path: root/include/linux/debugfs.h
2006-03-20[PATCH] debugfs: Add debugfs_create_blob() helper for exporting binary dataMichael Ellerman
I wanted to export a binary blob via debugfs, and although it was pretty easy it seems like it'd be easier if there was a helper for it. It's a pity we need the wrapper struct but I can't see a cleaner way to do it. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-04-18[PATCH] debugfs: fix !debugfs prototypesMichal Ostrowski
- Fix prototypes for debugfs functions (in configurations where debugfs is disabled). Signed-off-by: Michal Ostrowski <mostrows@speakeasy.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-04-18[PATCH] debugfs: Reduce <linux/debugfs.h> dependenciesRoland Dreier
The current <linux/debugfs.h> include file is a little fragile in that it is not self-contained and hence may cause compile warnings or errors depending on the files included before it, the kernel config and the architecture. This patch makes things a little more robust by: - including <linux/types.h> to get definitions of u32, mode_t, and so on. - forward declaring struct file_operations. - including <linux/err.h> when CONFIG_DEBUG_FS is not set The last change is particularly useful, as a kernel developer is likely to build with debugfs always enabled and never see the build breakage cased if debugfs is disabled. Signed-off-by: Roland Dreier <roland@topspin.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
