path: root/include/linux/futex.h
2007-11-05kernel/futex.c: make 3 functions staticAdrian Bunk
The following functions can now become static again: - get_futex_key() - get_futex_key_refs() - drop_futex_key_refs() Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-06-18Revert "futex_requeue_pi optimization"Thomas Gleixner
This reverts commit d0aa7a70bf03b9de9e995ab272293be1f7937822. It not only introduced user space visible changes to the futex syscall, it is also non-functional and there is no way to fix it proper before the 2.6.22 release. The breakage report ( http://lkml.org/lkml/2007/5/12/17 ) went unanswered, and unfortunately it turned out that the concept is not feasible at all. It violates the rtmutex semantics badly by introducing a virtual owner, which hacks around the coupling of the user-space pi_futex and the kernel internal rt_mutex representation. At the moment the only safe option is to remove it fully as it contains user-space visible changes to broken kernel code, which we do not want to expose in the 2.6.22 release. The patch reverts the original patch mostly 1:1, but contains a couple of trivial manual cleanups which were necessary due to patches, which touched the same area of code later. Verified against the glibc tests and my own PI futex tests. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Ulrich Drepper <drepper@redhat.com> Cc: Pierre Peiffer <pierre.peiffer@bull.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09FUTEX: new PRIVATE futexesEric Dumazet
Analysis of current linux futex code : -------------------------------------- A central hash table futex_queues[] holds all contexts (futex_q) of waiting threads. Each futex_wait()/futex_wait() has to obtain a spinlock on a hash slot to perform lookups or insert/deletion of a futex_q. When a futex_wait() is done, calling thread has to : 1) - Obtain a read lock on mmap_sem to be able to validate the user pointer (calling find_vma()). This validation tells us if the futex uses an inode based store (mapped file), or mm based store (anonymous mem) 2) - compute a hash key 3) - Atomic increment of reference counter on an inode or a mm_struct 4) - lock part of futex_queues[] hash table 5) - perform the test on value of futex. (rollback is value != expected_value, returns EWOULDBLOCK) (various loops if test triggers mm faults) 6) queue the context into hash table, release the lock got in 4) 7) - release the read_lock on mmap_sem <block> 8) Eventually unqueue the context (but rarely, as this part  may be done by the futex_wake()) Futexes were designed to improve scalability but current implementation has various problems : - Central hashtable : This means scalability problems if many processes/threads want to use futexes at the same time. This means NUMA unbalance because this hashtable is located on one node. - Using mmap_sem on every futex() syscall : Even if mmap_sem is a rw_semaphore, up_read()/down_read() are doing atomic ops on mmap_sem, dirtying cache line : - lot of cache line ping pongs on SMP configurations. mmap_sem is also extensively used by mm code (page faults, mmap()/munmap()) Highly threaded processes might suffer from mmap_sem contention. mmap_sem is also used by oprofile code. Enabling oprofile hurts threaded programs because of contention on the mmap_sem cache line. - Using an atomic_inc()/atomic_dec() on inode ref counter or mm ref counter: It's also a cache line ping pong on SMP. It also increases mmap_sem hold time because of cache misses. Most of these scalability problems come from the fact that futexes are in one global namespace. As we use a central hash table, we must make sure they are all using the same reference (given by the mm subsystem). We chose to force all futexes be 'shared'. This has a cost. But fact is POSIX defined PRIVATE and SHARED, allowing clear separation, and optimal performance if carefuly implemented. Time has come for linux to have better threading performance. The goal is to permit new futex commands to avoid : - Taking the mmap_sem semaphore, conflicting with other subsystems. - Modifying a ref_count on mm or an inode, still conflicting with mm or fs. This is possible because, for one process using PTHREAD_PROCESS_PRIVATE futexes, we only need to distinguish futexes by their virtual address, no matter the underlying mm storage is. If glibc wants to exploit this new infrastructure, it should use new _PRIVATE futex subcommands for PTHREAD_PROCESS_PRIVATE futexes. And be prepared to fallback on old subcommands for old kernels. Using one global variable with the FUTEX_PRIVATE_FLAG or 0 value should be OK. PTHREAD_PROCESS_SHARED futexes should still use the old subcommands. Compatibility with old applications is preserved, they still hit the scalability problems, but new applications can fly :) Note : the same SHARED futex (mapped on a file) can be used by old binaries *and* new binaries, because both binaries will use the old subcommands. Note : Vast majority of futexes should be using PROCESS_PRIVATE semantic, as this is the default semantic. Almost all applications should benefit of this changes (new kernel and updated libc) Some bench results on a Pentium M 1.6 GHz (SMP kernel on a UP machine) /* calling futex_wait(addr, value) with value != *addr */ 433 cycles per futex(FUTEX_WAIT) call (mixing 2 futexes) 424 cycles per futex(FUTEX_WAIT) call (using one futex) 334 cycles per futex(FUTEX_WAIT_PRIVATE) call (mixing 2 futexes) 334 cycles per futex(FUTEX_WAIT_PRIVATE) call (using one futex) For reference : 187 cycles per getppid() call 188 cycles per umask() call 181 cycles per ni_syscall() call Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Pierre Peiffer <pierre.peiffer@bull.net> Cc: "Ulrich Drepper" <drepper@gmail.com> Cc: "Nick Piggin" <nickpiggin@yahoo.com.au> Cc: "Ingo Molnar" <mingo@elte.hu> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09futex_requeue_pi optimizationPierre Peiffer
This patch provides the futex_requeue_pi functionality, which allows some threads waiting on a normal futex to be requeued on the wait-queue of a PI-futex. This provides an optimization, already used for (normal) futexes, to be used with the PI-futexes. This optimization is currently used by the glibc in pthread_broadcast, when using "normal" mutexes. With futex_requeue_pi, it can be used with PRIO_INHERIT mutexes too. Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Make futex_wait() use an hrtimer for timeoutPierre Peiffer
This patch modifies futex_wait() to use an hrtimer + schedule() in place of schedule_timeout(). schedule_timeout() is tick based, therefore the timeout granularity is the tick (1 ms, 4 ms or 10 ms depending on HZ). By using a high resolution timer for timeout wakeup, we can attain a much finer timeout granularity (in the microsecond range). This parallels what is already done for futex_lock_pi(). The timeout passed to the syscall is no longer converted to jiffies and is therefore passed to do_futex() and futex_wait() as an absolute ktime_t therefore keeping nanosecond resolution. Also this removes the need to pass the nanoseconds timeout part to futex_lock_pi() in val2. In futex_wait(), if there is no timeout then a regular schedule() is performed. Otherwise, an hrtimer is fired before schedule() is called. [akpm@linux-foundation.org: fix `make headers_check'] Signed-off-by: Sebastien Dugue <sebastien.dugue@bull.net> Signed-off-by: Pierre Peiffer <pierre.peiffer@bull.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08futex: get_futex_key, get_key_refs and drop_key_refsRusty Russell
lguest uses the convenient futex infrastructure for inter-domain I/O, so expose get_futex_key, get_key_refs (renamed get_futex_key_refs) and drop_key_refs (renamed drop_futex_key_refs). Also means we need to expose the union that these use. No code changes. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-10[PATCH] Fix noise in futex.hDavid Woodhouse
There are some kernel-only bits in the middle of <linux/futex.h> which should be removed in what we export to userspace. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-28[PATCH] pi-futex: robust-futex exitIngo Molnar
Fix robust PI-futexes to be properly unlocked on unexpected exit. For this to work the kernel has to know whether a futex is a PI or a non-PI one, because the semantics are different. Since the space in relevant glibc data structures is extremely scarce, the best solution is to encode the 'PI' information in bit 0 of the robust list pointer. Existing (non-PI) glibc robust futexes have this bit always zero, so the ABI is kept. New glibc with PI-robust-futexes will set this bit. Further fixes from Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] pi-futex: futex_lock_pi/futex_unlock_pi supportIngo Molnar
This adds the actual pi-futex implementation, based on rt-mutexes. [dino@in.ibm.com: fix an oops-causing race] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Dinakar Guniguntala <dino@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] pi-futex: futex code cleanupsIngo Molnar
We are pleased to announce "lightweight userspace priority inheritance" (PI) support for futexes. The following patchset and glibc patch implements it, ontop of the robust-futexes patchset which is included in 2.6.16-mm1. We are calling it lightweight for 3 reasons: - in the user-space fastpath a PI-enabled futex involves no kernel work (or any other PI complexity) at all. No registration, no extra kernel calls - just pure fast atomic ops in userspace. - in the slowpath (in the lock-contention case), the system call and scheduling pattern is in fact better than that of normal futexes, due to the 'integrated' nature of FUTEX_LOCK_PI. [more about that further down] - the in-kernel PI implementation is streamlined around the mutex abstraction, with strict rules that keep the implementation relatively simple: only a single owner may own a lock (i.e. no read-write lock support), only the owner may unlock a lock, no recursive locking, etc. Priority Inheritance - why, oh why??? ------------------------------------- Many of you heard the horror stories about the evil PI code circling Linux for years, which makes no real sense at all and is only used by buggy applications and which has horrible overhead. Some of you have dreaded this very moment, when someone actually submits working PI code ;-) So why would we like to see PI support for futexes? We'd like to see it done purely for technological reasons. We dont think it's a buggy concept, we think it's useful functionality to offer to applications, which functionality cannot be achieved in other ways. We also think it's the right thing to do, and we think we've got the right arguments and the right numbers to prove that. We also believe that we can address all the counter-arguments as well. For these reasons (and the reasons outlined below) we are submitting this patch-set for upstream kernel inclusion. What are the benefits of PI? The short reply: ---------------- User-space PI helps achieving/improving determinism for user-space applications. In the best-case, it can help achieve determinism and well-bound latencies. Even in the worst-case, PI will improve the statistical distribution of locking related application delays. The longer reply: ----------------- Firstly, sharing locks between multiple tasks is a common programming technique that often cannot be replaced with lockless algorithms. As we can see it in the kernel [which is a quite complex program in itself], lockless structures are rather the exception than the norm - the current ratio of lockless vs. locky code for shared data structures is somewhere between 1:10 and 1:100. Lockless is hard, and the complexity of lockless algorithms often endangers to ability to do robust reviews of said code. I.e. critical RT apps often choose lock structures to protect critical data structures, instead of lockless algorithms. Furthermore, there are cases (like shared hardware, or other resource limits) where lockless access is mathematically impossible. Media players (such as Jack) are an example of reasonable application design with multiple tasks (with multiple priority levels) sharing short-held locks: for example, a highprio audio playback thread is combined with medium-prio construct-audio-data threads and low-prio display-colory-stuff threads. Add video and decoding to the mix and we've got even more priority levels. So once we accept that synchronization objects (locks) are an unavoidable fact of life, and once we accept that multi-task userspace apps have a very fair expectation of being able to use locks, we've got to think about how to offer the option of a deterministic locking implementation to user-space. Most of the technical counter-arguments against doing priority inheritance only apply to kernel-space locks. But user-space locks are different, there we cannot disable interrupts or make the task non-preemptible in a critical section, so the 'use spinlocks' argument does not apply (user-space spinlocks have the same priority inversion problems as other user-space locking constructs). Fact is, pretty much the only technique that currently enables good determinism for userspace locks (such as futex-based pthread mutexes) is priority inheritance: Currently (without PI), if a high-prio and a low-prio task shares a lock [this is a quite common scenario for most non-trivial RT applications], even if all critical sections are coded carefully to be deterministic (i.e. all critical sections are short in duration and only execute a limited number of instructions), the kernel cannot guarantee any deterministic execution of the high-prio task: any medium-priority task could preempt the low-prio task while it holds the shared lock and executes the critical section, and could delay it indefinitely. Implementation: --------------- As mentioned before, the userspace fastpath of PI-enabled pthread mutexes involves no kernel work at all - they behave quite similarly to normal futex-based locks: a 0 value means unlocked, and a value==TID means locked. (This is the same method as used by list-based robust futexes.) Userspace uses atomic ops to lock/unlock these mutexes without entering the kernel. To handle the slowpath, we have added two new futex ops: FUTEX_LOCK_PI FUTEX_UNLOCK_PI If the lock-acquire fastpath fails, [i.e. an atomic transition from 0 to TID fails], then FUTEX_LOCK_PI is called. The kernel does all the remaining work: if there is no futex-queue attached to the futex address yet then the code looks up the task that owns the futex [it has put its own TID into the futex value], and attaches a 'PI state' structure to the futex-queue. The pi_state includes an rt-mutex, which is a PI-aware, kernel-based synchronization object. The 'other' task is made the owner of the rt-mutex, and the FUTEX_WAITERS bit is atomically set in the futex value. Then this task tries to lock the rt-mutex, on which it blocks. Once it returns, it has the mutex acquired, and it sets the futex value to its own TID and returns. Userspace has no other work to perform - it now owns the lock, and futex value contains FUTEX_WAITERS|TID. If the unlock side fastpath succeeds, [i.e. userspace manages to do a TID -> 0 atomic transition of the futex value], then no kernel work is triggered. If the unlock fastpath fails (because the FUTEX_WAITERS bit is set), then FUTEX_UNLOCK_PI is called, and the kernel unlocks the futex on the behalf of userspace - and it also unlocks the attached pi_state->rt_mutex and thus wakes up any potential waiters. Note that under this approach, contrary to other PI-futex approaches, there is no prior 'registration' of a PI-futex. [which is not quite possible anyway, due to existing ABI properties of pthread mutexes.] Also, under this scheme, 'robustness' and 'PI' are two orthogonal properties of futexes, and all four combinations are possible: futex, robust-futex, PI-futex, robust+PI-futex. glibc support: -------------- Ulrich Drepper and Jakub Jelinek have written glibc support for PI-futexes (and robust futexes), enabling robust and PI (PTHREAD_PRIO_INHERIT) POSIX mutexes. (PTHREAD_PRIO_PROTECT support will be added later on too, no additional kernel changes are needed for that). [NOTE: The glibc patch is obviously inofficial and unsupported without matching upstream kernel functionality.] the patch-queue and the glibc patch can also be downloaded from: http://redhat.com/~mingo/PI-futex-patches/ Many thanks go to the people who helped us create this kernel feature: Steven Rostedt, Esben Nielsen, Benedikt Spranger, Daniel Walker, John Cooper, Arjan van de Ven, Oleg Nesterov and others. Credits for related prior projects goes to Dirk Grambow, Inaky Perez-Gonzalez, Bill Huey and many others. Clean up the futex code, before adding more features to it: - use u32 as the futex field type - that's the ABI - use __user and pointers to u32 instead of unsigned long - code style / comment style cleanups - rename hash-bucket name from 'bh' to 'hb'. I checked the pre and post futex.o object files to make sure this patch has no code effects. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Jakub Jelinek <jakub@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] lightweight robust futexes updates 2Ingo Molnar
futex.h updates: - get rid of FUTEX_OWNER_PENDING - it's not used - reduce ROBUST_LIST_LIMIT to a saner value Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] lightweight robust futexes updatesIngo Molnar
- fix: initialize the robust list(s) to NULL in copy_process. - doc update - cleanup: rename _inuser to _inatomic - __user cleanups and other small cleanups Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] lightweight robust futexes: coreIngo Molnar
Add the core infrastructure for robust futexes: structure definitions, the new syscalls and the do_exit() based cleanup mechanism. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Arjan van de Ven <arjan@infradead.org> Acked-by: Ulrich Drepper <drepper@redhat.com> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] FUTEX_WAKE_OP: pthread_cond_signal() speedupJakub Jelinek
ATM pthread_cond_signal is unnecessarily slow, because it wakes one waiter (which at least on UP usually means an immediate context switch to one of the waiter threads). This waiter wakes up and after a few instructions it attempts to acquire the cv internal lock, but that lock is still held by the thread calling pthread_cond_signal. So it goes to sleep and eventually the signalling thread is scheduled in, unlocks the internal lock and wakes the waiter again. Now, before 2003-09-21 NPTL was using FUTEX_REQUEUE in pthread_cond_signal to avoid this performance issue, but it was removed when locks were redesigned to the 3 state scheme (unlocked, locked uncontended, locked contended). Following scenario shows why simply using FUTEX_REQUEUE in pthread_cond_signal together with using lll_mutex_unlock_force in place of lll_mutex_unlock is not enough and probably why it has been disabled at that time: The number is value in cv->__data.__lock. thr1 thr2 thr3 0 pthread_cond_wait 1 lll_mutex_lock (cv->__data.__lock) 0 lll_mutex_unlock (cv->__data.__lock) 0 lll_futex_wait (&cv->__data.__futex, futexval) 0 pthread_cond_signal 1 lll_mutex_lock (cv->__data.__lock) 1 pthread_cond_signal 2 lll_mutex_lock (cv->__data.__lock) 2 lll_futex_wait (&cv->__data.__lock, 2) 2 lll_futex_requeue (&cv->__data.__futex, 0, 1, &cv->__data.__lock) # FUTEX_REQUEUE, not FUTEX_CMP_REQUEUE 2 lll_mutex_unlock_force (cv->__data.__lock) 0 cv->__data.__lock = 0 0 lll_futex_wake (&cv->__data.__lock, 1) 1 lll_mutex_lock (cv->__data.__lock) 0 lll_mutex_unlock (cv->__data.__lock) # Here, lll_mutex_unlock doesn't know there are threads waiting # on the internal cv's lock Now, I believe it is possible to use FUTEX_REQUEUE in pthread_cond_signal, but it will cost us not one, but 2 extra syscalls and, what's worse, one of these extra syscalls will be done for every single waiting loop in pthread_cond_*wait. We would need to use lll_mutex_unlock_force in pthread_cond_signal after requeue and lll_mutex_cond_lock in pthread_cond_*wait after lll_futex_wait. Another alternative is to do the unlocking pthread_cond_signal needs to do (the lock can't be unlocked before lll_futex_wake, as that is racy) in the kernel. I have implemented both variants, futex-requeue-glibc.patch is the first one and futex-wake_op{,-glibc}.patch is the unlocking inside of the kernel. The kernel interface allows userland to specify how exactly an unlocking operation should look like (some atomic arithmetic operation with optional constant argument and comparison of the previous futex value with another constant). It has been implemented just for ppc*, x86_64 and i?86, for other architectures I'm including just a stub header which can be used as a starting point by maintainers to write support for their arches and ATM will just return -ENOSYS for FUTEX_WAKE_OP. The requeue patch has been (lightly) tested just on x86_64, the wake_op patch on ppc64 kernel running 32-bit and 64-bit NPTL and x86_64 kernel running 32-bit and 64-bit NPTL. With the following benchmark on UP x86-64 I get: for i in nptl-orig nptl-requeue nptl-wake_op; do echo time elf/ld.so --library-path .:$i /tmp/bench; \ for j in 1 2; do echo ( time elf/ld.so --library-path .:$i /tmp/bench ) 2>&1; done; done time elf/ld.so --library-path .:nptl-orig /tmp/bench real 0m0.655s user 0m0.253s sys 0m0.403s real 0m0.657s user 0m0.269s sys 0m0.388s time elf/ld.so --library-path .:nptl-requeue /tmp/bench real 0m0.496s user 0m0.225s sys 0m0.271s real 0m0.531s user 0m0.242s sys 0m0.288s time elf/ld.so --library-path .:nptl-wake_op /tmp/bench real 0m0.380s user 0m0.176s sys 0m0.204s real 0m0.382s user 0m0.175s sys 0m0.207s The benchmark is at: http://sourceware.org/ml/libc-alpha/2005-03/txt00001.txt Older futex-requeue-glibc.patch version is at: http://sourceware.org/ml/libc-alpha/2005-03/txt00002.txt Older futex-wake_op-glibc.patch version is at: http://sourceware.org/ml/libc-alpha/2005-03/txt00003.txt Will post a new version (just x86-64 fixes so that the patch applies against pthread_cond_signal.S) to libc-hacker ml soon. Attached is the kernel FUTEX_WAKE_OP patch as well as a simple-minded testcase that will not test the atomicity of the operation, but at least check if the threads that should have been woken up are woken up and whether the arithmetic operation in the kernel gave the expected results. Acked-by: Ingo Molnar <mingo@redhat.com> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Jamie Lokier <jamie@shareable.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
