnect to the host on VMBUS. This functionality is needed by kexec in Linux. To use this functionality we need to negotiate version 3.0 of the VMBUS protocol. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Cc: <stable@vger.kernel.org> [3.9+] Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-08Drivers: hv: vmbus: Increase the limit on the number of pfns we can handleK. Y. Srinivasan
Increase the number of PFNs we can handle in a single vmbus packet. Some network packets may have more PFNs than the current limit we have. This is not a bug and this patch can be applied to the *next tree. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-24vmbus: use resource for hyperv mmio regionGerd Hoffmann
Use a resource for the hyperv mmio region instead of start/size variables. Register the region properly so it shows up in /proc/iomem. Signed-off-by: Gerd Hoffmann <kraxel@redhat.com> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-18Drivers: hv: Implement the file copy serviceK. Y. Srinivasan
Implement the file copy service for Linux guests on Hyper-V. This permits the host to copy a file (over VMBUS) into the guest. This facility is part of "guest integration services" supported on the Windows platform. Here is a link that provides additional details on this functionality: http://technet.microsoft.com/en-us/library/dn464282.aspx In V1 version of the patch I have addressed comments from Olaf Hering <olaf@aepfle.de> and Dan Carpenter <dan.carpenter@oracle.com> In V2 version of this patch I did some minor cleanup (making some globals static). In V4 version of the patch I have addressed all of Olaf's most recent set of comments/concerns. In V5 version of the patch I had addressed Greg's most recent comments. I would like to thank Greg for suggesting that I use misc device; it has significantly simplified the code. In V6 version of the patch I have cleaned up error message based on Olaf's comments. I have also rebased the patch based on the current tip. In this version of the patch, I have addressed the latest comments from Greg. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-18Merge 3.14-rc3 into char-misc-nextGreg Kroah-Hartman
We need the fixes here for future mei and other patches. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-07Drivers: hv: vmbus: Support per-channel driver stateK. Y. Srinivasan
As we implement Virtual Receive Side Scaling on the networking side (the VRSS patches are currently under review), it will be useful to have per-channel state that vmbus drivers can manage. Add support for managing per-channel state. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-07Drivers: hv: vmbus: Cleanup the packet send pathK. Y. Srinivasan
The current channel code is using scatterlist abstraction to pass data to the ringbuffer API on the send path. This causes unnecessary translations between virtual and physical addresses. Fix this. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-07Drivers: hv: vmbus: Extract the mmio information from DSDTK. Y. Srinivasan
On Gen2 firmware, Hyper-V does not emulate the PCI bus. However, the MMIO information is packaged up in DSDT. Extract this information and export it for use by the synthetic framebuffer driver. This is the only driver that needs this currently. In this version of the patch mmio, I have updated the hyperv header file (linux/hyperv.h) with mmio definitions. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-07hv: Add hyperv.h to uapi headersBjarke Istrup Pedersen
This patch adds the hyperv.h header to the uapi folder, and adds it to the Kbuild file. Doing this enables compiling userspace Hyper-V tools using the installed headers. Version 2: Split UAPI parts into new header, instead of duplicating. Signed-off-by: Bjarke Istrup Pedersen <gurligebis@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-07Drivers: hv: vmbus: Specify the target CPU that should receive notificationK. Y. Srinivasan
During the initial VMBUS connect phase, starting with WS2012 R2, we should specify the VPCU in the guest that should receive the notification. Fix this issue. This fix is required to properly connect to the host in the kexeced kernel. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Cc: <stable@vger.kernel.org> [3.9+] Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-29Merge 3.12-rc3 into char-misc-nextGreg Kroah-Hartman
We need/want the mei fixes in here so we can apply other updates that are depending on them. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26Drivers: hv: util: Correctly support ws2008R2 and earlierK. Y. Srinivasan
The current code does not correctly negotiate the version numbers for the util driver when hosted on earlier hosts. The version numbers presented by this driver were not compatible with the version numbers supported by Windows Server 2008. Fix this problem. I would like to thank Olaf Hering (ohering@suse.com) for identifying the problem. Reported-by: Olaf Hering <ohering@suse.com> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26hv: delete struct hv_dev_port_infoGreg Kroah-Hartman
It's no longer needed, and the struct hv_ring_buffer_debug_info structure shouldn't be "global" so move it to the local .h file instead. Tested-by: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26hv: delete vmbus_get_debug_info()Greg Kroah-Hartman
It's only used once, only contains 2 function calls, so just make those calls directly, deleting the function, and the now unneeded structure entirely. Tested-by: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26hv: move "client/server_monitor_conn_id" bus attributes to dev_groupsGreg Kroah-Hartman
This moves the "client_monitor_conn_id" and "server_monitor_conn_id" bus attributes to the dev_groups structure, removing the need for it to be in a temporary structure. Tested-by: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26hv: move "client/server_monitor_latency" bus attributes to dev_groupsGreg Kroah-Hartman
This moves the "client_monitor_latency" and "server_monitor_latency" bus attributes to the dev_groups structure, removing the need for it to be in a temporary structure. Tested-by: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26hv: move "client/server_monitor_pending" bus attributes to dev_groupsGreg Kroah-Hartman
This moves the "client_monitor_pending" and "server_monitor_pending" bus attributes to the dev_groups structure, removing the need for it to be in a temporary structure. Tested-by: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26hv: move "device_id" bus attribute to dev_groupsGreg Kroah-Hartman
This moves the "device_id" bus attribute to the dev_groups structure, removing the need for it to be in a temporary structure. Tested-by: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26hv: move "class_id" bus attribute to dev_groupsGreg Kroah-Hartman
This moves the "class_id" bus attribute to the dev_groups structure, removing the need for it to be in a temporary structure. Tested-by: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26hv: move "monitor_id" bus attribute to dev_groupsGreg Kroah-Hartman
This moves the "state" bus attribute to the dev_groups structure, removing the need for it to be in a temporary structure. Tested-by: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26hv: move "state" bus attribute to dev_groupsGreg Kroah-Hartman
2013-09-26hv: use dev_groups for device attributesGreg Kroah-Hartman
This patch is the first in a series that moves the hv bus code to use the dev_groups field instead of dev_attrs, as dev_attrs is going away in future kernel releases. It moves the id sysfs file to the dev_groups structure, and creates the needed show/store functions, instead of relying on one "universal" function for this. By doing this, it removes the need for this to be in a temporary structure. Tested-by: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-02Drivers: hv: remove HV_DRV_VERSIONOlaf Hering
Remove HV_DRV_VERSION, it has no meaning for upstream drivers. Initially it was supposed to show the "Linux Integration Services" version, now it is not in sync anymore with the out-of-tree drivers available from the MSFT website. The only place where a version string is still required is the KVP command "IntegrationServicesVersion" which is handled by tools/hv/hv_kvp_daemon.c. To satisfy such KVP request from the host pass the current string to the daemon during KVP userland registration. Signed-off-by: Olaf Hering <olaf@aepfle.de> Acked-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-26Drivers: hv: util: Fix a bug in version negotiation code for util servicesK. Y. Srinivasan
The current code picked the highest version advertised by the host. WS2012 R2 has implemented a protocol version for KVP that is not compatible with prior protocol versions of KVP. Fix the bug in the current code by explicitly specifying the protocol version that the guest can support. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-03Drivers: hv: Add the GUID fot synthetic fibre channel deviceK. Y. Srinivasan
In preparation for supporting synthetic Fiber Channel device, add the GUID for this service. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-03Drivers: hv: vmbus: Implement multi-channel supportK. Y. Srinivasan
Starting with Win8, the host supports multiple sub-channels for a given device. As in the past, the initial channel offer specifies the device and is associated with both the type and the instance GUIDs. For performance critical devices, the host may support multiple sub-channels. The sub-channels share the same type and instance GUID as the primary channel. The number of sub-channels offerrred to the guest depends on the number of virtual CPUs assigned to the guest. The guest can request the creation of these sub-channels and once created and opened, the guest can distribute the traffic across all the channels (the primary and the sub-channels). A request sent on a sub-channel will have the response delivered on the same sub-channel. At channel (sub-channel) creation we bind the channel interrupt to a CPU and with this sub-channel support we will be able to spread the interrupt load of a given device across all available CPUs. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-29drivers/video: add Hyper-V Synthetic Video Frame Buffer DriverHaiyang Zhang
This is the driver for the Hyper-V Synthetic Video, which supports screen resolution up to Full HD 1920x1080 on Windows Server 2012 host, and 1600x1200 on Windows Server 2008 R2 or earlier. It also solves the double mouse cursor issue of the emulated video mode. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org>, Cc: Olaf Hering <olaf@aepfle.de> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-15Drivers: hv: Add a new driver to support host initiated backupK. Y. Srinivasan
This driver supports host initiated backup of the guest. On Windows guests, the host can generate application consistent backups using the Windows VSS framework. On Linux, we ensure that the backup will be file system consistent. This driver allows the host to initiate a "Freeze" operation on all the mounted file systems in the guest. Once the mounted file systems in the guest are frozen, the host snapshots the guest's file systems. Once this is done, the guest's file systems are "thawed". This driver has a user-level component (daemon) that invokes the appropriate operation on all the mounted file systems in response to the requests from the host. The duration for which the guest is frozen is very short - a few seconds. During this interval, the diff disk is comitted. In this version of the patch I have addressed the feedback from Olaf Herring. Also, some of the connector related issues have been fixed. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Cc: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-25Drivers: hv: vmbus: Consolidate all offer GUID definitions in hyperv.hK. Y. Srinivasan
Consolidate all GUID definitions in hyperv.h and use these definitions in implementing channel bindings (as far as interrupt delivery goes). Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17Drivers: hv: Enable protocol negotiation with win8 hostsK. Y. Srinivasan
Now that we have implemented all of the Win8 (WS2012) functionality, negotiate Win8 protocol with the host. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17Drivers: hv: Add state to manage incoming channel interrupt loadK. Y. Srinivasan
Add state to bind a channel to a specific VCPU. This will help us better distribute incoming interrupt load. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17Drivers: hv: Manage signaling state on a per-connection basisK. Y. Srinivasan
The current code has a global handle for supporting signaling of the host from guest. Make this a per-channel attribute as on some versions of the host we can signal on per-channel handle. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17Drivers: hv: Move vmbus version definitions to hyperv.hK. Y. Srinivasan
To support version specific optimization in various vmbus drivers, move the vmbus definitions to the public header file. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17Drivers: hv: Save and export negotiated vmbus versionK. Y. Srinivasan
Export the negotiated vmbus version as this may be useful for individual drivers. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17Drivers: hv: Extend/modify vmbus_channel_offer_channel for win7 and beyondK. Y. Srinivasan
The "offfer" message sent by the host has been extended in win7 (ws2008 R2). Add/modify state to reflect this extension. All these changes are backward compatible. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17Drivers: hv: Update the ring buffer structure to match win8 functionalityK. Y. Srinivasan
Update the ringbuffer structure to support win8 functionality. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17Drivers: hv: Support handling multiple VMBUS versionsK. Y. Srinivasan
The current code hard coded the vmbus version independent of the host it was running on. Add code to dynamically negotiate the most appropriate version. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17Drivers: hv: Add state to manage batched readingK. Y. Srinivasan
For the "read" side signaling optimization, the reader has to completely drain the queue before exiting. Add state to manage this "batched" reading. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-10Tools: hv: Implement the KVP verb - KVP_OP_SET_IP_INFOK. Y. Srinivasan
Implement the KVP verb - KVP_OP_SET_IP_INFO. This operation configures the specified interface based on the given configuration. Since configuring an interface is very distro specific, we invoke an external (Distro specific) script to configure the interface. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-16Drivers: hv: Explicitly size elements of protocol structuresK. Y. Srinivasan
Use explicitly sized types in data structures defining the host/guest protocol. Reported-by: Juan Sanchez-Agrelo <jagrelo@cisco.com> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-16Drivers: hv: kvp: Cleanup error handling in KVPK. Y. Srinivasan
In preparation to implementing IP injection, cleanup the way we propagate and handle errors both in the driver as well as in the user level daemon. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: Olaf Hering <olaf@aepfle.de> Reviewed-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-16Drivers: hv: Add KVP definitions for IP address injectionK. Y. Srinivasan
Add the necessary definitions for supporting the IP injection functionality. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: Olaf Hering <olaf@aepfle.de> Reviewed-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-22Merge tag 'driver-core-3.5-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg Kroah-Hartman: "Here's the driver core, and other driver subsystems, pull request for the 3.5-rc1 merge window. Outside of a few minor driver core changes, we ended up with the following different subsystem and core changes as well, due to interdependancies on the driver core: - hyperv driver updates - drivers/memory being created and some drivers moved into it - extcon driver subsystem created out of the old Android staging switch driver code - dynamic debug updates - printk rework, and /dev/kmsg changes All of this has been tested in the linux-next releases for a few weeks with no reported problems. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fix up conflicts in drivers/extcon/extcon-max8997.c where git noticed that a patch to the deleted drivers/misc/max8997-muic.c driver needs to be applied to this one. * tag 'driver-core-3.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (90 commits) uio_pdrv_genirq: get irq through platform resource if not set otherwise memory: tegra{20,30}-mc: Remove empty *_remove() printk() - isolate KERN_CONT users from ordinary complete lines sysfs: get rid of some lockdep false positives Drivers: hv: util: Properly handle version negotiations. Drivers: hv: Get rid of an unnecessary check in vmbus_prep_negotiate_resp() memory: tegra{20,30}-mc: Use dev_err_ratelimited() driver core: Add dev_*_ratelimited() family Driver Core: don't oops with unregistered driver in driver_find_device() printk() - restore prefix/timestamp printing for multi-newline strings printk: add stub for prepend_timestamp() ARM: tegra30: Make MC optional in Kconfig ARM: tegra20: Make MC optional in Kconfig ARM: tegra30: MC: Remove unnecessary BUG*() ARM: tegra20: MC: Remove unnecessary BUG*() printk: correctly align __log_buf ARM: tegra30: Add Tegra Memory Controller(MC) driver ARM: tegra20: Add Tegra Memory Controller(MC) driver printk() - restore timestamp printing at console output printk() - do not merge continuation lines of different threads ...
2012-05-14Drivers: hv: util: Properly handle version negotiations.K. Y. Srinivasan
The current version negotiation code is not "future proof". Fix this by allowing each service the flexibility to either specify the highest version it can support or it can support the highest version number the host is offering. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-03net/hyperv: Add flow control based on hi/low watermarkHaiyang Zhang
In the existing code, we only stop queue when the ringbuffer is full, so the current packet has to be dropped or retried from upper layer. This patch stops the tx queue when available ringbuffer is below the low watermark. So the ringbuffer still has small amount of space available for the current packet. This will reduce the overhead of retries on sending. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-16Tools: hv: Support enumeration from all the poolsK. Y. Srinivasan
We have only supported enumeration only from the AUTO pool. Now support enumeration from all the available pools. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-16Drivers: hv: Support the newly introduced KVP messages in the driverK. Y. Srinivasan
Support the newly defined KVP message types. It turns out that the host pushes a set of standard key value pairs as soon as the guest opens the KVP channel. Since we cannot handle these tuples until the user level daemon loads up, defer reading the KVP channel until the user level daemon is launched. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-13Drivers: hv: Add new message types to enhance KVPK. Y. Srinivasan
Add additional KVP (Key Value Pair) protocol messages to enhance KVP functionality for Linux guests on Hyper-V. As part of this, patch define an explicit version negoitiation message. Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-09Merge 3.3-rc6 into driver-core-nextGreg Kroah-Hartman
This was done to resolve a conflict in the drivers/base/cpu.c file. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-09drivers: hv: kvp: Cleanup the kernel/user protocolK. Y. Srinivasan
Now, cleanup the user/kernel KVP protocol by using the same structure definition that is used for host/guest KVP protocol. This simplifies the code. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
