path: root/include/linux/gen_stats.h
2009-08-17net: restore gnet_stats_basic to previous definitionEric Dumazet
In 5e140dfc1fe87eae27846f193086724806b33c7d "net: reorder struct Qdisc for better SMP performance" the definition of struct gnet_stats_basic changed incompatibly, as copies of this struct are shipped to userland via netlink. Restoring old behavior is not welcome, for performance reason. Fix is to use a private structure for kernel, and teach gnet_stats_copy_basic() to convert from kernel to user land, using legacy structure (struct gnet_stats_basic) Based on a report and initial patch from Michael Spang. Reported-by: Michael Spang <mspang@csclub.uwaterloo.ca> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-20net: reorder struct Qdisc for better SMP performanceEric Dumazet
dev_queue_xmit() needs to dirty fields "state", "q", "bstats" and "qstats" On x86_64 arch, they currently span three cache lines, involving more cache line ping pongs than necessary, making longer holding of queue spinlock. We can reduce this to one cache line, by grouping all read-mostly fields at the beginning of structure. (Or should I say, all highly modified fields at the end :) ) Before patch : offsetof(struct Qdisc, state)=0x38 offsetof(struct Qdisc, q)=0x48 offsetof(struct Qdisc, bstats)=0x80 offsetof(struct Qdisc, qstats)=0x90 sizeof(struct Qdisc)=0xc8 After patch : offsetof(struct Qdisc, state)=0x80 offsetof(struct Qdisc, q)=0x88 offsetof(struct Qdisc, bstats)=0xa0 offsetof(struct Qdisc, qstats)=0xac sizeof(struct Qdisc)=0xc0 Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
