path: root/include/linux/compiler-gcc4.h
2007-07-21x86: Support __attribute__((__cold__)) in gcc 4.3Andi Kleen
gcc 4.3 supports a new __attribute__((__cold__)) to mark functions cold. Any path directly leading to a call of this function will be unlikely. And gcc will try to generate smaller code for the function itself. Please use with care. The code generation advantage isn't large and in most cases it is not worth uglifying code with this. This patch marks some common error functions like panic(), printk() as cold. This will longer term make many unlikely()s unnecessary, although we can keep them for now for older compilers. BUG is not marked cold because there is currently no way to tell gcc to mark a inline function told. Also all __init and __exit functions are marked cold. With a non -Os build this will tell the compiler to generate slightly smaller code for them. I think it currently only uses less alignments for labels, but that might change in the future. One disadvantage over *likely() is that they cannot be easily instrumented to verify them. Another drawback is that only the latest gcc 4.3 snapshots support this. Unfortunately we cannot detect this using the preprocessor. This means older snapshots will fail now. I don't think that's a problem because they are unreleased compilers that nobody should be using. gcc also has a __hot__ attribute, but I don't see any sense in using this in the kernel right now. But someday I hope gcc will be able to use more aggressive optimizing for hot functions even in -Os, if that happens it should be added. Includes compile fix from Thomas Gleixner. Cc: Jan Hubicka <jh@suse.cz> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09compiler: introduce __used and __maybe_unusedDavid Rientjes
__used is defined to be __attribute__((unused)) for all pre-3.3 gcc compilers to suppress warnings for unused functions because perhaps they are referenced only in inline assembly. It is defined to be __attribute__((used)) for gcc 3.3 and later so that the code is still emitted for such functions. __maybe_unused is defined to be __attribute__((unused)) for both function and variable use if it could possibly be unreferenced due to the evaluation of preprocessor macros. Function prototypes shall be marked with __maybe_unused if the actual definition of the function is dependant on preprocessor macros. No update to compiler-intel.h is necessary because ICC supports both __attribute__((used)) and __attribute__((unused)) as specified by the gcc manual. __attribute_used__ is deprecated and will be removed once all current code is converted to using __used. Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07Add unitialized_var() macro for suppressing gcc warningsBorislav Petkov
Introduce a macro for suppressing gcc from generating a warning about a probable uninitialized state of a variable. Example: - spinlock_t *ptl; + spinlock_t *uninitialized_var(ptl); Not a happy solution, but those warnings are obnoxious. - Using the usual pointlessly-set-it-to-zero approach wastes several bytes of text. - Using a macro means we can (hopefully) do something else if gcc changes cause the `x = x' hack to stop working - Using a macro means that people who are worried about hiding true bugs can easily turn it off. Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-01-14[PATCH] When CONFIG_CC_OPTIMIZE_FOR_SIZE, allow gcc4 to control inliningIngo Molnar
If optimizing for size (CONFIG_CC_OPTIMIZE_FOR_SIZE), allow gcc4 compilers to decide what to inline and what not - instead of the kernel forcing gcc to inline all the time. This requires several places that require to be inlined to be marked as such, previous patches in this series do that. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] Make __always_inline actually force always inliningIngo Molnar
This patch is the first in a series that tries to optimize the kernel in terms of size (and thus cache behavior, both cpu and pagecache). This first patch changes __always_inline to be a forced inline instead of the "regular" inline it was on everything except alpha. This forced inline matches the intention of the define better as a matter of documentation. There is no change in behavior by this patch, since "inline" currently is mapped to a forced inline anyway. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] remove gcc-2 checksAndrew Morton
Remove various things which were checking for gcc-1.x and gcc-2.x compilers. From: Adrian Bunk <bunk@stusta.de> Some documentation updates and removes some code paths for gcc < 3.2. Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
