Pull core block layer changes from Jens Axboe:
"This is the core block IO pull request for 3.18. Apart from the new
and improved flush machinery for blk-mq, this is all mostly bug fixes
and cleanups.
- blk-mq timeout updates and fixes from Christoph.
- Removal of REQ_END, also from Christoph. We pass it through the
->queue_rq() hook for blk-mq instead, freeing up one of the request
bits. The space was overly tight on 32-bit, so Martin also killed
REQ_KERNEL since it's no longer used.
- blk integrity updates and fixes from Martin and Gu Zheng.
- Update to the flush machinery for blk-mq from Ming Lei. Now we
have a per hardware context flush request, which both cleans up the
code should scale better for flush intensive workloads on blk-mq.
- Improve the error printing, from Rob Elliott.
- Backing device improvements and cleanups from Tejun.
- Fixup of a misplaced rq_complete() tracepoint from Hannes.
- Make blk_get_request() return error pointers, fixing up issues
where we NULL deref when a device goes bad or missing. From Joe
Lawrence.
- Prep work for drastically reducing the memory consumption of dm
devices from Junichi Nomura. This allows creating clone bio sets
without preallocating a lot of memory.
- Fix a blk-mq hang on certain combinations of queue depths and
hardware queues from me.
- Limit memory consumption for blk-mq devices for crash dump
scenarios and drivers that use crazy high depths (certain SCSI
shared tag setups). We now just use a single queue and limited
depth for that"
* 'for-3.18/core' of git://git.kernel.dk/linux-block: (58 commits)
block: Remove REQ_KERNEL
blk-mq: allocate cpumask on the home node
bio-integrity: remove the needless fail handle of bip_slab creating
block: include func name in __get_request prints
block: make blk_update_request print prefix match ratelimited prefix
blk-merge: don't compute bi_phys_segments from bi_vcnt for cloned bio
block: fix alignment_offset math that assumes io_min is a power-of-2
blk-mq: Make bt_clear_tag() easier to read
blk-mq: fix potential hang if rolling wakeup depth is too high
block: add bioset_create_nobvec()
block: use bio_clone_fast() in blk_rq_prep_clone()
block: misplaced rq_complete tracepoint
sd: Honor block layer integrity handling flags
block: Replace strnicmp with strncasecmp
block: Add T10 Protection Information functions
block: Don't merge requests if integrity flags differ
block: Integrity checksum flag
block: Relocate bio integrity flags
block: Add a disk flag to block integrity profile
block: Add prefix to block integrity profile flags
REQ_KERNEL is no longer used. Remove it and drop the redundant uio
argument to nfs_file_direct_{read,write}.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
Pull vfs updates from Al Viro:
"The big thing in this pile is Eric's unmount-on-rmdir series; we
finally have everything we need for that. The final piece of prereqs
is delayed mntput() - now filesystem shutdown always happens on
shallow stack.
Other than that, we have several new primitives for iov_iter (Matt
Wilcox, culled from his XIP-related series) pushing the conversion to
->read_iter()/ ->write_iter() a bit more, a bunch of fs/dcache.c
cleanups and fixes (including the external name refcounting, which
gives consistent behaviour of d_move() wrt procfs symlinks for long
and short names alike) and assorted cleanups and fixes all over the
place.
This is just the first pile; there's a lot of stuff from various
people that ought to go in this window. Starting with
unionmount/overlayfs mess... ;-/"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (60 commits)
fs/file_table.c: Update alloc_file() comment
vfs: Deduplicate code shared by xattr system calls operating on paths
reiserfs: remove pointless forward declaration of struct nameidata
don't need that forward declaration of struct nameidata in dcache.h anymore
take dname_external() into fs/dcache.c
let path_init() failures treated the same way as subsequent link_path_walk()
fix misuses of f_count() in ppp and netlink
ncpfs: use list_for_each_entry() for d_subdirs walk
vfs: move getname() from callers to do_mount()
gfs2_atomic_open(): skip lookups on hashed dentry
[infiniband] remove pointless assignments
gadgetfs: saner API for gadgetfs_create_file()
f_fs: saner API for ffs_sb_create_file()
jfs: don't hash direct inode
[s390] remove pointless assignment of ->f_op in vmlogrdr ->open()
ecryptfs: ->f_op is never NULL
android: ->f_op is never NULL
nouveau: __iomem misannotations
missing annotation in fs/file.c
fs: namespace: suppress 'may be used uninitialized' warnings
It would make more sense to pass char __user * instead of
char * in callers of do_mount() and do getname() inside do_mount().
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Seunghun Lee <waydi1@gmail.com>
Currently they both just return 0. Fix them to return more appropriate
values instead.
For better or worse, most places in the kernel return -EINVAL when
leases aren't available. -ENOLCK would probably have been better, but
let's follow suit here in the case of F_SETLEASE.
In the F_GETLEASE case, just return F_UNLCK since we know that no
lease will have been set.
Signed-off-by: Jeff Layton <jlayton@primarydata.com>
Like flock locks, leases are owned by the file description. Now that the
i_have_this_lease check in __break_lease is gone, we don't actually use
the fl_owner for leases for anything. So, it's now safe to set this more
appropriately to the same value as the fl_file.
While we're at it, fix up the comments over the fl_owner_t definition
since they're rather out of date.
Christoph suggests:
"Add a return value to lm_break so that the lock manager can tell the
core code "you can delete this lease right now". That gets rid of
the games with the timeout which require all kinds of race avoidance
code in the users."
Do that here and have the nfsd lease break routine use it when it detects
that there was a race between setting up the lease and it being broken.
There was only one place where we still could free a file_lock while
holding the i_lock -- lease_modify. Add a new list_head argument to the
lm_change operation, pass in a private list when calling it, and fix
those callers to dispose of the list once the lock has been dropped.
...and move the fasync setup into it for fcntl lease calls. At the same
time, change the semantics of how the file_lock double-pointer is
handled. Up until now, on a successful lease return you got a pointer to
the lock on the list. This is bad, since that pointer can no longer be
relied on as valid once the inode->i_lock has been released.
Change the code to instead just zero out the pointer if the lease we
passed in ended up being used. Then the callers can just check to see
if it's NULL after the call and free it if it isn't.
The priv argument has the same semantics. The lm_setup function can
zero the pointer out to signal to the caller that it should not be
freed after the function returns.
In later patches, we're going to add a new lock_manager_operation to
finish setting up the lease while still holding the i_lock. To do
this, we'll need to pass a little bit of info in the fcntl setlease
case (primarily an fasync structure). Plumb the extra pointer into
there in advance of that.
We declare this pointer as a void ** to make it clear that this is
private info, and that the caller isn't required to set this unless
the lm_setup specifically requires it.
security_file_set_fowner always returns 0, so make it f_setown and
__f_setown void return functions and fix up the error handling in the
callers.
Cc: linux-security-module@vger.kernel.org
GFS2 and NFS have setlease routines that always just return -EINVAL.
Turn that into a generic routine that can live in fs/libfs.c.
Cc: <linux-nfs@vger.kernel.org>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: <cluster-devel@redhat.com>
Acked-by: Trond Myklebust <trond.myklebust@primarydata.com>
There are no callers of these functions.
NFSD or other lockmanager may increase the owner's reference,
so adds two new options for copying and releasing owner.
v5: change order from 2/6 to 3/6
v4: rename lm_copy_owner/lm_release_owner to lm_get_owner/lm_put_owner
Reviewed-by: Jeff Layton <jlayton@primarydata.com>
Signed-off-by: Kinglong Mee <kinglongmee@gmail.com>
Jeff advice, " Right now __locks_copy_lock is only used to copy
conflocks. It would be good to rename that to something more
distinct (i.e.locks_copy_conflock), to make it clear that we're
generating a conflock there."
v5: change order from 3/6 to 2/6
v4: new patch only renaming function name
This argument is always NULL so don't pass it around.
[jlayton: remove dependencies on previous patches in series]
"Stuff in here:
- acct.c fixes and general rework of mnt_pin mechanism. That allows
to go for delayed-mntput stuff, which will permit mntput() on deep
stack without worrying about stack overflows - fs shutdown will
happen on shallow stack. IOW, we can do Eric's umount-on-rmdir
series without introducing tons of stack overflows on new mntput()
call chains it introduces.
- Bruce's d_splice_alias() patches
- more Miklos' rename() stuff.
- a couple of regression fixes (stable fodder, in the end of branch)
and a fix for API idiocy in iov_iter.c.
There definitely will be another pile, maybe even two. I'd like to
get Eric's series in this time, but even if we miss it, it'll go right
in the beginning of for-next in the next cycle - the tricky part of
prereqs is in this pile"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (40 commits)
fix copy_tree() regression
__generic_file_write_iter(): fix handling of sync error after DIO
switch iov_iter_get_pages() to passing maximal number of pages
fs: mark __d_obtain_alias static
dcache: d_splice_alias should detect loops
exportfs: update Exporting documentation
dcache: d_find_alias needn't recheck IS_ROOT && DCACHE_DISCONNECTED
dcache: remove unused d_find_alias parameter
dcache: d_obtain_alias callers don't all want DISCONNECTED
dcache: d_splice_alias should ignore DCACHE_DISCONNECTED
dcache: d_splice_alias mustn't create directory aliases
dcache: close d_move race in d_splice_alias
dcache: move d_splice_alias
namei: trivial fix to vfs_rename_dir comment
VFS: allow ->d_manage() to declare -EISDIR in rcu_walk mode.
cifs: support RENAME_NOREPLACE
hostfs: support rename flags
shmem: support RENAME_EXCHANGE
shmem: support RENAME_NOREPLACE
btrfs: add RENAME_NOREPLACE
This patch (of 6):
The i_mmap_writable field counts existing writable mappings of an
address_space. To allow drivers to prevent new writable mappings, make
this counter signed and prevent new writable mappings if it is negative.
This is modelled after i_writecount and DENYWRITE.
This will be required by the shmem-sealing infrastructure to prevent any
new writable mappings after the WRITE seal has been set. In case there
exists a writable mapping, this operation will fail with EBUSY.
Note that we rely on the fact that iff you already own a writable mapping,
you can increase the counter without using the helpers. This is the same
that we do for i_writecount.
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Ryan Lortie <desrt@desrt.ca>
Cc: Lennart Poettering <lennart@poettering.net>
Cc: Daniel Mack <zonque@gmail.com>
Put these suckers on per-vfsmount and per-superblock lists instead.
Note: right now it's still acct_lock for everything, but that's
going to change.
definition and use
The DEFINE_SIMPLE_ATTRIBUTE macro should not end in a ; Fix the one use
in the kernel tree that did not have a semicolon.
Acked-by: Guenter Roeck <linux@roeck-us.net>
Acked-by: Luca Tettamanti <kronos.it@gmail.com>
fl_owner_t is a cookie that can store all kinds of different pointers,
so don't pretends it points to a file structure.
For now just change the typedef, but as a follow on this will allow
to get rids of lots of casts and eventually the typedef itself.
Pull file locking fixes from Jeff Layton:
"File locking related bugfixes
Nothing too earth-shattering here. A fix for a potential regression
due to a patch in pile #1, and the addition of a memory barrier to
prevent a race condition between break_deleg and generic_add_lease"
* tag 'locks-v3.16-2' of git://git.samba.org/jlayton/linux:
locks: set fl_owner for leases back to current->files
locks: add missing memory barrier in break_deleg
"This the bunch that sat in -next + lock_parent() fix. This is the
minimal set; there's more pending stuff.
In particular, I really hope to get acct.c fixes merged this cycle -
we need that to deal sanely with delayed-mntput stuff. In the next
pile, hopefully - that series is fairly short and localized
(kernel/acct.c, fs/super.c and fs/namespace.c). In this pile: more
iov_iter work. Most of prereqs for ->splice_write with sane locking
order are there and Kent's dio rewrite would also fit nicely on top of
this pile"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (70 commits)
lock_parent: don't step on stale ->d_parent of all-but-freed one
kill generic_file_splice_write()
ceph: switch to iter_file_splice_write()
shmem: switch to iter_file_splice_write()
nfs: switch to iter_splice_write_file()
fs/splice.c: remove unneeded exports
ocfs2: switch to iter_file_splice_write()
->splice_write() via ->write_iter()
bio_vec-backed iov_iter
optimize copy_page_{to,from}_iter()
bury generic_file_aio_{read,write}
lustre: get rid of messing with iovecs
ceph: switch to ->write_iter()
ceph_sync_direct_write: stop poking into iov_iter guts
ceph_sync_read: stop poking into iov_iter guts
new helper: copy_page_from_iter()
fuse: switch to ->write_iter()
btrfs: switch to ->write_iter()
ocfs2: switch to ->write_iter()
xfs: switch to ->write_iter()
no callers left
iter_file_splice_write() - a ->splice_write() instance that gathers the
pipe buffers, builds a bio_vec-based iov_iter covering those and feeds
it to ->write_iter(). A bunch of simple cases coverted to that...
[AV: fixed the braino spotted by Cyrill]
break_deleg is subject to the same potential race as break_lease. Add
a memory barrier to prevent it.
Description by Jan Kara:
"A lot of older filesystems don't properly flush volatile disk caches
on fsync(2) which can lead to loss of fsynced data after power failure.
This patch makes generic_file_fsync() issue proper cache flush to fix the
problem. Sysadmin can use /sys/devices/.../cache_type to tell the system
it should not send the cache flush."
[akpm@linux-foundation.org: nuke ifdef]
[akpm@linux-foundation.org: fix warning]
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Suggested-by: Jan Kara <jack@suse.cz>
Suggested-by: Christoph Hellwig <hch@infradead.org>
Cc: Jan Kara <jack@suse.cz>
Cc: "Theodore Ts'o" <tytso@mit.edu>
no callers left
all users converted to __generic_file_write_iter() now
Beginning to introduce those. Just the callers for now, and it's
clumsier than it'll eventually become; once we finish converting
aio_read and aio_write instances, the things will get nicer.
For now, these guys are in parallel to ->aio_read() and ->aio_write();
they take iocb and iov_iter, with everything in iov_iter already
validated. File offset is passed in iocb->ki_pos, iov/nr_segs -
in iov_iter.
Main concerns in that series are stack footprint and ability to
split the damn thing cleanly.
[fix from Peter Ujfalusi <peter.ujfalusi@ti.com> folded]
Since we are about to introduce new methods (read_iter/write_iter), the
tests in a bunch of places would have to grow inconveniently. Check
once (at open() time) and store results in ->f_mode as FMODE_CAN_READ
and FMODE_CAN_WRITE resp. It might end up being a temporary measure -
once everything switches from ->aio_{read,write} to ->{read,write}_iter
it might make sense to return to open-coded checks. We'll see...
Now It Can Be Done(tm) - we don't need to do iov_shorten() in
generic_file_direct_write() anymore, now that all ->direct_IO()
instances are converted to proper iov_iter methods and honour
iter->count and iter->iov_offset properly.
Get rid of count/ocount arguments of generic_file_direct_write(),
while we are at it.
iov_iter-using variant of generic_file_aio_read(). Some callers
converted. Note that it's still not quite there for use as ->read_iter() -
we depend on having zero iter->iov_offset in O_DIRECT case. Fortunately,
that's true for all converted callers (and for generic_file_aio_read() itself).
unmodified, for now
all callers of ->aio_read() and ->aio_write() have iov/nr_segs already
checked - generic_segment_checks() done after that is just an odd way
to spell iov_length().
File-private locks have been re-christened as "open file description"
locks. Finish the symbol name cleanup in the internal implementation.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
"The first vfs pile, with deep apologies for being very late in this
window.
Assorted cleanups and fixes, plus a large preparatory part of iov_iter
work. There's a lot more of that, but it'll probably go into the next
merge window - it *does* shape up nicely, removes a lot of
boilerplate, gets rid of locking inconsistencie between aio_write and
splice_write and I hope to get Kent's direct-io rewrite merged into
the same queue, but some of the stuff after this point is having
(mostly trivial) conflicts with the things already merged into
mainline and with some I want more testing.
This one passes LTP and xfstests without regressions, in addition to
usual beating. BTW, readahead02 in ltp syscalls testsuite has started
giving failures since "mm/readahead.c: fix readahead failure for
memoryless NUMA nodes and limit readahead pages" - might be a false
positive, might be a real regression..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
missing bits of "splice: fix racy pipe->buffers uses"
cifs: fix the race in cifs_writev()
ceph_sync_{,direct_}write: fix an oops on ceph_osdc_new_request() failure
kill generic_file_buffered_write()
ocfs2_file_aio_write(): switch to generic_perform_write()
ceph_aio_write(): switch to generic_perform_write()
xfs_file_buffered_aio_write(): switch to generic_perform_write()
export generic_perform_write(), start getting rid of generic_file_buffer_write()
generic_file_direct_write(): get rid of ppos argument
btrfs_file_aio_write(): get rid of ppos
kill the 5th argument of generic_file_buffered_write()
kill the 4th argument of __generic_file_aio_write()
lustre: don't open-code kernel_recvmsg()
ocfs2: don't open-code kernel_recvmsg()
drbd: don't open-code kernel_recvmsg()
constify blk_rq_map_user_iov() and friends
lustre: switch to kernel_sendmsg()
ocfs2: don't open-code kernel_sendmsg()
take iov_iter stuff to mm/iov_iter.c
process_vm_access: tidy up a bit
Pull xfs update from Dave Chinner:
"There are a couple of new fallocate features in this request - it was
decided that it was easiest to push them through the XFS tree using
topic branches and have the ext4 support be based on those branches.
Hence you may see some overlap with the ext4 tree merge depending on
how they including those topic branches into their tree. Other than
that, there is O_TMPFILE support, some cleanups and bug fixes.
The main changes in the XFS tree for 3.15-rc1 are:
- O_TMPFILE support
- allowing AIO+DIO writes beyond EOF
- FALLOC_FL_COLLAPSE_RANGE support for fallocate syscall and XFS
implementation
- FALLOC_FL_ZERO_RANGE support for fallocate syscall and XFS
implementation
- IO verifier cleanup and rework
- stack usage reduction changes
- vm_map_ram NOIO context fixes to remove lockdep warings
- various bug fixes and cleanups"
* tag 'xfs-for-linus-3.15-rc1' of git://oss.sgi.com/xfs/xfs: (34 commits)
xfs: fix directory hash ordering bug
xfs: extra semi-colon breaks a condition
xfs: Add support for FALLOC_FL_ZERO_RANGE
fs: Introduce FALLOC_FL_ZERO_RANGE flag for fallocate
xfs: inode log reservations are still too small
xfs: xfs_check_page_type buffer checks need help
xfs: avoid AGI/AGF deadlock scenario for inode chunk allocation
xfs: use NOIO contexts for vm_map_ram
xfs: don't leak EFSBADCRC to userspace
xfs: fix directory inode iolock lockdep false positive
xfs: allocate xfs_da_args to reduce stack footprint
xfs: always do log forces via the workqueue
xfs: modify verifiers to differentiate CRC from other errors
xfs: print useful caller information in xfs_error_report
xfs: add xfs_verifier_error()
xfs: add helper for updating checksums on xfs_bufs
xfs: add helper for verifying checksums on xfs_bufs
xfs: Use defines for CRC offsets in all cases
xfs: skip pointless CRC updates after verifier failures
xfs: Add support FALLOC_FL_COLLAPSE_RANGE for fallocate
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
"Major changes for 3.14 include support for the newly added ZERO_RANGE
and COLLAPSE_RANGE fallocate operations, and scalability improvements
in the jbd2 layer and in xattr handling when the extended attributes
spill over into an external block.
Other than that, the usual clean ups and minor bug fixes"
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (42 commits)
ext4: fix premature freeing of partial clusters split across leaf blocks
ext4: remove unneeded test of ret variable
ext4: fix comment typo
ext4: make ext4_block_zero_page_range static
ext4: atomically set inode->i_flags in ext4_set_inode_flags()
ext4: optimize Hurd tests when reading/writing inodes
ext4: kill i_version support for Hurd-castrated file systems
ext4: each filesystem creates and uses its own mb_cache
fs/mbcache.c: doucple the locking of local from global data
fs/mbcache.c: change block and index hash chain to hlist_bl_node
ext4: Introduce FALLOC_FL_ZERO_RANGE flag for fallocate
ext4: refactor ext4_fallocate code
ext4: Update inode i_size after the preallocation
ext4: fix partial cluster handling for bigalloc file systems
ext4: delete path dealloc code in ext4_ext_handle_uninitialized_extents
ext4: only call sync_filesystm() when remounting read-only
fs: push sync_filesystem() down to the file system's remount_fs()
jbd2: improve error messages for inconsistent journal heads
jbd2: minimize region locked by j_list_lock in jbd2_journal_forget()
jbd2: minimize region locked by j_list_lock in journal_get_create_access()
Pull file locking updates from Jeff Layton:
"Highlights:
- maintainership change for fs/locks.c. Willy's not interested in
maintaining it these days, and is OK with Bruce and I taking it.
- fix for open vs setlease race that Al ID'ed
- cleanup and consolidation of file locking code
- eliminate unneeded BUG() call
- merge of file-private lock implementation"
* 'locks-3.15' of git://git.samba.org/jlayton/linux:
locks: make locks_mandatory_area check for file-private locks
locks: fix locks_mandatory_locked to respect file-private locks
locks: require that flock->l_pid be set to 0 for file-private locks
locks: add new fcntl cmd values for handling file private locks
locks: skip deadlock detection on FL_FILE_PVT locks
locks: pass the cmd value to fcntl_getlk/getlk64
locks: report l_pid as -1 for FL_FILE_PVT locks
locks: make /proc/locks show IS_FILE_PVT locks as type "FLPVT"
locks: rename locks_remove_flock to locks_remove_file
locks: consolidate checks for compatible filp->f_mode values in setlk handlers
locks: fix posix lock range overflow handling
locks: eliminate BUG() call when there's an unexpected lock on file close
locks: add __acquires and __releases annotations to locks_start and locks_stop
locks: remove "inline" qualifier from fl_link manipulation functions
locks: clean up comment typo
locks: close potential race between setlease and open
MAINTAINERS: update entry for fs/locks.c
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs
Pull renameat2 system call from Miklos Szeredi:
"This adds a new syscall, renameat2(), which is the same as renameat()
but with a flags argument.
The purpose of extending rename is to add cross-rename, a symmetric
variant of rename, which exchanges the two files. This allows
interesting things, which were not possible before, for example
atomically replacing a directory tree with a symlink, etc... This
also allows overlayfs and friends to operate on whiteouts atomically.
Andy Lutomirski also suggested a "noreplace" flag, which disables the
overwriting behavior of rename.
These two flags, RENAME_EXCHANGE and RENAME_NOREPLACE are only
implemented for ext4 as an example and for testing"
* 'cross-rename' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs:
ext4: add cross rename support
ext4: rename: split out helper functions
ext4: rename: move EMLINK check up
ext4: rename: create ext4_renament structure for local vars
vfs: add cross-rename
vfs: lock_two_nondirectories: allow directory args
security: add flags to rename hooks
vfs: add RENAME_NOREPLACE flag
vfs: add renameat2 syscall
vfs: rename: use common code for dir and non-dir
vfs: rename: move d_move() up
vfs: add d_is_dir()
Reclaim will be leaving shadow entries in the page cache radix tree upon
evicting the real page. As those pages are found from the LRU, an
iput() can lead to the inode being freed concurrently. At this point,
reclaim must no longer install shadow pages because the inode freeing
code needs to ensure the page tree is really empty.
Add an address_space flag, AS_EXITING, that the inode freeing code sets
under the tree lock before doing the final truncate. Reclaim will check
for this flag before installing shadow pages.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Minchan Kim <minchan@kernel.org>
Cc: Bob Liu <bob.liu@oracle.com>
Cc: Luigi Semenzato <semenzato@google.com>
Cc: Metin Doslu <metin@citusdata.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Ozgun Erdogan <ozgun@citusdata.com>
Cc: Roman Gushchin <klamm@yandex-team.ru>
Cc: Ryan Mallon <rmallon@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"Apart from reordering the SELinux mmap code to ensure DAC is called
before MAC, these are minor maintenance updates"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (23 commits)
selinux: correctly label /proc inodes in use before the policy is loaded
selinux: put the mmap() DAC controls before the MAC controls
selinux: fix the output of ./scripts/get_maintainer.pl for SELinux
evm: enable key retention service automatically
ima: skip memory allocation for empty files
evm: EVM does not use MD5
ima: return d_name.name if d_path fails
integrity: fix checkpatch errors
ima: fix erroneous removal of security.ima xattr
security: integrity: Use a more current logging style
MAINTAINERS: email updates and other misc. changes
ima: reduce memory usage when a template containing the n field is used
ima: restore the original behavior for sending data with ima template
Integrity: Pass commname via get_task_comm()
fs: move i_readcount
ima: use static const char array definitions
security: have cap_dentry_init_security return error
ima: new helper: file_inode(file)
kernel: Mark function as static in kernel/seccomp.c
capability: Use current logging styles
