path: root/include/linux/fib_rules.h
2006-09-22[IPV4]: Add support for fwmark masks in routing rulesPatrick McHardy
Add a FRA_FWMASK attributes for fwmark masks. For compatibility a mask of 0xFFFFFFFF is used when a mark value != 0 is sent without a mask. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV6] ROUTE: Routing by FWMARK.YOSHIFUJI Hideaki
Based on patch by Jean Lorchat <lorchat@sfc.wide.ad.jp>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2006-09-22[NET]: Introduce RTA_TABLE/FRA_TABLE attributesPatrick McHardy
Introduce RTA_TABLE route attribute and FRA_TABLE routing rule attribute to hold 32 bit routing table IDs. Usespace compatibility is provided by continuing to accept and send the rtm_table field, but because of its limited size it can only carry the low 8 bits of the table ID. This implies that if larger IDs are used, _all_ userspace programs using them need to use RTA_TABLE. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Protocol Independant Policy Routing Rules FrameworkThomas Graf
Derived from net/ipv/fib_rules.c Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
