path: root/include/linux/fcntl.h
2007-05-06locks: add lock cancel commandMarc Eshel
Lock managers need to be able to cancel pending lock requests. In the case where the exported filesystem manages its own locks, it's not sufficient just to call posix_unblock_lock(); we need to let the filesystem know what's happening too. We do this by adding a new fcntl lock command: FL_CANCELLK. Some day this might also be made available to userspace applications that could benefit from an asynchronous locking api. Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu>
2006-06-25[PATCH] Implement AT_SYMLINK_FOLLOW flag for linkatUlrich Drepper
When the linkat() syscall was added the flag parameter was added in the last minute but it wasn't used so far. The following patch should change that. My tests show that this is all that's needed. If OLDNAME is a symlink setting the flag causes linkat to follow the symlink and create a hardlink with the target. This is actually the behavior POSIX demands for link() as well but Linux wisely does not do this. With this flag (which will most likely be in the next POSIX revision) the programmer can choose the behavior, defaulting to the safe variant. As a side effect it is now possible to implement a POSIX-compliant link(2) function for those who are interested. touch file ln -s file symlink linkat(fd, "symlink", fd, "newlink", 0) -> newlink is hardlink of symlink linkat(fd, "symlink", fd, "newlink", AT_SYMLINK_FOLLOW) -> newlink is hardlink of file The value of AT_SYMLINK_FOLLOW is determined by the definition we already use in glibc. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] vfs: *at functions: coreUlrich Drepper
Here is a series of patches which introduce in total 13 new system calls which take a file descriptor/filename pair instead of a single file name. These functions, openat etc, have been discussed on numerous occasions. They are needed to implement race-free filesystem traversal, they are necessary to implement a virtual per-thread current working directory (think multi-threaded backup software), etc. We have in glibc today implementations of the interfaces which use the /proc/self/fd magic. But this code is rather expensive. Here are some results (similar to what Jim Meyering posted before). The test creates a deep directory hierarchy on a tmpfs filesystem. Then rm -fr is used to remove all directories. Without syscall support I get this: real 0m31.921s user 0m0.688s sys 0m31.234s With syscall support the results are much better: real 0m20.699s user 0m0.536s sys 0m20.149s The interfaces are for obvious reasons currently not much used. But they'll be used. coreutils (and Jeff's posixutils) are already using them. Furthermore, code like ftw/fts in libc (maybe even glob) will also start using them. I expect a patch to make follow soon. Every program which is walking the filesystem tree will benefit. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@ftp.linux.org.uk> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] Don't force O_LARGEFILE for 32 bit processes on ia64Yoav Zach
In ia64 kernel, the O_LARGEFILE flag is forced when opening a file. This is problematic for execution of 32 bit processes, which are not largefile aware, either by SW emulation or by HW execution. For such processes, the problem is two-fold: 1) When trying to open a file that is larger than 4G the operation should fail, but it's not 2) Writing to offset larger than 4G should fail, but it's not The proposed patch takes advantage of the way 32 bit processes are identified in ia64 systems. Such processes have PER_LINUX32 for their personality. With the patch, the ia64 kernel will not enforce the O_LARGEFILE flag if the current process has PER_LINUX32 set. The behavior for all other architectures remains unchanged. Signed-off-by: Yoav Zach <yoav.zach@intel.com> Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
