... and hide the memory regions dump behind it. Make it default-off.
Link: http://lkml.kernel.org/r/20141209095843.GA3990@pd.tnic
Acked-by: Laszlo Ersek <lersek@redhat.com>
Acked-by: Dave Young <dyoung@redhat.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Catalin Marinas:
"arm64 updates for 3.20:
- reimplementation of the virtual remapping of UEFI Runtime Services
in a way that is stable across kexec
- emulation of the "setend" instruction for 32-bit tasks (user
endianness switching trapped in the kernel, SCTLR_EL1.E0E bit set
accordingly)
- compat_sys_call_table implemented in C (from asm) and made it a
constant array together with sys_call_table
- export CPU cache information via /sys (like other architectures)
- DMA API implementation clean-up in preparation for IOMMU support
- macros clean-up for KVM
- dropped some unnecessary cache+tlb maintenance
- CONFIG_ARM64_CPU_SUSPEND clean-up
- defconfig update (CPU_IDLE)
The EFI changes going via the arm64 tree have been acked by Matt
Fleming. There is also a patch adding sys_*stat64 prototypes to
include/linux/syscalls.h, acked by Andrew Morton"
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (47 commits)
arm64: compat: Remove incorrect comment in compat_siginfo
arm64: Fix section mismatch on alloc_init_p[mu]d()
arm64: Avoid breakage caused by .altmacro in fpsimd save/restore macros
arm64: mm: use *_sect to check for section maps
arm64: drop unnecessary cache+tlb maintenance
arm64:mm: free the useless initial page table
arm64: Enable CPU_IDLE in defconfig
arm64: kernel: remove ARM64_CPU_SUSPEND config option
arm64: make sys_call_table const
arm64: Remove asm/syscalls.h
arm64: Implement the compat_sys_call_table in C
syscalls: Declare sys_*stat64 prototypes if __ARCH_WANT_(COMPAT_)STAT64
compat: Declare compat_sys_sigpending and compat_sys_sigprocmask prototypes
arm64: uapi: expose our struct ucontext to the uapi headers
smp, ARM64: Kill SMP single function call interrupt
arm64: Emulate SETEND for AArch32 tasks
arm64: Consolidate hotplug notifier for instruction emulation
arm64: Track system support for mixed endian EL0
arm64: implement generic IOMMU configuration
arm64: Combine coherent and non-coherent swiotlb dma_ops
git://git.kernel.org/pub/scm/linux/kernel/git/mfleming/efi into x86/efi
Pull EFI updates from Matt Fleming:
" - Move efivarfs from the misc filesystem section to pseudo filesystem,
since that's a more logical and accurate place - Leif Lindholm
- Update efibootmgr URL in Kconfig help - Peter Jones
- Improve accuracy of EFI guid function names - Borislav Petkov
- Expose firmware platform size in sysfs for the benefit of EFI boot
loader installers and other utilities - Steve McIntyre
- Cleanup __init annotations for arm64/efi code - Ard Biesheuvel
- Mark the UIE as unsupported for rtc-efi - Ard Biesheuvel
- Fix memory leak in error code path of runtime map code - Dan Carpenter
- Improve robustness of get_memory_map() by removing assumptions on the
size of efi_memory_desc_t (which could change in future spec
versions) and querying the firmware instead of guessing about the
memmap size - Ard Biesheuvel
- Remove superfluous guid unparse calls - Ivan Khoronzhuk
- Delete unnecessary chosen@0 DT node FDT code since was duplicated
from code in drivers/of and is entirely unnecessary - Leif Lindholm
There's nothing super scary, mainly cleanups, and a merge from Ricardo who
kindly picked up some patches from the linux-efi mailing list while I
was out on annual leave in December.
Perhaps the biggest risk is the get_memory_map() change from Ard, which
changes the way that both the arm64 and x86 EFI boot stub build the
early memory map. It would be good to have it bake in linux-next for a
while.
Split of the remapping code from efi_config_init() so that the caller
can perform its own remapping. This is necessary to correctly handle
virtually remapped UEFI memory regions under kexec, as efi.systab will
have been updated to a virtual address.
Acked-by: Matt Fleming <matt.fleming@intel.com>
Tested-by: Leif Lindholm <leif.lindholm@linaro.org>
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Call it what it does - "unparse" is plain-misleading.
Signed-off-by: Ricardo Neri <ricardo.neri-calderon@linux.intel.com>
This adds support to the UEFI side for detecting the presence of
a SMBIOS 3.0 64-bit entry point. This allows the actual SMBIOS
structure table to reside at a physical offset over 4 GB, which
cannot be supported by the legacy SMBIOS 32-bit entry point.
Since the firmware can legally provide both entry points, store
the SMBIOS 3.0 entry point in a separate variable, and let the
DMI decoding layer decide which one will be used.
Tested-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com>
Acked-by: Leif Lindholm <leif.lindholm@linaro.org>
There are some circumstances that call for trying to write an EFI
variable in a non-blocking way. One such scenario is when writing pstore
data in efi_pstore_write() via the pstore_dump() kdump callback.
Now that we have an EFI runtime spinlock we need a way of aborting if
there is contention instead of spinning, since when writing pstore data
from the kdump callback, the runtime lock may already be held by the CPU
that's running the callback if we crashed in the middle of an EFI
variable operation.
The situation is sufficiently special that a new EFI variable operation
is warranted.
Introduce ->set_variable_nonblocking() for this use case. It is an
optional EFI backend operation, and need only be implemented by those
backends that usually acquire locks to serialize access to EFI
variables, as is the case for virt_efi_set_variable() where we now grab
the EFI runtime spinlock.
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
At the moment, there are three architectures debug-printing the EFI memory
map at initialization: x86, ia64, and arm64. They all use different format
strings, plus the EFI memory type and the EFI memory attributes are
similarly hard to decode for a human reader.
Introduce a helper __init function that formats the memory type and the
memory attributes in a unified way, to a user-provided character buffer.
The array "memory_type_name" is copied from the arm64 code, temporarily
duplicating it. The (otherwise optional) braces around each string literal
in the initializer list are dropped in order to match the kernel coding
style more closely. The element size is tightened from 32 to 20 bytes
(maximum actual string length + 1) so that we can derive the field width
from the element size.
Signed-off-by: Laszlo Ersek <lersek@redhat.com>
Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
[ Dropped useless 'register' keyword, which compiler will ignore ]
Add the following macro from the UEFI spec, for completeness:
EFI_MEMORY_UCE Memory cacheability attribute: The memory region
supports being configured as not cacheable, exported,
and supports the "fetch and add" semaphore mechanism.
noefi param can be used for arches other than X86 later, thus move it
out of x86 platform code.
Signed-off-by: Dave Young <dyoung@redhat.com>
We need a way to customize the behaviour of the EFI boot stub, in
particular, we need a way to disable the "chunking" workaround, used
when reading files from the EFI System Partition.
One of my machines doesn't cope well when reading files in 1MB chunks to
a buffer above the 4GB mark - it appears that the "chunking" bug
workaround triggers another firmware bug. This was only discovered with
commit 4bf7111f5016 ("x86/efi: Support initrd loaded above 4G"), and
that commit is perfectly valid. The symptom I observed was a corrupt
initrd rather than any kind of crash.
efi= is now used to specify EFI parameters in two very different
execution environments, the EFI boot stub and during kernel boot.
There is also a slight performance optimization by enabling efi=nochunk,
but that's offset by the fact that you're more likely to run into
firmware issues, at least on x86. This is the rationale behind leaving
the workaround enabled by default.
Also provide some documentation for EFI_READ_CHUNK_SIZE and why we're
using the current value of 1MB.
Cc: Roy Franz <roy.franz@linaro.org>
Cc: Maarten Lankhorst <m.b.lankhorst@gmail.com>
Cc: Leif Lindholm <leif.lindholm@linaro.org>
Cc: Borislav Petkov <bp@suse.de>
This patch does two things. It passes EFI run time mappings to second
kernel in bootparams efi_info. Second kernel parse this info and create
new mappings in second kernel. That means mappings in first and second
kernel will be same. This paves the way to enable EFI in kexec kernel.
This patch also prepares and passes EFI setup data through bootparams.
This contains bunch of information about various tables and their
addresses.
These information gathering and passing has been written along the lines
of what current kexec-tools is doing to make kexec work with UEFI.
[akpm@linux-foundation.org: s/get_efi/efi_get/g, per Matt]
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Eric Biederman <ebiederm@xmission.com>
Cc: Greg Kroah-Hartman <greg@kroah.com>
Cc: Dave Young <dyoung@redhat.com>
Cc: WANG Chao <chaowang@redhat.com>
Cc: Baoquan He <bhe@redhat.com>
Cc: Matt Fleming <matt@console-pimps.org>
The comment describing how struct efivars->lock is used hasn't been
updated in sync with the code. Fix it.
Reported-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Mike Waychison <mikew@google.com>
efi_set_rtc_mmss() is never used to set RTC due to bugs found
on many EFI platforms. It is set directly by mach_set_rtc_mmss().
Hence, remove unused efi_set_rtc_mmss() function.
Signed-off-by: Daniel Kiper <daniel.kiper@oracle.com>
Introduce EFI_PARAVIRT flag. If it is set then kernel runs
on EFI platform but it has not direct control on EFI stuff
like EFI runtime, tables, structures, etc. If not this means
that Linux Kernel has direct access to EFI infrastructure
and everything runs as usual.
This functionality is used in Xen dom0 because hypervisor
has full control on EFI stuff and all calls from dom0 to
EFI must be requested via special hypercall which in turn
executes relevant EFI code in behalf of dom0.
It appears that the BayTrail-T class of hardware requires EFI in order
to powerdown and reboot and no other reliable method exists.
This quirk is generally applicable to all hardware that has the ACPI
Hardware Reduced bit set, since usually ACPI would be the preferred
method.
Cc: Len Brown <len.brown@intel.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: "Rafael J. Wysocki" <rafael.j.wysocki@intel.com>
Not only can EfiResetSystem() be used to reboot, it can also be used to
power down machines.
By and large, this functionality doesn't work very well across the range
of EFI machines in the wild, so it should definitely only be used as a
last resort. In an ideal world, this wouldn't be needed at all.
Unfortunately, we're starting to see machines where EFI is the *only*
reliable way to power down, and nothing else, not PCI, not ACPI, works.
efi_poweroff_required() should be implemented on a per-architecture
basis, since exactly when we should be using EFI runtime services is a
platform-specific decision. There's no analogue for reboot because each
architecture handles reboot very differently - the x86 code in
particular is pretty complex.
Patches to enable this for specific classes of hardware will be
submitted separately.
Tested-by: Mark Salter <msalter@redhat.com>
Implement efi_reboot(), which is really just a wrapper around the
EfiResetSystem() EFI runtime service, but it does at least allow us to
funnel all callers through a single location.
It also simplifies the callsites since users no longer need to check to
see whether EFI_RUNTIME_SERVICES are enabled.
In order to move from the #include "../../../xxxxx.c" anti-pattern used
by both the x86 and arm64 versions of the stub to a static library
linked into either the kernel proper (arm64) or a separate boot
executable (x86), there is some prepatory work required.
This patch does the following:
- move forward declarations of functions shared between the arch
specific and the generic parts of the stub to include/linux/efi.h
- move forward declarations of functions shared between various .c files
of the generic stub code to a new local header file called "efistub.h"
- add #includes to all .c files which were formerly relying on the
#includor to include the correct header files
- remove all static modifiers from functions which will need to be
externally visible once we move to a static library
In order for other archs (such as arm64) to be able to reuse the virtual
mode function call wrappers, move them to drivers/firmware/efi/runtime-wrappers.c.
Both ARM and ARM64 stubs will update the device tree that they pass to
the kernel. In both cases they primarily need to add the same UEFI
related information, so the function can be shared. Create a new FDT
related file for this to avoid use of architecture #ifdefs in
efi-stub-helper.c.
Signed-off-by: Roy Franz <roy.franz@linaro.org>
[ Fixed memory node deletion code. ]
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Leif Lindholm <leif.lindholm@linaro.org>
Acked-by: Grant Likely <grant.likely@linaro.org>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
ARM and ARM64 architectures use the device tree to pass UEFI parameters
from stub to kernel. These parameters are things known to the stub but
not discoverable by the kernel after the stub calls ExitBootSerives().
There is a helper function in:
drivers/firmware/efi/fdt.c
which the stub uses to add the UEFI parameters to the device tree.
This patch adds a complimentary helper function which UEFI runtime
support may use to retrieve the parameters from the device tree.
If an architecture wants to use this helper, it should select
CONFIG_EFI_PARAMS_FROM_FDT.
Signed-off-by: Mark Salter <msalter@redhat.com>
In preparation for compat support, we can't assume that user variable
object is represented by a 'struct efi_variable'. Convert the validation
functions to take the variable name as an argument, which is the only
piece of the struct that was ever used anyway.
There are a lot of places in the kernel which iterate through an
EFI memory map. Most of these places use essentially the same
for-loop code. This patch adds a for_each_efi_memory_desc()
helper to clean up all of the existing duplicate code and avoid
more in the future.
arch/x86/kernel/setup.c
arch/x86/platform/efi/efi.c
arch/x86/platform/efi/efi_64.c
The traditional approach of using machine-specific types such as
'unsigned long' does not allow the kernel to interact with firmware
running in a different CPU mode, e.g. 64-bit kernel with 32-bit EFI.
Add distinct EFI structure definitions for both 32-bit and 64-bit so
that we can use them in the 32-bit and 64-bit code paths.
Acked-by: Borislav Petkov <bp@suse.de>
There's no good reason to keep efi_enabled() under CONFIG_X86 anymore,
since nothing about the implementation is specific to x86.
Set EFI feature flags in the ia64 boot path instead of claiming to
support all features. The old behaviour was actually buggy since
efi.memmap never points to a valid memory map, so we shouldn't be
claiming to support EFI_MEMMAP.
Fortunately, this bug was never triggered because EFI_MEMMAP isn't used
outside of arch/x86 currently, but that may not always be the case.
Reviewed-and-tested-by: Tony Luck <tony.luck@intel.com>
As we grow support for more EFI architectures they're going to want the
ability to query which EFI features are available on the running system.
Instead of storing this information in an architecture-specific place,
stick it in the global 'struct efi', which is already the central
location for EFI state.
While we're at it, let's change the return value of efi_enabled() to be
bool and replace all references to 'facility' with 'feature', which is
the usual word used to describe the attributes of the running system.
drivers/firmware/efi/Kconfig
kexec kernel will need exactly same mapping for EFI runtime memory
ranges. Thus here export the runtime ranges mapping to sysfs,
kexec-tools will assemble them and pass to 2nd kernel via setup_data.
Introducing a new directory /sys/firmware/efi/runtime-map just like
/sys/firmware/memmap. Containing below attribute in each file of that
directory:
attribute num_pages phys_addr type virt_addr
Tested-by: Toshi Kani <toshi.kani@hp.com>
Export fw_vendor, runtime and config table physical addresses to
/sys/firmware/efi/{fw_vendor,runtime,config_table} because kexec kernels
need them.
From EFI spec these 3 variables will be updated to virtual address after
entering virtual mode. But kernel startup code will need the physical
address.
completed
Currently, when mounting pstore file system, a read callback of
efi_pstore driver runs mutiple times as below.
- In the first read callback, scan efivar_sysfs_list from head and pass
a kmsg buffer of a entry to an upper pstore layer.
- In the second read callback, rescan efivar_sysfs_list from the entry
and pass another kmsg buffer to it.
- Repeat the scan and pass until the end of efivar_sysfs_list.
In this process, an entry is read across the multiple read function
calls. To avoid race between the read and erasion, the whole process
above is protected by a spinlock, holding in open() and releasing in
close().
At the same time, kmemdup() is called to pass the buffer to pstore
filesystem during it. And then, it causes a following lockdep warning.
To make the dynamic memory allocation runnable without taking spinlock,
holding off a deletion of sysfs entry if it happens while scanning it
via efi_pstore, and deleting it after the scan is completed.
To implement it, this patch introduces two flags, scanning and deleting,
to efivar_entry.
On the code basis, it seems that all the scanning and deleting logic is
not needed because __efivars->lock are not dropped when reading from the
EFI variable store.
But, the scanning and deleting logic is still needed because an
efi-pstore and a pstore filesystem works as follows.
In case an entry(A) is found, the pointer is saved to psi->data. And
efi_pstore_read() passes the entry(A) to a pstore filesystem by
releasing __efivars->lock.
And then, the pstore filesystem calls efi_pstore_read() again and the
same entry(A), which is saved to psi->data, is used for resuming to scan
a sysfs-list.
So, to protect the entry(A), the logic is needed.
[ 1.143710] ------------[ cut here ]------------
[ 1.144058] WARNING: CPU: 1 PID: 1 at kernel/lockdep.c:2740 lockdep_trace_alloc+0x104/0x110()
[ 1.144058] DEBUG_LOCKS_WARN_ON(irqs_disabled_flags(flags))
[ 1.144058] Modules linked in:
[ 1.144058] CPU: 1 PID: 1 Comm: systemd Not tainted 3.11.0-rc5 #2
[ 1.144058] 0000000000000009 ffff8800797e9ae0 ffffffff816614a5 ffff8800797e9b28
[ 1.144058] ffff8800797e9b18 ffffffff8105510d 0000000000000080 0000000000000046
[ 1.144058] 00000000000000d0 00000000000003af ffffffff81ccd0c0 ffff8800797e9b78
[ 1.144058] Call Trace:
[ 1.144058] [<ffffffff816614a5>] dump_stack+0x54/0x74
[ 1.144058] [<ffffffff8105510d>] warn_slowpath_common+0x7d/0xa0
[ 1.144058] [<ffffffff8105517c>] warn_slowpath_fmt+0x4c/0x50
[ 1.144058] [<ffffffff8131290f>] ? vsscanf+0x57f/0x7b0
[ 1.144058] [<ffffffff810bbd74>] lockdep_trace_alloc+0x104/0x110
[ 1.144058] [<ffffffff81192da0>] __kmalloc_track_caller+0x50/0x280
[ 1.144058] [<ffffffff815147bb>] ? efi_pstore_read_func.part.1+0x12b/0x170
[ 1.144058] [<ffffffff8115b260>] kmemdup+0x20/0x50
[ 1.144058] [<ffffffff815147bb>] efi_pstore_read_func.part.1+0x12b/0x170
[ 1.144058] [<ffffffff81514800>] ? efi_pstore_read_func.part.1+0x170/0x170
[ 1.144058] [<ffffffff815148b4>] efi_pstore_read_func+0xb4/0xe0
[ 1.144058] [<ffffffff81512b7b>] __efivar_entry_iter+0xfb/0x120
[ 1.144058] [<ffffffff8151428f>] efi_pstore_read+0x3f/0x50
[ 1.144058] [<ffffffff8128d7ba>] pstore_get_records+0x9a/0x150
[ 1.158207] [<ffffffff812af25c>] ? selinux_d_instantiate+0x1c/0x20
[ 1.158207] [<ffffffff8128ce30>] ? parse_options+0x80/0x80
[ 1.158207] [<ffffffff8128ced5>] pstore_fill_super+0xa5/0xc0
[ 1.158207] [<ffffffff811ae7d2>] mount_single+0xa2/0xd0
[ 1.158207] [<ffffffff8128ccf8>] pstore_mount+0x18/0x20
[ 1.158207] [<ffffffff811ae8b9>] mount_fs+0x39/0x1b0
[ 1.158207] [<ffffffff81160550>] ? __alloc_percpu+0x10/0x20
[ 1.158207] [<ffffffff811c9493>] vfs_kern_mount+0x63/0xf0
[ 1.158207] [<ffffffff811cbb0e>] do_mount+0x23e/0xa20
[ 1.158207] [<ffffffff8115b51b>] ? strndup_user+0x4b/0xf0
[ 1.158207] [<ffffffff811cc373>] SyS_mount+0x83/0xc0
[ 1.158207] [<ffffffff81673cc2>] system_call_fastpath+0x16/0x1b
[ 1.158207] ---[ end trace 61981bc62de9f6f4 ]---
Signed-off-by: Seiji Aguchi <seiji.aguchi@hds.com>
Tested-by: Madper Xie <cxie@redhat.com>
Cc: stable@kernel.org
We map the EFI regions needed for runtime services non-contiguously,
with preserved alignment on virtual addresses starting from -4G down
for a total max space of 64G. This way, we provide for stable runtime
services addresses across kernels so that a kexec'd kernel can still use
them.
Thus, they're mapped in a separate pagetable so that we don't pollute
the kernel namespace.
Add an efi= kernel command line parameter for passing miscellaneous
options and chicken bits from the command line.
While at it, add a chicken bit called "efi=old_map" which can be used as
a fallback to the old runtime services mapping method in case there's
some b0rkage with a particular EFI implementation (haha, it is hard to
hold up the sarcasm here...).
Also, add the UEFI RT VA space to Documentation/x86/x86_64/mm.txt.
The x86/AMD64 EFI stubs must use a call wrapper to convert between
the Linux and EFI ABIs, so void pointers are sufficient. For ARM,
the ABIs are compatible, so we can directly invoke the function
pointers. The functions that are used by the ARM stub are updated
to match the EFI definitions.
Also add some EFI types used by EFI functions.
Acked-by: Mark Salter <msalter@redhat.com>
Reviewed-by: Grant Likely <grant.likely@linaro.org>
efi_lookup_mapped_addr() is a handy utility for other platforms than
x86. Move it from arch/x86 to drivers/firmware. Add memmap pointer
to global efi structure, and initialise it on x86.
Common to (U)EFI support on all platforms is the global "efi" data
structure, and the code that parses the System Table to locate
addresses to populate that structure with.
This patch adds both of these to the global EFI driver code and
removes the local definition of the global "efi" data structure from
the x86 and ia64 code.
Squashed into one big patch to avoid breaking bisection.
Acked-by: Tony Luck <tony.luck@intel.com>
Pull timer core updates from Thomas Gleixner:
"The timer changes contain:
- posix timer code consolidation and fixes for odd corner cases
- sched_clock implementation moved from ARM to core code to avoid
duplication by other architectures
- alarm timer updates
- clocksource and clockevents unregistration facilities
- clocksource/events support for new hardware
- precise nanoseconds RTC readout (Xen feature)
- generic support for Xen suspend/resume oddities
- the usual lot of fixes and cleanups all over the place
The parts which touch other areas (ARM/XEN) have been coordinated with
the relevant maintainers. Though this results in an handful of
trivial to solve merge conflicts, which we preferred over nasty cross
tree merge dependencies.
The patches which have been committed in the last few days are bug
fixes plus the posix timer lot. The latter was in akpms queue and
next for quite some time; they just got forgotten and Frederic
collected them last minute."
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (59 commits)
hrtimer: Remove unused variable
hrtimers: Move SMP function call to thread context
clocksource: Reselect clocksource when watchdog validated high-res capability
posix-cpu-timers: don't account cpu timer after stopped thread runtime accounting
posix_timers: fix racy timer delta caching on task exit
posix-timers: correctly get dying task time sample in posix_cpu_timer_schedule()
selftests: add basic posix timers selftests
posix_cpu_timers: consolidate expired timers check
posix_cpu_timers: consolidate timer list cleanups
posix_cpu_timer: consolidate expiry time type
tick: Sanitize broadcast control logic
tick: Prevent uncontrolled switch to oneshot mode
tick: Make oneshot broadcast robust vs. CPU offlining
x86: xen: Sync the CMOS RTC as well as the Xen wallclock
x86: xen: Sync the wallclock when the system time is set
timekeeping: Indicate that clock was set in the pvclock gtod notifier
timekeeping: Pass flags instead of multiple bools to timekeeping_update()
xen: Remove clock_was_set() call in the resume path
hrtimers: Support resuming with two or more CPUs online (but stopped)
timer: Fix jiffies wrap behavior of round_jiffies_common()
... to void * like the boot services and lose all the void * casts. No
functionality change.
All the virtualized platforms (KVM, lguest and Xen) have persistent
wallclocks that have more than one second of precision.
read_persistent_wallclock() and update_persistent_wallclock() allow
for nanosecond precision but their implementation on x86 with
x86_platform.get/set_wallclock() only allows for one second precision.
This means guests may see a wallclock time that is off by up to 1
second.
Make set_wallclock() and get_wallclock() take a struct timespec
parameter (which allows for nanosecond precision) so KVM and Xen
guests may start with a more accurate wallclock time and a Xen dom0
can maintain a more accurate wallclock for guests.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Seiji reported getting empty dmesg-* files, because the data was never
actually read in efi_pstore_read_func(), and so the memcpy() was copying
garbage data.
This patch necessitated adding __efivar_entry_get() which is callable
between efivar_entry_iter_{begin,end}(). We can also delete
__efivar_entry_size() because efi_pstore_read_func() was the only
caller.
Reported-by: Seiji Aguchi <seiji.aguchi@hds.com>
Tested-by: Seiji Aguchi <seiji.aguchi@hds.com>
Cc: Matthew Garrett <matthew.garrett@nebula.com>
Resolve conflicts for Ingo.
drivers/firmware/Kconfig
drivers/firmware/efivars.c
This registers /sys/firmware/efi/{,systab,efivars/} whenever EFI is enabled
and the system is booted with EFI.
This allows
*) userspace to check for the existence of /sys/firmware/efi as a way
to determine whether or it is running on an EFI system.
*) 'mount -t efivarfs none /sys/firmware/efi/efivars' without manually
loading any modules.
[ Also, move the efivar API into vars.c and unconditionally compile it.
This allows us to move efivars.c, which now only contains the sysfs
variable code, into the firmware/efi directory. Note that the efivars.c
filename is kept to maintain backwards compatability with the old
efivars.ko module. With this patch it is now possible for efivarfs
to be built without CONFIG_EFI_VARS - Matt ]
Cc: Seiji Aguchi <seiji.aguchi@hds.com>
Cc: Kay Sievers <kay@vrfy.org>
Cc: Jeremy Kerr <jk@ozlabs.org>
Cc: Chun-Yi Lee <jlee@suse.com>
Cc: Andy Whitcroft <apw@canonical.com>
Cc: Tobias Powalowski <tpowa@archlinux.org>
Signed-off-by: Tom Gundersen <teg@jklm.no>
efivars.c has grown far too large and needs to be divided up. Create a
new directory and move the persistence storage code to efi-pstore.c now
that it uses the new efivar API. This helps us to greatly reduce the
size of efivars.c and paves the way for moving other code out of
efivars.c.
Note that because CONFIG_EFI_VARS can be built as a module efi-pstore
must also include support for building as a module.
Reviewed-by: Tom Gundersen <teg@jklm.no>
Tested-by: Tom Gundersen <teg@jklm.no>
Cc: Anton Vorontsov <cbouatmailru@gmail.com>
Cc: Colin Cross <ccross@android.com>
There isn't really a formal interface for dealing with EFI variables
or struct efivar_entry. Historically, this has led to various bits of
code directly accessing the generic EFI variable ops, which inherently
ties it to specific EFI variable operations instead of indirectly
using whatever ops were registered with register_efivars(). This lead
to the efivarfs code only working with the generic EFI variable ops
and not CONFIG_GOOGLE_SMI.
Encapsulate everything that needs to access '__efivars' inside an
efivar_entry_* API and use the new API in the pstore, sysfs and
efivarfs code.
Much of the efivars code had to be rewritten to use this new API. For
instance, it is now up to the users of the API to build the initial
list of EFI variables in their efivar_init() callback function. The
variable list needs to be passed to efivar_init() which allows us to
keep work arounds for things like implementation bugs in
GetNextVariable() in a central location.
Allowing users of the API to use a callback function to build the list
greatly benefits the efivarfs code which needs to allocate inodes and
dentries for every variable. It previously did this in a racy way
because the code ran without holding the variable spinlock. Both the
sysfs and efivarfs code maintain their own lists which means the two
interfaces can be running simultaneously without interference, though
it should be noted that because no synchronisation is performed it is
very easy to create inconsistencies. efibootmgr doesn't currently use
efivarfs and users are likely to also require the old sysfs interface,
so it makes sense to allow both to be built.
There are currently two implementations of the utf16 string functions.
Somewhat confusingly, they've got different names.
Centralise the functions in efi.h.
Reviewed-by: Mike Waychison <mikew@google.com>
Let's not burden ia64 with checks in the common efivars code that we're not
writing too much data to the variable store. That kind of thing is an x86
firmware bug, plain and simple.
efi_query_variable_store() provides platforms with a wrapper in which they can
perform checks and workarounds for EFI variable storage bugs.
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux
Pull pstore patches from Tony Luck:
"A few fixes to reduce places where pstore might hang a system in the
crash path. Plus a new mountpoint (/sys/fs/pstore ... makes more
sense then /dev/pstore)."
Fix up trivial conflict in drivers/firmware/efivars.c
* tag 'please-pull-pstore' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux:
pstore: Create a convenient mount point for pstore
efi_pstore: Introducing workqueue updating sysfs
efivars: Disable external interrupt while holding efivars->lock
efi_pstore: Avoid deadlock in non-blocking paths
pstore: Avoid deadlock in panic and emergency-restart path
[Problem]
efi_pstore creates sysfs entries, which enable users to access to NVRAM,
in a write callback. If a kernel panic happens in an interrupt context,
it may fail because it could sleep due to dynamic memory allocations during
creating sysfs entries.
[Patch Description]
This patch removes sysfs operations from a write callback by introducing
a workqueue updating sysfs entries which is scheduled after the write
callback is called.
Also, the workqueue is kicked in a just oops case.
A system will go down in other cases such as panic, clean shutdown and emergency
restart. And we don't need to create sysfs entries because there is no chance for
users to access to them.
efi_pstore will be robust against a kernel panic in an interrupt context with this patch.
Signed-off-by: Tony Luck <tony.luck@intel.com>
Originally 'efi_enabled' indicated whether a kernel was booted from
EFI firmware. Over time its semantics have changed, and it now
indicates whether or not we are booted on an EFI machine with
bit-native firmware, e.g. 64-bit kernel with 64-bit firmware.
The immediate motivation for this patch is the bug report at,
https://bugs.launchpad.net/ubuntu-cdimage/+bug/1040557
which details how running a platform driver on an EFI machine that is
designed to run under BIOS can cause the machine to become
bricked. Also, the following report,
https://bugzilla.kernel.org/show_bug.cgi?id=47121
details how running said driver can also cause Machine Check
Exceptions. Drivers need a new means of detecting whether they're
running on an EFI machine, as sadly the expression,
if (!efi_enabled)
hasn't been a sufficient condition for quite some time.
Users actually want to query 'efi_enabled' for different reasons -
what they really want access to is the list of available EFI
facilities.
For instance, the x86 reboot code needs to know whether it can invoke
the ResetSystem() function provided by the EFI runtime services, while
the ACPI OSL code wants to know whether the EFI config tables were
mapped successfully. There are also checks in some of the platform
driver code to simply see if they're running on an EFI machine (which
would make it a bad idea to do BIOS-y things).
This patch is a prereq for the samsung-laptop fix patch.
Cc: David Airlie <airlied@linux.ie>
Cc: Corentin Chary <corentincj@iksaif.net>
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Olof Johansson <olof@lixom.net>
Cc: Peter Jones <pjones@redhat.com>
Cc: Colin Ian King <colin.king@canonical.com>
Cc: Steve Langasek <steve.langasek@canonical.com>
Cc: Konrad Rzeszutek Wilk <konrad@kernel.org>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: <stable@vger.kernel.org>
This reverts commit bd52276fa1d4 ("x86-64/efi: Use EFI to deal with
platform wall clock (again)"), and the two supporting commits:
da5a108d05b4: "x86/kernel: remove tboot 1:1 page table creation code"
185034e72d59: "x86, efi: 1:1 pagetable mapping for virtual EFI calls")
as they all depend semantically on commit 53b87cf088e2 ("x86, mm:
Include the entire kernel memory map in trampoline_pgd") that got
reverted earlier due to the problems it caused.
This was pointed out by Yinghai Lu, and verified by me on my Macbook Air
that uses EFI.
Pointed-out-by: Yinghai Lu <yinghai@kernel.org>
