This patch implements a new freezer subsystem in the control groups
framework. It provides a way to stop and resume execution of all tasks in
a cgroup by writing in the cgroup filesystem.
The freezer subsystem in the container filesystem defines a file named
freezer.state. Writing "FROZEN" to the state file will freeze all tasks
in the cgroup. Subsequently writing "RUNNING" will unfreeze the tasks in
the cgroup. Reading will return the current state.
* Examples of usage :
# mkdir /containers/freezer
# mount -t cgroup -ofreezer freezer /containers
# mkdir /containers/0
# echo $some_pid > /containers/0/tasks
to get status of the freezer subsystem :
# cat /containers/0/freezer.state
RUNNING
to freeze all tasks in the container :
# echo FROZEN > /containers/0/freezer.state
FREEZING
FROZEN
to unfreeze all tasks in the container :
# echo RUNNING > /containers/0/freezer.state
RUNNING
This is the basic mechanism which should do the right thing for user space
task in a simple scenario.
It's important to note that freezing can be incomplete. In that case we
return EBUSY. This means that some tasks in the cgroup are busy doing
something that prevents us from completely freezing the cgroup at this
time. After EBUSY, the cgroup will remain partially frozen -- reflected
by freezer.state reporting "FREEZING" when read. The state will remain
"FREEZING" until one of these things happens:
1) Userspace cancels the freezing operation by writing "RUNNING" to
the freezer.state file
2) Userspace retries the freezing operation by writing "FROZEN" to
the freezer.state file (writing "FREEZING" is not legal
and returns EIO)
3) The tasks that blocked the cgroup from entering the "FROZEN"
state disappear from the cgroup's set of tasks.
[akpm@linux-foundation.org: export thaw_process]
Signed-off-by: Cedric Le Goater <clg@fr.ibm.com>
Signed-off-by: Matt Helsley <matthltc@us.ibm.com>
Acked-by: Serge E. Hallyn <serue@us.ibm.com>
Tested-by: Matt Helsley <matthltc@us.ibm.com>
Now that the TIF_FREEZE flag is available in all architectures, extract
the refrigerator() and freeze_task() from kernel/power/process.c and make
it available to all.
The refrigerator() can now be used in a control group subsystem
implementing a control group freezer.
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
The freezer currently attempts to distinguish kernel threads from
user space tasks by checking if their mm pointer is unset and it
does not send fake signals to kernel threads. However, there are
kernel threads, mostly related to networking, that behave like
user space tasks and may want to be sent a fake signal to be frozen.
Introduce the new process flag PF_FREEZER_NOSIG that will be set
by default for all kernel threads and make the freezer only send
fake signals to the tasks having PF_FREEZER_NOSIG unset. Provide
the set_freezable_with_signal() function to be called by the kernel
threads that want to be sent a fake signal for freezing.
This patch should not change the freezer's observable behavior.
Acked-by: Pavel Machek <pavel@suse.cz>
Signed-off-by: Len Brown <len.brown@intel.com>
Introduce freezer-friendly wrappers around wait_event_interruptible() and
wait_event_interruptible_timeout(), originally defined in <linux/wait.h>, to
be used in freezable kernel threads. Make some of the freezable kernel
threads use them.
This is necessary for the freezer to stop sending signals to kernel threads,
which is implemented in the next patch.
Acked-by: Pavel Machek <pavel@ucw.cz>
Cc: Nigel Cunningham <nigel@nigel.suspend2.net>
Introduce CONFIG_SUSPEND representing the ability to enter system sleep
states, such as the ACPI S3 state, and allow the user to choose SUSPEND
and HIBERNATION independently of each other.
Make HOTPLUG_CPU be selected automatically if SUSPEND or HIBERNATION has
been chosen and the kernel is intended for SMP systems.
Also, introduce CONFIG_PM_SLEEP which is automatically selected if
CONFIG_SUSPEND or CONFIG_HIBERNATION is set and use it to select the
code needed for both suspend and hibernation.
The top-level power management headers and the ACPI code related to
suspend and hibernation are modified to use the new definitions (the
changes in drivers/acpi/sleep/main.c are, mostly, moving code to reduce
the number of ifdefs).
There are many other files in which CONFIG_PM can be replaced with
CONFIG_PM_SLEEP or even with CONFIG_SUSPEND, but they can be updated in
the future.
Kernel threads should not have TIF_FREEZE set when user space processes are
being frozen, since otherwise some of them might be frozen prematurely.
To prevent this from happening we can (1) make exit_mm() unset TIF_FREEZE
unconditionally just after clearing tsk->mm and (2) make try_to_freeze_tasks()
check if p->mm is different from zero and PF_BORROWED_MM is unset in p->flags
when user space processes are to be frozen.
Namely, when user space processes are being frozen, we only should set
TIF_FREEZE for tasks that have p->mm different from NULL and don't have
PF_BORROWED_MM set in p->flags. For this reason task_lock() must be used to
prevent try_to_freeze_tasks() from racing with use_mm()/unuse_mm(), in which
p->mm and p->flags.PF_BORROWED_MM are changed under task_lock(p). Also, we
need to prevent the following scenario from happening:
* daemonize() is called by a task spawned from a user space code path
* freezer checks if the task has p->mm set and the result is positive
* task enters exit_mm() and clears its TIF_FREEZE
* freezer sets TIF_FREEZE for the task
* task calls try_to_freeze() and goes to the refrigerator, which is wrong at
that point
This requires us to acquire task_lock(p) before p->flags.PF_BORROWED_MM and
p->mm are examined and release it after TIF_FREEZE is set for p (or it turns
out that TIF_FREEZE should not be set).
Cc: Gautham R Shenoy <ego@in.ibm.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Currently, the freezer treats all tasks as freezable, except for the kernel
threads that explicitly set the PF_NOFREEZE flag for themselves. This
approach is problematic, since it requires every kernel thread to either
set PF_NOFREEZE explicitly, or call try_to_freeze(), even if it doesn't
care for the freezing of tasks at all.
It seems better to only require the kernel threads that want to or need to
be frozen to use some freezer-related code and to remove any
freezer-related code from the other (nonfreezable) kernel threads, which is
done in this patch.
The patch causes all kernel threads to be nonfreezable by default (ie. to
have PF_NOFREEZE set by default) and introduces the set_freezable()
function that should be called by the freezable kernel threads in order to
unset PF_NOFREEZE. It also makes all of the currently freezable kernel
threads call set_freezable(), so it shouldn't cause any (intentional)
change of behaviour to appear. Additionally, it updates documentation to
describe the freezing of tasks more accurately.
[akpm@linux-foundation.org: build fixes]
Acked-by: Nigel Cunningham <nigel@nigel.suspend2.net>
Other than refrigerator, no one else calls frozen_process(). So move it from
include/linux/freezer.h to kernel/power/process.c.
Also, since a task can be marked as frozen by itself, we don't need to pass
the (struct task_struct *p) parameter to frozen_process().
Signed-off-by: Gautham R Shenoy <ego@in.ibm.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
This patch fixes the race pointed out by Oleg Nesterov.
* Freezer marks a thread as freezeable.
* The thread now marks itself PF_NOFREEZE, but it will be frozen on
on calling try_to_freeze(). Thus the task is frozen, even though it doesn't
want to.
* Subsequent thaw_processes() will also fail to thaw the task since it is
marked PF_NOFREEZE.
Avoid this problem by checking the task's PF_NOFREEZE status in
frozen_processes() before marking the task as frozen.
Currently try_to_freeze_tasks() has to wait until all of the vforked processes
exit and for this reason every user can make it fail. To fix this problem we
can introduce the additional process flag PF_FREEZER_SKIP to be used by tasks
that do not want to be counted as freezable by the freezer and want to have
TIF_FREEZE set nevertheless. Then, this flag can be set by tasks using
sys_vfork() before they call wait_for_completion(&vfork) and cleared after
they have woken up. After clearing it, the tasks should call try_to_freeze()
as soon as possible.
If the freezing of tasks fails and a task is preempted in refrigerator()
before calling frozen_process(), then thaw_tasks() may run before this task is
frozen. In that case the task will freeze and no one will thaw it.
To fix this race we can call freezing(current) in refrigerator() along with
frozen_process(current) under the task_lock() which also should be taken in
the error path of try_to_freeze_tasks() as well as in thaw_process().
Moreover, if thaw_process() additionally clears TIF_FREEZE for tasks that are
not frozen, we can be sure that all tasks are thawed and there are no pending
"freeze" requests after thaw_tasks() has run.
Currently, to tell a task that it should go to the refrigerator, we set the
PF_FREEZE flag for it and send a fake signal to it. Unfortunately there
are two SMP-related problems with this approach. First, a task running on
another CPU may be updating its flags while the freezer attempts to set
PF_FREEZE for it and this may leave the task's flags in an inconsistent
state. Second, there is a potential race between freeze_process() and
refrigerator() in which freeze_process() running on one CPU is reading a
task's PF_FREEZE flag while refrigerator() running on another CPU has just
set PF_FROZEN for the same task and attempts to reset PF_FREEZE for it. If
the refrigerator wins the race, freeze_process() will state that PF_FREEZE
hasn't been set for the task and will set it unnecessarily, so the task
will go to the refrigerator once again after it's been thawed.
To solve first of these problems we need to stop using PF_FREEZE to tell
tasks that they should go to the refrigerator. Instead, we can introduce a
special TIF_*** flag and use it for this purpose, since it is allowed to
change the other tasks' TIF_*** flags and there are special calls for it.
To avoid the freeze_process()-refrigerator() race we can make
freeze_process() to always check the task's PF_FROZEN flag after it's read
its "freeze" flag. We should also make sure that refrigerator() will
always reset the task's "freeze" flag after it's set PF_FROZEN for it.
Cc: Andi Kleen <ak@muc.de>
Cc: "Luck, Tony" <tony.luck@intel.com>
freezer.h uses task_struct fields so it should include sched.h.
CC [M] fs/jfs/jfs_txnmgr.o
In file included from fs/jfs/jfs_txnmgr.c:49:
include/linux/freezer.h: In function 'frozen':
include/linux/freezer.h:9: error: dereferencing pointer to incomplete type
include/linux/freezer.h:9: error: 'PF_FROZEN' undeclared (first use in this function)
include/linux/freezer.h:9: error: (Each undeclared identifier is reported only once
include/linux/freezer.h:9: error: for each function it appears in.)
include/linux/freezer.h: In function 'freezing':
include/linux/freezer.h:17: error: dereferencing pointer to incomplete type
include/linux/freezer.h:17: error: 'PF_FREEZE' undeclared (first use in this function)
include/linux/freezer.h: In function 'freeze':
include/linux/freezer.h:26: error: dereferencing pointer to incomplete type
include/linux/freezer.h:26: error: 'PF_FREEZE' undeclared (first use in this function)
include/linux/freezer.h: In function 'do_not_freeze':
include/linux/freezer.h:34: error: dereferencing pointer to incomplete type
include/linux/freezer.h:34: error: 'PF_FREEZE' undeclared (first use in this function)
include/linux/freezer.h: In function 'thaw_process':
include/linux/freezer.h:43: error: dereferencing pointer to incomplete type
include/linux/freezer.h:43: error: 'PF_FROZEN' undeclared (first use in this function)
include/linux/freezer.h:44: warning: implicit declaration of function 'wake_up_process'
include/linux/freezer.h: In function 'frozen_process':
include/linux/freezer.h:55: error: dereferencing pointer to incomplete type
include/linux/freezer.h:55: error: 'PF_FREEZE' undeclared (first use in this function)
include/linux/freezer.h:55: error: 'PF_FROZEN' undeclared (first use in this function)
fs/jfs/jfs_txnmgr.c: In function 'freezing':
include/linux/freezer.h:18: warning: control reaches end of non-void function
make[2]: *** [fs/jfs/jfs_txnmgr.o] Error 1
Acked-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
Move the loop from thaw_processes() to a separate function and call it
independently for kernel threads and user space processes so that the order
of thawing tasks is clearly visible.
Drop thaw_kernel_threads() which is never used.
Cc: Nigel Cunningham <nigel@suspend2.net>
Modify process thawing so that we can thaw kernel space without thawing
userspace, and thaw kernelspace first. This will be useful in later
patches, where I intend to get swsusp thawing kernel threads only before
seeking to free memory.
Signed-off-by: Nigel Cunningham <nigel@suspend2.net>
Move process freezing functions from include/linux/sched.h to freezer.h, so
that modifications to the freezer or the kernel configuration don't require
recompiling just about everything.
[akpm@osdl.org: fix ueagle driver]
