path: root/include/linux/compiler-gcc.h
2008-04-26generic: make optimized inlining arch-opt-inIngo Molnar
Stephen Rothwell reported that linux-next did not build on powerpc64. make optimized inlining dependent on architecture opt-in. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-26x86: add optimized inliningIngo Molnar
add CONFIG_OPTIMIZE_INLINING=y. allow gcc to optimize the kernel image's size by uninlining functions that have been marked 'inline'. Previously gcc was forced by Linux to always-inline these functions via a gcc attribute: #define inline inline __attribute__((always_inline)) Especially when the user has already selected CONFIG_OPTIMIZE_FOR_SIZE=y this can make a huge difference in kernel image size (using a standard Fedora .config): text data bss dec hex filename 5613924 562708 3854336 10030968 990f78 vmlinux.before 5486689 562708 3854336 9903733 971e75 vmlinux.after that's a 2.3% text size reduction (!). Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-18Replace __attribute_pure__ with __pureRalf Baechle
To be consistent with the use of attributes in the rest of the kernel replace all use of __attribute_pure__ with __pure and delete the definition of __attribute_pure__. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Russell King <rmk@arm.linux.org.uk> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Force erroneous inclusions of compiler-*.h files to be errorsRobert P. J. Day
Replace worthless comments with actual preprocessor errors when including the wrong versions of the compiler.h files. [akpm@linux-foundation.org: make it work] Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09compiler: introduce __used and __maybe_unusedDavid Rientjes
__used is defined to be __attribute__((unused)) for all pre-3.3 gcc compilers to suppress warnings for unused functions because perhaps they are referenced only in inline assembly. It is defined to be __attribute__((used)) for gcc 3.3 and later so that the code is still emitted for such functions. __maybe_unused is defined to be __attribute__((unused)) for both function and variable use if it could possibly be unreferenced due to the evaluation of preprocessor macros. Function prototypes shall be marked with __maybe_unused if the actual definition of the function is dependant on preprocessor macros. No update to compiler-intel.h is necessary because ICC supports both __attribute__((used)) and __attribute__((unused)) as specified by the gcc manual. __attribute_used__ is deprecated and will be removed once all current code is converted to using __used. Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07ARRAY_SIZE: check for typeRusty Russell
We can use a gcc extension to ensure that ARRAY_SIZE() is handed an array, not a pointer. This is especially important when code is changed from a fixed array to a pointer. I assume the Intel compiler doesn't support __builtin_types_compatible_p. [jdike@addtoit.com: uml: update UML definition of ARRAY_SIZE] Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] extend the set of "__attribute__" shortcut macrosRobert P. J. Day
Extend the set of "__attribute__" shortcut macros, and remove identical (and now superfluous) definitions from a couple of source files. based on a page at robert love's blog: http://rlove.org/log/2005102601 extend the set of shortcut macros defined in compiler-gcc.h with the following: #define __packed __attribute__((packed)) #define __weak __attribute__((weak)) #define __naked __attribute__((naked)) #define __noreturn __attribute__((noreturn)) #define __pure __attribute__((pure)) #define __aligned(x) __attribute__((aligned(x))) #define __printf(a,b) __attribute__((format(printf,a,b))) Once these are in place, it's up to subsystem maintainers to decide if they want to take advantage of them. there is already a strong precedent for using shortcuts like this in the source tree. The ones that might give people pause are "__aligned" and "__printf", but shortcuts for both of those are already in use, and in some ways very confusingly. note the two very different definitions for a macro named "ALIGNED": drivers/net/sgiseeq.c:#define ALIGNED(x) ((((unsigned long)(x)) + 0xf) & ~(0xf)) drivers/scsi/ultrastor.c:#define ALIGNED(x) __attribute__((aligned(x))) also: include/acpi/platform/acgcc.h: #define ACPI_PRINTF_LIKE(c) __attribute__ ((__format__ (__printf__, c, c+1))) Given the precedent, then, it seems logical to at least standardize on a consistent set of these macros. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-01-10[PATCH] Work around ppc64 compiler bugAnton Blanchard
In the process of optimising our per cpu data code, I found a ppc64 compiler bug that has been around forever. Basically the current RELOC_HIDE can end up trashing r30. Details of the bug can be found at http://gcc.gnu.org/bugzilla/show_bug.cgi?id=25572 This bug is present in all compilers before 4.1. It is masked by the fact that our current per cpu data code is inefficient and causes other loads that end up marking r30 as used. A workaround identified by Alan Modra is to use the =r asm constraint instead of =g. Signed-off-by: Anton Blanchard <anton@samba.org> [ Verified that this makes no real difference on x86[-64] */ Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] remove gcc-2 checksAndrew Morton
Remove various things which were checking for gcc-1.x and gcc-2.x compilers. From: Adrian Bunk <bunk@stusta.de> Some documentation updates and removes some code paths for gcc < 3.2. Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
