path: root/include/linux/device-mapper.h
2013-09-20dm mpath: disable WRITE SAME if it failsMike Snitzer
Workaround the SCSI layer's problematic WRITE SAME heuristics by disabling WRITE SAME in the DM multipath device's queue_limits if an underlying device disabled it. The WRITE SAME heuristics, with both the original commit 5db44863b6eb ("[SCSI] sd: Implement support for WRITE SAME") and the updated commit 66c28f971 ("[SCSI] sd: Update WRITE SAME heuristics"), default to enabling WRITE SAME(10) even without successfully determining it is supported. After the first failed WRITE SAME the SCSI layer will disable WRITE SAME for the device (by setting sdkp->device->no_write_same which results in 'max_write_same_sectors' in device's queue_limits to be set to 0). When a device is stacked ontop of such a SCSI device any changes to that SCSI device's queue_limits do not automatically propagate up the stack. As such, a DM multipath device will not have its WRITE SAME support disabled. This causes the block layer to continue to issue WRITE SAME requests to the mpath device which causes paths to fail and (if mpath IO isn't configured to queue when no paths are available) it will result in actual IO errors to the upper layers. This fix doesn't help configurations that have additional devices stacked ontop of the mpath device (e.g. LVM created linear DM devices ontop). A proper fix that restacks all the queue_limits from the bottom of the device stack up will need to be explored if SCSI will continue to use this model of optimistically allowing op codes and then disabling them after they fail for the first time. Before this patch: EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null) device-mapper: multipath: XXX snitm debugging: got -EREMOTEIO (-121) device-mapper: multipath: XXX snitm debugging: failing WRITE SAME IO with error=-121 end_request: critical target error, dev dm-6, sector 528 dm-6: WRITE SAME failed. Manually zeroing. device-mapper: multipath: Failing path 8:112. end_request: I/O error, dev dm-6, sector 4616 dm-6: WRITE SAME failed. Manually zeroing. end_request: I/O error, dev dm-6, sector 4616 end_request: I/O error, dev dm-6, sector 5640 end_request: I/O error, dev dm-6, sector 6664 end_request: I/O error, dev dm-6, sector 7688 end_request: I/O error, dev dm-6, sector 524288 Buffer I/O error on device dm-6, logical block 65536 lost page write due to I/O error on dm-6 JBD2: Error -5 detected when updating journal superblock for dm-6-8. end_request: I/O error, dev dm-6, sector 524296 Aborting journal on device dm-6-8. end_request: I/O error, dev dm-6, sector 524288 Buffer I/O error on device dm-6, logical block 65536 lost page write due to I/O error on dm-6 JBD2: Error -5 detected when updating journal superblock for dm-6-8. # cat /sys/block/sdh/queue/write_same_max_bytes 0 # cat /sys/block/dm-6/queue/write_same_max_bytes 33553920 After this patch: EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null) device-mapper: multipath: XXX snitm debugging: got -EREMOTEIO (-121) device-mapper: multipath: XXX snitm debugging: WRITE SAME I/O failed with error=-121 end_request: critical target error, dev dm-6, sector 528 dm-6: WRITE SAME failed. Manually zeroing. # cat /sys/block/sdh/queue/write_same_max_bytes 0 # cat /sys/block/dm-6/queue/write_same_max_bytes 0 It should be noted that WRITE SAME support wasn't enabled in DM multipath until v3.10. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Cc: Martin K. Petersen <martin.petersen@oracle.com> Cc: Hannes Reinecke <hare@suse.de> Cc: stable@vger.kernel.org # 3.10+
2013-09-05dm: add statistics supportMikulas Patocka
Support the collection of I/O statistics on user-defined regions of a DM device. If no regions are defined no statistics are collected so there isn't any performance impact. Only bio-based DM devices are currently supported. Each user-defined region specifies a starting sector, length and step. Individual statistics will be collected for each step-sized area within the range specified. The I/O statistics counters for each step-sized area of a region are in the same format as /sys/block/*/stat or /proc/diskstats but extra counters (12 and 13) are provided: total time spent reading and writing in milliseconds. All these counters may be accessed by sending the @stats_print message to the appropriate DM device via dmsetup. The creation of DM statistics will allocate memory via kmalloc or fallback to using vmalloc space. At most, 1/4 of the overall system memory may be allocated by DM statistics. The admin can see how much memory is used by reading /sys/module/dm_mod/parameters/stats_current_allocated_bytes See Documentation/device-mapper/statistics.txt for more details. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2013-07-10dm: optimize use SRCU and RCUMikulas Patocka
This patch removes "io_lock" and "map_lock" in struct mapped_device and "holders" in struct dm_table and replaces these mechanisms with sleepable-rcu. Previously, the code would call "dm_get_live_table" and "dm_table_put" to get and release table. Now, the code is changed to call "dm_get_live_table" and "dm_put_live_table". dm_get_live_table locks sleepable-rcu and dm_put_live_table unlocks it. dm_get_live_table_fast/dm_put_live_table_fast can be used instead of dm_get_live_table/dm_put_live_table. These *_fast functions use non-sleepable RCU, so the caller must not block between them. If the code changes active or inactive dm table, it must call dm_sync_table before destroying the old table. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2013-05-10dm: document iterate_devicesAlasdair G Kergon
Document iterate_devices in device-mapper.h. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2013-03-01dm: add target num_write_bios fnAlasdair G Kergon
Add a num_write_bios function to struct target. If an instance of a target sets this, it will be queried before the target's mapping function is called on a write bio, and the response controls the number of copies of the write bio that the target will receive. This provides a convenient way for a target to send the same data to more than one device. The new cache target uses this in writethrough mode, to send the data both to the cache and the backing device. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2013-03-01dm: rename request variables to biosAlasdair G Kergon
Use 'bio' in the name of variables and functions that deal with bios rather than 'request' to avoid confusion with the normal block layer use of 'request'. No functional changes. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2013-03-01dm: fix truncated status stringsMikulas Patocka
Avoid returning a truncated table or status string instead of setting the DM_BUFFER_FULL_FLAG when the last target of a table fills the buffer. When processing a table or status request, the function retrieve_status calls ti->type->status. If ti->type->status returns non-zero, retrieve_status assumes that the buffer overflowed and sets DM_BUFFER_FULL_FLAG. However, targets don't return non-zero values from their status method on overflow. Most targets returns always zero. If a buffer overflow happens in a target that is not the last in the table, it gets noticed during the next iteration of the loop in retrieve_status; but if a buffer overflow happens in the last target, it goes unnoticed and erroneously truncated data is returned. In the current code, the targets behave in the following way: * dm-crypt returns -ENOMEM if there is not enough space to store the key, but it returns 0 on all other overflows. * dm-thin returns errors from the status method if a disk error happened. This is incorrect because retrieve_status doesn't check the error code, it assumes that all non-zero values mean buffer overflow. * all the other targets always return 0. This patch changes the ti->type->status function to return void (because most targets don't use the return code). Overflow is detected in retrieve_status: if the status method fills up the remaining space completely, it is assumed that buffer overflow happened. Cc: stable@vger.kernel.org Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-12-21dm: remove map_infoMikulas Patocka
This patch removes map_info from bio-based device mapper targets. map_info is still used for request-based targets. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-12-21dm: move target request nr to dm_target_ioMikulas Patocka
This patch moves target_request_nr from map_info to dm_target_io and makes it accessible with dm_bio_get_target_request_nr. This patch is a preparation for the next patch that removes map_info. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-12-21dm: introduce per_bio_dataMikulas Patocka
Introduce a field per_bio_data_size in struct dm_target. Targets can set this field in the constructor. If a target sets this field to a non-zero value, "per_bio_data_size" bytes of auxiliary data are allocated for each bio submitted to the target. These data can be used for any purpose by the target and help us improve performance by removing some per-target mempools. Per-bio data is accessed with dm_per_bio_data. The argument data_size must be the same as the value per_bio_data_size in dm_target. If the target has a pointer to per_bio_data, it can get a pointer to the bio with dm_bio_from_per_bio_data() function (data_size must be the same as the value passed to dm_per_bio_data). Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-12-21dm: prepare to support WRITE SAMEMike Snitzer
Allow targets to opt in to WRITE SAME support by setting 'num_write_same_requests' in the dm_target structure. A dm device will only advertise WRITE SAME support if all its targets and all its underlying devices support it. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-07-27dm thin: commit before gathering statusAlasdair G Kergon
Commit outstanding metadata before returning the status for a dm thin pool so that the numbers reported are as up-to-date as possible. The commit is not performed if the device is suspended or if the DM_NOFLUSH_FLAG is supplied by userspace and passed to the target through a new 'status_flags' parameter in the target's dm_status_fn. The userspace dmsetup tool will support the --noflush flag with the 'dmsetup status' and 'dmsetup wait' commands from version 1.02.76 onwards. Tested-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-07-27dm: use bool bitfields in struct dm_targetAlasdair G Kergon
Use boolean bit fields for flags in struct dm_target. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-07-27dm: allow targets to request flushes regardless of underlying device supportJoe Thornber
Allow targets to override the 'supports flush' calculation. Set 'flush_supported' if a target needs to receive flushes regardless of whether or not its underlying devices have support. Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-07-27dm: introduce split_discard_requestsMikulas Patocka
This patch introduces a new variable split_discard_requests. It can be set by targets so that discard requests are split on max_io_len boundaries. When split_discard_requests is not set, discard requests are only split on boundaries between targets, as was the case before this patch. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-07-27dm: support non power of two target max_io_lenMike Snitzer
Remove the restriction that limits a target's specified maximum incoming I/O size to be a power of 2. Rename this setting from 'split_io' to the less-ambiguous 'max_io_len'. Change it from sector_t to uint32_t, which is plenty big enough, and introduce a wrapper function dm_set_target_max_io_len() to set it. Use sector_div() to process it now that it is not necessarily a power of 2. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2012-07-27dm: remove unused flush target methodJoe Thornber
Remove unused dm_flush_fn .flush target method from header. This was left-over from the FLUSH/FUA conversion and is no longer used. Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-10-31dm table: add immutable featureAlasdair G Kergon
Introduce DM_TARGET_IMMUTABLE to indicate that the target type cannot be mixed with any other target type, and once loaded into a device, it cannot be replaced with a table containing a different type. The thin provisioning pool device will use this. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-10-31dm table: add always writeable featureAlasdair G Kergon
Add a target feature flag DM_TARGET_ALWAYS_WRITEABLE to indicate that a target does not support read-only mode. The initial implementation of the thin provisioning target uses this. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-10-31dm table: add singleton featureAlasdair G Kergon
Introduce the concept of a singleton table which contains exactly one target. If a target type sets the DM_TARGET_SINGLETON feature bit device-mapper will ensure that any table that includes that target contains no others. The thin provisioning pool target uses this. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-10-31dm: use local printk ratelimitNamhyung Kim
printk_ratelimit() shares global ratelimiting state with all other subsystems, so its usage is discouraged. Instead, define and use dm's local state. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-09-25dm crypt: always disable discard_zeroes_dataMilan Broz
If optional discard support in dm-crypt is enabled, discards requests bypass the crypt queue and blocks of the underlying device are discarded. For the read path, discarded blocks are handled the same as normal ciphertext blocks, thus decrypted. So if the underlying device announces discarded regions return zeroes, dm-crypt must disable this flag because after decryption there is just random noise instead of zeroes. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-08-02dm table: share target argument parsing functionsMike Snitzer
Move multipath target argument parsing code into dm-table so other targets can share it. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-05-29dm table: allow targets to support discards internallyMike Snitzer
Permit a target to support discards regardless of whether or not all its underlying devices do. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-04-18md/dm - remove remains of plug_fn callback.NeilBrown
Now that unplugging is done differently, the unplug_fn callback is never called, so it can be completely discarded. Signed-off-by: NeilBrown <neilb@suse.de>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-13dm: per target unplug callback supportNeilBrown
Add per-target unplug callback support. Cc: linux-raid@vger.kernel.org Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-01-13dm: introduce target callbacks and congestion callbackNeilBrown
DM currently implements congestion checking by checking on congestion in each component device. For raid456 we need to also check if the stripe cache is congested. Add per-target congestion checker callback support. Extending the target_callbacks structure with additional callback functions allows for establishing multiple callbacks per-target (a callback is also needed for unplug). Cc: linux-raid@vger.kernel.org Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-08-12dm: factor out max_io_len_target_boundaryMike Snitzer
Split max_io_len_target_boundary out of max_io_len so that the discard support can make use of it without duplicating max_io_len code. Avoiding max_io_len's split_io logic enables DM's discard support to submit the entire discard request to a target. But discards must still be split on target boundaries. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-08-12dm: linear support discardMike Snitzer
Allow discards to be passed through to linear mappings if at least one underlying device supports it. Discards will be forwarded only to devices that support them. A target that supports discards should set num_discard_requests to indicate how many times each discard request must be submitted to it. Verify table's underlying devices support discards prior to setting the associated DM device as capable of discards (via QUEUE_FLAG_DISCARD). Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Reviewed-by: Joe Thornber <thornber@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-08-12dm: rename map_info flush_request to target_request_nrMike Snitzer
'target_request_nr' is a more generic name that reflects the fact that it will be used for both flush and discard support. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-03-06dm table: remove unused dm_get_device range parametersNikanth Karthikesan
Remove unused parameters(start and len) of dm_get_device() and fix the callers. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm: export suspended state to targetsKiyoshi Ueda
This patch adds the exported dm_suspended() function so that targets can check whether or not they are suspended. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Cc: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm: rename dm_suspended to dm_suspended_mdKiyoshi Ueda
This patch renames dm_suspended() to dm_suspended_md() and keeps it internal to dm. No functional change. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Cc: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm: keep old table until after resume succeededAlasdair G Kergon
When swapping a new table into place, retain the old table until its replacement is in place. An old check for an empty table is removed because this is enforced in populate_table(). __unbind() becomes redundant when followed by __bind(). Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm: rename dm_get_table to dm_get_live_tableAlasdair G Kergon
Rename dm_get_table to dm_get_live_table. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-09-04dm stripe: expose correct io hintsMike Snitzer
Set sensible I/O hints for striped DM devices in the topology infrastructure added for 2.6.31 for userspace tools to obtain via sysfs. Add .io_hints to 'struct target_type' to allow the I/O hints portion (io_min and io_opt) of the 'struct queue_limits' to be set by each target and implement this for dm-stripe. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-07-23dm table: pass correct dev area size to device_area_is_validMike Snitzer
Incorrect device area lengths are being passed to device_area_is_valid(). The regression appeared in 2.6.31-rc1 through commit 754c5fc7ebb417b23601a6222a6005cc2e7f2913. With the dm-stripe target, the size of the target (ti->len) was used instead of the stripe_width (ti->len/#stripes). An example of a consequent incorrect error message is: device-mapper: table: 254:0: sdb too small for target Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-06-22dm: prepare for request based optionKiyoshi Ueda
This patch adds core functions for request-based dm. When struct mapped device (md) is initialized, md->queue has an I/O scheduler and the following functions are used for request-based dm as the queue functions: make_request_fn: dm_make_request() pref_fn: dm_prep_fn() request_fn: dm_request_fn() softirq_done_fn: dm_softirq_done() lld_busy_fn: dm_lld_busy() Actual initializations are done in another patch (PATCH 2). Below is a brief summary of how request-based dm behaves, including: - making request from bio - cloning, mapping and dispatching request - completing request and bio - suspending md - resuming md bio to request ============== md->queue->make_request_fn() (dm_make_request()) calls __make_request() for a bio submitted to the md. Then, the bio is kept in the queue as a new request or merged into another request in the queue if possible. Cloning and Mapping =================== Cloning and mapping are done in md->queue->request_fn() (dm_request_fn()), when requests are dispatched after they are sorted by the I/O scheduler. dm_request_fn() checks busy state of underlying devices using target's busy() function and stops dispatching requests to keep them on the dm device's queue if busy. It helps better I/O merging, since no merge is done for a request once it is dispatched to underlying devices. Actual cloning and mapping are done in dm_prep_fn() and map_request() called from dm_request_fn(). dm_prep_fn() clones not only request but also bios of the request so that dm can hold bio completion in error cases and prevent the bio submitter from noticing the error. (See the "Completion" section below for details.) After the cloning, the clone is mapped by target's map_rq() function and inserted to underlying device's queue using blk_insert_cloned_request(). Completion ========== Request completion can be hooked by rq->end_io(), but then, all bios in the request will have been completed even error cases, and the bio submitter will have noticed the error. To prevent the bio completion in error cases, request-based dm clones both bio and request and hooks both bio->bi_end_io() and rq->end_io(): bio->bi_end_io(): end_clone_bio() rq->end_io(): end_clone_request() Summary of the request completion flow is below: blk_end_request() for a clone request => blk_update_request() => bio->bi_end_io() == end_clone_bio() for each clone bio => Free the clone bio => Success: Complete the original bio (blk_update_request()) Error: Don't complete the original bio => blk_finish_request() => rq->end_io() == end_clone_request() => blk_complete_request() => dm_softirq_done() => Free the clone request => Success: Complete the original request (blk_end_request()) Error: Requeue the original request end_clone_bio() completes the original request on the size of the original bio in successful cases. Even if all bios in the original request are completed by that completion, the original request must not be completed yet to keep the ordering of request completion for the stacking. So end_clone_bio() uses blk_update_request() instead of blk_end_request(). In error cases, end_clone_bio() doesn't complete the original bio. It just frees the cloned bio and gives over the error handling to end_clone_request(). end_clone_request(), which is called with queue lock held, completes the clone request and the original request in a softirq context (dm_softirq_done()), which has no queue lock, to avoid a deadlock issue on submission of another request during the completion: - The submitted request may be mapped to the same device - Request submission requires queue lock, but the queue lock has been held by itself and it doesn't know that The clone request has no clone bio when dm_softirq_done() is called. So target drivers can't resubmit it again even error cases. Instead, they can ask dm core for requeueing and remapping the original request in that cases. suspend ======= Request-based dm uses stopping md->queue as suspend of the md. For noflush suspend, just stops md->queue. For flush suspend, inserts a marker request to the tail of md->queue. And dispatches all requests in md->queue until the marker comes to the front of md->queue. Then, stops dispatching request and waits for the all dispatched requests to complete. After that, completes the marker request, stops md->queue and wake up the waiter on the suspend queue, md->wait. resume ====== Starts md->queue. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-06-22dm: calculate queue limits during resume not loadMike Snitzer
Currently, device-mapper maintains a separate instance of 'struct queue_limits' for each table of each device. When the configuration of a device is to be changed, first its table is loaded and this structure is populated, then the device is 'resumed' and the calculated queue_limits are applied. This places restrictions on how userspace may process related devices, where it is often advantageous to 'load' tables for several devices at once before 'resuming' them together. As the new queue_limits only take effect after the 'resume', if they are changing and one device uses another, the latter must be 'resumed' before the former may be 'loaded'. This patch moves the calculation of these queue_limits out of the 'load' operation into 'resume'. Since we are no longer pre-calculating this struct, we no longer need to maintain copies within our dm structs. dm_set_device_limits() now passes the 'start' of the device's data area (aka pe_start) as the 'offset' to blk_stack_limits(). init_valid_queue_limits() is replaced by blk_set_default_limits(). Signed-off-by: Mike Snitzer <snitzer@redhat.com> Cc: martin.petersen@oracle.com Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-06-22dm target:s introduce iterate devices fnMike Snitzer
Add .iterate_devices to 'struct target_type' to allow a function to be called for all devices in a DM target. Implemented it for all targets except those in dm-snap.c (origin and snapshot). (The raid1 version number jumps to 1.12 because we originally reserved 1.1 to 1.11 for 'block_on_error' but ended up using 'handle_errors' instead.) Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: martin.petersen@oracle.com
2009-06-22dm table: replace struct io_restrictions with struct queue_limitsMike Snitzer
Use blk_stack_limits() to stack block limits (including topology) rather than duplicate the equivalent within Device Mapper. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-06-22dm: introduce num_flush_requestsMikulas Patocka
Introduce num_flush_requests for a target to set to say how many flush instructions (empty barriers) it wants to receive. These are sent by __clone_and_map_empty_barrier with map_info->flush_request going from 0 to (num_flush_requests - 1). Old targets without flush support won't receive any flush requests. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-05-22block: Do away with the notion of hardsect_sizeMartin K. Petersen
Until now we have had a 1:1 mapping between storage device physical block size and the logical block sized used when addressing the device. With SATA 4KB drives coming out that will no longer be the case. The sector size will be 4KB but the logical block size will remain 512-bytes. Hence we need to distinguish between the physical block size and the logical ditto. This patch renames hardsect_size to logical_block_size. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-09dm: remove limited barrier supportMikulas Patocka
Prepare for full barrier implementation: first remove the restricted support. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-02dm target: remove struct tt_internalCheng Renquan
The tt_internal is really just a list_head to manage registered target_type in a double linked list, Here embed the list_head into target_type directly, 1. to avoid kmalloc/kfree; 2. then tt_internal is really unneeded; Cc: stable@kernel.org Signed-off-by: Cheng Renquan <crquan@gmail.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Reviewed-by: Alasdair G Kergon <agk@redhat.com>
2009-01-06dm: support barriers on simple devicesAndi Kleen
Implement barrier support for single device DM devices This patch implements barrier support in DM for the common case of dm linear just remapping a single underlying device. In this case we can safely pass the barrier through because there can be no reordering between devices. NB. Any DM device might cease to support barriers if it gets reconfigured so code must continue to allow for a possible -EOPNOTSUPP on every barrier bio submitted. - agk Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-01-06dm request: extend target interfaceKiyoshi Ueda
This patch adds the following target interfaces for request-based dm. map_rq : for mapping a request rq_end_io : for finishing a request busy : for avoiding performance regression from bio-based dm. Target can tell dm core not to map requests now, and that may help requests in the block layer queue to be bigger by I/O merging. In bio-based dm, this behavior is done by device drivers managing the block layer queue. But in request-based dm, dm core has to do that since dm core manages the block layer queue. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-01-06dm: consolidate target deregistration error handlingMikulas Patocka
Change dm_unregister_target to return void and use BUG() for error reporting. dm_unregister_target can only fail because of programming bug in the target driver. It can't fail because of user's behavior or disk errors. This patch changes unregister_target to return void and use BUG if someone tries to unregister non-registered target or unregister target that is in use. This patch removes code duplication (testing of error codes in all dm targets) and reports bugs in just one place, in dm_unregister_target. In some target drivers, these return codes were ignored, which could lead to a situation where bugs could be missed. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdevLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdev: (66 commits) [PATCH] kill the rest of struct file propagation in block ioctls [PATCH] get rid of struct file use in blkdev_ioctl() BLKBSZSET [PATCH] get rid of blkdev_locked_ioctl() [PATCH] get rid of blkdev_driver_ioctl() [PATCH] sanitize blkdev_get() and friends [PATCH] remember mode of reiserfs journal [PATCH] propagate mode through swsusp_close() [PATCH] propagate mode through open_bdev_excl/close_bdev_excl [PATCH] pass fmode_t to blkdev_put() [PATCH] kill the unused bsize on the send side of /dev/loop [PATCH] trim file propagation in block/compat_ioctl.c [PATCH] end of methods switch: remove the old ones [PATCH] switch sr [PATCH] switch sd [PATCH] switch ide-scsi [PATCH] switch tape_block [PATCH] switch dcssblk [PATCH] switch dasd [PATCH] switch mtd_blkdevs [PATCH] switch mmc ...
