Description by Jan Kara:
"A lot of older filesystems don't properly flush volatile disk caches
on fsync(2) which can lead to loss of fsynced data after power failure.
This patch makes generic_file_fsync() issue proper cache flush to fix the
problem. Sysadmin can use /sys/devices/.../cache_type to tell the system
it should not send the cache flush."
[akpm@linux-foundation.org: nuke ifdef]
[akpm@linux-foundation.org: fix warning]
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Suggested-by: Jan Kara <jack@suse.cz>
Suggested-by: Christoph Hellwig <hch@infradead.org>
Cc: Jan Kara <jack@suse.cz>
Cc: "Theodore Ts'o" <tytso@mit.edu>
File-private locks have been re-christened as "open file description"
locks. Finish the symbol name cleanup in the internal implementation.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Pull vfs updates from Al Viro:
"The first vfs pile, with deep apologies for being very late in this
window.
Assorted cleanups and fixes, plus a large preparatory part of iov_iter
work. There's a lot more of that, but it'll probably go into the next
merge window - it *does* shape up nicely, removes a lot of
boilerplate, gets rid of locking inconsistencie between aio_write and
splice_write and I hope to get Kent's direct-io rewrite merged into
the same queue, but some of the stuff after this point is having
(mostly trivial) conflicts with the things already merged into
mainline and with some I want more testing.
This one passes LTP and xfstests without regressions, in addition to
usual beating. BTW, readahead02 in ltp syscalls testsuite has started
giving failures since "mm/readahead.c: fix readahead failure for
memoryless NUMA nodes and limit readahead pages" - might be a false
positive, might be a real regression..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
missing bits of "splice: fix racy pipe->buffers uses"
cifs: fix the race in cifs_writev()
ceph_sync_{,direct_}write: fix an oops on ceph_osdc_new_request() failure
kill generic_file_buffered_write()
ocfs2_file_aio_write(): switch to generic_perform_write()
ceph_aio_write(): switch to generic_perform_write()
xfs_file_buffered_aio_write(): switch to generic_perform_write()
export generic_perform_write(), start getting rid of generic_file_buffer_write()
generic_file_direct_write(): get rid of ppos argument
btrfs_file_aio_write(): get rid of ppos
kill the 5th argument of generic_file_buffered_write()
kill the 4th argument of __generic_file_aio_write()
lustre: don't open-code kernel_recvmsg()
ocfs2: don't open-code kernel_recvmsg()
drbd: don't open-code kernel_recvmsg()
constify blk_rq_map_user_iov() and friends
lustre: switch to kernel_sendmsg()
ocfs2: don't open-code kernel_sendmsg()
take iov_iter stuff to mm/iov_iter.c
process_vm_access: tidy up a bit
Pull xfs update from Dave Chinner:
"There are a couple of new fallocate features in this request - it was
decided that it was easiest to push them through the XFS tree using
topic branches and have the ext4 support be based on those branches.
Hence you may see some overlap with the ext4 tree merge depending on
how they including those topic branches into their tree. Other than
that, there is O_TMPFILE support, some cleanups and bug fixes.
The main changes in the XFS tree for 3.15-rc1 are:
- O_TMPFILE support
- allowing AIO+DIO writes beyond EOF
- FALLOC_FL_COLLAPSE_RANGE support for fallocate syscall and XFS
implementation
- FALLOC_FL_ZERO_RANGE support for fallocate syscall and XFS
implementation
- IO verifier cleanup and rework
- stack usage reduction changes
- vm_map_ram NOIO context fixes to remove lockdep warings
- various bug fixes and cleanups"
* tag 'xfs-for-linus-3.15-rc1' of git://oss.sgi.com/xfs/xfs: (34 commits)
xfs: fix directory hash ordering bug
xfs: extra semi-colon breaks a condition
xfs: Add support for FALLOC_FL_ZERO_RANGE
fs: Introduce FALLOC_FL_ZERO_RANGE flag for fallocate
xfs: inode log reservations are still too small
xfs: xfs_check_page_type buffer checks need help
xfs: avoid AGI/AGF deadlock scenario for inode chunk allocation
xfs: use NOIO contexts for vm_map_ram
xfs: don't leak EFSBADCRC to userspace
xfs: fix directory inode iolock lockdep false positive
xfs: allocate xfs_da_args to reduce stack footprint
xfs: always do log forces via the workqueue
xfs: modify verifiers to differentiate CRC from other errors
xfs: print useful caller information in xfs_error_report
xfs: add xfs_verifier_error()
xfs: add helper for updating checksums on xfs_bufs
xfs: add helper for verifying checksums on xfs_bufs
xfs: Use defines for CRC offsets in all cases
xfs: skip pointless CRC updates after verifier failures
xfs: Add support FALLOC_FL_COLLAPSE_RANGE for fallocate
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
"Major changes for 3.14 include support for the newly added ZERO_RANGE
and COLLAPSE_RANGE fallocate operations, and scalability improvements
in the jbd2 layer and in xattr handling when the extended attributes
spill over into an external block.
Other than that, the usual clean ups and minor bug fixes"
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (42 commits)
ext4: fix premature freeing of partial clusters split across leaf blocks
ext4: remove unneeded test of ret variable
ext4: fix comment typo
ext4: make ext4_block_zero_page_range static
ext4: atomically set inode->i_flags in ext4_set_inode_flags()
ext4: optimize Hurd tests when reading/writing inodes
ext4: kill i_version support for Hurd-castrated file systems
ext4: each filesystem creates and uses its own mb_cache
fs/mbcache.c: doucple the locking of local from global data
fs/mbcache.c: change block and index hash chain to hlist_bl_node
ext4: Introduce FALLOC_FL_ZERO_RANGE flag for fallocate
ext4: refactor ext4_fallocate code
ext4: Update inode i_size after the preallocation
ext4: fix partial cluster handling for bigalloc file systems
ext4: delete path dealloc code in ext4_ext_handle_uninitialized_extents
ext4: only call sync_filesystm() when remounting read-only
fs: push sync_filesystem() down to the file system's remount_fs()
jbd2: improve error messages for inconsistent journal heads
jbd2: minimize region locked by j_list_lock in jbd2_journal_forget()
jbd2: minimize region locked by j_list_lock in journal_get_create_access()
Pull file locking updates from Jeff Layton:
"Highlights:
- maintainership change for fs/locks.c. Willy's not interested in
maintaining it these days, and is OK with Bruce and I taking it.
- fix for open vs setlease race that Al ID'ed
- cleanup and consolidation of file locking code
- eliminate unneeded BUG() call
- merge of file-private lock implementation"
* 'locks-3.15' of git://git.samba.org/jlayton/linux:
locks: make locks_mandatory_area check for file-private locks
locks: fix locks_mandatory_locked to respect file-private locks
locks: require that flock->l_pid be set to 0 for file-private locks
locks: add new fcntl cmd values for handling file private locks
locks: skip deadlock detection on FL_FILE_PVT locks
locks: pass the cmd value to fcntl_getlk/getlk64
locks: report l_pid as -1 for FL_FILE_PVT locks
locks: make /proc/locks show IS_FILE_PVT locks as type "FLPVT"
locks: rename locks_remove_flock to locks_remove_file
locks: consolidate checks for compatible filp->f_mode values in setlk handlers
locks: fix posix lock range overflow handling
locks: eliminate BUG() call when there's an unexpected lock on file close
locks: add __acquires and __releases annotations to locks_start and locks_stop
locks: remove "inline" qualifier from fl_link manipulation functions
locks: clean up comment typo
locks: close potential race between setlease and open
MAINTAINERS: update entry for fs/locks.c
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs
Pull renameat2 system call from Miklos Szeredi:
"This adds a new syscall, renameat2(), which is the same as renameat()
but with a flags argument.
The purpose of extending rename is to add cross-rename, a symmetric
variant of rename, which exchanges the two files. This allows
interesting things, which were not possible before, for example
atomically replacing a directory tree with a symlink, etc... This
also allows overlayfs and friends to operate on whiteouts atomically.
Andy Lutomirski also suggested a "noreplace" flag, which disables the
overwriting behavior of rename.
These two flags, RENAME_EXCHANGE and RENAME_NOREPLACE are only
implemented for ext4 as an example and for testing"
* 'cross-rename' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs:
ext4: add cross rename support
ext4: rename: split out helper functions
ext4: rename: move EMLINK check up
ext4: rename: create ext4_renament structure for local vars
vfs: add cross-rename
vfs: lock_two_nondirectories: allow directory args
security: add flags to rename hooks
vfs: add RENAME_NOREPLACE flag
vfs: add renameat2 syscall
vfs: rename: use common code for dir and non-dir
vfs: rename: move d_move() up
vfs: add d_is_dir()
Reclaim will be leaving shadow entries in the page cache radix tree upon
evicting the real page. As those pages are found from the LRU, an
iput() can lead to the inode being freed concurrently. At this point,
reclaim must no longer install shadow pages because the inode freeing
code needs to ensure the page tree is really empty.
Add an address_space flag, AS_EXITING, that the inode freeing code sets
under the tree lock before doing the final truncate. Reclaim will check
for this flag before installing shadow pages.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Minchan Kim <minchan@kernel.org>
Cc: Bob Liu <bob.liu@oracle.com>
Cc: Luigi Semenzato <semenzato@google.com>
Cc: Metin Doslu <metin@citusdata.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Ozgun Erdogan <ozgun@citusdata.com>
Cc: Roman Gushchin <klamm@yandex-team.ru>
Cc: Ryan Mallon <rmallon@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"Apart from reordering the SELinux mmap code to ensure DAC is called
before MAC, these are minor maintenance updates"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (23 commits)
selinux: correctly label /proc inodes in use before the policy is loaded
selinux: put the mmap() DAC controls before the MAC controls
selinux: fix the output of ./scripts/get_maintainer.pl for SELinux
evm: enable key retention service automatically
ima: skip memory allocation for empty files
evm: EVM does not use MD5
ima: return d_name.name if d_path fails
integrity: fix checkpatch errors
ima: fix erroneous removal of security.ima xattr
security: integrity: Use a more current logging style
MAINTAINERS: email updates and other misc. changes
ima: reduce memory usage when a template containing the n field is used
ima: restore the original behavior for sending data with ima template
Integrity: Pass commname via get_task_comm()
fs: move i_readcount
ima: use static const char array definitions
security: have cap_dentry_init_security return error
ima: new helper: file_inode(file)
kernel: Mark function as static in kernel/seccomp.c
capability: Use current logging styles
always equal to &iocb->ki_pos.
same story - it's &iocb->ki_pos in all cases
It's always equal to &iocb->ki_pos, where iocb is the value of the 1st
argument.
generic_file_aio_read() was looping over the target iovec, with loop over
(source) pages nested inside that. Just set an iov_iter up and pass *that*
to do_generic_file_aio_read(). With copy_page_to_iter() doing all work
of mapping and copying a page to iovec and advancing iov_iter.
Switch shmem_file_aio_read() to the same and kill file_read_actor(), while
we are at it.
Signed-off-by: Kent Overstreet <kmo@daterainc.com>
new flag in ->f_mode - FMODE_WRITER. Set by do_dentry_open() in case
when it has grabbed write access, checked by __fput() to decide whether
it wants to drop the sucker. Allows to stop bothering with mnt_clone_write()
in alloc_file(), along with fewer special_file() checks.
it only makes control flow in __fput() and friends more convoluted.
Add new renameat2 syscall, which is the same as renameat with an added
flags argument.
Pass flags to vfs_rename() and to i_op->rename() as well.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Reviewed-by: J. Bruce Fields <bfields@redhat.com>
As Trond pointed out, you can currently deadlock yourself by setting a
file-private lock on a file that requires mandatory locking and then
trying to do I/O on it.
Avoid this problem by plumbing some knowledge of file-private locks into
the mandatory locking code. In order to do this, we must pass down
information about the struct file that's being used to
locks_verify_locked.
Reported-by: Trond Myklebust <trond.myklebust@primarydata.com>
Acked-by: J. Bruce Fields <bfields@redhat.com>
Once we introduce file private locks, we'll need to know what cmd value
was used, as that affects the ownership and whether a conflict would
arise.
In a later patch, we'll be adding a new type of lock that's owned by
the struct file instead of the files_struct. Those sorts of locks
will be flagged with a new FL_FILE_PVT flag.
Report these types of locks as "FLPVT" in /proc/locks to distinguish
them from "classic" POSIX locks.
Acked-by: J. Bruce Fields <bfields@fieldses.org>
This function currently removes leases in addition to flock locks and in
a later patch we'll have it deal with file-private locks too. Rename it
to locks_remove_file to indicate that it removes locks that are
associated with a particular struct file, and not just flock locks.
As Al Viro points out, there is an unlikely, but possible race between
opening a file and setting a lease on it. generic_add_lease is done with
the i_lock held, but the inode->i_flock check in break_lease is
lockless. It's possible for another task doing an open to do the entire
pathwalk and call break_lease between the point where generic_add_lease
checks for a conflicting open and adds the lease to the list. If this
occurs, we can end up with a lease set on the file with a conflicting
open.
To guard against that, check again for a conflicting open after adding
the lease to the i_flock list. If the above race occurs, then we can
simply unwind the lease setting and return -EAGAIN.
Because we take dentry references and acquire write access on the file
before calling break_lease, we know that if the i_flock list is empty
when the open caller goes to check it then the necessary refcounts have
already been incremented. Thus the additional check for a conflicting
open will see that there is one and the setlease call will fail.
Cc: Bruce Fields <bfields@fieldses.org>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: J. Bruce Fields <bfields@fieldses.org>
Use cmpxchg() to atomically set i_flags instead of clearing out the
S_IMMUTABLE, S_APPEND, etc. flags and then setting them from the
EXT4_IMMUTABLE_FL, EXT4_APPEND_FL flags, since this opens up a race
where an immutable file has the immutable flag cleared for a brief
window of time.
Reported-by: John Sullivan <jsrhbz@kanargh.force9.co.uk>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Cc: stable@kernel.org
instead of returning the flags by reference, we can just have the
low-level primitive return those in lower bits of unsigned long,
with struct file * derived from the rest.
Our write() system call has always been atomic in the sense that you get
the expected thread-safe contiguous write, but we haven't actually
guaranteed that concurrent writes are serialized wrt f_pos accesses, so
threads (or processes) that share a file descriptor and use "write()"
concurrently would quite likely overwrite each others data.
This violates POSIX.1-2008/SUSv4 Section XSI 2.9.7 that says:
"2.9.7 Thread Interactions with Regular File Operations
All of the following functions shall be atomic with respect to each
other in the effects specified in POSIX.1-2008 when they operate on
regular files or symbolic links: [...]"
and one of the effects is the file position update.
This unprotected file position behavior is not new behavior, and nobody
has ever cared. Until now. Yongzhi Pan reported unexpected behavior to
Michael Kerrisk that was due to this.
This resolves the issue with a f_pos-specific lock that is taken by
read/write/lseek on file descriptors that may be shared across threads
or processes.
Reported-by: Yongzhi Pan <panyongzhi@gmail.com>
Reported-by: Michael Kerrisk <mtk.manpages@gmail.com>
On a 64-bit system, a hole exists in the 'inode' structure after
i_writecount. This patch moves i_readcount to fill this hole.
Reported-by: David Howells <dhowells@redhat.com>
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Pull vfs fixes from Al Viro:
"A couple of fixes, both -stable fodder. The O_SYNC bug is fairly
old..."
fix a kmap leak in virtio_console
fix O_SYNC|O_APPEND syncing the wrong range on write()
Some filesystems can handle direct I/O writes beyond i_size safely,
so allow them to opt into receiving them.
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
It actually goes back to 2004 ([PATCH] Concurrent O_SYNC write support)
when sync_page_range() had been introduced; generic_file_write{,v}() correctly
synced
pos_after_write - written .. pos_after_write - 1
but generic_file_aio_write() synced
pos_before_write .. pos_before_write + written - 1
instead. Which is not the same thing with O_APPEND, obviously.
A couple of years later correct variant had been killed off when
everything switched to use of generic_file_aio_write().
All users of generic_file_aio_write() are affected, and the same bug
has been copied into other instances of ->aio_write().
The fix is trivial; the only subtle point is that generic_write_sync()
ought to be inlined to avoid calculations useless for the majority of
calls.
This changes 'do_execve()' to get the executable name as a 'struct
filename', and to free it when it is done. This is what the normal
users want, and it simplifies and streamlines their error handling.
The controlled lifetime of the executable name also fixes a
use-after-free problem with the trace_sched_process_exec tracepoint: the
lifetime of the passed-in string for kernel users was not at all
obvious, and the user-mode helper code used UMH_WAIT_EXEC to serialize
the pathname allocation lifetime with the execve() having finished,
which in turn meant that the trace point that happened after
mm_release() of the old process VM ended up using already free'd memory.
To solve the kernel string lifetime issue, this simply introduces
"getname_kernel()" that works like the normal user-space getname()
function, except with the source coming from kernel memory.
As Oleg points out, this also means that we could drop the tcomm[] array
from 'struct linux_binprm', since the pathname lifetime now covers
setup_new_exec(). That would be a separate cleanup.
Reported-by: Igor Zhbanov <i.zhbanov@samsung.com>
Tested-by: Steven Rostedt <rostedt@goodmis.org>
This will allow moving all the Posix ACL handling into the VFS and clean
up tons of cruft in the filesystems.
Rename simple_delete_dentry() to always_delete_dentry() and export it.
Export simple_dentry_operations, while we are at it, and get rid of
their duplicates
"All kinds of stuff this time around; some more notable parts:
- RCU'd vfsmounts handling
- new primitives for coredump handling
- files_lock is gone
- Bruce's delegations handling series
- exportfs fixes
plus misc stuff all over the place"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (101 commits)
ecryptfs: ->f_op is never NULL
locks: break delegations on any attribute modification
locks: break delegations on link
locks: break delegations on rename
locks: helper functions for delegation breaking
locks: break delegations on unlink
namei: minor vfs_unlink cleanup
locks: implement delegations
locks: introduce new FL_DELEG lock flag
vfs: take i_mutex on renamed file
vfs: rename I_MUTEX_QUOTA now that it's not used for quotas
vfs: don't use PARENT/CHILD lock classes for non-directories
vfs: pull ext4's double-i_mutex-locking into common code
exportfs: fix quadratic behavior in filehandle lookup
exportfs: better variable name
exportfs: move most of reconnect_path to helper function
exportfs: eliminate unused "noprogress" counter
exportfs: stop retrying once we race with rename/remove
exportfs: clear DISCONNECTED on all parents sooner
exportfs: more detailed comment for path_reconnect
NFSv4 uses leases to guarantee that clients can cache metadata as well
as data.
Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
Cc: Tyler Hicks <tyhicks@canonical.com>
Cc: Dustin Kirkland <dustin.kirkland@gazzang.com>
Acked-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
We'll need the same logic for rename and link.
We need to break delegations on any operation that changes the set of
links pointing to an inode. Start with unlink.
Such operations also hold the i_mutex on a parent directory. Breaking a
delegation may require waiting for a timeout (by default 90 seconds) in
the case of a unresponsive NFS client. To avoid blocking all directory
operations, we therefore drop locks before waiting for the delegation.
The logic then looks like:
acquire locks
test for delegation; if found:
take reference on inode
release locks
wait for delegation break
drop reference on inode
retry
It is possible this could never terminate. (Even if we take precautions
to prevent another delegation being acquired on the same inode, we could
get a different inode on each retry.) But this seems very unlikely.
The initial test for a delegation happens after the lock on the target
inode is acquired, but the directory inode may have been acquired
further up the call stack. We therefore add a "struct inode **"
argument to any intervening functions, which we use to pass the inode
back up to the caller in the case it needs a delegation synchronously
broken.
Implement NFSv4 delegations at the vfs level using the new FL_DELEG lock
type.
Note nfsd is the only delegation user and is only using read
delegations. Warn on any attempt to set a write delegation for now.
We'll come back to that case later.
For now FL_DELEG is just a synonym for FL_LEASE. So this patch doesn't
change behavior.
Next we'll modify break_lease to treat FL_DELEG leases differently, to
account for the fact that NFSv4 delegations should be broken in more
situations than Windows oplocks.
I_MUTEX_QUOTA is now just being used whenever we want to lock two
non-directories. So the name isn't right. I_MUTEX_NONDIR2 isn't
especially elegant but it's the best I could think of.
Also fix some outdated documentation.
We want to do this elsewhere as well.
Also catch any attempts to use it for directories (where this ordering
would conflict with ancestor-first directory ordering in lock_rename).
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Acked-by: "Theodore Ts'o" <tytso@mit.edu>
The filehandle lookup code wants this version of getattr.
The only thing we need it for is alt-sysrq-r (emergency remount r/o)
and these days we can do just as well without going through the
list of files.
