path: root/include/linux/compiler.h
2008-11-23trace: profile all if conditionalsSteven Rostedt
Impact: feature to profile if statements This patch adds a branch profiler for all if () statements. The results will be found in: /debugfs/tracing/profile_branch For example: miss hit % Function File Line ------- --------- - -------- ---- ---- 0 1 100 x86_64_start_reservations head64.c 127 0 1 100 copy_bootdata head64.c 69 1 0 0 x86_64_start_kernel head64.c 111 32 0 0 set_intr_gate desc.h 319 1 0 0 reserve_ebda_region head.c 51 1 0 0 reserve_ebda_region head.c 47 0 1 100 reserve_ebda_region head.c 42 0 0 X maxcpus main.c 165 Miss means the branch was not taken. Hit means the branch was taken. The percent is the percentage the branch was taken. This adds a significant amount of overhead and should only be used by those analyzing their system. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-23trace: consolidate unlikely and likely profilerSteven Rostedt
Impact: clean up to make one profiler of like and unlikely tracer The likely and unlikely profiler prints out the file and line numbers of the annotated branches that it is profiling. It shows the number of times it was correct or incorrect in its guess. Having two different files or sections for that matter to tell us if it was a likely or unlikely is pretty pointless. We really only care if it was correct or not. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-23trace: remove extra assign in branch checkSteven Rostedt
Impact: clean up of branch check The unlikely/likely profiler does an extra assign of the f.line. This is not needed since it is already calculated at compile time. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-12trace: rename unlikely profiler to branch profilerSteven Rostedt
Impact: name change of unlikely tracer and profiler Ingo Molnar suggested changing the config from UNLIKELY_PROFILE to BRANCH_PROFILING. I never did like the "unlikely" name so I went one step farther, and renamed all the unlikely configurations to a "BRANCH" variant. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-12tracing: branch tracer, fix vdso crashIngo Molnar
Impact: fix bootup crash the branch tracer missed arch/x86/vdso/vclock_gettime.c from disabling tracing, which caused such bootup crashes: [ 201.840097] init[1]: segfault at 7fffed3fe7c0 ip 00007fffed3fea2e sp 000077 also clean up the ugly ifdefs in arch/x86/kernel/vsyscall_64.c by creating DISABLE_UNLIKELY_PROFILE facility for code to turn off instrumentation on a per file basis. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-12tracing: profile likely and unlikely annotationsSteven Rostedt
Impact: new unlikely/likely profiler Andrew Morton recently suggested having an in-kernel way to profile likely and unlikely macros. This patch achieves that goal. When configured, every(*) likely and unlikely macro gets a counter attached to it. When the condition is hit, the hit and misses of that condition are recorded. These numbers can later be retrieved by: /debugfs/tracing/profile_likely - All likely markers /debugfs/tracing/profile_unlikely - All unlikely markers. # cat /debug/tracing/profile_unlikely | head correct incorrect % Function File Line ------- --------- - -------- ---- ---- 2167 0 0 do_arch_prctl process_64.c 832 0 0 0 do_arch_prctl process_64.c 804 2670 0 0 IS_ERR err.h 34 71230 5693 7 __switch_to process_64.c 673 76919 0 0 __switch_to process_64.c 639 43184 33743 43 __switch_to process_64.c 624 12740 64181 83 __switch_to process_64.c 594 12740 64174 83 __switch_to process_64.c 590 # cat /debug/tracing/profile_unlikely | \ awk '{ if ($3 > 25) print $0; }' |head -20 44963 35259 43 __switch_to process_64.c 624 12762 67454 84 __switch_to process_64.c 594 12762 67447 84 __switch_to process_64.c 590 1478 595 28 syscall_get_error syscall.h 51 0 2821 100 syscall_trace_leave ptrace.c 1567 0 1 100 native_smp_prepare_cpus smpboot.c 1237 86338 265881 75 calc_delta_fair sched_fair.c 408 210410 108540 34 calc_delta_mine sched.c 1267 0 54550 100 sched_info_queued sched_stats.h 222 51899 66435 56 pick_next_task_fair sched_fair.c 1422 6 10 62 yield_task_fair sched_fair.c 982 7325 2692 26 rt_policy sched.c 144 0 1270 100 pre_schedule_rt sched_rt.c 1261 1268 48073 97 pick_next_task_rt sched_rt.c 884 0 45181 100 sched_info_dequeued sched_stats.h 177 0 15 100 sched_move_task sched.c 8700 0 15 100 sched_move_task sched.c 8690 53167 33217 38 schedule sched.c 4457 0 80208 100 sched_info_switch sched_stats.h 270 30585 49631 61 context_switch sched.c 2619 # cat /debug/tracing/profile_likely | awk '{ if ($3 > 25) print $0; }' 39900 36577 47 pick_next_task sched.c 4397 20824 15233 42 switch_mm mmu_context_64.h 18 0 7 100 __cancel_work_timer workqueue.c 560 617 66484 99 clocksource_adjust timekeeping.c 456 0 346340 100 audit_syscall_exit auditsc.c 1570 38 347350 99 audit_get_context auditsc.c 732 0 345244 100 audit_syscall_entry auditsc.c 1541 38 1017 96 audit_free auditsc.c 1446 0 1090 100 audit_alloc auditsc.c 862 2618 1090 29 audit_alloc auditsc.c 858 0 6 100 move_masked_irq migration.c 9 1 198 99 probe_sched_wakeup trace_sched_switch.c 58 2 2 50 probe_wakeup trace_sched_wakeup.c 227 0 2 100 probe_wakeup_sched_switch trace_sched_wakeup.c 144 4514 2090 31 __grab_cache_page filemap.c 2149 12882 228786 94 mapping_unevictable pagemap.h 50 4 11 73 __flush_cpu_slab slub.c 1466 627757 330451 34 slab_free slub.c 1731 2959 61245 95 dentry_lru_del_init dcache.c 153 946 1217 56 load_elf_binary binfmt_elf.c 904 102 82 44 disk_put_part genhd.h 206 1 1 50 dst_gc_task dst.c 82 0 19 100 tcp_mss_split_point tcp_output.c 1126 As you can see by the above, there's a bit of work to do in rethinking the use of some unlikelys and likelys. Note: the unlikely case had 71 hits that were more than 25%. Note: After submitting my first version of this patch, Andrew Morton showed me a version written by Daniel Walker, where I picked up the following ideas from: 1) Using __builtin_constant_p to avoid profiling fixed values. 2) Using __FILE__ instead of instruction pointers. 3) Using the preprocessor to stop all profiling of likely annotations from vsyscall_64.c. Thanks to Andrew Morton, Arjan van de Ven, Theodore Tso and Ingo Molnar for their feed back on this patch. (*) Not ever unlikely is recorded, those that are used by vsyscalls (a few of them) had to have profiling disabled. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Theodore Tso <tytso@mit.edu> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-14ftrace: move notrace to compiler.hSteven Rostedt
The notrace define belongs in compiler.h so that it can be used in init.h Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-18rcu: remove redundant ACCESS_ONCE definition from rcupreempt.cPaul E. McKenney
Remove the redundant definition of ACCESS_ONCE() from rcupreempt.c in favor of the one in compiler.h. Also merge the comment header from rcupreempt.c's definition into that in compiler.h. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-10Move ACCESS_ONCE() to <linux/compiler.h>Linus Torvalds
It actually makes much more sense there, and we do tend to need it for non-RCU usage too. Moving it to <linux/compiler.h> will allow some other cases that have open-coded the same logic to use the same helper function that RCU has used. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04add noinline_for_stackAndrew Morton
People are adding `noinline' in various places to prevent excess stack consumption due to gcc inlining. But once this is done, it is quite unobvious why the `noinline' is present in the code. We can comment each and every site, or we can use noinline_for_stack. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28remove __attribute_used__Adrian Bunk
Remove the deprecated __attribute_used__. [Introduce __section in a few places to silence checkpatch /sam] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28compiler.h: introduce __section()Sam Ravnborg
Add a new helper: __section() that makes a section definition much shorter and more readable. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-25Permit silencing of __deprecated warnings.Jeff Garzik
The __deprecated marker is quite useful in highlighting the remnants of old APIs that want removing. However, it is quite normal for one or more years to pass, before the (usually ancient, bitrotten) code in question is either updated or deleted. Thus, like __must_check, add a Kconfig option that permits the silencing of this compiler warning. This change mimics the ifdef-ery and Kconfig defaults of MUST_CHECK as closely as possible. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18Replace __attribute_pure__ with __pureRalf Baechle
To be consistent with the use of attributes in the rest of the kernel replace all use of __attribute_pure__ with __pure and delete the definition of __attribute_pure__. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Russell King <rmk@arm.linux.org.uk> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26make __chk_{user,io}_ptr() accept pointers to volatileAl Viro
2007-07-21x86: Support __attribute__((__cold__)) in gcc 4.3Andi Kleen
gcc 4.3 supports a new __attribute__((__cold__)) to mark functions cold. Any path directly leading to a call of this function will be unlikely. And gcc will try to generate smaller code for the function itself. Please use with care. The code generation advantage isn't large and in most cases it is not worth uglifying code with this. This patch marks some common error functions like panic(), printk() as cold. This will longer term make many unlikely()s unnecessary, although we can keep them for now for older compilers. BUG is not marked cold because there is currently no way to tell gcc to mark a inline function told. Also all __init and __exit functions are marked cold. With a non -Os build this will tell the compiler to generate slightly smaller code for them. I think it currently only uses less alignments for labels, but that might change in the future. One disadvantage over *likely() is that they cannot be easily instrumented to verify them. Another drawback is that only the latest gcc 4.3 snapshots support this. Unfortunately we cannot detect this using the preprocessor. This means older snapshots will fail now. I don't think that's a problem because they are unreleased compilers that nobody should be using. gcc also has a __hot__ attribute, but I don't see any sense in using this in the kernel right now. But someday I hope gcc will be able to use more aggressive optimizing for hot functions even in -Os, if that happens it should be added. Includes compile fix from Thomas Gleixner. Cc: Jan Hubicka <jh@suse.cz> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-21x86_64: Support gcc 5 properlyAndi Kleen
The ifdef tests were broken. Assume it acts like gcc 4 Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09compiler: introduce __used and __maybe_unusedDavid Rientjes
__used is defined to be __attribute__((unused)) for all pre-3.3 gcc compilers to suppress warnings for unused functions because perhaps they are referenced only in inline assembly. It is defined to be __attribute__((used)) for gcc 3.3 and later so that the code is still emitted for such functions. __maybe_unused is defined to be __attribute__((unused)) for both function and variable use if it could possibly be unreferenced due to the evaluation of preprocessor macros. Function prototypes shall be marked with __maybe_unused if the actual definition of the function is dependant on preprocessor macros. No update to compiler-intel.h is necessary because ICC supports both __attribute__((used)) and __attribute__((unused)) as specified by the gcc manual. __attribute_used__ is deprecated and will be removed once all current code is converted to using __used. Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-26[PATCH] Add const to pointer qualifiers for __chk_user_ptr and __chk_io_ptr.Russ Cox
Change prototypes for __chk_user_ptr and __chk_io_ptr to take const void* instead of void*, so that code can pass "const void *" to them. (Right now sparse does not warn about passing const void* to void* functions, but that is a separate bug that I believe Josh is working on, and once sparse does check this, the changed prototypes will be necessary.) Signed-off-by: Russ Cox <rsc@swtch.com> Signed-off-by: Josh Triplett <josh@freedesktop.org> Acked-by: Christopher Li <sparse@chrisli.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-12include/linux/compiler.h: reject gcc 3 < gcc 3.2Alistair John Strachan
The kernel doesn't compile with GCC <3.2, do not allow it to succeed if GCC 3.0.x or 3.1.x are used. Signed-off-by: Alistair John Strachan <s0348365@sms.ed.ac.uk> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-01[PATCH] Pass sparse the lock expression given to lock annotationsJosh Triplett
The lock annotation macros __acquires, __releases, __acquire, and __release all currently throw away the lock expression passed as an argument. Now that sparse can parse __context__ and __attribute__((context)) with a context expression, pass the lock expression down to sparse as the context expression. This requires a version of sparse from GIT commit 37475a6c1c3e66219e68d912d5eb833f4098fd72 or later. Signed-off-by: Josh Triplett <josh@freedesktop.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] Pass a lock expression to __cond_lock, like __acquire and __releaseJosh Triplett
Currently, __acquire and __release take a lock expression, but __cond_lock takes only a condition, not the lock acquired if the expression evaluates to true. Change __cond_lock to accept a lock expression, and change all the callers to pass in a lock expression. Signed-off-by: Josh Triplett <josh@freedesktop.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-25add CONFIG_ENABLE_MUST_CHECKAndrew Morton
Those 1500 warnings can be a bit of a pain. Add a config option to shut them up. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-05-04Restore __attribute_const__ to user-visibility in linux/compiler.h...for nowDavid Woodhouse
2006-05-02Guard some of linux/compiler.h with #ifdef __KERNEL__David Woodhouse
2006-01-08[PATCH] Abandon gcc-2.95.xAndrew Morton
There's one scsi driver which doesn't compile due to weird __VA_ARGS__ tricks and the rather useful scsi/sd.c is currently getting an ICE. None of the new SAS code compiles, due to extensive use of anonymous unions. The V4L guys are very good at exploiting the gcc-2.95.x macro expansion bug (_why_ does each driver need to implement its own debug macros?) and various people keep on sneaking in anonymous unions, which are rather nice. Plus anonymous unions are rather useful. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] Add deprecated_for_modulesPaul E. McKenney
Add a deprecated_for_modules macro that allows symbols to be deprecated only when used by modules, as suggested by Andrew Morton some months back. Signed-off-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
