Add support for allocating root device objects which group
device objects under /sys/devices directories.
Also add a sysfs 'module' symlink which points to the owner
of the root device object. This symlink will be used in virtio
to allow userspace to determine which virtio bus implementation
a given device is associated with.
[Includes suggestions from Cornelia Huck]
Signed-off-by: Mark McLoughlin <markmc@redhat.com>
Statically defined DEBUG should take precedence over
dynamically enabled debugging; otherwise adding DEBUG
(like, for example, via CONFIG_DEBUG_KOBJECT) does not
have the expected result of printing pr_debug() and dev_dbg()
messages unconditionally.
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Acked-by: Jason Baron <jbaron@redhat.com>
Nothing outside of the driver core should ever touch knode_bus, so
move it out of the public eye.
Cc: Kay Sievers <kay.sievers@vrfy.org>
Nothing outside of the driver core should ever touch knode_driver, so
Nothing outside of the driver core should ever touch klist_children, or
knode_parent, so move them out of the public eye.
This is to be used to move things out of struct device that no code
outside of the driver core should ever touch.
This minor rearrangement saves 16 bytes from sizeof(struct device)
according to pahole.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
PM: Simplify the new suspend/hibernation framework for devices
Following the discussion at the Kernel Summit, simplify the new
device PM framework by merging 'struct pm_ops' and
'struct pm_ext_ops' and removing pointers to 'struct pm_ext_ops'
from 'struct platform_driver' and 'struct pci_driver'.
After this change, the suspend/hibernation callbacks will only
reside in 'struct device_driver' as well as at the bus type/
device class/device type level. Accordingly, PCI and platform
device drivers are now expected to put their suspend/hibernation
callbacks into the 'struct device_driver' embedded in
'struct pci_driver' or 'struct platform_driver', respectively.
Acked-by: Pavel Machek <pavel@suse.cz>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
i2c_get_clientdata doesn't change the i2c_client it is passed as a
parameter, so it can be constified. Same for i2c_get_adapdata.
The PCI core wants to reorder the devices in the bus list. So move this
functionality out of the pci core and into the driver core so that
anyone else can also do this if needed. This also lets us change how
struct device is attached to drivers in the future without messing with
the PCI core.
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
in the line of dev_printk(), this patch introduces a dev_WARN() function,
that takes a struct device and then a printk format/args set of arguments.
Unlike dev_printk(), the effect is that of WARN() in that a full warning
message (including filename/line, module list, versions and a backtrace)
is printed in addition to the device name and the arguments.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Base infrastructure to enable per-module debug messages.
I've introduced CONFIG_DYNAMIC_PRINTK_DEBUG, which when enabled centralizes
control of debugging statements on a per-module basis in one /proc file,
currently, <debugfs>/dynamic_printk/modules. When, CONFIG_DYNAMIC_PRINTK_DEBUG,
is not set, debugging statements can still be enabled as before, often by
defining 'DEBUG' for the proper compilation unit. Thus, this patch set has no
affect when CONFIG_DYNAMIC_PRINTK_DEBUG is not set.
The infrastructure currently ties into all pr_debug() and dev_dbg() calls. That
is, if CONFIG_DYNAMIC_PRINTK_DEBUG is set, all pr_debug() and dev_dbg() calls
can be dynamically enabled/disabled on a per-module basis.
Future plans include extending this functionality to subsystems, that define
their own debug levels and flags.
Usage:
Dynamic debugging is controlled by the debugfs file,
<debugfs>/dynamic_printk/modules. This file contains a list of the modules that
can be enabled. The format of the file is as follows:
<module_name> <enabled=0/1>
<module_name> : Name of the module in which the debug call resides
<enabled=0/1> : whether the messages are enabled or not
For example:
snd_hda_intel enabled=0
fixup enabled=1
driver enabled=0
Enable a module:
$echo "set enabled=1 <module_name>" > dynamic_printk/modules
Disable a module:
$echo "set enabled=0 <module_name>" > dynamic_printk/modules
Enable all modules:
$echo "set enabled=1 all" > dynamic_printk/modules
Disable all modules:
$echo "set enabled=0 all" > dynamic_printk/modules
Finally, passing "dynamic_printk" at the command line enables
debugging for all modules. This mode can be turned off via the above
disable command.
[gkh: minor cleanups and tweaks to make the build work quietly]
Signed-off-by: Jason Baron <jbaron@redhat.com>
Now that the tree is cleaned up, device_create_drvdata can be safely
removed.
Iterating over entries using callback usually isn't too fun especially
when the entry being iterated over can't be manipulated freely. This
patch converts class->p->class_devices to klist and implements class
device iterator so that the users can freely build their own control
structure. The users are also free to call back into class code
without worrying about locking.
class_for_each_device() and class_find_device() are converted to use
the new iterators, so their users don't have to worry about locking
anymore either.
Note: This depends on klist-dont-iterate-over-deleted-entries patch
because class_intf->add/remove_dev() depends on proper synchronization
with device removal.
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Jens Axboe <jens.axboe@oracle.com>
This gives us a way to handle both the bus_id and init_name values being
used for a while during the transition period.
Add const markings to dev_name and dev_driver_string to make it clear that
dev_printk doesn't modify dev. This is a prerequisite to adding more
const markings to other functions make it clearer, which functions can
modify dev and which can't.
There is no such thing as a "device id size" in the driver core, so
remove the define and fix up any users of this odd define in the rest of
the kernel.
There is no such thing as a "device name size" in the driver core, so
the kernel.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Kobjects do not have a limit in name size since a while, so stop
pretending that they do.
This adds the infrastructure to properly handle lockdep issues when the
internal class semaphore is changed to a mutex.
Matthew wrote the original patch, and Greg fixed it up to work properly
with the class_create() function.
Cc: Dave Young <hidave.darkstar@gmail.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
This moves the portions of struct class that are dynamic (kobject and
lock and lists) out of the main structure and into a dynamic, private,
structure.
This mirrors the functionality that driver_find_device has as well.
We add a start variable, and all callers of the function are fixed up at
the same time.
The block layer will be using this new functionality in a follow-on
patch.
This mirrors the functionality that driver_for_each_device has as well.
the same time.
patch.
Now that device_create() has been audited, rename things back to the
original call to be sane.
Keep the device_create_drvdata macro around to make merges easier.
There are no more users of this, and it is racy. Use
device_create_drvdata() or device_create_vargs() instead.
Why?:
There are occasions where userspace would like to access sysfs
attributes for a device but it may not know how sysfs has named the
device or the path. For example what is the sysfs path for
/dev/disk/by-id/ata-ST3160827AS_5MT004CK? With this change a call to
stat(2) returns the major:minor then userspace can see that
/sys/dev/block/8:32 links to /sys/block/sdc.
What are the alternatives?:
1/ Add an ioctl to return the path: Doable, but sysfs is meant to reduce
the need to proliferate ioctl interfaces into the kernel, so this
seems counter productive.
2/ Use udev to create these symlinks: Also doable, but it adds a
udev dependency to utilities that might be running in a limited
environment like an initramfs.
3/ Do a full-tree search of sysfs.
[kay.sievers@vrfy.org: fix duplicate registrations]
[kay.sievers@vrfy.org: cleanup suggestions]
Cc: Neil Brown <neilb@suse.de>
Cc: Tejun Heo <htejun@gmail.com>
Acked-by: Kay Sievers <kay.sievers@vrfy.org>
Reviewed-by: SL Baur <steve@xemacs.org>
Acked-by: Mark Lord <lkml@rtr.ca>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Introduce 'struct pm_ops' and 'struct pm_ext_ops' ('ext' meaning
'extended') representing suspend and hibernation operations for bus
types, device classes, device types and device drivers.
Modify the PM core to use 'struct pm_ops' and 'struct pm_ext_ops'
objects, if defined, instead of the ->suspend(), ->resume(),
->suspend_late(), and ->resume_early() callbacks (the old callbacks
will be considered as legacy and gradually phased out).
The main purpose of doing this is to separate suspend (aka S2RAM and
standby) callbacks from hibernation callbacks in such a way that the
new callbacks won't take arguments and the semantics of each of them
will be clearly specified. This has been requested for multiple
times by many people, including Linus himself, and the reason is that
within the current scheme if ->resume() is called, for example, it's
difficult to say why it's been called (ie. is it a resume from RAM or
from hibernation or a suspend/hibernation failure etc.?).
The second purpose is to make the suspend/hibernation callbacks more
flexible so that device drivers can handle more than they can within
the current scheme. For example, some drivers may need to prevent
new children of the device from being registered before their
->suspend() callbacks are executed or they may want to carry out some
operations requiring the availability of some other devices, not
directly bound via the parent-child relationship, in order to prepare
for the execution of ->suspend(), etc.
Ultimately, we'd like to stop using the freezing of tasks for suspend
and therefore the drivers' suspend/hibernation code will have to take
care of the handling of the user space during suspend/hibernation.
That, in turn, would be difficult within the current scheme, without
the new ->prepare() and ->complete() callbacks.
Acked-by: Pavel Machek <pavel@ucw.cz>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Create the dev_set_name function now so that various subsystems can
start changing over to it before other changes in 2.6.27 will make it
compulsory.
We want to have the drvdata field set properly when creating the device
as sysfs callbacks can assume it is present and it can race the later
setting of this field.
So, create two new functions, deviec_create_vargs() and
device_create_drvdata() that take this new field.
device_create_drvdata() will go away in 2.6.27 as the drvdata field will
just be moved to the device_create() call as it should be.
because of the class_device was removed, now do the children list removing
Signed-off-by: Dave Young <hidave.darkstar@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6: (36 commits)
SCSI: convert struct class_device to struct device
DRM: remove unused dev_class
IB: rename "dev" to "srp_dev" in srp_host structure
IB: convert struct class_device to struct device
memstick: convert struct class_device to struct device
driver core: replace remaining __FUNCTION__ occurrences
sysfs: refill attribute buffer when reading from offset 0
PM: Remove destroy_suspended_device()
Firmware: add iSCSI iBFT Support
PM: Remove legacy PM (fix)
Kobject: Replace list_for_each() with list_for_each_entry().
SYSFS: Explicitly include required header file slab.h.
Driver core: make device_is_registered() work for class devices
PM: Convert wakeup flag accessors to inline functions
PM: Make wakeup flags available whenever CONFIG_PM is set
PM: Fix misuse of wakeup flag accessors in serial core
Driver core: Call device_pm_add() after bus_add_device() in device_add()
PM: Handle device registrations during suspend/resume
block: send disk "change" event for rescan_partitions()
sysdev: detect multiple driver registrations
Fixed trivial conflict in include/linux/memory.h due to semaphore header
file change (made irrelevant by the change to mutex).
After 2.6.24 there was a plan to make the PM core acquire all device
semaphores during a suspend/hibernation to protect itself from
concurrent operations involving device objects. That proved to be
too heavy-handed and we found a better way to achieve the goal, but
before it happened, we had introduced the functions
device_pm_schedule_removal() and destroy_suspended_device() to allow
drivers to "safely" destroy a suspended device and we had adapted some
drivers to use them. Now that these functions are no longer necessary,
it seems reasonable to remove them and modify their users to use the
normal device unregistration instead.
device_is_registered() can use the kobject value for this, so it will
now work with devices that are associated with only a class, not a bus
and a driver.
This patch (as1058) improves the wakeup macros in include/linux/pm.h.
All but the trivial ones are converted to inline routines, which
requires moving them to a separate header file since they depend on
the definition of struct device.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
(printf,x,y) to statement expression macros
When DEBUG is not defined, pr_debug and dev_dbg and some
other local debugging functions are specified as:
"inline __attribute__((format (printf, x, y)))"
This is done to validate printk arguments when not debugging.
Converting these functions to macros or statement expressions
"do { if (0) printk(fmt, ##arg); } while (0)"
or
"({ if (0) printk(fmt, ##arg); 0; })
makes at least gcc 4.2.2 produce smaller objects.
This has the additional benefit of allowing the optimizer to
avoid calling functions like print_mac that might have been
arguments to the printk.
defconfig x86 current:
$ size vmlinux
4716770 474560 618496 5809826 58a6a2 vmlinux
all converted: (More patches follow)
$ size vmlinux
4716642 474560 618496 5809698 58a622 vmlinux
Even kernel/sched.o, which doesn't even use these
functions, becomes smaller.
It appears that merely having an indirect include
of <linux/device.h> can cause bigger objects.
$ size sched.inline.o sched.if0.o
31385 2854 328 34567 8707 sched.inline.o
31366 2854 328 34548 86f4 sched.if0.o
The current preprocessed only kernel/sched.i file contains:
# 612 "include/linux/device.h"
static inline __attribute__((always_inline)) int __attribute__ ((format (printf, 2, 3)))
dev_dbg(struct device *dev, const char *fmt, ...)
return 0;
# 628 "include/linux/device.h"
dev_vdbg(struct device *dev, const char *fmt, ...)
return 0;
Removing these unused inlines from sched.i shrinks sched.o
IOMMUs merges scatter/gather segments without considering a low level
driver's restrictions. The problem is that IOMMUs can't access to the
limitations because they are in request_queue.
This patchset introduces a new structure, device_dma_parameters,
including dma information. A pointer to device_dma_parameters is added
to struct device. The bus specific structures (like pci_dev) includes
device_dma_parameters. Low level drivers can use dma_set_max_seg_size
to tell IOMMUs about the restrictions.
We can move more dma stuff in struct device (like dma_mask) to struct
device_dma_parameters later (needs some cleanups before that).
This includes patches for all the IOMMUs that could merge sg (x86_64,
ppc, IA64, alpha, sparc64, and parisc) though only the ppc patch was
tested. The patches for other IOMMUs are only compile tested.
This patch:
Add a new structure, device_dma_parameters, including dma information. A
pointer to device_dma_parameters is added to struct device.
- there are only max_segment_size and segment_boundary_mask there but we'll
device_dma_parameters later. segment_boundary_mask is not supported yet.
- new accessors for the dma parameters are added. So we can easily change
where to place struct device_dma_parameters in the future.
- dma_get_max_seg_size returns 64K if dma_parms in struct device isn't set
up properly. 64K is the default max_segment_size in the block layer.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Acked-by: Jeff Garzik <jeff@garzik.org>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Acked-by: Jens Axboe <jens.axboe@oracle.com>
Move the declaration of device_pm_schedule_removal() to device.h
and make it exported, as it will be used directly by some drivers
for unregistering device objects during suspend/resume cycles in a
safe way.
The driver core, and some other parts of the kernel just want to find a
device based on a name for a specific bus. Give them a simple wrapper
to prevent them from having to always roll their own.
This will be used in the PPC patch later in this series.
Finally clean up the odd spaces and other mess in device.h
Add the following class iteration functions for driver use:
class_find_device
class_for_each_child
class_find_child
Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com>
This patch removes the kobject, and a few other driver-core-only fields
out of struct driver and into the driver core only. Now drivers can be
safely create on the stack or statically (like they currently are.)
The iseries driver wants to hang kobjects off of its driver, so, to
preserve backwards compatibility, we need to add a call to the driver
core to allow future changes to work properly.
Hopefully no one uses this function in the future and the iseries_veth
driver authors come to their senses so I can remove this hack...
Cc: Dave Larson <larson1@us.ibm.com>
Cc: Santiago Leon <santil@us.ibm.com>
This is lot like default attributes for devices (and indeed,
a lot of the code is lifted from there).
struct bus_type is static everywhere in the kernel. This moves the
kobject in the structure out of it, and a bunch of other private only to
the driver core fields are now moved to a private structure. This lets
us dynamically create the backing kobject properly and gives us the
chance to be able to document to users exactly how to use the struct
bus_type as there are no fields they can improperly access.
Thanks to Kay for the build fixes on this patch.
This allows an easier way to get to the device klist associated with a
struct bus_type (you have three to choose from...) This will make it
easier to move these fields to be dynamic in a future patch.
The only user of this is the PCI core which horribly abuses this
interface to rearrange the order of the pci devices. This should be
done using the existing bus device walking functions, but that's left
for future patches.
This allows an easier way to get to the kset associated with a struct
bus_type (you have three to choose from...) This will make it easier to
This isn't used by anything in the driver core, and by no one in the 204
different usages of it in the kernel tree. Remove this field so no one
gets any idea that it is needed to be used.
