path: root/include/linux/dst.h
2009-12-23Staging: dst: remove from the treeGreg Kroah-Hartman
DST is dead, no one is using it and upstream has abandoned it, so remove it from the tree because it is not going anywhere. Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-03Staging: dst: core files.Evgeniy Polyakov
This patch contains DST core files, which introduce block layer, connector and sysfs registration glue and main headers. Connector is used for the configuration of the node (its type, address, device name and so on). Sysfs provides bits of information about running devices in the following format: +/* + * DST sysfs tree for device called 'storage': + * + * /sys/bus/dst/devices/storage/ + * /sys/bus/dst/devices/storage/type : 192.168.4.80:1025 + * /sys/bus/dst/devices/storage/size : 800 + * /sys/bus/dst/devices/storage/name : storage + */ DST header contains structure definitions and protocol command description. Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
