path: root/include/linux/fs.h
2009-06-16Merge branch 'akpm'Linus Torvalds
* akpm: (182 commits) fbdev: bf54x-lq043fb: use kzalloc over kmalloc/memset fbdev: *bfin*: fix __dev{init,exit} markings fbdev: *bfin*: drop unnecessary calls to memset fbdev: bfin-t350mcqb-fb: drop unused local variables fbdev: blackfin has __raw I/O accessors, so use them in fb.h fbdev: s1d13xxxfb: add accelerated bitblt functions tcx: use standard fields for framebuffer physical address and length fbdev: add support for handoff from firmware to hw framebuffers intelfb: fix a bug when changing video timing fbdev: use framebuffer_release() for freeing fb_info structures radeon: P2G2CLK_ALWAYS_ONb tested twice, should 2nd be P2G2CLK_DAC_ALWAYS_ONb? s3c-fb: CPUFREQ frequency scaling support s3c-fb: fix resource releasing on error during probing carminefb: fix possible access beyond end of carmine_modedb[] acornfb: remove fb_mmap function mb862xxfb: use CONFIG_OF instead of CONFIG_PPC_OF mb862xxfb: restrict compliation of platform driver to PPC Samsung SoC Framebuffer driver: add Alpha Channel support atmel-lcdc: fix pixclock upper bound detection offb: use framebuffer_alloc() to allocate fb_info struct ... Manually fix up conflicts due to kmemcheck in mm/slab.c
2009-06-16mm: remove __invalidate_mapping_pages variantMike Waychison
Remove __invalidate_mapping_pages atomic variant now that its sole caller can sleep (fixed in eccb95cee4f0d56faa46ef22fb94dd4a3578d3eb ("vfs: fix lock inversion in drop_pagecache_sb()")). This fixes softlockups that can occur while in the drop_caches path. Signed-off-by: Mike Waychison <mikew@google.com> Cc: Jan Kara <jack@suse.cz> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16readahead: make mmap_miss an unsigned intWu Fengguang
This makes the performance impact of possible mmap_miss wrap around to be temporary and tolerable: i.e. MMAP_LOTSAMISS=100 extra readarounds. Otherwise if ever mmap_miss wraps around to negative, it takes INT_MAX cache misses to bring it back to normal state. During the time mmap readaround will be _enabled_ for whatever wild random workload. That's almost permanent performance impact. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-15fs: introduce __getname_gfp()Vegard Nossum
The purpose of this change is to allow __getname() users to pass a custom GFP mask to kmem_cache_alloc(). This is needed for annotating a certain kmemcheck false positive. Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
2009-06-11New helper - simple_fsync()Al Viro
writes associated buffers, then does sync_inode() to write the inode itself (and to make it clean). Depends on ->write_inode() honouring the second argument. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11fs: Rearrange inode structure elements to avoid waste due to paddingTheodore Ts'o
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: linux-fsdevel@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11fs: Remove i_cindex from struct inodeTheodore Ts'o
The only user of the i_cindex element in the inode structure is used is by the firewire drivers. As part of an attempt to slim down the inode structure to save memory --- since a typical Linux system will have hundreds of thousands if not millions of inodes cached, a reduction in the size inode has high leverage. The firewire driver does not need i_cindex in any fast path, so it's simple enough to calculate when it is needed, instead of wasting space in the inode structure. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: krh@redhat.com Cc: stefanr@s5r6.in-berlin.de Cc: linux-fsdevel@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11Trim a bit of crap from fs.hAl Viro
do_remount_sb() is fs/internal.h fodder, fsync_no_super() is long gone. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11vfs: Rename fsync_super() to sync_filesystem() (version 4)Jan Kara
Rename the function so that it better describe what it really does. Also remove the unnecessary include of buffer_head.h. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11vfs: Move syncing code from super.c to sync.c (version 4)Jan Kara
Move sync_filesystems(), __fsync_super(), fsync_super() from super.c to sync.c where it fits better. [build fixes folded] Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11vfs: Make sys_sync() use fsync_super() (version 4)Jan Kara
It is unnecessarily fragile to have two places (fsync_super() and do_sync()) doing data integrity sync of the filesystem. Alter __fsync_super() to accommodate needs of both callers and use it. So after this patch __fsync_super() is the only place where we gather all the calls needed to properly send all data on a filesystem to disk. Nice bonus is that we get a complete livelock avoidance and write_supers() is now only used for periodic writeback of superblocks. sync_blockdevs() introduced a couple of patches ago is gone now. [build fixes folded] Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11vfs: Make __fsync_super() a static function (version 4)Jan Kara
__fsync_super() does the same thing as fsync_super(). So change the only caller to use fsync_super() and make __fsync_super() static. This removes unnecessarily duplicated call to sync_blockdev() and prepares ground for the changes to __fsync_super() in the following patches. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11remove s_async_listChristoph Hellwig
Remove the unused s_async_list in the superblock, a leftover of the broken async inode deletion code that leaked into mainline. Having this in the middle of the sync/unmount path is not helpful for the following cleanups. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11Switch collect_mounts() to struct pathAl Viro
2009-06-11dnotify: reimplement dnotify using fsnotifyEric Paris
Reimplement dnotify using fsnotify. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de>
2009-06-11fsnotify: add marks to inodes so groups can interpret how to handle those inodesEric Paris
This patch creates a way for fsnotify groups to attach marks to inodes. These marks have little meaning to the generic fsnotify infrastructure and thus their meaning should be interpreted by the group that attached them to the inode's list. dnotify and inotify will make use of these markings to indicate which inodes are of interest to their respective groups. But this implementation has the useful property that in the future other listeners could actually use the marks for the exact opposite reason, aka to indicate which inodes it had NO interest in. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de>
2009-05-22Merge branch 'master' into for-2.6.31Jens Axboe
Conflicts: drivers/block/hd.c drivers/block/mg_disk.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11splice: implement default splice_read methodMiklos Szeredi
If f_op->splice_read() is not implemented, fall back to a plain read. Use vfs_readv() to read into previously allocated pages. This will allow splice and functions using splice, such as the loop device, to work on all filesystems. This includes "direct_io" files in fuse which bypass the page cache. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-09Fix races around the access to ->s_optionsAl Viro
Put generic_show_options read access to s_options under rcu_read_lock, split save_mount_options() into "we are setting it the first time" (uses in foo_fill_super()) and "we are relacing and freeing the old one", synchronize_rcu() before kfree() in the latter. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-09Switch open_exec() and sys_uselib() to do_open_filp()Al Viro
... and make path_lookup_open() static Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-09New helper: deactivate_locked_super()Al Viro
Does equivalent of up_write(&s->s_umount); deactivate_super(s); However, it does not does not unlock it until it's all over. As the result, it's safe to use to dispose of new superblock on ->get_sb() failure exits - nobody will see the sucker until it's all over. Equivalent using up_write/deactivate_super is safe for that purpose if superblock is either safe to use or has NULL ->s_root when we unlock. Normally filesystems take the required precautions, but a) we do have bugs in that area in some of them. b) up_write/deactivate_super sequence is extremely common, so the helper makes sense anyway. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-20fs: Mark get_filesystem_list() as __init function.Tetsuo Handa
"int get_filesystem_list(char * buf)" is called by only "static void __init get_fs_names(char *page)". We can mark get_filesystem_list() as "__init". Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-20kill vfs_stat_fd / vfs_lstat_fdChristoph Hellwig
There's really no reason to keep vfs_stat_fd and vfs_lstat_fd with Oleg's vfs_fstatat. Use vfs_fstatat for the few cases having the directory fd, and switch all others to vfs_stat / vfs_lstat. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-20Separate out common fstatat code into vfs_fstatatOleg Drokin
This is a version incorporating Christoph's suggestion. Separate out common *fstatat functionality into a single function instead of duplicating it all over the code. Signed-off-by: Oleg Drokin <green@linuxhacker.ru> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-15splice: add helpers for locking pipe inodeMiklos Szeredi
There are lots of sequences like this, especially in splice code: if (pipe->inode) mutex_lock(&pipe->inode->i_mutex); /* do something */ if (pipe->inode) mutex_unlock(&pipe->inode->i_mutex); so introduce helpers which do the conditional locking and unlocking. Also replace the inode_double_lock() call with a pipe_double_lock() helper to avoid spreading the use of this functionality beyond the pipe code. This patch is just a cleanup, and should cause no behavioral changes. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-15splice: remove generic_file_splice_write_nolock()Miklos Szeredi
Remove the now unused generic_file_splice_write_nolock() function. It's conceptually broken anyway, because splice may need to wait for pipe events so holding locks across the whole operation is wrong. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-15Document and move the various READ/WRITE typesJens Axboe
It's a somewhat twisty maze of hints and behavioural modifiers, try and clear it up a bit with some documentation. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-07namespaces: move proc_net_get_sb to a generic fs/super.c helperSerge E. Hallyn
The mqueuefs filesystem will use this helper as well. Proc's main get_sb could also be made to use it, but that will require a bit more rework. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-06Merge branch 'kmemtrace-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'kmemtrace-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: kmemtrace: trace kfree() calls with NULL or zero-length objects kmemtrace: small cleanups kmemtrace: restore original tracing data binary format, improve ABI kmemtrace: kmemtrace_alloc() must fill type_id kmemtrace: use tracepoints kmemtrace, rcu: don't include unnecessary headers, allow kmemtrace w/ tracepoints kmemtrace, rcu: fix rcupreempt.c data structure dependencies kmemtrace, rcu: fix rcu_tree_trace.c data structure dependencies kmemtrace, rcu: fix linux/rcutree.h and linux/rcuclassic.h dependencies kmemtrace, mm: fix slab.h dependency problem in mm/failslab.c kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_unlzma.c kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_bunzip2.c kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_inflate.c kmemtrace, squashfs: fix slab.h dependency problem in squasfs kmemtrace, befs: fix slab.h dependency problem kmemtrace, security: fix linux/key.h header file dependencies kmemtrace, fs: fix linux/fdtable.h header file dependencies kmemtrace, fs: uninline simple_transaction_set() kmemtrace, fs, security: move alloc_secdata() and free_secdata() to linux/security.h
2009-04-06block: Add flag for telling the IO schedulers NOT to anticipate more IOJens Axboe
By default, CFQ will anticipate more IO from a given io context if the previously completed IO was sync. This used to be fine, since the only sync IO was reads and O_DIRECT writes. But with more "normal" sync writes being used now, we don't want to anticipate for those. Add a bio/request flag that informs the IO scheduler that this is a sync request that we should not idle for. Introduce WRITE_ODIRECT specifically for O_DIRECT writes, and make sure that the other sync writes set this flag. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-06Add WRITE_SYNC_PLUG and SWRITE_SYNC_PLUGJens Axboe
(S)WRITE_SYNC always unplugs the device right after IO submission. Sometimes we want to build up a queue before doing so, so add variants that explicitly DON'T unplug the queue. The caller must then do that after submitting all the IO. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-03kmemtrace, fs: uninline simple_transaction_set()Ingo Molnar
Impact: cleanup We want to remove percpu.h from rcupdate.h (for upcoming kmemtrace changes), but this is not possible currently without breaking the build because fs.h has an implicit include file depedency: it uses PAGE_SIZE but does not include asm/page.h which defines it. This problem gets masked in practice because most fs.h using sites use rcupreempt.h (and other headers) which includes percpu.h which brings in asm/page.h indirectly. We cannot add asm/page.h to asm/fs.h because page.h is not an exported header. Move simple_transaction_set() to the other simple-transaction file helpers in fs/libfs.c. This removes the include file hell and also reduces kernel size a bit. Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: paulmck@linux.vnet.ibm.com LKML-Reference: <1237898630.25315.83.camel@penberg-laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-03kmemtrace, fs, security: move alloc_secdata() and free_secdata() to ↵Pekka Enberg
linux/security.h Impact: cleanup We want to remove percpu.h from rcupdate.h (for upcoming kmemtrace changes), but this is not possible currently without breaking the build because fs.h has implicit include file depedencies: it uses GFP_* types in inlines but does not include gfp.h. In practice most fs.h using .c files get gfp.h included implicitly, via an indirect route: via rcupdate.h inclusion - so this underlying problem gets masked in practice. So we want to solve fs.h's dependency on gfp.h. gfp.h can not be included here directly because it is not exported and it would break the build the following way: /home/mingo/tip/usr/include/linux/bsg.h:11: found __[us]{8,16,32,64} type without #include <linux/types.h> /home/mingo/tip/usr/include/linux/fs.h:11: included file 'linux/gfp.h' is not exported make[3]: *** [/home/mingo/tip/usr/include/linux/.check] Error 1 make[2]: *** [linux] Error 2 As suggested by Alexey Dobriyan, move alloc_secdata() and free_secdata() to linux/security.h - they belong there. This also cleans fs.h of GFP_* usage. Suggested-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> LKML-Reference: <1237906803.25315.96.camel@penberg-laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: Remove two unneeded exports and make two symbols static in fs/mpage.c Cleanup after commit 585d3bc06f4ca57f975a5a1f698f65a45ea66225 Trim includes of fdtable.h Don't crap into descriptor table in binfmt_som Trim includes in binfmt_elf Don't mess with descriptor table in load_elf_binary() Get rid of indirect include of fs_struct.h New helper - current_umask() check_unsafe_exec() doesn't care about signal handlers sharing New locking/refcounting for fs_struct Take fs_struct handling to new file (fs/fs_struct.c) Get rid of bumping fs_struct refcount in pivot_root(2) Kill unsharing fs_struct in __set_personality()
2009-04-01filesystem freeze: allow SysRq emergency thaw to thaw frozen filesystemsEric Sandeen
Now that the filesystem freeze operation has been elevated to the VFS, and is just an ioctl away, some sort of safety net for unintentionally frozen root filesystems may be in order. The timeout thaw originally proposed did not get merged, but perhaps something like this would be useful in emergencies. For example, freeze /path/to/mountpoint may freeze your root filesystem if you forgot that you had that unmounted. I chose 'j' as the last remaining character other than 'h' which is sort of reserved for help (because help is generated on any unknown character). I've tested this on a non-root fs with multiple (nested) freezers, as well as on a system rendered unresponsive due to a frozen root fs. [randy.dunlap@oracle.com: emergency thaw only if CONFIG_BLOCK enabled] Signed-off-by: Eric Sandeen <sandeen@redhat.com> Cc: Takashi Sato <t-sato@yk.jp.nec.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01Cleanup after commit 585d3bc06f4ca57f975a5a1f698f65a45ea66225Al Viro
fsync_bdev() export and a bunch of stubs for !CONFIG_BLOCK case had been left behind Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-31New helper - current_umask()Al Viro
current->fs->umask is what most of fs_struct users are doing. Put that into a helper function. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-30Merge branch 'bkl-removal' of git://git.lwn.net/linux-2.6Linus Torvalds
* 'bkl-removal' of git://git.lwn.net/linux-2.6: Fix a lockdep warning in fasync_helper() Add a missing unlock_kernel() in raw_open()
2009-03-30Fix a lockdep warning in fasync_helper()Jonathan Corbet
Lockdep gripes if file->f_lock is taken in a no-IRQ situation, since that is not always the case. We don't really want to disable IRQs for every acquisition of f_lock; instead, just move it outside of fasync_lock. Reported-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Reported-by: Larry Finger <Larry.Finger@lwfinger.net> Reported-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2009-03-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (37 commits) fs: avoid I_NEW inodes Merge code for single and multiple-instance mounts Remove get_init_pts_sb() Move common mknod_ptmx() calls into caller Parse mount options just once and copy them to super block Unroll essentials of do_remount_sb() into devpts vfs: simple_set_mnt() should return void fs: move bdev code out of buffer.c constify dentry_operations: rest constify dentry_operations: configfs constify dentry_operations: sysfs constify dentry_operations: JFS constify dentry_operations: OCFS2 constify dentry_operations: GFS2 constify dentry_operations: FAT constify dentry_operations: FUSE constify dentry_operations: procfs constify dentry_operations: ecryptfs constify dentry_operations: CIFS constify dentry_operations: AFS ...
2009-03-27vfs: simple_set_mnt() should return voidSukadev Bhattiprolu
simple_set_mnt() is defined as returning 'int' but always returns 0. Callers assume simple_set_mnt() never fails and don't properly cleanup if it were to _ever_ fail. For instance, get_sb_single() and get_sb_nodev() should: up_write(sb->s_unmount); deactivate_super(sb); if simple_set_mnt() fails. Since simple_set_mnt() never fails, would be cleaner if it did not return anything. [akpm@linux-foundation.org: fix build] Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-27fs: move bdev code out of buffer.cNick Piggin
Move some block device related code out from buffer.c and put it in block_dev.c. I'm trying to move non-buffer_head code out of buffer.c Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-27vfs: Further changes from macro to inline function in fs.hSteven Whitehouse
There is a second set of macros for when CONFIG_FILE_LOCKING is not set. This patch updates those to become inline functions as well. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-27vfs: Update fs.h to use inline functions when no file locking setSteven Whitehouse
This avoids various issues which might give rise to compiler warnings about missing functions and/or unused variable with the previous macros. This also fixes a bug where one of the macros was returning 0, but it should have been void. Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Tested-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-27do_pipe cleanup: drop its last user in arch/alpha/Cheng Renquan
The last user of do_pipe is in arch/alpha/, after replacing it with do_pipe_flags, the do_pipe can be totally dropped. Signed-off-by: Cheng Renquan <crquan@gmail.com> Acked-by: Richard Henderson <rth@twiddle.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-26Merge branch 'bkl-removal' of git://git.lwn.net/linux-2.6Linus Torvalds
* 'bkl-removal' of git://git.lwn.net/linux-2.6: Rationalize fasync return values Move FASYNC bit handling to f_op->fasync() Use f_lock to protect f_flags Rename struct file->f_ep_lock
2009-03-26Add a strictatime mount optionMatthew Garrett
Add support for explicitly requesting full atime updates. This makes it possible for kernels to default to relatime but still allow userspace to override it. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-16Use f_lock to protect f_flagsJonathan Corbet
Traditionally, changes to struct file->f_flags have been done under BKL protection, or with no protection at all. This patch causes all f_flags changes after file open/creation time to be done under protection of f_lock. This allows the removal of some BKL usage and fixes a number of longstanding (if microscopic) races. Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2009-03-16Rename struct file->f_ep_lockJonathan Corbet
This lock moves out of the CONFIG_EPOLL ifdef and becomes f_lock. For now, epoll remains the only user, but a future patch will use it to protect f_flags as well. Cc: Davide Libenzi <davidel@xmailserver.org> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2009-02-18Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: fix deadlock in blk_abort_queue() for drivers that readd to timeout list block: fix booting from partitioned md array block: revert part of 18ce3751ccd488c78d3827e9f6bf54e6322676fb cciss: PCI power management reset for kexec paride/pg.c: xs(): &&/|| confusion fs/bio: bio_alloc_bioset: pass right object ptr to mempool_free block: fix bad definition of BIO_RW_SYNC bsg: Fix sense buffer bug in SG_IO
